#601 |
Postovi: 8,638
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 18.01.2026. u 16:24. |
#603 |
Datum registracije: Jun 2024
Lokacija: Space
Postovi: 851
"OpenAI is in the red and, at this rate, will run out of money by 2027, having overestimated the profitability of AI. Recent analyses and internal projections indicate annual losses of around $14 billion in 2026, following roughly $8 billion in 2025. This stems from overestimating near-term profitability, as high inference and data center expenses continue to dominate despite strong user adoption and billions in revenue. Without repeated massive funding rounds, analysts warn the company could face a cash shortfall as early as mid-2027."
Miquella is mine and mine alone. |
#604 |
Datum registracije: Sep 2011
Postovi: 1,191
Pukne bubble ![]() valjda če onda pati i cijene RAM-a i HDDa |
#605 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,732
#606 |
Lokacija: Space
Postovi: 851
Evo izvore kome se cita naširoko, naravno, samo za klovnove: https://www.tomshardware.com/tech-in...panys-finances
#607 |
Datum registracije: Dec 2014
Lokacija: Area 51
Postovi: 269
#608 |
Lokacija: Space
Postovi: 851
Mislim da se radi o pritisku ulagaca. Moze se danima gubiti vrijeme u teoretisanju, ali suština je ova: A.I. Is Real. But OpenAI Might Still Fail. "Investors were briefly spooked last July when an M.I.T. study suggested that almost none of this is useful to businesses. Corporations had poured tens of billions of dollars into A.I., yet only one in 20 projects had succeeded, the study reported. The problem for A.I. developers is that most users aren’t paying for their services. People can choose among multiple free and excellent models; unless they have especially complex and compute-intensive queries, they have little reason to subscribe to the premium versions. If a model maker imposes a paywall or displays irritating ads, customers will migrate elsewhere." Ostaje pitanje dokle jos mogi funkcionisati u deficitu. Mislim da su se preracunali i oko konkurencije i oko profitabinosti. S toga bombasticne izjave o propadanju od strane klovnoa i dalje stoje. Kako i sam clanak kaze, istina je negdje u sredini. AI, its here to stay. Ali mislim da slijedi neka normalizacija hajpa u narednoj godini. A s tim i veci gubitci.
#609 |
Postovi: 8,638
OK, nek im eJaJ tu bude i ostane, ali ako bude to ostalo na generiranju nimalo korisnog audio-video materijala za postove na društvenim mrežama i prepisivanju sažetih sažetaka mailova, dok se cijela stvar prodaje kao J.A.R.V.I.S. kojem je dosta reći nek nađe lijek za sve vrste bolesti i to je to - čovječanstvno je spašeno. E jebiga, pa nisu za drugo, nego da propadnu zajedno s maglom koju uvaljuju bez trunke srama.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX |
#611 |
Lokacija: Dalmacija
Postovi: 5,987
Šteta bi bilo da propadne, može neko volit ili ne volit ali je veliki tehnološli iskorak svakako. Isto tako početnom razvoju skoro ništa nije profitabilno, ali problem trenutni AIa je što su se ne-tehnički manageri uhvatili na AI hype i poceli pucat lovu unutra ko maniti i pristupaju rjesenju problema pumanjem love a ne na tehnološki pristup. Mislim da i dalje stoji ona koju smo komentirali, propast ce 95% AI firmi, ovih 5 ce drzat monopol, a to ce vjerojatno bit 5 istih koje i sad drze monopole(MS,AMZ,GOOG...) i to ti je to. Što se tiče financijske samoodrživosti, vecina firmi nije profitabilna bila prvih par godina, Tesla skoro 10 godina, Youtube 5 godina itd. itd. Zato se pumpa lova, usluge su jeftine, pa ce se prestat pumpat lova pa ce Chatgpt+ bit 100e misecno i tako to ide |
#612 |
White Rabbit
Postovi: 5,513
Pretpostavljam da ce se s vremenom dogodit da Bubble pukne - Bullshit projekti i firme padaju u vodu i onda ostaje ono gdje AI ima smisla kao osobni asistent, uz regulacije i cijene/reklame. Tek tada ocekujem da AI postane smislenije koristan. Slicno se dogodilo nakon dot com booma , eto Amazon ( na primjer ) je jos tu i ziv. Tak da vjerujem da AI ostaje i da ce tek nakon implozije poceti znatnije dobivati na kvaliteti. Vidli bumo. |
#613 |
Lokacija: Space
Postovi: 851
Moguce da se sve svede opet nazad na Google. OpenAI je pod pritiskom i od Muska dok je Apple odustao od AI utrke i dao Googleu da odradi za njih posao. Mene od svega samo zanima kad cu preci na AM5. Nadam se prije AM6 platforme.
#614 | |
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,929
promo, koliko traju AMD platforme, teško da ćeš preskočiti AM5.
#615 |
Lokacija: Space
Postovi: 851
Kazem ironicno, cijenaam RAM-a se ne blizi stabilizacija. Ko zna koliko ce ovo potrajati. Prije dvije godine 128GB bilo 450€, sad za te pare jedva 32GB.
#616 |
Lokacija: tu
Postovi: 3,929
Pitanje je što će se dogoditi kroz koju godinu. Ako im je cilj stvarno taj da prisile ljude na cloud, onda možda cijene niti ne budu išle dolje. Jedino će onda ostale komponente gore. S time da moraju naći neki balans u međuvremenu, jer ako digneš cijenu 5x a prodaja padne 15x, kratkoročno to bude imalo loš efekt na likvidnost.
#617 |
Postovi: 8,638
IMHO cijene memorije, ostalog hardvera i potrošačke elektronike se neće vratiti u neku normalnu, jer firme koje su i stvorile ovu situaciju sad na tjednoj bazi daju službene izjave kak se kompletno bacaju u AI, dok se ostali tržišni segmenti lagano zapostavljaju, jer ih jednostavno boli briga. Vrla stvar kaj je netko voljan dati 5.000€ za RTX 5090 da se igra na 4K ekranu ili par tisuća eura za par stotina gigabajta memorije, kad su im za eJaJ potrebe - zalihe (koje imaju i nemaju) unaprijed rasprodane do minimalno 2030. i živo im se fućka.
#619 |
Lokacija: Space
Postovi: 851
Izgradnja AI servera ne moze rasti eksponencijalno. Pocet ce polako padati i doci do nekog "flatline". U tom momentu ce se memorija vratiti u neku normalnu. E sada kada ce doci taj momenat. Da li za godinu, dvije, deset. To mene brine. Ali ne vjerujem da ce zauvjek ostati u tom segmentu "egzoticnih uredjaja". Jer ne mogu tehnički uredjaji biti cloud. Potrosacka elektronika ce i dalje ostati u istoj formi. Gaming moze preci na cloud i to je to. Posao koji zahtjeva high end racunare, bas i ne. Cloud Windows je buducnost, ali jos daleko od realnosto. Hajd nadam se da ce Ai uspjeh biti jednak NFT bullshitu. Samo da ugrabim 128GB rama pa neka opet divljaju ![]()
#620 |
Postovi: 8,638
Ma bojim se da cijene neće biti vraćene u normalu, jer budu prije sve skupa natjerali da se priviknu na novo normalno, pošto je ista stvar već prošla za vrijeme kripto pizdarija i COVID-19 situacije. Cijene su se digle radi nestašice i nikad se nisu vratile u normalnu, mada je odavno prošla i kripto ludnica i COVID-19 situacija, dok su se ljudi u međuvremenu navikli na novo normalno i nitko više nema problema dati 1.200€ za prosječnu RTX karticu koja služi za igranje, jer najbolje se plaća, a ono kaj valja to i košta i tome slične gluposti. Kvaliteta svih mogućih proizvoda iz svake generacije ide nizbrdo, dok se cijene samo povećavaju i to je to, a ovi pričaju o AI budućnosti di pola dana moraš provesti s nekim LLM-om kojeg ko malo dijete držiš za ruku i paziš na svaku riječ inače te svjetski zajebe koliko ti pomaže da budeš bolji i efikasniji u poslu i životu općenito. ![]() ![]()
#621 |
Lokacija: Space
Postovi: 851
Sad je stvar sta je referenca jake graficke karte. Mislim da je 4K i dalje luksuz, a ne standard. A ja sam 4070 TI Super uzeo za 850€ prije 5000 serije i evo nemam nikakvih problema sa novim naslovima, napucanom grafikom itd, na 4K rezoluciji. Zbog 16GB bit cu jos dugo miran. iRacing i LMU tjeram na 3x4K. Jedino se slazem da su graficke poskupile zajedno sa svim ostalim ali opet, kolega je uzeo nedavno u Austriji 5080 za 890€ i bit ce miran jako dugo. Gledajuci cijene svega ostalog, GPU se ipak vratio u "normalu" i ako danas normalnost ne postoji. A na temi AI panike: "Microsoft chief executive Satya Nadella has warned that AI risks becoming a speculative bubble unless its use spreads beyond big tech companies and wealthy economies. Nadella on Tuesday said that the long-term success of the fast-developing technology would depend on it being used by a broad range of industries as well as on uptake outside of the developed world. “For this not to be a bubble by definition, it requires that the benefits of this are much more evenly spread,” said Nadella. He noted that a “tell-tale sign of if it’s a bubble” would be if only tech groups were benefiting from the rise of AI, rather than companies in other sectors." https://www.ft.com/content/2a29cbc9-...2-bc88189672e6
#622 |
Lokacija: tu
Postovi: 3,929
> Izgradnja AI servera ne moze rasti eksponencijalno. Pocet ce polako padati i doci do nekog "flatline". Do toga je već došlo, sami su nedavno kazali da su GPU proizvedene ali nema dovoljno slobodnih elektrona da to sve upogoni. Što se cijena općenito tiče, o tome neka brine tržište. Ako ljudi budu kupovali, cijene budu išle gore, to je prirodno. Ono što nije prirodno su razne intervencije na tržište. Meni miriše da bi mogla pasti jedna "nacionalizacija" kada pukne balon po provjerenim sistemima too big to fail, your data belongs to us i sl. Jer ako sve ovo nije pogonjeno financijskim motivima, a stvarno se ovoga puta čini kako nije, onda se treba zapitati kojim motivima jeste pogonjeno.
#623 | |
Postovi: 8,638
#624 |
Lokacija: Space
Postovi: 851
A to se slazem, ja sam mislio na onaj mali kratki predah od pada kripto mininga do poskupljenja zbog AI. A sad sve tehnicke stvari treba cuvati, mobitel u dvije silikonske zastitite, TV i konzolu spojiti na UPS zajedno sa PC-em i kome treba nesto, neka sada kupi dok jos nije kasno. Ja sam isao do te mjere da kupim komplet PC samo radi rama kontajuci da imaju neki koji nisu digli cijene zbog ali vraga. PC sa 1000€ na 2000€ lagano podigli. Ova zima ce potrajati.
#625 |
Uptime 99.99%
Postovi: 2,761
Microsoft CEO warns that we must 'do something useful' with AI or they'll lose 'social permission' to burn electricity on it > "I would say we will quickly lose even the social permission to actually take something like energy, which is a scarce resource, and use it to generate these tokens, if these tokens are not improving health outcomes, education outcomes, public sector efficiency, private sector competitiveness across all sectors." Sent from my SM-S931B using Tapatalk
#627 |
Postovi: 8,638
"Kako to", pa ideja je bila da pričamo sa svojim uređajima koji umjesto nas odrade kaj god treba bez pardona i problema, a sad se traži neka namjena za taj silni AI. ![]() ![]()
#628 |
Uptime 99.99%
Postovi: 2,761
Mislili su da ce korisnici naci smisao, njihov cilj je bio samo da ga prisilno gurnu. Microsoft CEO Satya Nadella warns that AI could lose public support unless it delivers tangible, real-world impact. "Otherwise, I don't think this makes much sense." Sent from my SM-S931B using Tapatalk
#629 |
Lokacija: Space
Postovi: 851
Osim sto takve izjave lidera industrije cine cijelu situaciju neozbiljnom, ovo me sve podsjeca na pocetak VR price. Imaju proizvod i cekaju da neko napravi korist od njega. I onda ljudi ne kupuju VR jer nema dovoljno igara, a nema igara jer ljudi ne kupuju VR. I tako AI giganti cekaju da AI prihvati svako bice na planeti i ako ni sami ne znaju za koji ce q AI koristiti prosjecna osoba kojoj je dovoljan facebook i google search. Ili ako idemo jos malo u nazad. Mislim da se uredjaj zvao "leap motion". Stvori 3D prostor ispred ekrana koji detektuje obje ruke gdje se ocekivala revolucija poput Minority Report. A onda koristici kontaju, sta ja da radim s ovim, a developeri cekali da neko nadje korist od hardwarea. I na kraju ih mislim kupi Oculus. I sad je taj VR negdje na periferiji drustva kao gadget koji je cool ponekada probati dok svakodnevni zivot s njim cini napornim. ![]()
