#571 | |
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 4,001
#572 |
Postovi: 8,653
Nažalost nakon CES-a sve je puno takvog materijala, ali kad se ove PR i marketing prezentacije razvodne i novi hardver objektivno konkretno testira, IMHO B390 iGPU je najbolje kaj su najavili i pokazali.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX |
#574 |
Datum registracije: Feb 2004
Postovi: 1,311
Ima i nešto malo istine u članku In a sense, Intel has battled AMD on easy mode, but that’s AMD’s fault. AMD’s current-gen integrated graphics are based on its RDNA 3.5 graphics architecture, while its desktop GPUs use RDNA 4. With RDNA 4, AMD gains support for AI upscaling, receives more powerful compute units, and a suite of architectural enhancements. Had AMD kept its integrated graphics in line with its desktop offerings, AMD would be in a much more competitive position. That said, AMD can only blame itself for letting its mobile graphics fall behind. |
#575 |
Lokacija: Zabok
Postovi: 3,427
Meni je zanimljiv podatak (iz GN videa) da se proizvođaču isplati grafe slati avionom (20$ per unit) u odnosu na brod (5-7$ per unit). Ako im u tom segmentu (do 300$) marža to pokriva, kolio tek onda grabe NV/AMD ? |
#576 |
Lokacija: Sv.Nedelja
Postovi: 5,838
https://www.pcmag.com/news/intel-pan...test_variant=B Ajmo intel, bit ce nesto i od njega. |
#577 |
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,583
pitanje za razmišljanje. ima li smisla ubaciti arc karticu u "media server" i na taj način mašini omogućiti qsv enkodiranje videa? pri tome, dostupan je samo x1 slot. koliko čitam po redditu, qsv će raditi i bez spojenog monitora, a samo za enkodiranje je dovoljan i x1 slot. |
#578 |
Postovi: 8,653
IMHO Sparkle ARC A310 ECO bi bila idealna u slučaju da stvarno radi bez problema u PCI-E x1 slotu.
#579 |
Lokacija: istra
Postovi: 3,583
imam karticu. pitanje je di mi je riser, i kako to ugurat u sff kučište. LOL očito ovako https://www.youtube.com/watch?v=Qj4nZWVYTVw |
#580 | |
Datum registracije: Jan 2026
Lokacija: n.zagreb
Postovi: 16
#581 |
Lokacija: istra
Postovi: 3,583
za test sam a310 ubacio u i5-7400 mašinu , i to u x16 slot. mašina ne podržava rebar. arc driveri su zadnji dostupni. i qurčina. handbrake sa qsv enkoderom (nebitno dal av1, h265 ili h264) nakon pola minute potone na 10tak fps-a. prvih par sekundi uspije oko 70tak držat. qsv od igpu uspijeva oko 35-40 u h264 izgurat. neznam do čega je. vidi se u task manageru da gpu nešto radi, ali minimalno. |
#582 |
Lokacija: istra
Postovi: 3,583
nastavak sage. ovo qurca ne radi. ubacio a310 u i3-10300 mašinu koja podržava rebar i upaljen je. intel app javi da je OK. handbrake ponudi qsv, međutim to i dalje ide samo oko 100fps-a. kad stavim igpu na disable, ide oko 100fps-a, kad pustim igpu solo, opet ide oko 100 fps-a. JE, ponudi on av1-10bit qsv (to podržava samo intel arc kartica), ali i on zapne na 100njak fps-a. |
#583 |
Postovi: 8,653
Eventualno da provjeriš s nekom Linux distribucijom, čisto da eliminiraš da li je do kartice ili OS-a, jer Handbrake je svakak podržan.
