#3511 | |
White Rabbit
Postovi: 5,580
#3512 | |
jedan i jedini :D
Lokacija: novi zagreb
Postovi: 5,310
Super fora. Thanks! |
#3513 |
Uptime 99.99%
Postovi: 2,780
Satya Nadella announced Microsoft needs an "engineering quality czar" and appointed Charlie Bell, who used to lead security, into the new role. The company also hired Google Cloud's president for customer experience to take over security. Nadella's post doesn't say why Microsoft suddenly needs someone focused on engineering quality. Could be the Azure outages. Could be the Windows patches that break the OS instead of fixing it. Could be the out-of-band patch spree. Could be that only 3.3% of Microsoft 365 users are willing to pay for Copilot. ...Or maybe it's because Microsoft uses AI to write 30% of its own code now. My Take Microsoft laid off their dedicated QA teams back in 2014 under Nadella. They've been relying on the Windows Insider program as free testing ever since. Now they're hiring a "quality czar" to fix problems that exist because they cut the people who used to catch them. They bragged about 30% of their code being AI-written. GitClear found code churn doubled after AI tools were introduced. Microsoft's own researchers found developers miss 40% more bugs reviewing AI-generated code. Stock is down 23% since earnings. They're pulling engineers off new features to stabilize Windows 11. And now they need a czar to address quality issues. I'm not saying AI caused all of this. But when you cut QA, replace human code with AI code, and then scramble to hire someone to fix quality, it's worth asking whether the efficiency gains were ever real or just deferred costs showing up later. Sent from my SM-S931B using Tapatalk
#3514 |
Datum registracije: Oct 2021
Postovi: 76
Znači došlo iz dupeta u glavu nakon 12 godina kad je već i djeci u osnovnoj školi valjda postalo vidljivo da je vrag odnio šalu i da dalje ovako više ne može. Fantastično. Do čega smo došli, nakon početnih mušica i dječjih bolesti, softver pa ranije i Windowsi bi generalno s protekom vremena postali bolji i bugovi bi se ispravljali, a kod win 11 nakon više od 4 godine otkad su izašli ne da su bolji nego postaju sve veći krš i lom svakim novim updateom, nevjerojatno nešto. I to su dakle top inženjerski umovi svijeta koji rade u kompanijama ala Microsoft. Teško da će ikome biti jasno zašto se kao neka osnova nije mogao uzeti Windows 7 kao dokazano moglo bi se reći najbolji Windowsi koje su napravili pa samo nastaviti na toj bazi nadograđivati i dodavati što već treba od fičera. Ili je to ono - nove generacije programera moraju pljunuti na ono staro prije njih jer u njihovim glavama "to ne valja" pa imaju potrebu dodavati svoje umotvorine i izdrkotine. I tako s vremenom dobijemo one drive, cortanu/copilot, bitlocker itd. hrpu nepotrebnog smeća i bloatwarea i sad smo tu gdje smo. |
#3516 |
Postovi: 76
Onda s ljudima u vodstvu kompanije koji donose odluke što će se i kako implementirati, jer bar još za sad AI to ne odlučuje sam za sebe. Kako god, naprosto sve što rade zadnjih godina je promašeno i krivo. |
#3517 |
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 4,033
Previše je ljudi koji su na te neke middle management pozicije zaposleni direktno, bez da znaju čime se ljudi ispod njih bave, bez da su na svojoj koži iskusili probleme koji nastaju kada ljudi koji nemaju pojma što rade izdaju naredbe koje ne razumiju. Mnogima od tih ljudi takvi položaji su sami sebi svrha i smatraju se uspješnima bez da su išta pokazali. Najlakše ih je prepoznati kada zahtijevaju stvari koje su tehnički nemoguće. Kada takvi konsolidiraju pozicije i okruže se klimavcima, nema tu više kruha.
#3518 |
Datum registracije: Dec 2014
Lokacija: Area 51
Postovi: 273
Idemo dalje https://www.youtube.com/watch?v=i5vzm0GjPXc |
#3519 |
Datum registracije: Oct 2002
Lokacija: Zagreb/Rijeka
Postovi: 2,121
Evo jedna fora usporedba Windowsa - XP x64, Vista, 7, 8.1, 10, 11... Po ovome ispada da su Win8.1 bili mozda najbolja najbolja verzija Windowsa do sada... ![]() https://youtu.be/7VZJO-hOT4c?si=Wk2B6Ab7RIIehH-e
