Staro 11.04.2025., 12:32   #4051
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,835
Autor spiderhr Pregled postova
Toliko sam lijen da ne mislim mijenjati distribuciju. Navikao se na Debian i ima sve kaj mi treba, skoro sve. Toliko lijen da ga znam i na VPS-u koristiti.
Sasvim legitiman razlog Meni je svejedno kaj staviš pred mene al se na Fedori osjećam "doma".
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / Micron M.2 2242 1TB / nVidia Geforce RTX 4050 / Windows 11 Pro
Lenovo Thinkpad L15 Gen 1 || Intel Core i5 10210U / 16GB DDR4 / WD SN730 256GB / Intel UHD / FreeBSD 14.3
Staro 11.04.2025., 16:30   #4052
Postovi: 23,523
Aha, znači FedMan 😁
Staro 11.04.2025., 16:32   #4053
tomek@vz
tomek@vz's Avatar
Postovi: 4,835
Autor Nikky Pregled postova
Aha, znači FedMan 😁
Yep
Staro 11.04.2025., 16:48   #4054
tomek@vz
tomek@vz's Avatar
Postovi: 4,835
With both Ubuntu 25.04 and Fedora 42 releasing this month you may be curious how these two Linux distributions are competing for performance. Well, it's a very tight race for common Intel/AMD x86_64 hardware. In this article are some benchmarks looking at clean installs of Ubuntu 25.04 and Fedora Workstation 42 on AMD Strix Point.
> Phoronix
TLDR: Fedora je bolja za Gaming, Ubuntu za "znanstvene" aplikacije
Ahead of the Linux 6.15-rc2 release on Sunday, there's now a big batch of DRM fixes merged to kernel codebase. On the AMDGPU driver side a notable change this week isn't a "fix" so much as squeezing in a feature. AMDGPU has landed its cgroups implementation around simple managing of discrete video memory (VRAM). In Linux 6.14 the infrastructure was added for device memory "DMEM" cgroup support to allow limiting GPU vRAM and similar uses. Squeezing in post-6.15 merge window is the bit of integration needed for exposing the DMEM cgroups support for the AMDGPU driver with discrete AMD graphics/accelerators.
> Phoronix
Merged today was this week's batch of x86 fixes ahead of the Linux 6.15-rc2 release on Sunday. Notable with these x86 fixes are landing several patches to fix and clean-up the Spectre Return Stack Buffer "RSB" mitigation handling as well as introducing a new document to clarify the overall state and current mitigations.
> Phoronix
Staro 12.04.2025., 06:04   #4055
tomek@vz
tomek@vz's Avatar
Postovi: 4,835
Fedora has proposed a major change for its upcoming version 43 release that aims to achieve 99% package reproducibility, addressing growing concerns about supply-chain security. According to the change proposal announced March 31, Fedora has already reached 90% reproducibility through infrastructure changes including "clamping" file modification times and implementing a Rust-based "add-determinism" tool that standardizes metadata. The remaining 10% will require individual package maintainer involvement, treating reproducibility failures as bugs.
The effort will use a public instance of rebuilderd to independently verify that binary packages can be reproduced from source code. Unlike Debian's bit-by-bit reproducibility definition, Fedora allows differences in package signatures and some metadata while requiring identical payloads. The initiative follows similar efforts by Debian and openSUSE, and comes amid heightened focus on supply-chain security after the recent XZ backdoor incident.
Staro 12.04.2025., 08:11   #4056
tomek@vz
tomek@vz's Avatar
Postovi: 4,835
APT 3.0 is powered by Solver3, a new, more efficient package dependency resolver that significantly improves how package installations and upgrades are handled. As a backtracking algorithm, it allows for more efficient dependency resolution and better handling of complex package conflicts.
> itsfoss
Staro 13.04.2025., 18:26   #4057
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,554
Živijo kapitalizam, korisnik je uvijek u pravu!
The total amount donated to Linux Mint over the past five years (2020–2024) can be estimated based on available data:
  1. 2019–2022: According to donation charts, Linux Mint received approximately $300,000 annually during this period, totaling around $1.2 million for these four years3.
  2. 2023–2024: While specific annual totals for these years are not available, monthly donations ranged from $10,000 to $31,720 in peak months (e.g., December 2022). Assuming an average of $15,000 per month, donations for these two years would approximate $360,000 annually, totaling about $720,000.
  3. 2025 (up to April): Monthly donations have continued steadily, with February 2025 seeing $31,720 raised. Assuming similar monthly averages as prior years, donations for the first four months of 2025 likely exceed $120,000.
Estimated Total
Combining these figures, the total donations to Linux Mint over the past five years are approximately $2 million.
Staro 13.04.2025., 19:22   #4058
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Vinkovci
Postovi: 2,769
Bar Mint redovno svaki mjesec objavi točno koliko je donirano. Treba samo imati volje proći sve objave na blogu.
Neka samo imaju i razvijaju lagano proizvod.
Staro 13.04.2025., 20:06   #4059
tomek@vz
tomek@vz's Avatar
Postovi: 4,835
Autor kopija Pregled postova
Poanta posta?
P.S.- evo radije jedan post za totalne noobove:
5 awesome Linux features that will blow the mind of a Windows user
> xda
Staro 14.04.2025., 07:54   #4060
tomek@vz
tomek@vz's Avatar
Postovi: 4,835
Nekaj iz ropotarnice povijesti...
Revolution OS: History of Linux & Open Source | Documentary (2001)
The Code: Story of Linux documentary
Naravno interesantno je vidjeti kako su neka stajalista na modernim primjenama veliki "no-no" (Hint: Stallman o lozinkama u MIT labu u Revolution OS).
Staro 14.04.2025., 13:15   #4061
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,377
To je bilo u doba telneta, prije Interneta, kad su samo takvi ko Stallman imali pristup nekom terminalu.
Vrlo zanimljiva vremena .
Staro 15.04.2025., 09:18   #4062
medo
#erase startup-config
medo's Avatar
Postovi: 3,699
Stallman i ekipa imaju moj veliki respect za ono što su napravili sa GNU-om i free softwareom općenito. Vidjeli su daleko ispred svih po tom pitanju.
Samo… nekada mi se čini da on živi u nekoj utopiji i da je dosta težak kao osoba. Svijet nije uvijek onakav kakvim si ga oni zamišljaju ili kakav bi oni htjeli da bude.
Staro 15.04.2025., 10:15   #4063
strikoo
strikoo's Avatar
Postovi: 960
https://www.bug.hr/operacijski-susta...da-eu-os-48669
Europska unija pokreće vlastiti operativni sustav otvorenog koda EU OS
Projekt će kao osnovu koristiti Fedora Linux
strikoo je offline   Reply With Quote
Staro 15.04.2025., 10:26   #4064
c-shadow
c-shadow's Avatar
Postovi: 3,477
To bi moglo proći kao LiMux u Munchenu nekad
Staro 15.04.2025., 10:52   #4065
tomek@vz
tomek@vz's Avatar
Postovi: 4,835
Iz prve ruke - nope. Grad trenutno masivno gure Apple uredaje u skolama.
Staro 15.04.2025., 11:20   #4066
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,729
jel možeš pokojeg nabaviti povoljno?
Staro 15.04.2025., 11:52   #4067
tomek@vz
tomek@vz's Avatar
Postovi: 4,835
Mos mislit Ja sam dobio jednog kao "testni" uredaj al ne podnosim iOS jednostavno pa ga koristim iskljucivo kad na skolama nekaj moram testirat jer tvrde da ne radi i da je do Linux servera na lokaciji (nikad pa ni onda).
Staro 15.04.2025., 11:55   #4068
c-shadow
c-shadow's Avatar
Postovi: 3,477
Opet je neka druga stranka došla na vlast pa guraju Apple?
Staro 15.04.2025., 12:31   #4069
tomek@vz
tomek@vz's Avatar
Postovi: 4,835
Ma jok. Uciteljima je fora drzat Ipad u rukama i "prezentirat" sadrzaj preko Apple TV iako imaju i digitalne ploce i sva ostala moderna pomagala. Par "tehnicki potkovanih Apple evangelista" se udruzilo, zalilo se ovima na vlasti kako bi oni to u skolama i - dobili su. S tim da sad mogu dobiti i MAC mini/Macbook uredaje za "po doma" (eto odakle "push"). To sto je sve to totalno nekompatibilno sa svom postojecom infrastrukturom ne zanima nikog. Kao ni cinjenica koje smo sve moguce sigurnosne ustupke morali napraviti radi tih govanaca. Zale se recimo da ih kod prijave u WLAN pita uredaj (managed i unmanaged) dali zeli prihvatiti vazeci Let's Encrypt Certifikat i takve gluposti.
Staro 15.04.2025., 13:54   #4070
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,554
Aj budala, za te nofce su mogli nabaviti kvadrilijun NOA tableta koji izvrsno rade samo nemaju kameru i zna im ekran sam od sebe napuknut.
Staro 15.04.2025., 14:25   #4071
tomek@vz
tomek@vz's Avatar
Postovi: 4,835
Da bar postoje 2in1 rijesenja bazirana na Windows OS-u...oh wait
Staro 15.04.2025., 14:43   #4072
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,554
Naletio na ovu vijest prije par tjedana ali nije mi se činilo vrijedno repostati.
relevantno
strah: najbolji motivator
Staro 16.04.2025., 05:53   #4073
tomek@vz
tomek@vz's Avatar
Postovi: 4,835
The Fedora team has announced the release of Fedora 42. The new version elevates the KDE Plasma spin to "edition" status, alongside the existing GNOME edition, and introduces a new COSMIC desktop spin. "We've promoted our KDE Plasma desktop offering to 'Edition' status. The Fedora KDE team has been hard at work making sure bugs get fixed and everything is polished just so. We're confident that this can stand along our other amazing flagship offerings. I know the naming is a bit confusing, with GNOME-powered 'Workstation' using a generic label while KDE Plasma has the tech right in the name. We'll get that figured out eventually. If you don't know where to start, don't panic. Pick one and see how it goes." Additional information is available in the release announcement and in the release notes. The project also acknowledges a cosmetic bug: "We discovered a problem with the live boot media at the last minute, and since the release was already out of the airlock, we can't do much about it. It doesn't damage anything, but is annoying: just booting the Live media adds an unexpected entry to the UEFI boot loader even when Fedora Linux 42 is not installed to the local system." Download (pkglist): Fedora-Workstation-Live-42-1.1.x86_64.iso (2,287MB, SHA256), Fedora-KDE-Desktop-Live-42-1.1.x86_64.iso (2,712MB, SHA256), Fedora-Server-dvd-x86_64-42-1.1.iso (2,790MB, SHA256).
> Distrowatch
Staro 17.04.2025., 13:38   #4074
tomek@vz
tomek@vz's Avatar
Postovi: 4,835
I’m not entirely sure how to link to this properly, but what we have here is a simple, to-the-point text file describing some of the benefits of Slackware, the oldest still maintained Linux distribution. It’s still run by Patrick Volkerding, and focuses on conservative choices and simplicity over ease. I doubt I have to explain the benefits of Slackware to the average OSNews reader, but this simple little text file does serve as a great marketing tool.
Jos uvijek imam nostalgicna sjecanja na Slackware i Slackbook. Distro na kojem se "zakuhala" moja ljubav prema Linux OS-evima i OpenSource ideji i na kojem sam zbilja zasukao rukave i naucio sto je Linux i kako baratati njime.
Staro 17.04.2025., 14:01   #4075
spiderhr
spiderhr's Avatar
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,047
Jel OpenSuse jedina distra koja je iz EU?
Ima li još koja?
Možda da probam OpenSuse... : razmišlja :
Staro 17.04.2025., 16:17   #4076
Postovi: 8,228
Fino dela Fedora 42, a u međuvremenu je OCCT i službeno postal dostupan za Linux.
Staro 17.04.2025., 16:43   #4077
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,753
Kakvi klošari, hahaha...
https://imgur.com/a/v4l49BE
Programer
Staro 17.04.2025., 16:45   #4078
Postovi: 8,228
Uj, kakve su cijene uopće za ozbiljne firme, traže neke gadne nofce ili je donekle prihvatljivo?
Staro 17.04.2025., 16:46   #4079
Libertus
Libertus's Avatar
Lokacija: Vinkovci
Postovi: 2,769
Ima li još koja?
Jel nije da Mint vodi francuz?
Staro 17.04.2025., 17:09   #4080
strikoo
strikoo's Avatar
Postovi: 960
Clem lives in Ireland. The Linux Mint Limited is also registered there.
