#31 |
Postovi: 8,661
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX |
#32 |
#erase startup-config
Postovi: 3,733
AMD Radeon RX 9000 series (Navi RDNA4)
Današnja kučišta (mislim, akvariji) su sve samo ne jeftina ![]() |
#33 |
Postovi: 8,661
Ne takva, više ovi standardni modeli ko npr. moj Fractal Define 7 Compact i tome slični klasnični izbor s kojim si kasnije miran cijelo desetljeće. ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 05.03.2025. u 13:16. |
#34 |
Prvoklasni Krkan
Postovi: 5,480
Ja volim mesh iliti mrežasto, zrak FTW, vodu sam imao prvi i zadnji put na Athlonu X (Barton). Neki sklepanac koji je netko ručno proizdovio doma i prodavao. Pumpa je bila do akvarija i utopljena u doslovno tupperwareu, blok je bio onako solidan komad čistog bakra, a radijator je bio navodno od stojadina od grijača kabine... Imam slike negdje doma tog čudovišta. ![]() |
#35 |
Postovi: 8,661
I takvih modela imaš koliko te volja, samo odaberi neki koji ti cijenom najbolje paše i miran si onda jedno dulje vrijeme.
#36 | |
Lokacija: Međimurje
Postovi: 175
GIGABYTE GAMING OC PowerColor Reaper (bez bracketa) ASRock Steel Legend 9070 XT cheat sheet |
#37 |
Xulos :)
Postovi: 7,581
#38 |
Datum registracije: Aug 2020
Postovi: 900
Kad izlaze recenzije? |
#40 |
Postovi: 8,661
#41 |
Prvoklasni Krkan
Postovi: 5,480
Vidim nabrzinu da je to doslovno po svemu XTX sa manje VRAMa. I potrošnja i performanse su na razini statističke pogreške... RT bolji 15% od XTX, što je super, samo me ne zanima. :P Samo i jedino cijena... Izgleda da je i FSR napokon kako rabi. ![]() EDIT: A 9070 je za dlaku brža i manje troši od nepostojeće 5070 (i više VRAM, dakle doslovno SVE bolje). Bome su ih dobro stukli, još da nekim čudom isprave cijenu i ovo bi bila bomba. Ali i za 550 je bomba prema 5070, samo bi ih doslovno satrali da stave nižu cijenu i da je i u stvarnosti cijena kako treba. I napokon očito stvarni napredak za razliku od zelenih. Zadnje izmijenjeno od: Disco. 05.03.2025. u 16:22. |
#42 |
Postovi: 8,661
Mislim da se australski Steve negdje poprilično sjebal u brojkama, jer ni jedan test mu nije ni sličan ostalim recenzijama koje su otprilike iste. ![]() Primjera radi, Alan Wake 2@1440p + RT se u Australiji vrti na kakvih 30 FPS-a, a svi ostali za iste uvjete imaju skoro duplo više sličica u sekundi. Također, potrošnja svih kartica mu je dobrih 100W veća u usporedbi s ostatkom pisanih i YouTube recenzija.
#43 |
Prvoklasni Krkan
Postovi: 5,480
Mislim da on stavlja ukupnu potrošnju sistema, a ostali samo GPU. Ali znali su oni imati neke nebuloze da, ispravit će vj. Nebitno, grafe su bomba, sada je samo i jedino bitna cijena. A za sam udio je 9060 dio još bitniji. 300$ za 12Gb i nešto u rangu obične 4070 bi bio apsolutni hit. |
#44 |
Postovi: 8,661
Da, kak god se okrene, HUB Steve ima skroz čudne brojke, a onda je na temelju toga složil zaključak, dok svi ostali imaju poprilično pozitivne dojmove. EDIT:Australci su koristili stare 24.12.1 drivere, dok svi ostali imaju RDNA 4 24.30.31.03 Press Driver, a za GPU potrošnju piše da mjeri PCI-E + EPS od kartice.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 05.03.2025. u 17:02. |
#45 |
All-rounder
Datum registracije: Sep 2013
Postovi: 1,342
Mislio sam da je dobio lošije rezultate jer downclocka kartice na stock, a drugi out of the box, pa nitro+ donese još 5% razlike. Ali drugi driveri sigurno doprinose razlici. Iako, to je grafička koja je trebala biti vani prije mjesec dana... Nudi mi se 7900 XTX za 750e, pa se nešto nećkam, omilili mi se ovi novi upscaleri i RT, a cijena tu negdje... Baš čekam cijene da vidim. |
#46 |
Postovi: 8,661
#48 | |||||||||||||||||||||||||||||||||||||||||||||||||
Datum registracije: Mar 2021
Postovi: 72
Powercolor Reaper koju i osobno ciljam ti je dugačka 289. Evo ti liste modela i dimenzije:
#49 | |
Postovi: 72
To su jači modeli. Gaming OC i 3x8. Ovi referentni će biti jeftiniji. Računaj 568 € bi XT bila u EU + naš porez, to ti je gore 140€. Do 750 bi trebali biti ovi jeftini modeli. Ovi OC i premium kao što si spomenuo, e to će koštati. |
#50 |
Lokacija: rijeka
Postovi: 3,903
da ne zaboravim pitat s obzirom da je nvidia sa serijom 5 pa na dalje izbacila podršku za 32 bitne igre,pa je neko spojio rtx 5090 i rtx 3050 da bi mogo igrat starije naslove,amd to nije napravio/za sad nije?? https://videocardz.com/newz/nvidia-e...in-older-games https://hothardware.com/news/rtx-5090-plus-3050-physx |
#51 | |
Postovi: 5,997
4070 super su isto bile 600$ pa ih nije bilo ispod 800 eura kod nas. 7800xt 500$ pa u startu ih nije bilo ispod 650 eura kod nas.. Hellhound se cini ok sa 2x 8pin i uobicajno odlicnim hladnjakom. Mozda i piknem ovih dana, neda mi se jos i novo napajanje kupovat zbog trceg 8pin konektora.. |
#52 | |
Prvoklasni Krkan
Postovi: 5,480
nV je izbbacila podrsku za 32bitni physx i cuda, to radeon nema i nije ni imao. 32 bitne igre uredno rade. |
#53 | |
Postovi: 747
da su izbacili 9700xtx to bi bila druga prica |
#55 |
Lokacija: Zagreb, Črnomerec
Postovi: 2,713
Da se zove 9700 Pro, odmah bi kupio ![]() Sviđa mi se ovaj 9070XT, AMD je u principu ispunio što je obećao. FSR4 je veliki korak naprijed, ray tracing je jači, i grafa je tu negdje između 4070ti-s i 5070ti. Ako budu tražili cca 650-700 eura, to će bit ok, pogotovo s obzirom na to da je konkurencija trenutno nepostojeća. Po meni je trebala bit veća razlika u cijeni između 9070 i 9070XT al ok, valjda AMD zna što radi ![]() |
#57 |
Prvoklasni Krkan
Postovi: 5,480
Sada vidim da je tih 289 bez ''bracket'', a sa je 304mm. Što je točno bracket? Ono što ju drži da se ne savija? Na svom webu nemaju nikakve slike toga ni objašnjenje... Frajer je napravio kompilaciju rivjua 9070XT, rezlutati su posvuda, blago rečeno. Zadnje izmijenjeno od: Disco. 06.03.2025. u 08:54. |
#59 |
Prvoklasni Krkan
Postovi: 5,480
36cm...i najjači porno glumci bi joj pozavidjeli! ![]() Pa hmm....not my cup of tea, ali cijena prema nVu čabe, prema 7900XT i en baš dobra cijena, ali...ovo je vj najjači model 9070XT, treba vidjeti ove malo običnije. pretpostavljam da neće biti modela ispod 700€. |
#60 |
prof.dr. gospodar svemira
Postovi: 432
Svi pricaju o FSR4, ali resirenost implementacije je glavna stvar. Kada sam ja kupovao 7800XT (10 mj. 2023) FSR3 je mislim taman bio launchan i to je trebao biti veliki AMD odgovor na DLSS. Na stranu razlike u kvaliteti i to, ali od svih igara koje sam isprobao i igrao jedino sam ga vidio u Cyberpunku i to je to. Sve ostalo i dalje FSR2.0 ili ga uopce nema. S druge strane sve igre koje sam isprobao imaju DLSS 3.X (ili nemaju uopce nikakav upscaler), jedino mislim da je RDR2 na DLSS 2.x, ali nisam siguran. Tako da ako ne bude siroke implementacije FSR4 i to ne u kojekakvim bezveznim igrama, djaba su oni krecili.
If you are not paranoid you don't have enough information |
