#3931 |
Postovi: 10,254
Iskreno, ne sjecam se vise do koje mjere je radilo na Vivaldiju. Znam da nije radilo out of the box i da sam nesto cackao oko toga. Edit: moram se ispraviti, FF je radio out of the box, a Vivaldi samo ako ga pokrenem kroz terminal. Ovdje smo pricali o tome: http://forum.pcekspert.com/showthread.php?p=3747545
#3932 |
#erase startup-config
Postovi: 3,732
Radi i sa 6.11 kernelom. Nisam stigao testirati ffmpeg/ffplay ali budući da on koristi vaapi koji vidi dekodere onda ne bi trebalo biti problema. Ali Firefox... I ja sam duugo čekao hw akceleraciju na Tiger Lakeu i jedva dočekao. Ali bar je radila h264 akceleracija. Ovdje ne radi ništa. Samo software dekodiranje za sve codece a HEVC uopće ne dekodira ni softwareski. Firefox Code:
Codec Name Software Decoding Hardware Decoding H264 Supported Unsupported VP9 Supported Unsupported VP8 Supported Unsupported AV1 Supported Unsupported HEVC Unsupported Unsupported Theora Supported Unsupported AAC Supported Unsupported MP3 Supported Unsupported Opus Supported Unsupported Vorbis Supported Unsupported FLAC Supported Unsupported Wave Supported Unsupported Code:
Trying display: wayland
vainfo: VA-API version: 1.22 (libva 2.22.0)
vainfo: Driver version: Mesa Gallium driver 24.2.8-1ubuntu1~24.10.1 for AMD Radeon Graphics (radeonsi, raphael_mendocino, LLVM 19.1.1, DRM 3.59, 6.11.0-18-generic)
vainfo: Supported profile and entrypoints
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointEncSlice
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileHEVCMain10 : VAEntrypointEncSlice
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile2 : VAEntrypointVLD
VAProfileAV1Profile0 : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
Code:
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Root Complex 00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge IOMMU 00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge 00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge GPP Bridge 00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge 00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge GPP Bridge 00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge 00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge 00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge 00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Internal GPP Bridge to Bus [C:A] 00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Internal GPP Bridge to Bus [C:A] 00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 71) 00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51) 00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 0 00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 1 00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 2 00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 3 00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 4 00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 5 00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 6 00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 7 01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller S4LV008[Pascal] 02:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Upstream Port (rev 01) 03:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01) 03:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01) 03:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01) 03:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01) 03:0b.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01) 03:0c.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01) 03:0d.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01) 07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 05) 09:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset USB 3.2 Controller (rev 01) 0a:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset SATA Controller (rev 01) 0b:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Granite Ridge [Radeon Graphics] (rev c6) 0b:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Rembrandt Radeon High Definition Audio Controller 0b:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 19h PSP/CCP 0b:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge USB 3.1 xHCI 0b:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge USB 3.1 xHCI 0b:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h/1ah HD Audio Controller 0c:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15b8 |
#3933 |
Postovi: 1,019
#3934 | |
Postovi: 3,515
Kad već spominješ tigerlake, nije još uvijek bajna situacija, FF podržava u hw samo H264, VP9 i AV1. Očito su u FF podržali minimalan broj codeca da bi radio YT. Ne vidim zašto bi netko trebao hevc u browseru... Spomenuti YT meni servira isključivo VP9 i AV1, nekako na random. Jesi probao forsirati FF akcel. za AMDa? Arch ima dobre i ažurne upute: https://wiki.archlinux.org/title/Fir...o_acceleration Znam da je tlaka, ali prije nativne podrške u FF radilo je neko vrijeme na intelu isključivo s tim postavljenim parametrima, bilo je bitno samo da ffmpeg radi. Osjetilo se na laptopima lijepo po cpu zauzeću dok gledaš yt video ![]() |
#3935 |
Postovi: 3,732
Tako je i meni bilo. FF je ponekad zbog toga bio malo nestabilan ali je radilo ![]() Nisu svi videi kodirani u AV1 na YT |
#3936 |
White Rabbit
Postovi: 5,295
#3937 | ||
White Rabbit
Postovi: 5,295
#3938 |
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,138
Jel pipewire mora biti instaliran za pulseaudio ili ga se može deinstalirati?
tomek@vz: ajd nemoj | Mali Čile SAD Češka Peru | Windows Free |
#3939 | |
White Rabbit
Postovi: 5,295
Pipewire zamjenjuje pulseaudio. Ali to ne znaci da mozes sve pulseaudio pakete maknut. Zavisi od distre do distre, eto situacije na Fedori 41: Code:
$ rpm -qa |grep 'pulseaudio\|pipewire' |sort pipewire-1.2.7-1.fc41.i686 pipewire-1.2.7-1.fc41.x86_64 pipewire-alsa-1.2.7-1.fc41.i686 pipewire-alsa-1.2.7-1.fc41.x86_64 pipewire-gstreamer-1.2.7-1.fc41.x86_64 pipewire-libs-1.2.7-1.fc41.i686 pipewire-libs-1.2.7-1.fc41.x86_64 pipewire-plugin-libcamera-1.2.7-1.fc41.x86_64 pipewire-pulseaudio-1.2.7-1.fc41.x86_64 pipewire-utils-1.2.7-1.fc41.x86_64 pulseaudio-libs-17.0-2.fc41.i686 pulseaudio-libs-17.0-2.fc41.x86_64 pulseaudio-libs-glib2-17.0-2.fc41.x86_64 pulseaudio-utils-17.0-2.fc41.x86_64 qemu-audio-pipewire-9.1.2-3.fc41.x86_64 vlc-plugin-pipewire-3-4.fc41.x86_64 vlc-plugin-pulseaudio-3.0.21-15.fc41.x86_64 |
#3940 |
Postovi: 3,732
Linux OS - info, how-to, pitanja, novosti, savjeti, problemi...
Nešto testiram danas, maknem tracker-miner-fs na Ubuntu 24.10 i skužim da mi je maknuo xwayland, gnome-session i svašta nešto… Fora. Ako neš’ imati indexera neš’ imat X-e ![]() Btw: danas sam uspoređivao Ryzen 8700G sa 9600X. vainfo kaže da 8700G može enkodirati AV1 dok 9600X ne može. Oba ga mogu dekodirati. Niti jednom niti drugom ne radi akceleracija u Firefoxu. Koliko vidim to je zato jer Firefox nema podršku za vulkan i kako stvari stoje pitanje je da li će ikada imati. ffmpeg i mpv uredno koriste hw akceleraciju za video. ffplay radi preko vulkana a kad forsiram vaapi kaže da ne postoji veza između vulkana i vaapi-ja. Budući da Firefox zna koristiti (samo) vaapi… it’s Intel or bust ![]() |
#3941 |
Postovi: 8,526
Ryzen 7 8700G ima 780M RDNA 3 iGPU i to je već dosta konkretnije rješenje u usporedbi s osnovnim RDNA 2 iGPU-om koji je u Ryzen 9000 modelima.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#3942 |
Postovi: 3,732
S druge strane 9600X sa svojih 6 jezgri radi skoro jednako brzo kao i 8700G sa 8 jezgri. Imao sam nekoliko APUa. Njihova grafika mi je… meh. Za igre preslaba a za uredski posao nepotrebna. BTW: ugasio sam boost na 8700G. Temperatura u loadu je pala za 20 stupnjeva (sa 95 na 75) a pad performansi u 7-Zipu nije bio bi 10%. Wraith ga hladi. |
#3943 |
Postovi: 8,526
Da, 8700G je mobilni Zen 4, dok je 9600X baziran na boljoj Zen 5 arhitekturi.
#3944 |
Postovi: 3,732
Nakon malo guglanja prisjetih se da Firefox još uvijek podržava ffmpeg iako je to po defaultu disejblano about:config Code:
media.ffmpeg.vaapi.enabled = true Jubito 4k@60fps dekodira pri zauzeću GPU media dekodera 13-15% (amdgpu_top) što odgovara benchmarku u ffmpegu koji preko vulkana dekodira ~7.5x CPU usage je 2-4% |
#3947 |
Postovi: 3,732
VP9 i AV1 kako koji video. Pušta AV1 ali ako je AV1 u 10bit HDRu onda mi pusti 8bit VP9. |
#3948 |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,108
Bogdaj, nekolko pitanja: - Kak u Fedori 41 (GNOME) složiti per app scaling? AnyDesk na 125% scalingu izgleda jako mali i teško je vidjeti ikaj i klikati po sučelju - nekad kad alt-tabbam ne pojave se svi programi, tj treba oko 10ak sekundi da se pojavi program iako je upaljen i vidljiv na ekranu. Bug ili feature? - preporuka za RDP program koji radi, probal sam Connections i Thincast Remote ali oba se smrznu sekundu-dvije nakon logiranja na remote komp Inače zgodan OS, usporedil sam GNOME i KDE i na kraju mi je GNOME puuuuuuno bolje legel. Izgleda milijun puta bolje i taman je dovoljno jednostavan a praktičan za korištenje od strane average luzer ko npr. ja ![]() I jaaaaaaaaaaako mi je drago da su složili fractional scaling u Waylandu, ubijalo me to kad sam imal eskapade prošle godine s pokušajima da se prebacim na Linux
#3951 |
Lokacija: Bistra
Postovi: 5,108
Hmmmmm, not impressed: ![]() + ima neki čudan bug s keyboard layoutom, kao da su tipke pomaknute za 5-6 stupaca prema levo... niš, budem malo pogledal opcije, možda je user error... iak sumnjam
#3952 |
White Rabbit
Postovi: 5,295
Kak si instaliral Remminu? Iz sluzbenog RPM repoa ili Flatpak? Postaj debug Log kad se skrsi. Koristim ju na dnevnoj bazi i nisam imal tih problema koje opisujes. Kaj se tipkovnice tice provjeri postavke u Settings > RDP. P.S. > ak ti se Gnome svida cekiraj i ovo https://extensions.gnome.org/#sort=downloads |
#3953 |
Postovi: 3,515
Firefox 136 Code:
Hardware video decoding is now enabled for AMD GPUs on Linux. |
#3958 |
Postovi: 3,732
Remminu koristim poslovno. Nije kao Microsoftov RDP ali radi. |
#3959 |
Postovi: 83
koji linux da stavim na laptop....dosta mi je win 11
Bok majstori od linuxa Kaj ima ekipo ? Vidim da win 11 sve više seruckaju i meni ih je jednostavno navrh glave te ih se želim riješiti. Čitam da win 11 ver.24H2 znao fino smrdati HP računala i ne samo njih i nemam namjeru napraviti nadogradnju. Volio bi izabrati distru linuxa koja će najbolje raditi na mom laptopu HP 650 G5. Evo i slika gdje se vidi kakav je procesor , RAM i ostalo , pa da mi lakše pomognete u izboru. Procesor i RAM https://postimg.cc/sMQxVCNC Tip sistema https://postimg.cc/MnQ6CbnW Eto toliko od mene , pa vi sada navalite sa prijedlozima. |
