Postovi: 156
Na Thinkpad T14 Gen2 laptopu imam problem da kada imam spojen ethernet kabl, radi neko vrijeme (sat, dva, tri...) i onda se nešto zbrejka i kao da kabl nije uključen - https://imgur.com/a/F8C0ofZ Ako je wifi enablean, prebacit će se na njega, a ako nije, onda sam bez interneta. Izvlačenje kabla i ponovno ukapčanje najčešće riješi problem, ali dosta je iritantno ovo. OS je Win11 - ali događalo se i kroz par dana što sam se igrao sa Debianom Probao sa više kablova, pa me zanima zapravo - jel bi se isplatilo mijenjati ethernet port na laptopu i jel to izvedivo i koliko košta otprilike? EDIT: eh, i u device manageru sam disableao ono da se ethernet port gasi radi uštede energije |
#2 | |
Datum registracije: Jun 2020
Postovi: 177
možda je problem u switchu/routeru probaj pingat router i nešto drugo na mreži kad se to dogodi ne možeš samo tako mijenjati ethernet port, ne možeš niti na desktopu, kamoli na laptopu, možeš eventualno probati koristiti usb/ethernet adapter |
#3 | |
Postovi: 156
Code:
ping 192.168.178.1
Pinging 192.168.178.1 with 32 bytes of data:
Reply from 192.168.178.1: bytes=32 time=3ms TTL=64
Reply from 192.168.178.1: bytes=32 time=2ms TTL=64
Ping statistics for 192.168.178.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 2ms, Maximum = 3ms, Average = 2ms
Code:
ping 192.168.178.21
Pinging 192.168.178.21 with 32 bytes of data:
Reply from 192.168.178.21: bytes=32 time=4ms TTL=128
Reply from 192.168.178.21: bytes=32 time=2ms TTL=128
Reply from 192.168.178.21: bytes=32 time=3ms TTL=128
Ping statistics for 192.168.178.21:
Minimum = 2ms, Maximum = 4ms, Average = 3ms
Code:
ping 192.168.178.1
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
![]() https://imgur.com/a/Ksc4tPe Edit: i par minuta kasnije se odspojio i prebacio u wifi... https://imgur.com/a/2991eiG |
Postovi: 177
daj ipconfig /all kad se to dogodi |
Postovi: 156
Rekao bih da je Ethernet 2 adapter kojeg treba gledati: Wifi, kabl nije u laptopu: Code:
>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Interceptor
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : fritz.box
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : 6C-24-08-0C-F3-85
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Unknown adapter Tailscale:
Description . . . . . . . . . . . : Tailscale Tunnel
DHCP Enabled. . . . . . . . . . . : No
Link-local IPv6 Address . . . . . : fe80::c3e5:5bb2:9b7e:ee95%7(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.83.107(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
NetBIOS over Tcpip. . . . . . . . : Disabled
Wireless LAN adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 12-6F-D9-9F-E5-F5
Wireless LAN adapter Local Area Connection* 10:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 12-6F-D9-9F-F5-E5
Wireless LAN adapter WiFi:
Connection-specific DNS Suffix . : fritz.box
Description . . . . . . . . . . . : MediaTek Wi-Fi 6 MT7921 Wireless LAN Card
Physical Address. . . . . . . . . : 10-6F-D9-9F-C5-D5
IPv6 Address. . . . . . . . . . . : fd00::7062:d8a8:67d1:da3a(Preferred)
Temporary IPv6 Address. . . . . . : fd00::ecf5:9223:3f5:1d38(Preferred)
Link-local IPv6 Address . . . . . : fe80::5ec3:c173:9f26:f588%9(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.178.52(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 26. rujna 2025. 12:55:35
Lease Expires . . . . . . . . . . : 06. listopada 2025. 13:00:34
Default Gateway . . . . . . . . . : 192.168.178.1
DHCP Server . . . . . . . . . . . : 192.168.178.1
DHCPv6 IAID . . . . . . . . . . . : 470839257
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-30-60-0A-AE-6C-24-08-0C-F3-85
DNS Servers . . . . . . . . . . . : fd00::1eed:6fff:fe9d:7e20
192.168.178.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Ethernet 2:
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller #2
Physical Address. . . . . . . . . : 6C-24-08-0C-F3-84
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 10-6F-D9-9F-C5-D6
Code:
>ipconfig /all
Link-local IPv6 Address . . . . . : fe80::3fb8:4721:8053:b528%16(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.178.65(Preferred)
Lease Obtained. . . . . . . . . . : 26. rujna 2025. 12:57:17
Lease Expires . . . . . . . . . . : 06. listopada 2025. 19:52:53
DHCPv6 IAID . . . . . . . . . . . : 124527624
192.168.178.1
Lease Expires . . . . . . . . . . : 06. listopada 2025. 13:00:35
192.168.178.1
Code:
>ipconfig /all
192.168.178.1
Émile Flournoy
Lokacija: Chicharija
Postovi: 1,537
Probaj u postavkama adaptera ograničiti brzinu na 100 Mbita i niže. Nekad u doba dsl-a sam tako "popravljao" mrežne kartice "nagorene" nakon grmljavine. Neke bi se stabilizirale tek na 10 Mbit / half-duplex. Kako izlgledaju lamelice u rj45 utičnici, da li su čiste i dovoljno napete prema konektoru ? Ako se neka od njih iskrivila napneš ju nazad sa plastičnom kukicom. |
Postovi: 23,657
Koji je precizno Machine type ? Po ispisu mrežna je neka Realtek - ova. Izvadi pa zalijepi ovdje Device / Hardware ID, možda na Realtek - ovom site ima noviji drajver. |
#8 | ||
Postovi: 156
Probam i sa ograničavanjem, ali mi to zapravo nije rješenje, hoću full working ethernet ![]() Citiraj:
Hardware ID kaže: Code:
PCI\VEN_10EC&DEV_8168&SUBSYS_509417AA&REV_15 PCI\VEN_10EC&DEV_8168&SUBSYS_509417AA PCI\VEN_10EC&DEV_8168&CC_020000 PCI\VEN_10EC&DEV_8168&CC_0200 Device description: Code:
Realtek PCIe GbE Family Controller |
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,207
Probaj staviti stariji driver i onemogući da se nadogradi na novi. Jednom sam imao problema isto da radi radi i puf ne radi. Mamlaz se nadogradio na novi driver u pozadini koji nije radio dobro. Onda sam onemogućio nadogradnju drivera i vratio stari i radi.
tomek@vz: ajd nemoj | Mali Čile SAD Češka Peru | Windows Free |
Postovi: 156
Pokušat ću i sa starijim driverima. Jel nekakav indikator to što lampice na konektoru (ni zelena ni narančasta) ne blinkaju uopće, čak ni kad je ethernet aktivan? Sve mi se čini da će sjesti neki usb-c dock/hub (jer mi tak i tak treba zbog USB-a i dva externa monitora), pa će uvjet biti i da ima ethernet. |
#12 | |
Postovi: 156
Postovi: 23,657
Po Realtek - u na ovom linku > https://www.realtek.com/Download/ToD...ownloadid=3613 trebao bi dobiti Install_Win11_Win10_10077_08282025.zip file, unutra jedino "korisno" sam upload - o ovdje > https://limewire.com/d/4NEbo#qctAPPMyVr raspakiraj u neki prazni folder pa kroz Device Manager napravi Update drajvera. To je valjda zadnja verzija 10.77 drajvera. Akternativa (moguće da tu verziju već imaš) je sa M$ update > https://www.catalog.update.microsoft...0EC%26DEV_8168 tu za W11 ima verzija 10.72.xxxx, npr: https://www.catalog.update.microsoft...c-1595796e326c Ovo da Led - ice na konektoru ne blinkaju / svijetle (kad konekcija radi) ne miriše na dobro ![]() |
