#6061 | |
Postovi: 8,638
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX |
#6062 |
All-rounder
Datum registracije: Sep 2013
Postovi: 1,342
Hm, ali ne slaže mi se ta priča, jer Intel je odbacio AVX prije nego što je AMD bio i blizu toga da bude konkurentan. Moja poanta, a ispravi me ako sam krivo skužio timeline, jest da je Intel gurao AVX i odbacio ga u Alderu (2021) kad je vidio da ga nitko relevantan ne koristi na desktopu barem. A AMD da se upecao i pojačao njegovu implementaciju u Zen 4 (2022) i naročito u ZEN 5 (2024). Čime su se upecali na Intelovu navlakušu i sad imaju 20% ili nešto manje čipa koji se nigdje ne koristi. AVX 2021. kad ga je Intel odbacio je bio još 256-bitni u Zen 3. Kužim tvoju poantu, ali mislim da nitko nije šljivio AVX ni onda ni sad, zato nije nikog bilo briga kad ga je Intel odbacio, i zato mi nije jasno zašto je to prednost AMD-a, rekao bih da je nedostatak ako su vrijeme i prostor na čipu trošili na to. https://www.anandtech.com/show/16881...rchitectures/5 "Intel isn’t even supporting AVX-512 with a dual-issue AVX2 mode over multiple operations - it simply won’t work on Alder Lake. If AMD’s Zen 4 processors plan to support some form of AVX-512 as has been theorized, even as dual-issue AVX2 operations, we might be in some dystopian processor environment where AMD is the only consumer processor on the market to support AVX-512." |
#6063 | |
Postovi: 8,638
Intel i AMD su dulji niz godina imali AVX, nije to ništa novo, nije ih Intel dobil na foru, ali AMD to i dalje može imati bez ikakvog udara na performanse, zagrijavanje i potrošnju diljem svih svojih proizvoda, kad koriste jedan pristup za sve kroz mobilno, desktop i server tržište. Intel je postepeno dolazil do toga da izbace AVX iz mainstream modela, jer su zapeli u vremenu i prostoru s monolitnim jezgrama i svojim proizvodnim procesima, a ovo čudo AVX tehnike im dodatno drobi ionak zdrobljene procesore, tak da su odlučili da to "nije bitno", a bilo je godinama u svim mogućim PR materijalima. Velim, svi to koristimo bez da znamo, jer hrpa običnih svakodnevnih aplikacija podržava AVX instrukcije, a serverski procesori s obje strane nude itekakve mogućnosti, ali Intel je sam sebe stjeral u kut, dok je AMD na kraju i za Zen 4c i sada novi Zen 5c samo malo presložil LEGO kockice, zadržal SMT i AVX-512, tak da sad jedan 192-core EYPC košta i troši manje, dok parira najnovijim dual-Xeon mašinama. Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 11.10.2024. u 12:44. |
#6064 | |
Postovi: 375
Čestitke Intelu na "at-least-it's-not-broken lake"-u, u što ubrajam i konačno stavljanje pod kontrolu potrošnje. Čak i kad ona ne bi dovodila do samouništenja Intelovih CPUa, za mene je to poluproizvod koji je nasviran iznad granica mogućnosti u grčevitom pokušaju da konkuriraš, a ne možeš. S time da ovo sada nije nešto "wow", nego konačno dovođenje u normalu. Sve ostalo, . I to još na boljem node-u od AMD-a. Da AMD nije AMD, mogli su ih sa Zen5 doslovno uništiti, u dugoročnijem smislu. I ovako to mogu cijenom i X3D modelima i sa još opcija koje imaju. |
#6065 | |
Datum registracije: Feb 2021
Lokacija: Sveti Petar
Postovi: 313
Zašto je to tako? Možda više nema puno prostora za inovaciju što se tiče x86. Za razliku od ARMa x86 je jako kompliciran i ima puno više instrukcija. Evo gledam ove leakove Snapdragon 8 gen 4 +45% single core performance a Dimensity 9400 +30%. Intel i AMD se mogu sramiti na što su spali sad više. |
#6066 |
Postovi: 8,638
Ne znam da li si vidjel jučerašnje 192-core Zen 5c EPYC vs. 192-core ARM recenzije, pa je ispalo da je x86 itekako ispred po svemu, tak da ne treba odmah prekrižiti sve skupa. Osim toga, Arrow Lake i Zen 5 nisu tolika stagnacija, samo kaj Intel lovi AMD i ovo im je sad konkretni potez, dok AMD u Zen 5 ima kompletnu novu arhitekturu, samo jebiga, igre nemaju koristi od AVX-512, pa stoga nisu bile Zen 5: 55% uplift recenzije, već Zen 5: 5% sidegrade. ![]()
#6067 | |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
#6068 |
Postovi: 8,638
Intel je dobar dio proteklog desetljeća reklamiral AVX-512 podršku i to je prolazilo relativno nezapaženo, jer em većina ne mari, em nisu imali nikakvu konkurenciju, ali čim se to dolaskom Zena okrenulo naglavačke, AVX-512 im više nije bitan. Na stranu čak i serverske namjene, ali taj set instrukcija se fino udomaćil u svakodnenim primjenama, tak da npr. Blender, OpenSSL, x264 (H.264), x265 (HEVC) enkodiranje, AV1 enkodiranje i dekodiranje, PCSX2 i RPCS3 emulatori i mnoštvo običnog softvera uspješno iskorištava AVX-512 implementaciju ukoliko CPU podržava taj set instrukcija.
#6069 | ||
Postovi: 8,638
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 16.10.2024. u 11:01. |
#6070 |
All-rounder
Postovi: 1,342
Tu se svakako vidi neučinkovitost AMD pristupa (po prvi put), kad za desktop printaju 2 milijarde dodatnih tranzistora na svakom chipletu bez ikakve koristi za veliku većinu korisnika, što nepotrebno diže cijenu proizvodnje. I ponavljam, kad je Intel prije par godina prestao koristiti AVX512 na desktopu, nitko se nije uzbudio, jer mu nitko nije ni pronašao namjenu tamo. Slično očekujem od Radeona, koji će sad putem Vege i Radeona VII kroz ujedinjenu arhitekturu, puno tranzistora i zagrijavanja, malo performansi (osim specifične publike). Zaključak je da smo mi desktop bagra zadnja rupa na svirali jer je to financijski najmanje tržište, čak i mobilci dobivaju svoje posebne modele, a desktop ne. |
#6071 |
Postovi: 8,638
Kaj nije upravo suprotno ispalo, jer sad Intel brže-bolje ide u suradnju s AMD-om koji je svoje AVX implementacije sprovel u djelo kak spada, bez dodatne potrošnje i zagrijavanja, a radi chiplet pristupa, nemaju neki preveliki trošak, kad im je to ista podloga. Mobilna izdanja imaju Zen 4 AVX verzije koje koliko se vidi, također nisu za odbaciti, makar većina ljudi ne zna kaj bi s tim, dokle god se ne odrade dodatne optimizacije popularnih softverskih paketa. Možda sam u krivu, ali IMHO ova Intel + AMD suradnja prije svega Intelu otvara mogućnosti da dodatno iskoristi dijelove koje sami nisu mogli, a AMD je ipak dobro posložil.
#6072 |
All-rounder
Postovi: 1,342
Pa u tome je stvar, Intel to forsira cijelo desetljeće i softverska podrška nije došla, ne znam zašto bi sad bila prekretnica, naročito kad je Intel odustao od AVX-a na desktopu već 3 generacije, a još uvijek čini većinu install baze. Da je AVX tako bitan, zar ne bi Zen 4 i 5 ubijali Intel u poslovnim aplikacijama, a čini mi se da to baš ne vidimo? A zajednički razvoj x86 je pozitivna stvar, iako više brak iz nužnosti. |
#6073 |
Postovi: 8,638
Intel je to neuspješno forsiral, jer su procesori momentalno postali neupotrebljivi zbog potrošnje i zagrijavanja, kad se pokrenul ikakav AVX-512 materijal, zato im nije uspjelo i zato su na kraju lagano odustali, a onda je šrot AMD složil kak spada i sad je i Intelu u interesu da imaju uvid kroz ovu suradnju. Rekel sam već u nekoliko navrata diljem posljednjih postova, AVX se itekak koristi, AMD sa Zen 4 i Zen 5 itekak ima prednost nad Intelom u tim namjenama, zato im i EPYC sad drži 35% serverskog tržišta, a bili su ispod nule prije par godina. Kaj se desktopa tiče, velim jedan običan emulator je u stanju iskoristiti prednosti AVX implementacije, tak da ne bude dugo trebalo da i ostatak softvera skoči na taj vlak, isto kak su skočili na AVX2 i AVX-256.
#6074 | |
Datum registracije: Aug 2020
Postovi: 900
#6075 |
Postovi: 8,638
Nažalost, pitanje Intelovog općenitog opstanka se i dalje povlači diljem Interneta, mada je to do nedavno bilo u Sci-Fi rangu. I u slučaju da vrlo vjerojatno ne ispadne ništa od potencijalne kupnje/prodaje, sama činjenica da se o tome sad naveliko javno priča i nagađa, dodatno pokazuje u kakvoj nezahvalnoj situaciji su se našli ponajprije zahvaljujući voCtvu koje se pretvaralo da konkurencija ne postoji.
#6076 |
All-rounder
Postovi: 1,342
Samo bi dodao da je TSMC jeftiniji od Intelovih in-house procesa Tako da čak i uz profit TSMC-a taj potez zapravo pomaže kompaniji. Meni se čini neizbježnim da se dizajn i proizvodnja razdvoje. Imaju možda još jednu priliku da pokažu da mogu sve sami, a ako ne uspiju kao i zadnjih X puta, onda ide cijepanje kompanije. |
#6077 |
Postovi: 8,638
IMHO nema tu računice za Intel, jer samo za Arrow i Lunar Lake naručuju od TSMC-a 3nm, 5nm i 6nm kapacitete, plus GPU divizija uz AI rješenja, tj. to im svakak masno plaćaju, makar ih možda košta manje, nego Intel nativni procesi, dok je TSMC 3nm trenutno najbolji i najskuplji. Intel k tome istovremeno kod sebe vrti ASML High-NA EUV mašine, ali nitko od vanjskih partnera ne grize, kad u Intelu ni sami nisu na čisto s otkazanih 20A, dok se kunu u 18A, 16A, 14A, i tak dalje. Kaj se razdvajanja tiče, da ih država ne spašava, već bi se to sprovelo po uzoru na AMD, ali ovak ih mogu držati na životu unedogled, jer su im od strateške važnosti.
#6078 |
Postovi: 8,638
#6079 | |
#erase startup-config
Postovi: 3,733
Vijesti i novosti o Intel procesorima i čipsetima
Podbačaj me još uvijek služi ![]() Drago mi je da je bio podbačaj jer sam bolje prošao u dućanu, hehe. Onda su još RAMovi potonuli pa sam uzeo 4x8GB DDR3 za siću tamo negdje u ljeto 2016. ![]() |
#6080 | |
MadModerator
Lokacija: N/A
Postovi: 5,195
#6082 |
Postovi: 8,638
Mogli su ko Intel, taj dio kroz BIOS kompletno isključiti ili prilikom proizvodnje namjerno "laserski odrezati" za desktop izdanja i krajnji proizvod opet ne bi bil ništa jeftiniji. Samo bi po uzoru na Intel slušali od strane kritike i publike zbog čega toga više nema, a bilo je u prijašanjim generacijama, makar kak veliš, "nitko to nije koristil", ali kad je nestalo, tražilo se. Kak god se okrene nije dobro. ![]()
#6083 | |
Postovi: 313
#6084 | ||
Postovi: 8,638
Valjda bude nekaj iz toga, jer ovi slajdovi im se temelje na MLPerf i Geekbench testiranju, a zapravo je riječ o istom čipu koji su plasirali za Microsoft ARM laptope. Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 22.10.2024. u 09:15. |
#6085 | |
Prvoklasni Krkan
Postovi: 5,465
Da nisu pustili AVX 512, ne bi imali nikakav napredak u odnosu na zen4, i tek onda bi bili u banani. Siguran sam da bi nam svi oni podvalili ili uskratili sve što mogu dodatno naplatiti. A ne bi me čudilo da u budućnosti dobijemo HW DLC ala BMW i grijana sjedala i slične kapitalističke nebuloze. @binary: I dalje su navodno sporiji od Apple u SC-u, u MC su brži, a za grafu ne znam, tu je Apple uvijek bio osjetno bolji od svih ostalih. |
#6086 | |
Postovi: 8,638
#6087 | ||||
Postovi: 8,638
#6088 |
Xulos :)
Postovi: 7,581
Neznam jel bilo ali : https://www.tweaktown.com/news/10141...ina/index.html
#6089 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,733
Zašto su im dali tolki popust, mislio sam da su im svi kapaciteti popunjeni zbog AI ludila? |
#6090 |
Postovi: 8,638
To je bilo dogovoreno još za vrijeme prijašnjeg direktora (1 - 2), jer se već onda znalo da TSMC proizvodi svašta za Intel, kad su ovi nakupovali razne firme koje su već bile kod TSMC-a uz tak jasno u ono vrijeme friške Intelove potrebe za TSMC pogonima, jer "Intel sve proizvodi sam na domaćem tlu". U TSMC-u su se držali dogovora i onda novi bajni direktor preuzme štafetu i iz dana u dan sere kvake kroz kojekakve izjave za javnost, bilo za AMD, bilo za nVidiju, bilo za ARM, bilo za TSMC, nema koga i čega se nije dotaknul, jer Intel je najbolji, konkurencija ne postoji i tome slično. Komentirali (1 - 2 - 3) smo sve to diljem ove teme kak se odvijalo tokom godina, a pošto danas imaju svoje kvartalno izvješće, vrlo vjerojatno najgore u povijesti firme, pa moguće da čak i objave kako aktualni direktor radi "osobnih razloga" odlazi iz firme. ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 31.10.2024. u 14:08. |
