#482 | ||
Postovi: 8,677
Super je kaj se sad sve optimizacije za 9950X3D fino preslikavaju na 7950X3D, jedino je zajeb da Arrow Lake i dalje ispada ni vrit ni mimo, unatoč i usprkos Intel popravcima. ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 11.03.2025. u 19:17. |
#483 |
Datum registracije: Aug 2020
Postovi: 900
Minuta šutnje za ona 2-3 preostala Intelova fana, ili koliko ih je već ostalo na ovom planetu: https://wccftech.com/amd-ryzen-9-995...-package-ever/ |
#485 | |
Postovi: 8,677
UserBenchmark, Frame Chasers i sl. već testiraju novi 18A proces. ![]() ![]() Futura IT ih ima za 830€, kaj čak i nije toliko loše, jer se 7950X3D prodaje za 800€.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX |
#486 | |
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,228
Bez AMD-a ovog pristanka i potpisivanja novog ugovora o licenciranju (broad cross-licensing agreemen) x86 i 64 procesora i patenata ništa od lakog preuzimanja dok je Intel na koljenima ... Citiraj:
TSMC and Broadcom explore deals to split Intel's foundry and chip design wings, says report Trump is 'unlikely' to support TSMC running Intel's fabs — US gov't downplays chances of TSMC takeover
/connect 185.107.96.125:28990 server rcon: oldschool COD2 PCekspert ekipa https://discord.com/invite/zZ4PeqVpBv Zadnje izmijenjeno od: Blue Spirit. 12.03.2025. u 19:49. |
#488 | |
Postovi: 8,677
Evo ga, dok im običan 9950X ide za kakvih 740€. Citiraj:
#490 |
Prvoklasni Krkan
Postovi: 5,488
AMD i/ili nV nema šanse da preuzmu Intel. Jedino ako ovaj narančasti retard promijeni te zakone...a to je najgora opcija za svih osim dvije spomenute korporacije. ![]() |
#491 |
Postovi: 8,677
Evo, svjedočimo tome da TSMC nudi AMD-u i nVidiji da zajedno budu u tome, dok TSMC zapravo vodi sve kak spada, makar ta Intel priča je već toliko žalosna da je sve moguće, a realno ni jedna od tih firmi ne treba izaći u susret Intelu. I sad kad imaju (opet) novog direktora, lako bi se mogle kojekakve kombinacije izvrtjeti. EDIT: Nije dugo trebalo.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 13.03.2025. u 22:33. |
#492 |
Lokacija: Yautja Prime
Postovi: 1,229
Jel ima vlasnika 9800X3D voljni napraviti jedan mali test? Zanima me na koliko vam skoči temperatura procesora tijekom Cinebench R23 multicore testa. Usporedbu radim samo. Kod mene sa 360 AIO dođe na 85 stupnjeva. A vama? ![]() Download link za Cinebench: https://www.guru3d.com/download/down...cinebench-r23/ |
#493 | |
Postovi: 1,712
CPU max 64 CPU packgage max 75 Ventovi gotovo na silent. Ide to i nize. Sjecam se kad sam tek slozio sistem i testirao sa ventovima na full, milsim da je mozda jos i 10st dolje, ali je bucno AIO je ASUS RYUYIN III 360 u push-pull sa LianLi SF120 na cca 800rpm te Kryonaut pastom u NZXT H9 kucistu. ![]() |
#495 |
#erase startup-config
Postovi: 3,733
#496 |
Postovi: 7,738
__________________ |
#497 |
Postovi: 8,677
AMD ovaj put ima više konkurencije, tak da se ne budu doveli u situaciju kakvu su imali prije 20 godina, dok Intel s novim direktorom opet obećava sve i svašta, a ništa konkretno. Sudeći po Zen 6 najavama, AMD ne planira usporiti ni prestati s daljnjim napretkom i inovacijama, dok se društvo u Intelu i dalje tješi da su na korak do povratka na staru slavu.
#498 | |
Dobro je sve.
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,536
https://postimg.cc/jwpzd4rx https://postimg.cc/sG3gcMYP https://postimg.cc/64z51Bck Ocisti radijator ispusi ga ventove kuciste ,pasta nova na proc pa probaj opet to mi se cini malo previse. |
#499 |
Postovi: 1,712
Zadnje izmijenjeno od: jucca. 17.03.2025. u 23:20. |
#500 |
Postovi: 1,229
Zanimljivo. Jer frendu se popne i do 90, no on ima 240 aio. A brzinskom pretragom na netu vidim da i drugima bude oko 85, pa i 90+. Ne mogu probit u čemu je caka. Komp je čist ko suza, sve friško očišćeno iako nije ni bio nešto prašnjav. Nova termalna pasta. Case je 011 popunjen sa 120 ventovima. 6 intake dole i bočno plus 3 na vrhu na aio koji tjeraju van zrak kroz hladnjak. Jeste vi čačkali šta u biosu? Meni je sve default što se CPU tiče. Edit: evo par linkova od ovog što sam pretražio https://forums.guru3d.com/threads/no...800x3d.455386/ https://www.overclock.net/threads/98...temps.1814346/ https://linustechtips.com/topic/1596...ith-360mm-aio/ Ovaj na LTT namjestio PBO pa mu je palo na 71-72. Da nemate i vi tak u biosu pa zato imate tako male temp? Da stvar bude bolja vidim da vam je i score bolji za 1-2k bodova. Miriše mi na uV nekakav? ![]() Nakon sto godina sam opet u crvenom taboru. Podijelite info ako ima nešto što ne znam. ![]() Zadnje izmijenjeno od: PR3DA70R. 17.03.2025. u 23:57. |
#501 |
Dobro je sve.
Lokacija: 00001
Postovi: 2,536
Da Undervolt mo sad je -30 https://youtu.be/2oD4ISZYjbA?si=HM-zQ2oOhyL4Gzqo Probaj nista te ne kosta osim 10 min vrimena Poslano sa mog SM-S918B koristeći Tapatalk |
#503 |
Postovi: 1,229
Okej mislim da sam otkrio throttle onda. Zato sam vas tražio ako možete testirati. Meni daje 20k bodova i temp je 86-87 stupnjeva stock. Iako još nisam probao uV. Budem kad dođem doma. Bit će da je problem aio star skoro 5 godina. Otvorio sam RMA pa ćemo vidjet šta kažu. |
#505 |
Postovi: 8,677
Lako moguće da ovo u pitanju, pa novi BIOS ili flashback popravlja situaciju. ![]()
#506 | |
Postovi: 1,229
Evo rezultata samo sa curve optimizerom. -30 -20 ![]() Razlika je mizerija. Nisam zadovoljan... Čitam u komentarima na videu likovima pala temp nakon -20/30 za cirka 20 stupnjeva. Nešto tu ne štima, a glavna sumnja je AIO. Čekam da mi se javi support za RMA ticket koji sam otvorio. |
#507 |
Postovi: 8,677
U BIOS-u imaš sve opcije da CPU ograničiš na Tjmax 75°C, 105W TDP i 142W PPT, a po potrebi pomoću Curve Optimizera dodatno kasnije samo fino podesiš.
#508 | |
Postovi: 1,229
Još k tome temperatura prostora trenutno 15C. AIO ne hladi kako spada očigledno. ![]() Evo i stock: ![]() Frekvencija na stock padne na 5.0GHz time naravno i rezultat R23 lošiji, znači da throttla. |
#509 | |
Dobro je sve.
Lokacija: 00001
Postovi: 2,536
Thermalright AM5 Secure Frame na procu sad dali on stvara nekakvu temperaturnu razliku cisto sumnjam više je za ono da pasta ne upada .Aio je očito po meni nema šta, isparila voda ,pumpa dali se čuje? Ako kvrcka znači fali vode ..mislim može da je sam proc čorak ali ovi 9800x3d su baš binani posebno da svaki bude pobjeda silikon lutrije Poslano sa mog SM-S918B koristeći Tapatalk |
#510 | |
Postovi: 8,677
I kasnije opet možeš ograničiti CPU da ne ide temperaturom nebu pod oblake, a zadržiš sve performanse.
