Staro 04.02.2026., 23:15   #5191
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,578
Za takve prigode imam ovo...mozda pomogne:
Code:
#!/bin/sh
ps -eo rss,pid,user,command | sort -rn | head -$1 | awk '{ hr[1024**2]="GB"; hr[1024]="MB";
 for (x=1024**3; x>=1024; x/=1024) {
 if ($1>=x) { printf ("%-6.2f %s ", $1/x, hr[x]); break }
 } } { printf ("%-6s %-10s ", $2, $3) }
 { for ( x=4 ; x<=NF ; x++ ) { printf ("%s ",$x) } print ("\n") }
Staro 04.02.2026., 23:36   #5192
domy_os
domy_os's Avatar
Postovi: 19,024
Koristi li netko Keu kao DHCP server (nasljednik ISC dhcpd-a)? Imam manje više defaultnu instalaciju u Dockeru, produžio sam samo lease time i dodao rezervacije. Sve to fercera, ali ne baš brzo, dugo treba da klijenti pokupe IP adrese. U logovima nema grešaka, samo ova tri warninga koja su ajmo reći normalna:
Code:
2026/02/04 21:18:21,stdout,"2026-02-04 20:18:21.653 WARN  [kea-dhcp4.dhcp4/1.140203944382720] DHCP4_MULTI_THREADING_INFO enabled: yes, number of threads: 4, queue size: 28
2026/02/04 21:18:21,stdout,2026-02-04 20:18:21.619 WARN  [kea-dhcp4.dhcp4/1.140203944382720] DHCP4_RESERVATIONS_LOOKUP_FIRST_ENABLED Multi-threading is enabled and host reservations lookup is always performed first.
2026/02/04 21:18:21,stdout,2026-02-04 20:18:21.619 WARN  [kea-dhcp4.dhcpsrv/1.140203944382720] DHCPSRV_MT_DISABLED_QUEUE_CONTROL disabling dhcp queue control when multi-threading is enabled.
Dokumentacija ima fuckin' 1433 stranice i oči sam već izgubio...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 05.02.2026., 03:10   #5193
Dule
Dule's Avatar
Postovi: 741
Code:
~ >> ./ps.sh
77.44  MB 1043   igor       /usr/lib/Xorg :1 vt1 -keeptty -noreset -auth /home/igor/.local/share/sx/xauthority
63.83  MB 1196   igor       /usr/bin/node /home/igor/arch/tint2/tint2.js
44.30  MB 1214   igor       termite
43.67  MB 966    root       node /home/igor/arch/cron/cron.js
25.91  MB 1048   igor       /usr/bin/openbox --sm-disable --startup /home/igor/arch/openbox/autostart
24.32  MB 1178   igor       tint2 -c /home/igor/arch/tint2/tint2rc-top
22.93  MB 1179   igor       tint2 -c /home/igor/arch/tint2/tint2rc-bottom
18.36  MB 1208   igor       conky -q -c /home/igor/arch/tint2/conkyrc-tint2
13.59  MB 1177   igor       conky -q -d -c /home/igor/arch/conky/conkyrc-kernel --xinerama-head 1
  13.52  MB 1175   igor       conky -q -d -c /home/igor/arch/conky/conkyrc-kernel --xinerama-head 0
Ovo je slično kao ps_mem, samo running aplikacije... point je da što više rama kernel ima na raspolaganju, više se raskomoti sa raznim internim cachiranjem. Odgovor je u /proc/meminfo negdje, samo nisam dovoljno stručan da utvrdim što i zašto
Zadnje izmijenjeno od: Dule. 05.02.2026. u 03:54.
Dule je online   Reply With Quote
Staro 05.02.2026., 07:50   #5194
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,578
Autor domy_os Pregled postova
Code:
Yep. Na 2 bare metal instalacije (jedna na OpenSuse, jedna na Debianu) koje opsluzuju 60-ak fizickih servera i nekoliko desktop klijentana + cca 300-njak virtualki u vcenter clusteru. Nemam zamjerki. Migrirao sam stari config sa isc-dhcpd servera na novi kontrukt, pocistio sto vise nije podrzano i to je to, nisam kemijao.
Da ti se ovak nekaj ne dogada?
https://forum.netgate.com/topic/1961...wer-to-queries
Zadnje izmijenjeno od: tomek@vz. 05.02.2026. u 10:20.
Staro 05.02.2026., 12:36   #5195
domy_os
domy_os's Avatar
Postovi: 19,024
Ni blizu, ali svakako hvala na traženju. CPU je 0%, a RAM ispod 30 MB, watchdog nemam.
Nego, dodao sam ove tri naredbe i sad šljaka normalno, čak i brže nego prosječan router.
Code:
"host-reservation-identifiers": [ "hw-address" ]
"match-client-id": false
"reservations-out-of-pool": true
Znači sve vezano uz rezervacije, a kako ih imam samo po MAC adresi, ostavio sam samo hw-address.
Ako bude trebalo, u ovoj dokumentaciji ima još toga, dio je već bio postavljen po defaultu, dio je overkill za moj environment.
https://kb.isc.org/docs/kea-performance-optimization
Staro 05.02.2026., 13:50   #5196
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,578
Code:
A gle korak po korak. Optimizacije u nekim firmama traju godinama. Tak da ako vec ovo sljaka superiska
