#1801 |
Datum registracije: Jun 2024
Lokacija: Space
Postovi: 861
Za YT koristim Premium. Ugasen je adblock na njemu. A desava mi se i na tvitteru. Low rez video samo stan ne sredini. I isto na drugom sajtu gledao UFC, buffering svaki munut. Ili skoci video i vrati se nazad 20 sekundi recimo. I onda nakon sto me smori, prebacim link na Edge ili Brave i radi bez greske.
Miquella is mine and mine alone. |
#1802 |
Lokacija: Rijeka / Grobnik
Postovi: 4,534
Duck duck go browser na mobu. To ja koristim za duze stvari gledat, pa cast na tv. Ili skinem video sa jdownloaderom i pogledam kako hocu i kad hoću. Hebo yt i njihovo guranje smeća down the throats of users. Ne sjecam se kad sam zadnji put reklamu vidio.
"We all must hang together, or surly we will hang separately." AMD Ryzen7 7800x3D+Noctua NH-D14 | MSI Tomahawk WIFI AMD B650 | 2x16GB Corsair Vengeance DDR5-6000 CL30 1,39v | SAPPHIRE Pulse RX 9070xt UV/OC | 1tb NVMe sammy 970 evo plus, 2TB Samsung 990 EVO Plus, 128gb NVMe Patriot P300, Crucial MX500 500GB, Kingston 480gb | Riotoro ENIGMA G2 850W 80 Gold | Corsair Carbide 300R modded | Win10 ENT LTSC IoT (work) + Win11 ENT LTSC IoT (gejming) | logitech g403 | ROCCAT Horde | AOC CQ27C4 + AOC C24G1 + 50" Hisense H50A6140 AMD Ryzen5 2600+Xilence Cryon M806D.B | Asus x370 Prime Pro rev1.03 (bios 6203) | GSkill Aegis 32GB (2x16) DDR4@3,2GHz | 2x Intel 545s 128GB, 1x Crucial MX500 500GB | Gigabyte GTX960 | sisa 620w | Fractal Design Focus G | Win7 x64 + Win10 ENT LTSC IoT | logitech g403 | ROCCAT SuoraFX intel i5 2500k@4,5ghz (1,28v)+FSP Windale 4 | ASRock Z68 Ext4 Gen3 (bios 1.20) | 2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27,1,5V | Samsung SSD 64gb, 2x256gb SSD | iGPU | corsair vx450w | CoolerMaster Centurion 534 modded | Win7 x64 |
#1803 | |
White Rabbit
Postovi: 5,537
Probaj koristiti recimo brave samo pa vidi dal ti se kroz duzi püeriod isto dogada da nije do neceg drugog... |
#1806 |
PRO
Postovi: 4,903
Android app - kad upalim app i upisem url, prvo url se loada barem 7-8 sec. Nakon toga radi normalno. Nema extensiona nikakvih, sve cisto, taman instalirano. Koji k? Proba na samsung s22 ultra i na xiaomi 15 ultra, isti vrag.
#1808 |
Lokacija: Space
Postovi: 861
Evo upravo mi kresao tab sa videom na Patrionu. Ovo nije win11 ltsc vec na win10 pro. Probat cu kako kolega rece Brave par dana cisto da vidim ima lii ste simptome ali na FF video reprodukcija nece pa nece. Ovo je reinstaliran FF skroz. ![]()
#1809 |
PRO
Postovi: 4,903
#1810 |
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,956
Ivo, to ti je po meni neki neodređeni problem sa profilom u browseru. Kada sam navodio razne individue oko čudnih problema s browserom rekao bih im da probaju portable verziju. Jednostavno, nema instalacije, radi nezavisno od računala. To je u pravilu uvijek nudilo rješenje problema koje bi onda ekipa često odbijala jer imaju svašta nešto u profilu. Promo, da li si maknuo stari profil kod deinstalacije? Džaba ti reinstalacija ako je profil isti.
#1811 |
Lokacija: Space
Postovi: 861
Da, obrisem foldere iz user/appdata local i roming i gdje vec izbaci Mozilla folder. Ali obzirom da se desava na win11 LTSC i win10 pro. Ne vjerujem da je do profila.
