Staro 20.10.2022., 23:21   #331
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,539
kako da lokam fps u drajveru? mogu jedino sa afterburnerom...
Staro 20.10.2022., 23:29   #332
Postovi: 8,715
Ovak je kod mene.
Za GeForce ide ...
nVidia Control Panel. Click on the "Manage 3D settings" menu item under the 3D Settings heading, and then scroll down through the "Global Settings" panel until you see the "Max Frame Rate" option.
Once there, turn it on and then decide on a limit. Usually, it's best to go with one that's equivalent to your monitor's refresh rate. So, for example, if you have a 144Hz monitor, set a 144 FPS max.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750
Staro 21.10.2022., 00:32   #333
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,539
ok sutra cu probat
(nije nv odavna bila u mene pa neznam cake)
da rješeno kroz driver fps 74/vsync on
nema laga više
zavaljujem na pomoći
Zadnje izmijenjeno od: Tajl3r. 25.10.2022. u 01:39.
Staro 03.02.2023., 09:02   #334
grizli1
Datum registracije: Aug 2008
Lokacija: Daruvar
Postovi: 254
Discord u pozadini smanjuje brzinu memorije nVidia grafičkama, objavili su tutorial kako popraviti dok ne objave sami fix pa evo link
https://nvidia.custhelp.com/app/answ...ail/a_id/5443/
grizli1 je offline   Reply With Quote
Staro 22.08.2023., 18:12   #335
Sauron
Datum registracije: Dec 2022
Lokacija: Mordor
Postovi: 78
Sauron je offline   Reply With Quote
Staro 03.11.2024., 17:56   #336
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,151
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 04.11.2024., 09:54   #337
Dottore
Dottore's Avatar
Postovi: 7,743
Autor Mario92 Pregled postova
Koji driver izlazi?
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 27.02.2025., 19:05   #338
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,636
danas odem instalirat nove drajvere i usred instalacije komp ode u black screen i moro sam hard reboot, pa ddu, pa nanovo fresh install
ovo mi se prije nije dešavalo, vidim na redditu da nisam jedini
Staro 27.02.2025., 19:13   #339
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,504
FUN FACT: Ovi današnji driveri su ti koji riješavaju BS i BSOD na Blackwellu.
Jakna FTW!
Slobodno me dodajte na PSN
Staro 27.02.2025., 20:18   #340
Dottore
Dottore's Avatar
Postovi: 7,743
Koji driver u pitanju?
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 27.02.2025., 21:15   #341
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,906
zadnji 572.60,čito na videocardzu što je mamutarka brzao,serija 3 nije ni spomenuta,tako da su trojkaški vratili drivere iz decembra.
Staro 01.03.2025., 23:44   #342
Postovi: 8,715
nVidia addresses DisplayPort black screen issues with new driver hotfix
Earlier this week, nVidia launched a new GPU driver that fixed three known problems causing black screens, it seems that not all of them. nVidia has identified another black screen bug, this time related to the DisplayPort connection. If your GeForce card experienced black screens, especially right after installing the latest display drivers, then this hotfix might be a solution for you. It focuses on this specific issue after drivers were installed and PCs were rebooted, only to show a black screen. Apparently, this has something to do with the DisplayPort connection.
If you’re not experiencing such problems, or you’re not using DisplayPort for a monitor, then there’s most likely no reason to install this hotfix, which is based on the latest 572.60 Game Ready release. The hotfix only addresses this single problem, and judging from the comments on the nVidia Subreddit, this issue was quite common. nVidia has had several problems with the drivers recently, mostly related to the launch of the RTX 50 series and multiple drivers that were released alongside each launch. Some users say that the quality of nVidia drivers has dropped, and they were not experiencing such issues before.
Izvor: VideoCardz
Staro 12.03.2025., 14:18   #343
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,577
decki sta stavit braticu na 3060tku kad stigne? sta je latest OK?
zadnje vidim 572.60 i 572.70, al vidim i probleme neke prijavljuju.
Staro 12.03.2025., 14:23   #344
Postovi: 8,715
Verzije 572.47, 572.42 i 572.16 su bili zadnji vredu driveri, prije ovih Blackwell hotfix bedastoća kojima izgleda nema kraja.
Staro 12.03.2025., 14:30   #345
Dr. Strange
Datum registracije: Aug 2020
Postovi: 901
Mislio sam da Nvidia ima odlične drivere, a kad ono svaki tjedan po dva updatea koja popravljaju raznorazne probleme. S 2000 serijom sam dosta dugo imao raznoraznih sitnih problema, stalna rušenja drivera i nakratko crni ekran. Event Viewer mi je stalno javljao da se nvk... nešto srušilo. I onda sad s novom serijom imaju i hardverske defekte. Sve se poklopilo.
Staro 12.03.2025., 14:46   #346
geronimo_2
geronimo_2's Avatar
Postovi: 4,577
fala decki.
bum probal sa 572.47.
Staro 12.03.2025., 15:53   #347
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,504
Ma mislim da su problemi sa driverima samo na BL, ali da, ja npr skoro pa nikad nemam najnovije. Naučio sam da u 80% slučajeva izbace hotfix nakon tj dana. Guru3d forum je i dalje naj za pregled ima li ili nema problema sa driverima
Staro 12.03.2025., 15:59   #348
Postovi: 8,715
Da, Blackwell ima hardverskih problema koje nVidia pokušava riješiti softverski, pa su nažalost s tim hotfix driverima koje temelje na game ready/WHQL izdanju, uspjeli zahvatiti i korisnike koji nemaju/nisu imali nikakvih problema. Makar kak god se okrene, sve moguće varijacije na temu problema s driverima bilo GeForce, bilo Radeon tematike su kamilica u usporedbi s onim kaj je Intel izvel za ARC kartice.
Staro 12.03.2025., 16:23   #349
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,636
Autor Disco Pregled postova
nop, ada lovelace prilikom instalacije prošlih drajvera samo otišlo u black screen i moro hard restart, pa DDU itd., nisam jedini tada bio, na redditu hrpa ljudi isto, opetovana instalacija prošla normalno
Staro 12.03.2025., 16:32   #350
Postovi: 8,715
To je proizašlo iz Blackwell situacije, pa sad ljudi sa starijim karticama ni krivi ni dužni, prolaze iste kalvarije zbog drivera koji "popravljaju" RTX 5000.
Staro 26.02.2026., 21:51   #351
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,636
današnji drajveri šitstorm
https://www.reddit.com/r/nvidia/comm...faqdiscussion/
February 26th, 11am PT Update: We have discovered a bug in the Game Ready and Studio 595.59 WHQL drivers and have removed the downloads temporarily while our team investigates. For users that have already installed this driver, and are experiencing issues with fan control, please roll back to 591.86 WHQL.
Staro 26.02.2026., 21:59   #352
Postovi: 8,715
Vibe coding efekt i obzirom da su unutar dva-tri sata od puštanja, brže-bolje povukli nove drivere, internog testiranja valjda nije ni bilo, jer AI zna kaj radi..
Following the driver update releases, gamers started to complain about "black screen and freezing" issues with nVidia's RTX 50 series GPUs. There were instability issues across multiple gaming titles, and according to users on the forum, they couldn't find a solution to these troubles. GPU overheating, crashing, and black screens are among the more prevalent issues with the latest v595.59 driver update, and there are tens of complaints from gamers, if not more, about how the release is buggy and not suitable for distribution. Other users reported issues with the GPU fan control utility, saying their fans weren't working at all or that customized configurations weren't effective. Gamers are reporting locked voltages, performance losses, and several other issues, indicating that the driver release isn't just a matter of a 'single bug'; it involves a much deeper problem.
Staro 26.02.2026., 22:12   #353
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,723
Izgleda da jensen & co. toliko sranja o tom AI-u pričaju da su počeli i sami vjerovat u te pričice. Slop coding ftw
Staro 03.03.2026., 18:30   #354
Postovi: 8,715
Zadnje izmijenjeno od: The Exiled. 03.03.2026. u 18:49.
Staro 03.03.2026., 20:27   #355
Dr. Strange
Postovi: 901
Pomalo je ironično da AI-first kompanija poput Nvidije, koja reklamira AI na svakom koraku i čiji CEO govori da developeri neće biti potrebni u budućnosti pa je bolje da prestanemo učiti programirati, na svojoj koži najbolje osjeti što znači kada se puno oslanjaš na AI u pisanju drivera. Točno se moglo primijetiti kada su dobar dio zadataka prepustili AI-ju i kada su im driveri postali predmet sprdnje na internetu, kao nekad AMD-ovi. Volio bih da Jensena kada opet bude držao govor na pozornici, netko pita za situaciju s driverima i A.I-em.
Staro 03.03.2026., 20:56   #356
Postovi: 8,715
Iskreno, tip bi se pravil Englez, odmah bi odmahnul rukom da on to nikada nije rekel, te da mu se ne stavljaju riječi u usta, pošto je dosad u već nekoliko navrata točno takve eskapade izvodil čim su mu novinari rekli da njegove vlastite riječi ne drže vodu. I odmah ovaj baca kontru i u zaobilaznom načinu izmišlja toplu vodu, mada jako dobro zna da je točno takve pizdarije rekel u kameru kad god mu se pružila prilika, do te mjere da je sad non-stop u eteru s kojekakvim AI prognozama.
Makar s jedne strane ga živo boli briga za nekakve gaming kartice i njihove drivere, dokle god CUDA i prateći AI hardver zgrću milijarde, jer taman da sutra sve to ode nizbrdo, on je svoje pošteno naplatil i konkretan hardver isporučil, a to kaj od većine implementacija ne bude ništa - lagano ga zaboli, pare su na računu. I dosta je da se kasnije izda DLSS 5.75, pa da svi mogući mediji kroz 200% zoom i 300% slowdown pokažu kako je razlika između tri piksela itekako primjetna, to je to, kakvi 12VHPWR požari i sfušani eJaJ driveri. I to prolazi svaki put bez greške.
