Staro 12.10.2024., 19:15   #1
Postovi: 8,464
Intel "Arrow Lake" LGA-1851 Info Thread
With Arrow Lake, Intel aims to bring many of the technological innovations it debuted with the Core Ultra 1-series Meteor Lake on the mobile platform, including on-chip AI acceleration, a completely new set of CPU cores, generational power and thermal improvements, and new platform I/O. The Core Ultra 2-series Arrow Lake-S also debuts a new desktop platform, and a new socket—LGA1851, so you'll need a new motherboard. Intel is also debuting the new 800-series desktop chipset.
Intel's goal with Arrow Lake isn't just to introduce new technology across the board—the CPU cores, NPU, and I/O, but also address the weakest aspect of the preceding processor generations by Intel going all the way back to the 10th Gen Core Comet Lake—power draw. Since its switch to TSMC and 7 nm with the Ryzen 3000 Zen 2, AMD has consistently stayed ahead of Intel in energy efficiency, as Intel had to drag on 14 nm for two more generations (Comet Lake and Rocket Lake), and by the time its 10 nm process (later rebranded Intel 7) arrived, AMD had already developed the efficient Zen 3 on 7 nm, and was preparing to transition to 5 nm and Zen 4. Ryzen is now on 4 nm with Zen 5. Intel held onto its own Intel 4 node (7 nm) with the compute tile of Meteor Lake, but decided on TSMC for Ultra 2-series. Arrow Lake is the first high-performance client Intel architecture to use TSMC for the CPU cores, with its Compute tile being built on TSMC 3 nm—a more advanced node than the 4 nm that Zen 5 uses.
Intel is sticking with its power ratings system it started with the 12th Gen Core "Alder Lake." All five processor models come with 125 W processor base power. The 285K, 265K, and 265KF come with 250 W maximum turbo power. The 245K and 245KF, on the other hand, have their maximum turbo power value reduced to 159 W. This is interesting, as this value used to be 181 W for its Core i5 predecessors, such as the i5-14600K and i5-13600K. As for pricing, the Core Ultra 9 285K is positioned on the top, with a suggested price of USD $589. This is followed by the Core Ultra 7 265K at $394. The 265KF can be had for $379. The Core Ultra 5 245K goes for $309, followed by the 245KF at $294. These are the exact same price points Intel launched the previous generation i9-14900K, i7-14700K/KF, and the i5-14600K/KF at, respectively. All processors being announced today go on sale from October 23, 2024.
Izvor: TechPowerUp
Staro 14.10.2024., 14:40   #2
Postovi: 8,464
MSI claims unlocked Core Ultra 9 285K will require less power and offer lower temps than i9-14900K - sudeći po ovim MSI prezentacijama, proizvođači matičnih ploča budu i dalje radili kaj god ih volja, dok Intel opet i za Arrow Lake ima popriličnu slagalicu strave, kad su u pitanju "defaultne" postavke. Tim više, jer Intelovi službeni materijali navode 58% nižu potrošnju u odnosu na Raptor Lake, a onda se skuži da su do te brojke došli na način da kroz Arrow Lake NPU chiplet puste AI test, tako da CPU miruje bez da zna kaj se u pozadini događa, dok se 14900K hoće zapaliti, jer male i velike jezgre nemaju dedicirani AI NPU off-load chiplet koji im može poslužiti.
The first and arguably most important tile is the Compute tile. This is built on the 3 nm TSMC N3B process. This contains the CPU cores. The next most important tile is the SoC tile. This takes up a mostly-central region of the chip, and is built on the 6 nm TSMC N6 node. The SoC tile integrates an NPU 3 unit, which appears to have been carried over from "Meteor Lake." This is based on Intel's 3rd Gen NPU architecture, compared to the 4th Gen NPU on "Lunar Lake." NPU 3 has a peak throughput of 13 AI TOPS, which means it falls short of the 40 TOPS requirement for Microsoft Copilot+ local acceleration. The unit contains two NCEs (neural compute engines), with two INT8/FP16 MAC arrays, four SHAVE DSPs, and a 4 MB scratchpad RAM.
Zadnje izmijenjeno od: The Exiled. 14.10.2024. u 14:47.
Staro 14.10.2024., 19:56   #3
markecSMB
Lokacija: Cro
Postovi: 1,034
Mislim da generaliziranje procesora nema smisla.
AMD je prvi korak napravio s tim ekstra cache. Ne možeš imat procesor da zadovolji i jedne i druge, odnosno možeš al je kompromis.
Ja gledam svoju perspektivu, koji koristi isključivo za igre i simulacije.
Meni odgovara 8 jezgri, bez HT s velikim cache, po mogućnosti integrirani memoriski kontroler i 4 kanala RAM. Bez problema bi za to platio 1000€ za 50% više performansi od tog što nude. I nije to tehnički neizvedivo i prodavalo bi se (dokaz je AMD).
AMD pristup je loš, procesor koji im je baza i za servere i za klijente, ljepljenje čipleta povezanih super sporom sabirnicom.
Intelov je još i gori, te male jezgre.
Kak već oboje lijepe kockice, nek nam daju na izbor.
Ja ne želim male jezgre, ni jednu, al oću extra $. Nekom možda odgovara imat 64 male jezgrice jer vrti 1000 web servera i slično. Prije il kasnije će doć do toga da možeš birat kaj želiš da ti zalijepe.
AMD je vidio prvi da se to x3D dobro prodaje, procesor uglavnom za igre, i generalno sam zadovoljan.
Staro 14.10.2024., 20:14   #4
Postovi: 8,464
AMD-ov pristup koji sad nakon skoro osam godina Intel kopira je točno ono kojim smjerom se trebalo krenuti, a vidimo iz aktualnih financijskih stanja obje firme da taj pristup itekak funkcionira. AMD nudi sve ovo kaj spominješ uz mogućnost odabira glavnih sastojaka, ali prvenstveno za serverska i općenito enterprise izdanja, do te mjere da više ni sabirnica nije problem, a bome novi EYPC modeli su i to dokazali. Nažalost iste igračke se ne nude za običan puk, mada se baziraju na identičnom chiplet dizajnu, ali klasičan desktop korisnik još jedno vrijeme neće uživati u tim tehničkim rješenjima, dok se EPYC (obične i 3D cache) verzije u HEDT Threadripper izdanjima vrlo lijepo uklapaju uz ostatak ponude, tak da je sve relativno dobro pokriveno.
Intel također nudi svoju paletu, samo kaj su oni zbog malih i velikih jezgri morali kompletno razdvojiti serverski dio, pa sad zasebno nude Xeon modele sa samo većim i samo manjim jezgrama, dok opet po uzoru na Threadripper, za HEDT tržište na izbor imaju za to prilagođene Xeone, bilo s manjim ili većim jezgrama. Mobilna i desktop izdanja su im ostala konsolidirana kaj se tiče manjih i većih jezgri, tak da krajnji kupci hoće-neće, dobivaju jedno i drugo u istom paketu. Arrow Lake nastavlja taj put, pa ostaje vidjeti službene recenzije sljedeći tjedan.
Staro 14.10.2024., 21:26   #5
stitrek
Datum registracije: Feb 2021
Lokacija: TRPI
Postovi: 456
@The Exiled
Sve je to manje više solidno kod Intela bez obzira što nisu našli cvrsti smjer, svakako trebaju u ponudu Arrow Lake-a uvrstiti i neki jeftiniji procesor, jer polazna tocka od 300$ za "i5" je previše uz trenutnu Amd konkurenciju, cijene ce vjerovatno ici dolje nakon nekoliko mjeseci ili ce ponuditi jos koji model...
Staro 14.10.2024., 21:42   #6
Postovi: 8,464
Lako moguće da ne bude nekih jeftinih, tj. slabijih Core Ultra 3 modela, jer sad više nemaju ni mogućnost da, kak je to inače bil slučaj, iskoriste prijašnju prepakiranu generaciju za donji tržišni segment, pošto im je sve skroz novo; TSMC proces, LGA-1851 i chiplet dizajn. Naravno, pod uvjetom da Arrow Lake ne ispadne još jedan nastavak 300W+ ili 400W+ sage, obzirom na onu MSI prezentaciju i Intel "default" papirologiju.
Staro 14.10.2024., 21:45   #7
stitrek
Lokacija: TRPI
Postovi: 456
A bin chipova, ono ne radi nekoliko jezgri i nazoveš ga Core Ultra 5 195 za 195$
Staro 14.10.2024., 22:06   #8
Postovi: 8,464
Da, samo ovaj put plaćaju posebno skupi TSMC 3nm proces, tak da pitanje kakva im je računica ili budu sfušane primjerke rađe ostavili za mobilna izdanja.
Staro 14.10.2024., 22:08   #9
stitrek
Lokacija: TRPI
Postovi: 456
A šta je sa njihovim fabovima, jesu li razvili nešto blizu pravih 3-4nm ili je to još u razvoju?
Staro 14.10.2024., 22:17   #10
Postovi: 8,464
To su trebali biti njihovi 20A, 18A, 16A i sl. procesi. Arrow Lake je trebal biti orginalno na 20A, a sad je na TSMC 3nm, dok su u Intelu nedavno otkazali 18A.
Uglavnom, ne bi oni ništa kupovali od TSMC-a, da su Intelove tvornice u stanju kakvom ih direktor Pat uz prateći marketing redovito nastoji prikazati.
Staro 14.10.2024., 22:20   #11
stitrek
Lokacija: TRPI
Postovi: 456
Pa trebali su razviti 20A i držati se toga za Arrow Lake koji ocito nece dobiti refresh, Zen5 je ionako 4nm i bili bi konkuretni, vjerovatno...7nm od 12-13-14gen je ipak prevelik i grijalica za konkuriranje...
Staro 14.10.2024., 22:30   #12
Postovi: 8,464
Krenuli su oni s razvojem svega (na papiru), ali malo toga im prolazi u konkretna rješenja, a odmakom vremena morali su u potpunosti prijeći na TSMC i sad imaju zapravo najbolji proces koji bude s novom Arrow Lake arhitekturom tek dosta za rang AMD Zen 4 i Zen 5 modela. Alder Lake i Raptor Lake su bili na 10nm++ koji su onda u jednom trenutku odlučili preimonovati u Intel 7, tak da marketing odradi svoje, pa se stekne dojam da Intel kao i TSMC ima 7nm EUV. Nisu bili ni blizu tome i ostali su na 10nm godinama, a taj proces je ionak kasnil i pokrenul cijelu lavinu problema iz kojih se Intel još dugo neće izvući.
Staro 14.10.2024., 22:38   #13
stitrek
Lokacija: TRPI
Postovi: 456
Znaci za high-end chipove je Intel u situaciji kao i što je bio Amd sa GlobalFoundries i prelazak na TSMC...kad su svi uglavnom kod TSMC-a to im daje još veci buđet za R&D tako da ce Intel još dosta vremena imati probleme sa svojim tvornicama da budu konkuretni u segmentu 1-2-3nm hmmm, za desetak godina ce valjda svi doci do 1-2nm zajedno sa Samsungom...
Staro 14.10.2024., 22:44   #14
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,871
Staro 14.10.2024., 22:59   #15
Postovi: 8,464
Autor stitrek Pregled postova
Intel je u goroj situaciji, nego svojevremeno AMD, jer je Intel izgubil svu prednost koji su držali cijelo desetljeće, a AMD nije imal ništa za izgubiti kad su se ionako vraćali s ruba propasti. Intelov glavni problem su prijašnje i sadašnje voCtvo, jer ti ljudi su utjecali i još uvijek direktno utječu na peripetije firme, lako za puste nanometre, kad se Intel prvo mora kompletno presložiti.
Staro 15.10.2024., 01:21   #16
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,620
Kad budu recenzije?
Gledam ploce, prvo dolazi Z890. Znaci onaj i7 ako bude oko 400 eur a te ploce cca 250, nekako mi se ne svidja bas. Htio sam iz fore malo promijenit platformu ali moram prvo vidit cijene.
Staro 15.10.2024., 01:36   #17
Postovi: 8,464
Sljedeći tjedan u srijedu ili četvrtak budu recenzije, jer procesori idu u prodaju 24.10. Cijene su popularne, a LGA-1851 lako moguće udomi samo Arrow Lake.
Staro 15.10.2024., 10:16   #18
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,337
Performanse otprilike znamo, ajmo računati i neka su 5% niže od prikazanog i to će IMHO i dalje biti jako dobro, ali mene ova potrošnja baš češe, jedva čekam vidjeti taj segment.
A zanima me i što će biti sa mobilnim CPUima po tom pitanju.
Slobodno me dodajte na PSN
Staro 15.10.2024., 18:41   #19
Postovi: 8,464
Mobilna izdanja budu ista stvar ko i desktop, tj. kaj su i prije radili, pa isti čipovi idu za jedno i drugo, jedino ih mogu još dodatno ograničiti po pitanju potrošnje.
Staro 16.10.2024., 09:26   #20
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,337
Pa to da, kako će se ponašati sa 15-30w.
Do koliko već W idu uopće U ili neki normalni, ugl ne H...
Staro 16.10.2024., 10:11   #21
Postovi: 8,464
E, normalni budu zapravo prepakirani primjerci, a Lunar Lake im sad pokriva ovaj 15W do 30W rang.
Nije HUB Tim bezveze odustal od testiranja laptopa, jer više nije znal ko pije, a ko plaća, dok su identični modeli bili različiti.
Staro 21.10.2024., 20:47   #22
Postovi: 8,464
Unlocked Intel Core Ultra 9 285K approaches 370W power draw during Cinebench test
According to new screenshots shared on social media, the Core Ultra 9 285K will consume between 360-370W when fully unlocked. This power draw can be observed during a multi-core Cinebench R23 test, with all P-Cores locked at 5.6 GHz and all E-Cores running at 3.9 GHz, as claimed. Leakers have shared some values, and we are including our own data for more perspective. The performance of the stock 285K CPU should reach 42K points, but unlocking the power limits can yield an additional 3K points, with another 1K increase when the power limit is fully unlocked.
Izvor: VideoCardz
Staro 22.10.2024., 18:06   #23
Postovi: 8,464
Die-Shots of Intel Core Ultra "Arrow Lake-S"
The whole-chip die-shot gives us a bird's eye view of the four key logic tiles—Compute, Graphics, SoC, and I/O, sitting on top of the Foveros base tile. Our article from earlier this week goes into the die areas of the individual tiles, and the base tile. The Compute tile is built on the most advanced foundry node among the four tiles, the 3 nm TSMC N3B. Unlike the older generation "Raptor Lake-S" and "Alder Lake-S," the P-cores and E-core clusters aren't clumped into the two ends of the CPU complex. In "Arrow Lake-S," they follow a staggered layout, with a row of P-cores, followed by a row of E-core clusters, followed by two rows of P-cores, and then another row of E-core clusters, before the final row of P-cores, to achieve the total core-count of 8P+16E. This arrangement reduces concentration of heat when the P-cores are loaded (eg: when gaming), and ensures each E-core cluster is just one ringbus stop away from a P-core, which should improve thread-migration latencies. The central region of the tile has this ringbus, and 36 MB of L3 cache shared among the P-cores and E-core clusters.
Izvor: TechPowerUp
Staro 23.10.2024., 18:01   #24
Postovi: 8,464
Intel Core Ultra 285K/265K and 245K review leaks out
The media has all three processors which are set to launch tomorrow (285K, 265K and 245). The review appears to be unfinished; hence there are missing details such as memory configurations, but it appears that the system is using Kingston DDR5-8400 memory from what we can see in the CPU-Z data. Perhaps the biggest unknowns until now were gaming performance and power/energy efficiency. According to the media the Arrow Lake-S CPUs won’t challenge the 14900KS, the flagship model within the (still) current series. In OC3D Tom Logan’s own words, “Core i9-14900KS is still the unchallenged king of the hill in nearly all scenarios”. The Core Ultra 200S series does not hold the top position in gaming benchmarks. It appears that the i5-13600K and i5-14600K can offer higher performance than even the flagship 285K, as shown. Compared to the 14th Gen Core series, the new series appears to be using less power and generate less heat, while the flagship Ryzen 9 9950X seems to require less power under load in OCCT benchmark.
Izvor: VideoCardz
Zadnje izmijenjeno od: The Exiled. 23.10.2024. u 23:14.
Staro 23.10.2024., 18:46   #25
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,337
Link je već mrtav, ajd dobro da si iskopirao.
Dakle taj novi flagship je sporiji od xx600K varijanti po ovom leaku. Pa to znači da XX900K a bome X900 i X950 ryzeni igraju nogomet sa AL-S.
Doduše, ti intelovi XX600 su izgelda poprilično opaki sa hrpicom CB jezgri, pa su dosta moćni za rad.
Ali pričekajmo još i HUB i GN, a i TP. Ja uvijek uzmem neki prosjek od par tih kojima donekle vjerujem.
Drago mi je da je potrošnja niža, ali bome AMD ih opet tu debelo šiba i po ovim grafovima mi se čini da koliko su niže perf u donosu na 13 i 14, toliko je niža i potrošnja.
''Optimizirali'' ih kažu. Ne može njih izgleda nikakav proces izrade spasit kad su usrali arhitekturu. Ali ovo je izgleda prvi korak u pravom smjeru.
Staro 23.10.2024., 18:49   #26
Postovi: 8,464
Je, link je izdržal kakvih 5min, prije nego su sve ubili, ali barem imamo neku najavu za sutrašnje recenzije.
Staro 23.10.2024., 20:28   #27
Exy
Exy's Avatar
Postovi: 2,620
Najgore je što su ovo vrlo vjerojatno rezultati sa 23H2, nadolazeći 24H2 jako boosta ryzene u igrama. Sad situacija izgleda loše, kako li će tek to izgledati malo kasnije.
Planirao sam neki (potpuno nepotrebni) upgrade, pa sam gledao arrow lake-a ali sad se čini da će to biti fail. Ispada da je alder lake zadnje pošteno od Intela, 12700K je bio zadnji pošteni gayming proc.
Inače, ako AMD zbilja počne polako povlačiti zen4 a ovaj arrow natjera intel da povuče prijašnje generacije, mogle bi poskupiti cpu performanse.
Razmišljam uzeti sad neki 7700 za 250E dok ih još ima, nepotrebno naravno ali da malo šarafim
Staro 23.10.2024., 21:21   #28
Postovi: 8,464
IMHO možeš komotno na 9800X3D kad stigne, jer te košta manje od planirane Arrow Lake migracije.
Intel Arrow Lake power testing might not be easy: Power Test bench build log
Staro 24.10.2024., 07:12   #29
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,337
Zadnji MLID video od jučer je rekao da je AL u nekim gadnim problemima, BSOD-i, konstantna nestabilnost i slično...da su rivjueri ludi jer ne mogu testirati kako spada.
Intel navodno sve zna i rade na updateu BIOSa. Bome, ne ide to na dobro.
@Exy: Pa mislim da ti je to baš bzvz, sa 7600 na 7700. Uzmi X3D kako ti kaže Exiled da vidiš bar nekakav boost u perf. Osim ako je nadoplata simbolična, onda je vj nebitno.
Staro 24.10.2024., 09:22   #30
Postovi: 8,464
Iskreno, moguće da ima nekaj u tome kaj ovaj MLID Tom priča po pitanju Arrow Lake problema u pozadini, jer lokalni stručLJak i plaćenik je već odradil PR etapu.
Nije mu baš pošlo po planu, jer ljudi više ne puše od Intela servirane priče da su za sve krivi proizvođači matičnih ploča.
