#631 | |
Postovi: 8,655
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX |
#633 |
Postovi: 8,719
#634 |
Lokacija: Zagreb, Črnomerec
Postovi: 2,711
But the important thing, though, because this computing platform requires all of the layers underneath it, it has started, and you guys are, everybody's seeing it right now, it has started the largest infrastructure build-out in human history. We're now a few hundred billion dollars into it. We're a few hundred billion dollars into it. Larry and I, we get the opportunity to work on many projects together. There are trillions of dollars of infrastructure that needs to be built out, and it's sensible. It's sensible because all of these contexts have to be processed so that the AI, so that the models can generate the intelligence necessary to power the applications that ultimately sit on top. - NVIDIA's Jensen Huang Genijalno. Kad jednom čitava stvar malo pukne, ovakvi quotes će se koristit kao primjer da je od početka bilo očito da se prodaje magla. Naravno, to će govorit isti oni koji trenutno tvrde da će LLM napravit bogataša od svakog čovjeka, izliječit bolesti i omogućit nam kolonizaciju Alphe Centauri. Retroaktivno će bit sve jasno, kako to obično biva. Dakle, Jensen kaže da je sensible da se ulažu bilijuni dolara (slučajno dobar dio ide u njegove džepove) u infrastrukturu koja će nam omogućit da se procesira neko procesiranje tj. AI tj. modeli, oću reć da se generira...inteligencija, koja nam je potrebna da bi ovaj, pokretali ove, zapravo, aplikacije koje su tu zapravo, već, ali još nisu powered by AI, ali bit će i onda ćemo imati ovaj.....nešto što sad nemamo i onda slijedi taj raj na zemlji kojeg još nemamo jer nema struje dosta i fali tvornica koje proizvode inteligenciju, ali bit će. Znao sam da me njegovo trkeljanje na nešto podsjetilo: Ja sam tog dana obavljao najnormalnije funkcije, ovaj jutarnje. Zalje-zaljevao sam pesticidima polje iznad-iznad Bukovice, uh, kad se iznenada na lijevoj strani sam u vidokrugu primjetio neki objekat, uh, nepoznat, koji je bio blještav. Ustvari, mijenjo je boju. Us-ustvari, bio je žut. Ah. Zelenkaste boje. Povremeno. Onda sam, uh, iznenada začudio sam se jer sam prim-primjetio da je avion jednostavno stoji na mjestu i da se elisa pri tom ne-ne okreće. A ja sam, ovaj, znao da se avion mora kretat jer sam ga upalio i sve. Međutim, motor je mirovao, sve je stajalo. Taj ob-objekat je proletio par puta pred mene. Pogled'o sam dole, pesticidi su, oh Nisu padali po njivi nego su na moje, na moje, o-o-opšte iznenađenje stajali u zraku. Onda sam s ovaj, nisam gubio pribranost ni jednog momenta. Pokušao sam da pokrenem avion — nije mi polazilo za rukom. Kad-kad mi se taj objekat izgubio, ne-nepoznati, blješteći, uh, zeleni. Ustvari, crveni je bio. Taj zelenkasti objekat kad-kad s-kad se izgubio iz vidokruga avion je sam kren'o naprijed i ja sam imao apsolutnu kontrolu. Nemojte me više, stvarno |
#635 |
Postovi: 8,655
Nažalost frajer prodaje hardver i softver, tak da kad sve skupa ode u Mp3 on bude i dalje prodaval isti taj hardver i softver koji je do prije koju godinu gural na sve moguće kripto i blockchain fore, a kad se AI izjalovi, ode Jensen u kvantna računala zajedno s CUDA-Q implementacijama. Začarani krug bez greške, ali ako ništa drugo, sad se praktički na dnevnoj (očajnoj) bazi javljaju kaj Jensen, kaj ostali takvi direktori koji nas uvjeravaju da je AI tu da nam pomogne i poboljša - nešto, a kaj točno, e to ćemo saznati u sljedećoj epizodi Gruntovčana. ![]() ![]()
#637 | ||
White Rabbit
Postovi: 5,578
> AI hype meets reality as majority of CEOs report no financial returns Citiraj:
> eBay bans AI agents from shopping, but hints at future approved bots |
#641 |
Master Of Disaster
Datum registracije: Nov 2002
Postovi: 1,281
#642 |
Datum registracije: Jun 2024
Lokacija: Space
Postovi: 871
Tesko je raditi shorting dionica koje su bezvrijedne. Zato nisu public. "Revenue goes up" Jeste, kao i ulaganja. Trebao ga je pitati; kada ce se profit pojaviti. Ali iskreno ne znam zasto ova drama oko njegovih pojavljivanja. Nema gdje nije bio gost. I sta to on ima reci da je vrijedno? Lik je prodavac. Promotor. Njegov posao je prodavati proizvod ili reklamirati sta je slijedece. Naravno da nece nikada biti pesimista i iskren. Trziste govori istinu. Ova godina je presudna za AI. Ako prestanu siriti centre i ako postojece stanje zadovolji kupce, ako centri postanu samo-odrzivi, mogao bi se pojaviti i profit. Medjutim, uvijek postoiji opcija da ih kinezi pregaze koji, osim sto tvrde da sa manje "snage" dobiju isti rezultat, kinezima bi bilo od nacionalnog znacaja tako da ulaganaj nemaju granicu. Dok je openAI samo jedna od privatnih kompanija koje ne mogu beskonacno gomilati dugovanja.
Miquella is mine and mine alone. |
#643 |
Lokacija: Space
Postovi: 871
Izgleda da su nasli fix. They just need more money: "Nvidia, Microsoft, Amazon in talks to invest up to $60 billion in OpenAI, The Information reports" https://www.reuters.com/business/ret...ts-2026-01-29/
#647 |
Lokacija: Space
Postovi: 871
"The $100 Billion Megadeal Between OpenAI and Nvidia Is on Ice Nvidia CEO Jensen Huang has privately played down likelihood original deal will be finalized, although the two companies will continue to have a close collaboration. Nvidia Chief Executive Jensen Huang has privately emphasized to industry associates in recent months that the original $100 billion agreement was nonbinding and not finalized, people familiar with the matter said. He has also privately criticized what he has described as a lack of discipline in OpenAI’s business approach and expressed concern about the competition it faces from the likes of Google and Anthropic, some of the people said." https://www.wsj.com/tech/ai/the-100-...n-ice-aa3025e3
#648 | |
Postovi: 741
#649 |
Uptime 99.99%
Postovi: 2,780
Izgleda da se Nvidia povlaci NVidia looks to be dropping out of investing 100B into OpenAI, which is losing money faster than any startup in history. Sam Altman and OpenAI can’t pay for all the DRAM he ordered. Sent from my SM-S931B using Tapatalk
#650 |
Postovi: 8,655
Ovi bi se prvo mogli međusobno dogovoriti s kojom i kakvom pričom idu u javnost, jer trenutno stanje je u čušpajz fazi. ![]() ![]() Iza kulisa je valjda žešće sranje, jer eJaJ forsiranje ne prolazi po planu i programu.
#652 | |
Postovi: 8,719
https://github.com/openclaw/openclaw Citiraj:
#653 |
Lokacija: Dalmacija
Postovi: 6,011
Oprezan sa ovim, vrlo ja bi ga zboxao u sandbox, ograničio pristup drugim uredjajima na mrezi i tako. Imam openai codex i lokalne agente za development, i lako se oni pogube i pocmu rokati sto treba i ne treba u konzolu, nisam ih jos pustio da slobodno rokaju, moram sandbox napravit. |
#654 | |
Postovi: 8,719
Pokrenuti na nekom laptopu za eksperimentiranje ili u VM-u... |
#655 | |
White Rabbit
Postovi: 5,578
Mda... Citiraj:
> OpenClaw (formerly Clawdbot) can manage your entire digital life, but it might leak your credentials |
#656 |
Postovi: 8,655
#657 |
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 4,030
Da li vi koji pratite možete ukazati na neki dobar use case za tu tehnologiju? Jer taj spisak "manage schedules, book flights, perform research, reorganize email inboxes" meni nije sam po sebi pretjerano impresivan, pogotovo ako nakon obavljene radnje moraš pretpostaviti kako nije nešto sjebo jer nemaš zapravo uvida u sve što je dirao.
#658 |
Postovi: 8,655
Nažalost to je taj eJaJ lajt motiv, sve može, ništa vi ne brinite, tu smo da vam olakšamo i pomognemo, a onda vi sve dodatno i detaljno provjerite, jer zajebi su svjetski i itekako mogući.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 02.02.2026. u 22:16. |
#659 |
White Rabbit
Postovi: 5,578
Ejaj je danas u formatu u kojem je jednostavno za one koji ili nemaju vremena ili im se neda prouvacat/naucit nesto da bi dosli do nekog rijesenja. Probao sam ga za neke stvari koristiti (pomoc oko ucenja programiranja, pisanja bash skripti na brzaka ili kad jednostavno hocu vidjeti kako bi neki komad namjestaja ili hardwera izgledalo u odredenoj boji). Za takve stvari se da koristiti ako osoba koja postavlja pitanja (koja moraju biti vrlo precizna) ima dovoljno znanja da ispravi te greske. Ja to zovem Google 2.0 ili kad si prelijen za googlanje. |
