#334 | |
Postovi: 8,655
Na kraju bude ovisilo o modelu pojedinog proizvođača, ali općenito su kartice u rangu s onim kaj smo i dosad imali na tržištu. ![]() Citiraj:
I sad bude slična situacija, odnosno RX 9070 modeli imaju preporučena napajanja (za cijelu konfiguraciju) koja uvelike nadilaze njihove realne potrošnje.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 16.02.2025. u 16:53. |
#335 |
¯\_(ツ)_/¯
Lokacija: Sibenik
Postovi: 1,156
#336 | ||
Postovi: 8,655
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX |
#337 | |
prof.dr. gospodar svemira
Postovi: 432
³Recommended power supply for AMD Radeon RX 7800 XT graphics card is minimum 800W or greater power supply with 12V output > 62A. Minimum recommended system power supply wattage is based on a PC configured with an AMD Ryzen 9 7950X processor plus typical power requirements of other system components. Your system requirements may differ. Ja sam ju bez problema drzao na EVGA SuperNova G2 650W dugo vremena. Doduse, uparenu sa 12400F koji i nije neki potrosac, ali ipak na 650W dobrom napajanju isla bez beda.
If you are not paranoid you don't have enough information |
#338 |
Datum registracije: Mar 2009
Postovi: 474
#339 |
Prvoklasni Krkan
Postovi: 5,475
Radeon RX 9070 XT At Work On Linux: 3.24 GHz Clock at 330 Watts ![]() A ove cijene iznad su odlične, ODLIČNE, baš u AMD stilu. ![]() Još malo pa će vidimo "prave" cijene. Zadnje izmijenjeno od: Disco. 25.02.2025. u 11:43. |
#340 | |
Lokacija: Zagreb, Črnomerec
Postovi: 2,710
Ma te fore sa napajanjem su da se zaštite od likova sa sumnjivim kutijicama teškim 100 grama nazivne snage 1200W ![]() Meni je 7800XT bio na 550W napajanju i mogao sam još štošta spojit na to, par žarulja ![]() Dobre su ovo cijene za 9070XT, možda je samo placeholder a možda je FSR4 bolji od DLSS-a 4 ![]() |
#341 | ||
Postovi: 8,655
Cijene smo već komentirali, kaj u ovoj, kaj u RTX 5000 temi, tak jasno da one cifre nemaju veze s vezom, a krajem ovog i sredinom sljedećeg tjedna bude sve jasno. ![]() EDIT:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 25.02.2025. u 16:23. |
#342 |
mag.math.
Datum registracije: Dec 2021
Lokacija: Daruvar/Zagreb, Republika Hrvatska
Postovi: 366
Prema zadnjim informacijama, cijene su 649 američkih dolara za Radeon RX 9070XT model i 499 američkih dolara za RX 9070 model. No to neće imati puno veze ako se iste nađu kod trgovina koje će odrediti cijene koje oni misle da bi bile prikladne. nVidia GeForce 5070Ti grafičke kartice imaju 750 američkih dolara preporučenu cijenu ali vidimo cijene koje su skoro 100 posto veće ali ne kod naprimjer Amazon-a nego trgovaca koji imaju jedan ili malo više komada dostupno za isporuku odmah. Ukoliko AMD Radeon bude isporučio veće količine i to većim trgovinama poput Amazon-a ili po Europi MediaMarkt-a cijene ne bi trebale biti u rango ovih od 1200 i više eura već vrlo blizu preporučene cijene. Američki dolar i euro su ionako sada skoro pa 1:1. |
#343 |
Prvoklasni Krkan
Postovi: 5,475
Eto, AMD marketing nije razočarao. ![]() Lupaju oni po svom i boli ih briga, mogu samo zaključiti da su očito općenito zadovoljni prodajom. A naravno za koji mj slijedi neslužbeno spuštanje cijene. |
#344 |
Postovi: 5,997
500$ za rx 9070 je odlicna cijena. 16gb, pref ko 7900xt, RT bolji od bilo kojeg Radeona do sad i uz malo srece ogroman OC potencijal. Mene 9070 vise interesira nego XT, nista nije pretjerano srezano i sve ima ko XT. Ak nekom to nebu dosta uskoro bu rtx 5070 izasla ![]() |
#345 |
¯\_(ツ)_/¯
Lokacija: Sibenik
Postovi: 1,156
#347 |
Postovi: 8,655
Ne bude, taman da je 50€ MSRP ne valja, jer nije nVidia GeForce, koja s duplo većom cijenom, imaginarnom raspoloživosti i bonusom samozapaljivanja daje bolji omjer uloženog i dobivenog. ![]()
#348 |
smeghead
Postovi: 3,193
ja bi recimo dao 1k max za najbolje modele kao nitro+/red devil, ako su u rangu 4080s, posto su najbolji modeli 5080/5070ti/4080 iznad 1300e ovaj slabiji me ne interesira, radije bi uzeo 7800xt koji nudi najbolji omjer fps/euro atm |
#349 |
¯\_(ツ)_/¯
Lokacija: Sibenik
Postovi: 1,156
#350 | |
Postovi: 5,997
7900xt je kostala preko 1000 eura kod nas kad je dosla u ducane. Sadasnje cijene su normalne za 3 godina staru grafu na zalasku i to je uvijek izbor. |
#351 |
Prvoklasni Krkan
Postovi: 5,475
Nema šanse da košta kao 7800XT. Namjerno talijanska nabava jer uredno imaju bolje cijene od švaba. Dakle 500-550€. Dok je 7900XT u prosjeku 800€. Ima ona jedna Pulsica za 710 što mi se čini kao OK deal. 4070 Ti SUPER po cca 1100€. (Za razliku kupiš pošten CPU) 5070Ti kreće od 1100€, ali je zapravo velika većina veselih 1500€. Kad se sve uzme u obzir...AMD je fakat čabe. ![]() ....Ali su zato 5090 po 4kile € tj po 6 kila €. Dobije se azbestna dekica i aparat za gašenje uz svaku! Zadnje izmijenjeno od: Disco. 26.02.2025. u 13:24. |
#352 | ||
Postovi: 8,655
#353 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,736
Kaže mi Grok da je 4nm TSMC proces na 90-100% utilizacije. Ako budu iole dobre ne samo da budu skupe neg ih nebu bilo u dućanima uopće. |
#354 |
Postovi: 8,655
Zen 5 je također na TSMC 4nm, pa ih ima i cijene nisu pretjerane. TSMC 3nm je sad tražena roba u gradu. ![]() EDIT: ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 27.02.2025. u 08:55. |
#355 |
Prvoklasni Krkan
Postovi: 5,475
Ljepo je to Stevica US sažeo, ono što uporno svi ponavljamo. Spustite usranu cijenu jer to vam je jedini izlaz. Pokazao je kako nV diktira sve, od fićra do cijene i ljudi će uvijek radije nV ako je to sve tu negdje. I ne sramotite se više sa kao nekim podjebavanjem nV-a na socijalnim mrežama jer svaki put napravite to isto, od količine VRAMa do svega drugo na što ste se zajebavali. A Jakna i njegovi fino šute, još se Jakna uredno zajebava na svoj račun u prezentacijama i ubiru enormne količine novaca na svim poljima. Nisam znao da je AMD ovako gadno izgubio udio na tržištu...od 40+% do 10% u zadnjih 15 godina. Treba to znat. Spomenuo je i to da se očito interno AMD šefovima jebe za Radeon dio i da je ekipa iz Radeona frustrirana jer bi htjeli uspjet, ali im se zapravo stalno bacaju klipovi u kotače ili koji bi već prikladan izraz bio. ![]() Ugl, ajd još jedan dan, ali ja sam siguran da će zasrat cijenu, em će staviti previsok MSRP, em on neće imati veze sa stvarnošću, kao ni oni od Intela i nV. |
#356 |
Postovi: 8,655
I kaj se tiče sramoćenja i Radeon šefova lijepo je ko i uvijek u svom stilu stavil hrpu materijala vezanog za gospodina Franka Azora koji je glavni akter u neuspješnom podjebavanju.
#358 |
Datum registracije: Aug 2020
Postovi: 900
Neka kažu lijepo da ih zaboli ona stvar za Radeon diviziju i doviđenja, ovako nam neizravno to poručuju, i nemaju nikakve koristi od toga, market share im sve više i više pada itd. |
#360 | |
Prvoklasni Krkan
Postovi: 5,475
Zapravo da se napravi G X3D CPU, mislim da bi to tek bio hit, ali opet po nekoj OK cijeni jer bi i integruša profitirala i to samo tako od tog cachea, zapravo umjesto da taj dodatni cahe služi za CPU, on bi trebao biti onaj infinity cache za GPU i tu bi razvalio siguran sam. Taman bi se pogurao spori sistemski DDR... A neka pusta glupa maštanja... ![]() ![]() |
