#1291 |
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,556
ovisi šta ti imaju klijenti... ako imaš ax, ja bi išao na ax. uvijek možeš poduplati kanal na 160mhz i progurati skoro gigabit na wifiju. ac uz sav trud i sve, zapne na oko 600mbita. 4x4 ti ne znači previše ako ti klijenti imaju samo 2x2. |
#1293 |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,118
Koju preporuku imate za VDSL modem koji bi znal hendlati loše snr margine? Code:
xDSLFwVersion: FwVer:5.12.31.1_B_A60901 HwVer:T14.F7_0.0
Line State: Up
Modulation: ITU G.993.2(VDSL2), G.998.4(G.INP)
Annex Mode: ANNEX_B
INP downstream: 0
INP upstream: 16512
shineGINPdownstream: 420
shineGINPupstream: 480
reinGINPdownstream: 20
reinGINPupstream: 20
TPSTC type: 64/65B PTM TC
near-end interleaved channel bit rate: 40946 kbps
near-end fast channel bit rate: 0 kbps
far-end interleaved channel bit rate: 0 kbps
far-end fast channel bit rate: 10602 kbps
near-end FEC error fast: 0
near-end FEC error interleaved: 139265615
near-end CRC error fast: 0
near-end CRC error interleaved: 13
near-end HEC error fast: 0
near-end HEC error interleaved: 0
far-end FEC error fast: 76
far-end FEC error interleaved: 0
far-end CRC error fast: 0
far-end CRC error interleaved: 0
far-end HEC error fast: 0
far-end HEC error interleaved: 0
DSL uptime :1 day, 22:57, 0 secs
DSL activetime :0 min, 15 secs
Downstream:
relative capacity occupation: 100%
noise margin downstream: 8.2 dB
output power upstream: 6.8 dbm
attenuation downstream: 17.1 dB
Upstream:
noise margin upstream: 8.0 dB
output power downstream: 18.8 dbm
attenuation upstream: 7.1 dB
Bit table:
carrier load: number of bits per tone
tone 0- 31: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 bc de
tone 32- 63: ef ff ff ff ff ff ff ff ff ff ff ff ee ee d0 00
tone 64- 95: 0b cc dc dc dd dd dd dd de ed dd dd dd dd ee de
tone 96-127: dd dd dd dd dd dd dd dd dd dd dd dd ed dd dd dd
tone 128-159: dd dd dd dd dd dc cd dc cc cd cc dc dc cc cd dd
tone 160-191: dd cd dc dd dc dd cd cc cc cd cc cc cc cc cc cc
tone 192-223: cc cc cc bc cc cb cb bb bb bc cb bc bc cb bb bb
tone 224-255: bb bc bc bc bb bc cb bc bb bb bb bb bb bb bb bb
Hvala!
#1294 |
Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,596
Asus DSL-AX82U radi Broadcom chipseta ili ako želiš Fritza onda FritzBox 7530AX. EDIT#1 Koliko vidim po SNRu ti si na FR1 profilu. Riješi sam ako znaš problem sa paricom i traži od SZKa da ti isključe FR profil. Nećeš ništa posebno postići sa vlastitim modem routerom dokle nerješiš problem sa paricom i FR1 profilom. Sent from my Pixel 7 Pro using Tapatalk Zadnje izmijenjeno od: Karlo666. 24.04.2025. u 18:44. |
#1295 |
Lokacija: Bistra
Postovi: 5,118
Ma niš od toga, to je kod frenda, em je A1 pa nemre ubaciti svoj modem, em je HT infrastruktura i oni su nekoliko puta rekli da je parica OK i da se tu niš nemre napraviti. Ne znam kak drugo more srediti problem s paricom sam, to HT mora kopati a premalo je selo da im se isplati... Hvala na preporukama!
#1296 |
Postovi: 8,493
Preporuka routera
Ja sam imao na vdslu tplink vr2100. Imao sam puno errora na innboxu, vr2100 mi je smanjio to na minimum i radio kako treba. Sada sam ga maknuo u ladicu jer dolazi optika, ako zelis mozemo se dogovoriti da ti posaljem i probas ga par dana, ako radi dobro platis cijenu po dogovoru ![]() Sad vidio da ne moze ubaciti svoj modem. Ako je A1 neka ode na HT i stavi jedan ovakav vr2100. Cak moze i na jeftiniji iskon i dobit ce user pass za ht infrastrukturu. Sry ![]() Zadnje izmijenjeno od: spawn. 24.04.2025. u 23:02. |
#1297 | |
Postovi: 8,493
Preporuka routera
Da nadodam, nisam probao ozbiljniji mesh sustav s kontrolerom, nego samo citam i prenosim iskustva clanova koji to imaju. Edit: da ne pisem drugi post: Da li zna netko postoji li mogucnost da se fritz podesi tako da sacuva dobar ping na jednom uređaju tj da ne utjece rad ostalih uređaja na gaming? Qos nekako sredi prioritet kod tplinka i kod fritza (on nema qos ali ima opciju prioritize bez dodatnih podesenja ili limita) ali svejedno malo pozderu ping. Zadnje izmijenjeno od: spawn. 17.05.2025. u 17:27. |
#1298 | |
Postovi: 1,596
Sent from my Pixel 7 Pro using Tapatalk |
#1300 |
Postovi: 10,296
Sta ti varira ping na jednom uredjaju dok recimo netko na mrezi nesto radi/skida? Mene je mucio isti problem pa je ispalo da je problem bufferbloat. Promjenio ruter (openwrt) i podesio sqm qos, sve je automagicno prodisalo. Realno bilo kakav ruter koji moze prozvakati sqm (asus npr) ce biti ok. Jesi ono na iskonu? Na serveru mi idu torrenti bez ogranicenja, meni na kompu ping vise ne skace kako mu pukne. Ako i varira, sad govorimo o 1-2ms gore-dole. Lan ili wifi, jednako iskustvo makar kod wifija uvijek postoji onih extra nekoliko ms kojih kod zicane veze nema. Testiraj si bufferbloat: https://www.waveform.com/tools/bufferbloat Dok testiras, na istom kompu pokreni cmd i pingaj nesto. "ping 1.1.1.1 -t" i prati koliko ti varira ping dok se vrti test. Moj prije/poslije rezultat: https://i.imgur.com/lHnyqTA.jpeg Mene nije mucio gaming jer ne igram nego iptv koji mi je bio jako osjetljiv na ove promjene u latencijama kad nesto skidam ili uploadam na netu.
#1301 |
Postovi: 8,493
Digne se download sa 17 na 27. Ostalo je isto cca. 16 - 17/27 - 2. Grade A u oba slucaja. Isprobano sa Huawei gpon i tplink G7 xpon + Fritzbox 7490. ,btw probao sam ranije G7 sa fritzom igrati cs2, nisam vidio neku promjenu u radu u odnosu na Huawei ont od iskona. Ping je manji za 1,a gaming isti. Sutra cu probati G7 plus tplink AX55, VR2100 i Asus AX58U. Za ovaj Ax58U V2 sada postoji Merlin ali onaj gnuton,ne znam jel valja. Nakon svih njih probat cu nesto dosta skuplje. Koji router ti imas na ovom testu i da li imas Iskon ili HT? Koji bi preporučio za sqm,vidim da neki kažu da je dosta zahtjvena,pa kad već slažem da uzmem neki dobar i jak oruter koji će to hendlat bez problema. EDIT: Upravo ubacio zadnji merlin gnuton u Ax58U v2, nema SQM, ukljucio samo qos - game mode, nista se nije promijenilo. Grade A, sve cca isto. Još nisam probao Vr2100 sa G7,vjerojatno bude isto. Također ovih dana cu provući nanovo kroz bužir novi kabel od routera do PC-a,pa da eliminiram i to ![]() Zadnje izmijenjeno od: spawn. 18.05.2025. u 00:04. |
#1302 |
Postovi: 10,296
Dok sam bio na 4G netu na jadnih ~70/20 Mbps AC86U me spasio jer je podrzavao SQM (fq_codel) kroz Merlin i FlexQoS. Doslovno me spasio jer je tad pocela korona i rad od doma i sve je stekalo kad bi zena gledala tv ili jutub. Kod mene je zasad iskon 300/100. Prvo sam imao Omadin ruter ER605 v2 i sve divno krasno osim sto bi iptv bufferao kad nesto radim na netu i trebalo mi ne vremena dok sam skuzio sto je tocno problem. Na kraju probao dignuti Openwrt na random mini pcu i skuzim da stvar radi, nema vise problema sa pingom, SQM je bio rjesenje. Na kraju sam uzeo Nanopi R4S kao ulog u buducnost. Mislim, ruter je jeftin, samo je overkill za Openwrt. Svidio mi se Openwrt, lijepo suradjuje i sa Omadom cije uredjaje i SDN imam u kuci pa rekog neka se nadje i bolji ruter ako ikad odem na 1 Gbps brzine. Imam huawei ONT, ne planiram ga mijenjati.
#1303 |
Postovi: 8,493
Preporuka routera
Openwrt podrzani uređaji podrzavaju sqm ali nemaju svi merlin uređaji sqm. Evo ovaj nazalost ne podrzava openwrt a i ne podrzava sqm preko merlina, nema te opcije u gui-ju. Ima adaptive gaming qos,veza mi sada svakako radi bolje sa tim merlinom, malo je to prodisalo , mozda zbog onog ugrađenom game qos u merlinu, ali svakako bih volio izvuci sto bolji ping i da da svi uređaji u kuci rade bez smetnji, mozda uzmem taj nano, ili taj Asus ili bilo koji jaci asus sa sqm. Jedino sto mi se ne svidja kod ovog nano uređaja je to sto moras imati par uređaja za net. Ont- nano - mesh komplet ili router plus jos nesto. Milijun kablova i opcija pa treba lijepo ugradit sve u zid ili kutiju. Hvala na savjetima. Btw, mislim da je G7 ont bacanje para, ali nije neka lova pa je ok da se jedan od njih ima kao backup. Zadnje izmijenjeno od: spawn. 18.05.2025. u 11:02. |
#1304 |
Postovi: 10,296
Da, custom ruteru je mana najcesce sto je to samo ruter. Za malo vise se da naci i varijatni sa wifi-jem, ali ne znam, ako vec imas slozeno wifi rjesenje koje te zadovoljava potpuno razumijem zasto se NE bi odlucio na router-only device. Makar ajde, ovaj openwrt zbilja ne trebam nikada dirati i eno ga skoro dva mjeseca uptimea bez da sam uopce sucelje otvorio osim dodati neki port forward ili static IP. Kod mene je to dosta elegantno, ali ispod stola je kaos (ovo je stari setup sa mini pcem i bez spojenih svih klijenata)https://i.imgur.com/AUbF0Zf.jpeg
#1305 |
Postovi: 23,626
Svezao ih da ne bježe samovoljno ![]() Kako se dižu brzine (optika), br. klijenata, zahtjevi (pametan QoS), dosta ljudi ima nekakav kantun / policu / ormarić u zidu .... onda je bolje da je "Router only a WiFi dio odrađuju drugi uređaji koje bolje / lakše pozicioniraš, mijenjaš po potrebi ... |
#1306 |
Postovi: 8,493
Preporuka routera
I to mi je palo na pamet. Taj router only i na svaki kat po jedan mesh povezani kablom za wifi potrebe a utp direkt u PC. Kuća je sranje za povezivanje, treba naci mjesto gdje ce biti samo router i onda naravno 2 “mesh” uređaja povezana kablom radi boljeg wifija. Mozda bi najbolja solucija bila 2x ax58u sa merlinom u aimesh preko kabla na 2 kata , i ont plus taj nano kao glavni router sa openwrt i sređenim qos sqm. Slozim sve elegantno da se ne vidi osim sto mi je glavni dovod optike na katu a ne dolje, provucem jedan novi utp u komadu od routera dolje do pc-a i jedan do ax58u kao mesh uredjaju. Ax58u ima dosta dobar domet i ne kosta puno pa bi kao wifi uređaj u meshu bio dovoljan za sve potrebe jer pokriva cijeli kat od cca 100m2 bez problema kad je postavljen u sredini kata. Nece biti pravi kontrolirani mesh ali cu bar imati sve pokriveno bez velikih uloga i zezancije oko izbora routera kojih je sve manje koji podrzavaju openwrt. A i merlin, svaki drugi nema sqm. EDIT: Da updejtam post. Nakon xyz zavrzlama, dok se slozim da sve bude vrhunski bez glavobolja, vratio sam se na Huawei ONT plus frizbox 7490. Slozio malo onaj njegov qos, dodao kablom drugi 7530 u mesh, radi mi sve bolje nego sa asusom i merlinom. Gaming funcionira jako dobro bez obzira na IP adresu koju dobijem, na 89 je najbolje ali nema vise ajmoreci tolikog laga na 141, igra se dobro. Mesh digne ping za 1-2. Sto je zanimljivo, bufferbloat mi je losiji nego sa Asusom i tplink xpon-om ali sve radi bolje. Streaming, mobiteli, iptv, iskontv sve radi odlicno a gaming ne pati. Vjerojatno nije bas sve optimalno ali dok ne sredim nekakav openwrt router za sqm plus dobar mesh sustav, ovo ce raditi ok. Isprobavam vec 2 dana, za sada zadovoljan. Jedino sto mi fali je wan on-off switch na asus-u kad dobije adresu 213 jer mi na 213 jos uvijek ima malo veci lag pa zna zasmetat ali pregrmit cu. Zadnje izmijenjeno od: spawn. 20.05.2025. u 13:05. |
#1307 |
Datum registracije: Jun 2010
Lokacija: hr
Postovi: 887
Vi koji ste imali Max tv grešku X711 na vlastitoj opremi ...jel vam se to događalo na oba prijemnika ili samo na jednom.Imam Asus router RT-Be 88u i TP Link ONT G7.Jedan Max tv prijemnik uredno radi dok na drugom svako malo greška X711 uz prethodno zamrzavanje slike. |
#1308 |
Postovi: 23,626
Pitaj Karla, ako se dobro sjećam, ne prolazi dobro multicast promet, a sad kakve opcije imaš obzirom na tu opremu šta imaš ... |
#1309 |
Postovi: 1,596
Već smo razgovarali. Proban je i G7 i stariji FWovi Asusa ali oped isto. Ili Samsung STB zeza ili Asus router je u banani. Sent from my Pixel 7 Pro using Tapatalk |
#1310 |
Lokacija: hr
Postovi: 887
Zamijenio STB,ali idalje povremeno greška X711.Skužio sam dsa se to događa kada su oba STB-a na istom programu. |
#1311 |
Postovi: 23,626
Ha, u trebe je obrnuto nego obično ![]() Obično bude problem tj. ta greška kada na dva STB - a idu dva različita programa. Sad ću zvučati kao teta sa SZK, jesi li probao sve reboot - at (ugasit router i STB - ove > upalit router > kad router izađe online upalit 1. STB > kad 1. STB proradi upalit 2. STB) ? |
#1313 |
Lokacija: hr
Postovi: 887
Dečki koristim svoju opremu.Toliko me razmazila da mi ISP-ova više ne pada na pamet ![]() |
#1315 |
Lokacija: hr
Postovi: 887
Nije mi jasno što radi problem X711.Router ili ONT ![]() |
#1316 |
Postovi: 8,493
Preporuka routera
Zato smo i pitali da li si probao opremu koju si dobio od isp-a. Najprije probat ont plus router plus stb sve od isp-a. Ako nema greske, zamijeni jedno od toga npr ONT. Ako nema greske zamijenis ROUTER. Ako pocne stekati vrati original ONT i ostavi taj router. Proces eliminacije. Ako nista od toga ne rijesi onda nabavljas drugi ont i drugi router i trazis od isp-aradi problema drugi stb ako ga uspijes dobiti. Ako stvarno zelis saznati sta ti radi problem, moras se zajebavati i biti uporan ili odustanes i koristis ono sto radi. Treceg nema. |
#1317 |
Postovi: 34,079
Danas mi u firmu dolazi tehničar HT-a montirati novi router za optiku (brzina 1Gbps). Ne znam koji će mi uređaj donijeti (vidio sam u ponudi da je spominje nekakav Bussines router), a u rezervi imam HT-ov Speedport Smart 3. Bitan mi je prijenos signala u prostorije prekoputa stubišta zgrade, a Smart 3 ima ugrađen mesh. Trenutno je tamo neki TP-Link koji je prebačen u repeater mode, ali nisam zadovoljan signalom. Koji njegov uređaj da prihvatim ili odbijem jer je bolji/lošiji od Smarta 3?
#1318 |
Lokacija: istra
Postovi: 3,556
šališ se? ISP oprema u bilokakvom business okruženju može isključivo glumiti modem. sve iza toga bi morala biti tvoja vlastita oprema. makar to bio dućan u kojemu filipinka prodaje bižuteriju. uloži 100 eura molim te u vlastitu opremu. |
#1319 |
Postovi: 23,626
Samo nemoj da je na RDK platformi (nema klasični web konfig nego okljaštreno preko web portala) jer nećeš moći sam mijenjati router. Šta nisi napokon razvukao Lan kabel ?? |
#1320 | |
Postovi: 82
Business router - u pravilu AVM FritzFiber 5590, ima SFP ONT u sebi. Nije loš router, ne znam da li im je HT uklonio softverski podršku za mesh, jer Fritz to inače ima dobro riješeno. https://fritzshop.hr/collections/mesh-wifi |
