#5191 |
White Rabbit
Postovi: 5,573
Za takve prigode imam ovo...mozda pomogne: Code:
#!/bin/sh
ps -eo rss,pid,user,command | sort -rn | head -$1 | awk '{ hr[1024**2]="GB"; hr[1024]="MB";
for (x=1024**3; x>=1024; x/=1024) {
if ($1>=x) { printf ("%-6.2f %s ", $1/x, hr[x]); break }
} } { printf ("%-6s %-10s ", $2, $3) }
{ for ( x=4 ; x<=NF ; x++ ) { printf ("%s ",$x) } print ("\n") }
#5192 |
Postovi: 19,022
Koristi li netko Keu kao DHCP server (nasljednik ISC dhcpd-a)? Imam manje više defaultnu instalaciju u Dockeru, produžio sam samo lease time i dodao rezervacije. Sve to fercera, ali ne baš brzo, dugo treba da klijenti pokupe IP adrese. U logovima nema grešaka, samo ova tri warninga koja su ajmo reći normalna: Code:
2026/02/04 21:18:21,stdout,"2026-02-04 20:18:21.653 WARN [kea-dhcp4.dhcp4/1.140203944382720] DHCP4_MULTI_THREADING_INFO enabled: yes, number of threads: 4, queue size: 28 " 2026/02/04 21:18:21,stdout,2026-02-04 20:18:21.619 WARN [kea-dhcp4.dhcp4/1.140203944382720] DHCP4_RESERVATIONS_LOOKUP_FIRST_ENABLED Multi-threading is enabled and host reservations lookup is always performed first. 2026/02/04 21:18:21,stdout,2026-02-04 20:18:21.619 WARN [kea-dhcp4.dhcpsrv/1.140203944382720] DHCPSRV_MT_DISABLED_QUEUE_CONTROL disabling dhcp queue control when multi-threading is enabled.
#5193 |
Postovi: 737
Code:
~ >> ./ps.sh 77.44 MB 1043 igor /usr/lib/Xorg :1 vt1 -keeptty -noreset -auth /home/igor/.local/share/sx/xauthority 63.83 MB 1196 igor /usr/bin/node /home/igor/arch/tint2/tint2.js 44.30 MB 1214 igor termite 43.67 MB 966 root node /home/igor/arch/cron/cron.js 25.91 MB 1048 igor /usr/bin/openbox --sm-disable --startup /home/igor/arch/openbox/autostart 24.32 MB 1178 igor tint2 -c /home/igor/arch/tint2/tint2rc-top 22.93 MB 1179 igor tint2 -c /home/igor/arch/tint2/tint2rc-bottom 18.36 MB 1208 igor conky -q -c /home/igor/arch/tint2/conkyrc-tint2 13.59 MB 1177 igor conky -q -d -c /home/igor/arch/conky/conkyrc-kernel --xinerama-head 1 13.52 MB 1175 igor conky -q -d -c /home/igor/arch/conky/conkyrc-kernel --xinerama-head 0 ![]() Zadnje izmijenjeno od: Dule. Jučer u 03:54. |
#5194 | |
White Rabbit
Postovi: 5,573
Yep. Na 2 bare metal instalacije (jedna na OpenSuse, jedna na Debianu) koje opsluzuju 60-ak fizickih servera i nekoliko desktop klijentana + cca 300-njak virtualki u vcenter clusteru. Nemam zamjerki. Migrirao sam stari config sa isc-dhcpd servera na novi kontrukt, pocistio sto vise nije podrzano i to je to, nisam kemijao. Da ti se ovak nekaj ne dogada? https://forum.netgate.com/topic/1961...wer-to-queries Zadnje izmijenjeno od: tomek@vz. Jučer u 10:20. |
#5195 |
Postovi: 19,022
Ni blizu, ali svakako hvala na traženju. CPU je 0%, a RAM ispod 30 MB, watchdog nemam. Nego, dodao sam ove tri naredbe i sad šljaka normalno, čak i brže nego prosječan router. Code:
"host-reservation-identifiers": [ "hw-address" ] "match-client-id": false "reservations-out-of-pool": true Ako bude trebalo, u ovoj dokumentaciji ima još toga, dio je već bio postavljen po defaultu, dio je overkill za moj environment. https://kb.isc.org/docs/kea-performance-optimization
#5196 | |
White Rabbit
Postovi: 5,573
