Staro 21.07.2024., 12:50   #1951
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,141
Autor Mario92 Pregled postova
Meni je na mojem Superlightu počel krepavati lijevi klik pa sam onda odlemil i lijevi i desni i umesto njih zalemil Kailh GM 8.0 switcheve.
Evo godinu i pol dana, ko urica + klik je bolji, onak reskiji, ne znam kak da objasnim
Evo danas mi je krepal scroll pa sam moral lemiti skrol senzor da prodela.
Superlight je jeben miš, najbolji kaj sam ikad koristil, ali jebeš Logitech kontrolu kvalitete kad sam moral mijenjati switcheve i evo sad, skrol popravljati. Nožice sam u međuvremenu isto promijenil, uzel Superglide of Pulsara:
https://pulsargg.eu/collections/supe...48940262097225
Preskup je miš da ga bacim u smeće, ova abominacija bude gurala dokle god ne potrošim plastiku na tipkama
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 31.07.2024., 14:36   #1952
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,619
Logitech CEO Hanneke Faber talked about someting called the “forever mouse”, which would be, as the name implies, a mouse that customers could use for a very long time. While you may think this would mean an incredibly well-built mouse, or one that can be easily repaired, which Logitech already makes somewhat possible through a partnership with iFixIt, another option the company is thinking about is a subscription model. Yes.
Faber said subscription software updates would mean that people wouldn’t need to worry about their mouse. The business model is similar to what Logitech already does with video conferencing services (Logitech’s B2B business includes Logitech Select, a subscription service offering things like apps, 24/7 support, and advanced RMA).
Having to pay a regular fee for full use of a peripheral could deter customers, though. HP is trying a similar idea with rentable printers that require a monthly fee. The printers differ from the idea of the forever mouse in that the HP hardware belongs to HP, not the user. However, concerns around tracking and the addition of ongoing expenses are similar.
↫ Scharon Harding at Ars Technica
Hardwer na pretplatu...di ces bolje
/sarcasm off
Staro 02.08.2024., 15:48   #1953
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,489
Ovakve pizdarije mogu proći samo u firmama koje ionako većinom unajmljuju printere i tko zna što sve još, ali za po doma nekako sumnjam. Spominje se HP, a mislim da je GN Stevo spomenuo da se oko te debilne ideje digla odmah velika buka i da bi mogli odustati.
Imam neki filing da su za sve ove divote poluproizvoda na koje treba plaćati pretplatu nekako krivi smartphonei i njihove P2W igre i općenito appovi sa IAPom.
Slobodno me dodajte na PSN
Staro 04.09.2024., 00:17   #1954
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
Dali netko ima za prodati mozda switcheve za G502 Hero. Krenio na lijevom kliku "double click"
-Omron D2F-F-3-7
-Kailh GM 4.0 Red 60M Micro Switch
Preferiram ovo gore navedeno, ali ako ima netko nesto solidno da nisu obicni kinezi javite se slobodno.
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline   Reply With Quote
Staro 21.09.2024., 17:11   #1955
Old.machine
Old.machine's Avatar
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,461
Old.machine je online   Reply With Quote
Staro 23.09.2024., 10:43   #1956
sinke.ZG
sinke.ZG's Avatar
Postovi: 734
Ljudovi jel postoji neka alternativa za roccat kova miš, odličan mi je zbog puno tipki a počeo je dvoklikat
sinke.ZG je offline   Reply With Quote
Staro 25.09.2024., 11:56   #1957
blackshtef
blackshtef's Avatar
Postovi: 157
Ne znam jel nekome bitno - čini se da je neka akcija na Logitech miševe u nekolicini popularnih trgovina - G502 X Lightspeed je sa redovnih 150-ak na akciji za 100 eura, solidan popust.
blackshtef je offline   Reply With Quote
Staro 25.09.2024., 16:29   #1958
IHrvojeI
¯\_(ツ)_/¯
IHrvojeI's Avatar
Datum registracije: Sep 2016
Lokacija: Pag
Postovi: 1,257
Autor blackshtef Pregled postova
Da, kako je moj stari G602 otišao u dvoklik vode, malo sam guglao i vidim i ja akciju na neki pro black kurac palac reko ok, kupim a kad ono oni stavili besplatno i neki mouse pad - nije da mi treba, ali ok. E, ja sam direktno od logitecha kupovao.
Name:	Bez naslova.png‎
Staro 25.09.2024., 22:49   #1959
blackshtef
blackshtef's Avatar
Postovi: 157
Da da, ispada da je baš od Logitecha krenula akcija čini se, evo baš za G502 X Lightspeed - https://www.logitechg.com/en-eu/prod...10-006180.html
A vidio sam i da imaju neke combo pakete s tom podlogom, čak mislim da i možda wired varijanta G502 dolazi s time.
Staro 01.10.2024., 15:57   #1960
Ninja_Zg
Ninja_Zg's Avatar
Datum registracije: Aug 2013
Postovi: 273
Ima gdje u Zg izlozen Razer Basilisk V3 Pro da se moze probati?
Ninja_Zg je offline   Reply With Quote
Staro 01.10.2024., 18:48   #1961
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Hvala na ovome, cekam neku akciju vec mjesecima
Autor IHrvojeI Pregled postova
I ja sam sad probao naruciti od njih, odabrao zemlju, upisao sve podatke tocno, zakacio da zelim one mailove da mi salju i kad kliknem na "save and continue" za iduci korak, valjda shipping method, izbaci ovo "Error
Something's not right. Review your information below to check out. If you're still having trouble, contact us."
EDIT: Uspio, iz FF-a nije islo, iz Chroma proslo iz prve.
Zadnje izmijenjeno od: Veki-os. 01.10.2024. u 19:07.
Staro 07.10.2024., 18:02   #1962
Veki-os
Veki-os's Avatar
Postovi: 3,996
Izgleda da imam problem, stigao paket a unutra samo podloga za miša i račun za nju, 0 eura jer je poklon. Od misa ni traga, vi koji ste naručili jel stiglo u 1 kutiji sve ili u 2, možda dostavljač zaboravio dati drugu kutiju?
Navečer cu pisati Logitechu pa da vidim i sto oni kažu.
Sent from my SM-A528B using Tapatalk
Staro 07.10.2024., 20:15   #1963
blackshtef
blackshtef's Avatar
Postovi: 157
Ja sam kupio u Instaru, tak da ne mogu pomoći
Možda možeš njih pitati/nazvati pa da ti kažu čisto kak je upakirano - u jednoj ili dvije kutije. Vidio sam na polici to tamo, ali da me ubiješ - ne sjećam se jel bio neki pack ili odvojeno
Edit: nisam kupio taj komplet, nego G502x Lightspeed
Zadnje izmijenjeno od: blackshtef. 07.10.2024. u 22:05. Razlog: pojašnjenje
Staro 08.10.2024., 13:47   #1964
Veki-os
Veki-os's Avatar
Postovi: 3,996
Stigao mis danas, poslali su kao dva odvojena paketa, pitao na live chatu sinoc i zenska mi dala tracking broj za kutiju od misa dok sam ja imao samo broj koji su mi oni dali kod narudjbe i koji je bio za podlogu.
@blackshtef i ja sam taj uzeo ali je na njihovoj stranici bila i akcija za besplatnu podlogu.
Staro 08.10.2024., 21:27   #1965
blackshtef
blackshtef's Avatar
Postovi: 157
Eh, onda sam popušio podlogu, al ajde
Staro 20.02.2025., 22:09   #1966
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,717
Zna li netko gdje naći Logitech G400S, odnosno MX518 (legendary)? Nažalost ih više nema, izgleda da se nisu dovoljno dobro prodavali a ja budala nisam uzeo kad ih je bilo.
Staro 21.02.2025., 09:15   #1967
Postovi: 17,143
Autor Exy Pregled postova
Ebay ili njuškalo, ovako ga nećeš naći novoga u trgovinama. Čak ni Amazon ga nema.
Staro 21.02.2025., 11:13   #1968
axo
Datum registracije: Sep 2017
Postovi: 1,442
Ja ga još uvijek imam negdje u ormaru, kupio ga prije 10god sigurno. Služi kao relikvij
Staro 26.02.2025., 07:49   #1969
pdx
pdx's Avatar
Datum registracije: Dec 2009
Lokacija: krk
Postovi: 515
sto bas nitko od vas ne kupuje vaxee ili zowie miseve koji su miljama ispred logitech builda samo brickove neke uzimate :P
Pulsar je no go zbog optickih switceva.
pdx je offline   Reply With Quote
Staro 26.02.2025., 11:59   #1970
Postovi: 17,143
Zowie je miljama ispred Logitecha tako dugo do kad radi. A ne radi.
Imao sam 2, jedini miševi u mom životu koji su se pokvarili. Oba Zowie.
Logitech, ako nisam imao 20 komada, nisam ništa, sve kupio i prodao ovdje ili na njuški. Bez ijedne greške.
Nisam competitive gamer, niti igram CS.
Zowie u moju kuću više neće.
Staro 26.02.2025., 14:40   #1971
pdx
pdx's Avatar
Lokacija: krk
Postovi: 515
To je bas zanimljivo, kako koga potrefi ocito, od 2010 dok su jos zuti logo imali sam prvog kupio, 4 misa imam i dan danas rade sad si gledam uzeti vaxee e1.
Staro 01.03.2025., 13:13   #1972
keyser_s()ze
Postovi: 590
Brišem
Zadnje izmijenjeno od: keyser_s()ze. 01.03.2025. u 19:06.
keyser_s()ze je offline   Reply With Quote
Staro 04.04.2025., 21:29   #1973
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,860
Imam Logitech G502 Hero, mislim da je sada 4 ili 5 godina. Srednja tipka mu prestaje reagirati na klik. Od 5 puta, možda 2 puta uhvati klik. Ima li rješenje kako to popraviti, ili moram kupiti novi miš zbog toga?
Staro 07.04.2025., 10:27   #1974
Postovi: 17,143
Autor Libertus Pregled postova
Ispod plastike je običan switch.
Otvoriti miš, kupiti taj switch s aliexpressa i zamjeniti.
https://www.youtube.com/watch?v=pzt_n1qZnPk
https://www.aliexpress.com/w/wholesale-g502-switch.html
Staro 07.04.2025., 10:37   #1975
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,860
Zahvaljujem. Koliko sam shvatio nije taj switch koji prvi ispadne,nego neki manji. Naručio pa ćemo vidjeti kada dođe.
Staro 07.04.2025., 10:43   #1976
Postovi: 17,143
Nemam pojma točno, uvijek kad Logitech šteka, do tog switcha je.
Staro 07.04.2025., 12:41   #1977
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,860
https://www.aliexpress.com/item/1005006200418140.html
To sam naručio. Ispod kotačića se negdje nalazi, ne znam više da li sam vidio to na tom videu koji si linkao ili drugom. Po njima, to je za middle klik switch.
https://www.aliexpress.com/item/1005005751706746.html
Ovo je ako sam dobro shvatio za left/right klik.
Staro 07.04.2025., 14:07   #1978
Dottore
Dottore's Avatar
Postovi: 7,739
To je česti problem kod prejakog stiskanja ili udaranja. Zamjeniš i vozi dalje.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 29.04.2025., 23:21   #1979
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,860
Zamijenio, srednja tipka ponovno radi.
Staro 27.07.2025., 22:45   #1980
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,903
