#82081 | |
Postovi: 17,155
Neće presretač nikoga zaustaviti jer prvo, nema ih dosta, drugo ne može se gurati u gužvu, treće, to su nam turisti koji pune proračun, četvrto, nema alternative, 2 su samo trake itd. Brdo problema. Kužim frustraciju, ali riješenje nema. |
#82083 |
Lokacija: Velika Gorica
Postovi: 262
evo i misha je dao svoje misljenje o prometnoj izmedu porschea i bmwa So about that big nasty Nürburgring crash... Full video you know where, but "in short": I appreciate all your DMs asking whether I have seen it. Or any other NBR crash/incident/event. The locals see this stuff daily, but most of the times it stays within local WhatsApp groups or occassionally a picture gets posted on FB. Having said that: it's nothing special, this happens (almost) every day and crashes/incidents happen on almost every track day on every other track in the world. The "fireworks" of this one was of course quite big and massive thanks to today's safety standards for keeping everyone alive. In Porsche's case the driver had "just a few scratches", without helmet, HANS or any fire protective clothing. Who is at fault? One more than the other. Public sessions are classified as public road and the rule is = slow traffic stays right, fast traffic passes on the left. As it is an unlimited speed section of "the road", everyone is required to check their mirrors for faster traffic. M2 clearly failed to do that, when the faster traffic was behind it first and shortly after next to it. Rule Number 2: everyone is allowed to drive only as fast, as when they can make an immediate stop to avoid any accident. M2 turning in on you and you did not stop to avoid it? Own fault. Deer crossing the road and you hit it? Own fault. Asteroid fell out of the sky and hit you? Your own fault. Porsche driver COULD have anticipated that a foreign car is less experienced and may do silly things last moment. You can see the Porsche go off the gas earlier when M2 was on its line and started to accelerate when it moved out to the right. So there was no reckless behaviour from my point of view. Just very unfortunate split second wrong assumption and lack of awareness. The other "interesting" question is who will pick up the bill. The barrier damage and other very expensive car. This is something for the authorities to decide - who is responsible for how much % of the accident and it may get nasty. The main reason I am mentioning this is a reminder that you are liable for yourself and others during the public sessions and some track days too. So be prepared and stay focused. |
#82084 | |
#erase startup-config
Postovi: 3,738
Automobili
Kamere koje do 30 puta sekundi mogu očitati tucet registracija i automatski logirati prebrzu vožnju ili tailgating kao u ovom slučaju. Vidio sam demo toga na svoje oči kod nas u Zagrebu prije sedam godina. Stoga je pravo pitanje zašto to već nije implementirano. |
#82085 | |
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,420
Kupi si pošteni auto pa nečeš morati stajati sa strane dok kiša pada. ☝️😂
#82086 | |
Postovi: 17,155
Vienjete su jedna od tih. ![]() Zašto? Zato jer smo mi govno od države gdje ližemo noge Česima, Poljacima i Bugarima jer nam plaćaju 4EUR za kuglicu sladoleda i 200EUR za noć u Tučepima negdje u špajzi. Zato. |
#82087 | |
Postovi: 10,559
![]() Na stranu sto je europski DRL osmislio netko jako retardiran, zapravo ne razumijem zasto senzori za svjetlo i kisu ne pale kratka svjetla kad pocne kisa? Ono, registrirao si promjenu u osvjetljenju, ali nedovoljno da se upale kratka svjetla, ajde oke! Ali onda pocne kisa i auto kaze "hej, upali brisace". Daj jbt upali im onda i svjetla. Ili ako su kojim slucajem rucno upalili pozicije i time overrideali automatiku, ugasi im rasvjetu table i ekrana, napisi im na ekranu "upali svjetla konju", forsaj ih da okrenu taj sugavi knob svojim prsticima.
#82088 | |
Pod naletima kopita zla
Lokacija: SMB / ZGB
Postovi: 7,736
Nema to veze s autom nego je zdravo razumski ne voziti u takvim uslovima ako nije bađ nužno. Citiraj:
#82089 | |
Brat od Đon Vejna
Lokacija: zg-vg
Postovi: 1,205
#82090 |
Postovi: 10,559
Ako brod na pucini mora imati pozicije, zasto auto ne mora imati sve 4 pozicije apsolutno uvijek upaljene dok radi motor? To ne razumijem... I zasto skandinavci imaju svoj DRL mod koji uvijek pali sve 4 pozicije? Ako oni mogu, zasto ostatak EU ne moze? Mislim, promjene se dogadjaju, evo touch tipke odlaze u povijest. Tamo neki priuceni dizajneri auto interijera su se izdrkavali jedni po drugima sve ove godine dok se mi hebemo tapkajuci po ekranima.
#82091 |
The mighty pirate
Lokacija: London
Postovi: 9,216
Uzeo sam za probu nekakav paket za bezvodno pranje auta i jučer odradio pranje. Stvar je na bazi carnauba voska. Pošpricaš, obrišeš krpom od mikrofibre i kad prođeš cijeli auto, prođeš čistom krpom i stvar gotova. Odvoji prljavštinu i navodno ne grebe lak. Odradio sam to u garaži pod neonskim svjetlima pa nisam bio siguran kako će ispasti, ali zadovoljan sam. Prvi minus je što nigdje ne kažu da ne treba manijakalno špricati i natopiti auto, tako da sam potrošio pola jedne boce (kaže da se s jednom bocom može odraditi 6-8 pranja). Drugi minus je što nema šanse da operem tu krpu od mikrofibre .Masna je kao da sam je provukao kroz friške čvarke. Vjerojatno je puno istih stvari pod različitim imenima na tržištu. Eto, mogu preporučitic, stvar funkcionira. Trebalo mi je oko 45 minuta da operem auto (vele 30).
#82092 |
Postovi: 3,738
Skandinavci imaju stalno oblačno vrijeme pa tamo to dobro dođe i dobro se vidi. Mi imamo puno sunčanih dana pa se pozicije niti ne kuže kada su upaljene. Prije lampe nisu bile LED pa stalno upaljene ne bi dugo trajale. Ja sam od malih nogu naučen da palim svjetla kada je oblačno ili kada vozim u sjeni npr. vijadukt, šuma… |
#82093 | |
Datum registracije: Aug 2009
Lokacija: Zürich
Postovi: 711
#82094 | |
Postovi: 1,073
#82095 | |
The mighty pirate
Lokacija: London
Postovi: 9,216
Oprao sam ga normalno prije par dana i pao je pljusak od 10 minuta, skroz dovoljno da ga zasere, a da nije prljav. Ide prvo pod vodu ubuduće, pa onda lagano ovime. Ne planiram ga prati na suho samo ovime.
#82096 | |
Postovi: 10,559
Pitam se imaju li Englezi skandinavski DRL? Ivane? ![]()
#82097 | |
The mighty pirate
Lokacija: London
Postovi: 9,216
Kakav DRL, ovdje ni svjetla nisu obavezna po mraku ![]() Citiraj:
#82098 | |
jedan i jedini :D
Lokacija: novi zagreb
Postovi: 5,360
Znam samo da me se bolje vidi na cesti. Ovo sa DRL-om je suludo. Mislio sam da je problem samo kod nas, al bit će u cijeloj Europi debosi voze tako. |
#82099 |
Postovi: 3,738
#82100 |
White Rabbit
Lokacija: München/Varaždin
Postovi: 5,860
Meni se na Megane-u automatski pale svijetla čim upalim auto. Žarulje ne prde često kako sam mislio (pogotovo jer francuzi navodno imaju lošu elektroniku). Jedino kad sam gunđao zbog cijene je kad mi je 3-e stop svjetlo krepalo pa je njega trebalo mijenjat (LED naravno). |
#82101 |
Postovi: 10,559
Palio sam svjetla cijelu godinu na proslom pezou, kupovao nightbreakere i prdile su svako 6 mjeseci. Sa nalemljenim termistorom su durale malko duze, ali opet... Nisam imao DRL na njemu pa su kratka bila jedina opcija (ne racunam onu tinjalicu od pozicije). Mase na konektorima straznjih lampi su bile blago otopljene, francuska klasika jel. Ne znas da je tako dok ne prdne cijeli kluster/lampa a onda imas mrtvu poziciju, stop i rikverc svjetlo. Mislim da sam jedno 10ak parova zarulja promjenio u 6 godina ![]()
#82102 |
Postovi: 1,073
Najtbrejkeri, koja prevara. Dok su osram classic (original) jedine žarulje koje idu na moje aute |
#82103 | |
Datum registracije: Jun 2020
Postovi: 177
zašto prevara? počeo sam ih koristiti davno na fiat bravi koja je imala katastrofalne farove, nightbreaker su mi uz philips blue vision jedine kolko tolko osvjetljavale cestu ostala mi je navika kupovati i kasnije iako su auti poslije imali ok farove |
#82104 |
Postovi: 10,559
Meni su se pokazali isto kao najoptimalniji, osim po kisi al to sam i ocekivao i prihvacao. Takodjer, morao sam izvuci maks iz tog fara i ostale zarulje su mi jednostavno bile neuvjerljive. Prevara su na francuzima ali vidim na drugim autima te H7 zarulje znaju duze durati.Rezerva su mi bile neke osram obicne, ali svega par puta sam bio prisiljen koristiti ih (i bolje).
#82105 |
Postovi: 1,073
Ako ste zadovoljni, ok. Po meni uloženo dobiveno. Ispravni i dobri |
#82106 |
Postovi: 1,073
Ako ste zadovoljni, ok. Po meni uloženo dobiveno. Jako su skupi bili i kratko trajali naspram classic osrama. Ispravni i dobri farovi rade pravu razliku. |
#82107 |
jedan i jedini :D
Postovi: 5,360
#82108 | |
Master Of Disaster
Datum registracije: Nov 2002
Postovi: 1,288
nije bilo 100-130kmh, nego 90-100. mene osobno zivciraju ljudi koji voze do ogranicenja i onda misle da imaju pravo uzurpirati lijevu PRETICAJNU traku. znam da svi vozimo po guzvama i da nam fali jedna, ako ne dvije trake od ZG do Bosiljeva. Ali ako ne pretices u tom trenutku i imas mogucnosti skrenuti u desnu traku nakon svog preticanja, bio bi jako zahvalan da prepustis mene da vozim kako ja ocu i sam odgovaram za posljedice toga. pogotovo kad mi na nekim dijelovima autoceste jos imaju znak 80kmh ogranicenja od prije 4 mjeseca kad je HAC radio neko odrzavanje i zaboravili maknuti znak ![]()
#82109 |
Postovi: 3,738
Deset godina su bila tvornička svjetla u zadnjim farovima na Cliu. Kasnije su aftermarket pozicije/štopovi pregarali dva puta godišnje. To mi je išlo na živce pa sam kupio Philips Ultinon P21/5 sa 12god garancije. Već sedam godina veselo svijetle u zadnjim farovima i prolaze tehnički iako strogo gledano ne bi trebali. https://youtu.be/DWvIaY82Un8 |
