#572 |
Postovi: 8,540
Da, 9950X se ponaša podjednako efikasno. ![]() EDIT:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 16.08.2025. u 17:58. |
#574 |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,695
Evo, stigla nova kanta: Ryzen 9950x + NH-D15 MSI MAG x870 Tomahawk 256GB RAM RTX5080 u biosu mi je ECO mode disejblan i jedino što sam napravio je curve optimiser, all core -15 U CB23 dobivam 41613 all core, s max temp od 85°C nakon 10min. Je to ok?, Ne ganjam score, bitna mi je stabilnost i temp... p.s. za sve koji se češkaju po glavi i misle si čemu tolko rama - 3D lasersko skeniranje i fotogrametrija ![]() |
#575 |
Postovi: 8,540
Vredu je to, glavno da ti sve radi kak spada.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#576 |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,695
Onda više ne prčkam ![]() Dopuna, ipak sam prčkao ![]() Nasao sam tdp limit i kada stavim na 120w, co -15, temp je ugodnih 75 max, ali i performanse u real world testiranju cca 10% slabije. Zavrsio sam na tome da je tdp po difoltu, co -20 i temp sam ogranicio na 80. Rezultati prakticki isti kao kada je sve po difoltu, a hladniji. Kada je bio samo co -15 all core, u c23 nije isla temp preko 85, al je isla do 95 u fotogrametriji. Sad vise ne diram za ozbiljno ![]() Zadnje izmijenjeno od: Problem. 21.08.2025. u 12:34. |
#577 |
Postovi: 4,465
#578 |
Lokacija: Sv.Nedelja
Postovi: 5,830
Pozdrav. Slažem konfu pa trebam mišljenje.. Prioritet je stavljen na stabilnost i temperature tj potrošnja sistema. Traži se "rock solid" konfa. U pitanju je 9700X i Asus Rog Strix B850-F Gaming+G.Skill Trident (32gb) 6000 CL30. Pretpostavljam da je ta kombinacija ok? Jel postoje kakve mušice i sl s tom pločom, memorijom i procom u pogledu trzanja, nestabilnosti i sl? |
#579 |
Postovi: 8,540
OK su te komponente, a stabilnost ionak dodatno ovisi o postavkama koje namjeravaš koristiti, odnosno da baš ne ostaviš sve na auto i default u BIOS-u. ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 22.08.2025. u 10:34. |
#580 | ||
Postovi: 8,540
#585 | |
White Rabbit
Postovi: 5,321
> Techspot |
#586 |
Lokacija: Zagreb, Črnomerec
Postovi: 2,661
https://www.3dmark.com/3dm/140941912? Solidan iGPU na mobilnom zenu5. BG3 radi sasvim ok na medium 1080p. |
#587 |
Postovi: 8,540
#590 |
Postovi: 8,540
ASRock sam ne zna ili ne želi reći točan uzrok, pa je Heavy Metal Steve provel sat vremena u tom osvrtu uz popratne detalje potencijalnih uzroka. Makar čak i uz sav pozadinski čupajz kojem još uvijek nema kraja - AMD i dalje uredno uvažava sve CPU reklamacije.
#591 |
Lokacija: Zabok
Postovi: 3,419
Bar nešto pozitivno. Inače, primijetil sam na svojoj AM4 Extreme4 da po defaultu napucava CPU voltažom, jedina granica je valjda temperaturni trotling. Nakon petljanja s PBOom od kojeg sam na kraju odustao, najbolji se pokazao negativni offset od 0.75. IMHO, ta automatika s burstanjem voltaže i clocka nije baš pre-pametna, osobito kod neujednačenog i light workload-a. Npr. stare igre za koje i onako nije potreban nikakav burst. Ili stajanje na početnom meniju i sl. Pa zatim Epic Games launcher koji kod downloada prži CPU ... wtf i zašto? Za to sam složio Windows power profil koji ne bursta. Tako da mislim da si je ekipa i sama kriva za spržene CPUe jer su sve ostavili na defaultu, ili su pak ukucavali "bedaste" vrijednosti. Siguran sam da su ASRock-ove defaultne postavke jako "optimistične". Zadnje izmijenjeno od: stef. 03.10.2025. u 13:44. |
#593 |
Prvoklasni Krkan
Postovi: 5,372
AMD Gains CPU Share as Intel Hits Record Low on Steam September Hardware Survey Steam survey je rekao bih zakukac...ispada da AMD jedva dostiže Intel, a realna situacija je da su pomeli pod sa njima u zadnjih sigurno 6 godina. Ali pošto ne mijenjaju svi kompove, ima tu još vj hrpetina sandy derivata koji i dalje rade normalno pa ispada ovako kako ispada. Hajde da vidimo za cca godinu kada ga nam gurnu w11 niz grlo i da li će se situacija promijeniti. I ne, nije vjest negativna po AMD, ali mi je čudno da ispada da i dalje ima više intela kod gejmera (koji su voljni učestvovati u SSu, ja npr svaki put prihvatim kada me pita). @Stef: ima popriličan broj retardiranih igara koje na meniju nemaju vsync iako ga za igru imaju..pa se GPU i CPU rasdpadaju na max bezveze i slično... |
#594 |
Postovi: 8,540
Dobro je da Intel ovaj tjedan službeno najavljuje najavu najave za Panther Lake i 18A proces koji će onda biti predstavljen na CES-u 2026. i u rukama kupaca tijekom ljeta sljedeće godine. Tak da nisu loše ove Steam ankete, jer realnost je malo zajebanija stavka, pa nije lijepo pričati o mobilnim Panther Lake modelima koji su već trebali biti na tržištu.
#595 |
Datum registracije: Aug 2020
Postovi: 899
Još dobrih vijesti od AMD-a: https://zimo.dnevnik.hr/clanak/amd-i...---938671.html |
#596 |
All-rounder
Datum registracije: Sep 2013
Postovi: 1,342
Ovo je više za GPU temu, ali ima smisla i od strane korisnika AI hardvera da se diversificiraju. Vezanje za Nvidiu je najgora stvar koju su mogli napraviti za sebe. Em je usko grlo u deploymentu imati samo jednog proizvođača, em će ih kožnati oderati žive. |
#597 | ||
Postovi: 8,540
Lako moguće da se odvikavanje od nVidijinih rješenja i dodatno ubrza obzirom na ping-pong koji Jensen igra sa svim uključenim stranama. ![]() Citiraj:
#598 |
Postovi: 899
Dobro su neki govorili da je to s Nvidijom balon koji može puknuti bilo kad. Trenutno im ide odlično, Kožnati je finu lovu ugrabio, no Kinezi ubrzano rade na osamostaljenju. AMD nudi sve konkurentniji proizvod, točnije, hardverski su odavno konkurentni, no softverski zaostaju, ali su kupili nekoliko AI softverskih kompanija te sudeći po dogovoru s OpenAI-jem, imaju prilično zrelu platformu. Jensenu nije ugodno, koliko god trenutno izgledao svemoćno. Sve se to može u sekundi raspasti, svjestan je on toga, a ne pomaže mu ni Trump sa svojom politikom zatvaranja i pokazivanja srednjeg prsta svemu što nije američko. |
#599 |
Postovi: 8,540
Da, Jensen jako dobro zna da ne može dovijeka držati monopol nad kompletnim tržištem i koliko god se pravi da mu kinesko tržište nije baš neki preveliki gubitak, ipak je svjestan da gubi fini dio kolača. Makar istovremeno hvali sve strane, jer se nikome ne želi zamjeriti, dok im nameće svoje proizvode, nije glup, pa da vjeruje kak još dugo može sjediti na svim stolicama. Kina je kak smo i komentirali diljem raznih tema, ponajviše u kontekstu Intelovih peripetija i tzv. domaće proizvodnje, fino nadigrala i prešišala ostatak svijeta, te im uopće nije problem koristiti svoja domaća rješenja.
#600 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,714
Zadnje izmijenjeno od: kopija. 06.10.2025. u 18:33. |
