Staro 09.08.2024., 23:39   #91
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,881
Staro 10.08.2024., 14:15   #92
Postovi: 8,530
AMD keeps screwing up
EDIT:
We found the missing performance: Zen 5 tested with SMT disabled
We recently published our reviews of the AMD Ryzen 7 9700X and Ryzen 5 9600X processors powered by the Zen 5 architecture. These new chips offer contemporary levels of performance in their market segments, and are highly efficient, thanks to AMD building them on the low-power 4 nm TSMC N4P process, to the extent that AMD rated them with 65 W TDP. AMD advertised a roughly 16% IPC increase for Zen 5 over the previous Zen 4 architecture, and while we are fully aware that IPC doesn't linearly scale with gaming performance, we were a bit surprised to find that the 9700X and 9600X are no more than 3% faster than their predecessors in the most CPU-bottlenecked 720p gaming benchmarks.
Such a deviation from AMD's claims took everyone by surprise in the tech press, some reviewers even wondered initially if they had bad samples, there's plenty of discussion and drama in online communities. Like everyone else, we did several rounds of re-testing, and tried poking and prodding with the settings to figure out if we could better understand the architecture. Through the course of our testing, we found some interesting core scheduling behavior, and set out on an adventure.
In conclusion, AMD's Zen 5 architecture offers promising advancements, with particularly impressive single-threaded performance, but the unexpected SMT scaling raises many questions. In the past AMD has made changes to the behavior of their processors through AGESA BIOS updates, I think they will address the scheduling similarly.
Izvor: TechPowerUp
Zadnje izmijenjeno od: The Exiled. 10.08.2024. u 16:36.
Staro 11.08.2024., 20:20   #93
Silvio
Datum registracije: May 2016
Lokacija: Velika Gorica
Postovi: 110
Techpowerup mi se gadi sve vise i vise... bombastican naslov kao da su dobili 15% vise fpsa, a ono razlika 2%... da ne govorim kak je njima zen5 u gamingu skoro kao 14900k / 7800x3d a kod svih ostalih zen5 kaska jedno 15-20%.
Stvarno jedan jako jako jadan proizvod, na slajdovima super efikasni i prvi vrhu u gamingu, a u stvarnosti efikasnost na razini prosle generacije isto kao i gaming performanse. Puj
Edit: i vidi se kolko su dobar proizvod izbacili dok je mindfactory prodao tek 10 komada 9600x i 10 komada 9700x... i to su neki likovi koji najvjerovatnije nisu niti gledali recenzije
Silvio je offline   Reply With Quote
Staro 12.08.2024., 11:28   #94
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
Autor Silvio Pregled postova
To je kupio derbauer za deliding :P
Da, TPU ima bombastičan naslov i pomak na razini statističke pogreške, isto tako rijetko koja igra radi bolje sa SMT/HT na bilo kojem procesoru.
U 99,9% slučajeva radi mrvu bolje kada se to čudo isključi.
Slobodno me dodajte na PSN
Staro 12.08.2024., 11:30   #95
Postovi: 8,530
Kak god se okrene, nije rješenje isključiti pola tih čuda tehnike, tak da budemo pričekali još par dana za R9 9950X i 9900X recenzije.
U slučaju da je ista stvar kao i s ovim manjim modelima, tj. nema konkretnog pomaka u odnosu na Zen 4 - fala i doviđenja za Zen 5.
Staro 12.08.2024., 13:54   #96
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
Bit će vj duplo bolji od mališana. Ja im dajem 6-10% prednosti što je IMHO bzvz. Pričam naravno o ''produktivnosti'', a ne igrama, tu vj neće biti pomaka.
Staro 12.08.2024., 13:57   #97
Postovi: 8,530
Da, zato velim, ukoliko 9950X i 9900X ispadnu tu negdje sa 7950X i 7900X, onda je to ista situacija ko i ovi manji Zen 5 modeli u odnosu na aktualni Zen 4.
EDIT:
Did We Get It Wrong? Ryzen 7 9700X & Ryzen 5 9600X Re-Review
Zadnje izmijenjeno od: The Exiled. 12.08.2024. u 14:05.
Staro 13.08.2024., 09:53   #98
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
Danas to pogledao, došao je do jedinog zaključka do kojeg je i mogao doći. PBO za igre i skoro veliku većinu programa koje koriste kućni korisnici nema skoro nikakvu ulogu osim nenormalnog povećanja potrošnje. Jednostavno drugačija arhitektura i možemo se samo nadati da će sa zen6 to ispraviti. Pa sa zen4 se na kraju pokazalo da skoro ništa ne gubi u tzv eko modu, UVu i slično, umjesto da se kuri na defaultnih 95 stupnjeva, e tu su očito zen4 i 5 slični. Odlični su na niskoj potrošnji i za razliku od Intela ne skaliraju dobro kad ih se napumpa vatima. Zaključak, 65w je više no dovoljno.
Mene sada zanima, hoće li Intel uspjet ovo iskoristiti na pametan način?
Isto tako je i realno da AMD nema ništa što može konkurirati njihovim i3 i i5 xx400 desktopima. Intel je prije debakla imao puno puno bolji low- mid/low end.
Staro 13.08.2024., 14:05   #99
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,340
Zen 4 je vjerojatno nasviran budući da im je bio prvi na 5nm i nisu bili sigurni u yieldove. Onda kad su pustili non-X i bio je ista stvar sa 40W manje. Mislim da je to iznenadilo i AMD malo, da su imali jedan plan na papiru i nisu se prilagodili u hodu. Pa su drugi put (Zen 5) odlučili postaviti tako stvari od početka. Samo što sad nemaju kako nazvati non-X modele, osim ako ne idu u 9500 kerefeke... A taj step down model ionako znači drugu stvari drugu arhitekturu svaku generaciju, i tu su malo izmiješali stvari. Vjerojatno će ukinuti non-X modele skroz jer tu samo gube novac. X i non-X koštaju posve jednako za izradu i non-X uzima prodaju X-u, pa je logično da ga maknu.
Staro 13.08.2024., 14:12   #100
Postovi: 8,530
Autor Disco Pregled postova
Izgleda da i Arrow Lake ide u sličnom smjeru, a obzirom da na sve kaj ih je vlastitom krivicom snašlo, ko zna kaj bude Intel izvel, ali recimo da bude Arrow Lake po planu.
Intel’s next-gen Arrow Lake-S desktop processors will reportedly come with higher power limits than preceding Alder and Raptor Lake offerings. The top-end Core Ultra 9 285K will retain its predecessor’s “PL2” boost power limits when using the Baseline or Performance profiles. However, the Extreme power profile, exclusive to the 24-core CPU, will allow a boost power “PL2” consumption of up to 295W (up from 253W on the 13900K/14900K). The boost power consumption of the Core Ultra 7 265K and the Core Ultra 5 245K have reduced by up to 18W and 29W in the baseline and performance profiles, respectively. Arrow Lake-S is expected to launch this fall (or winter) alongside the new LGA-1851 socket. Only the three K-series processors are expected to debut this year, with the 65W non-K and mobility SKUs planned for early 2025.
Kaj se pak Zen 5 arhitekture tiče, serverska i mobilna linija proizvoda je i više nego OK, tj. točno prema najavama i očekivanjima, ali su desktop izdanja negdje krivo skrenula.
Staro 13.08.2024., 14:13   #101
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
@Odrinarius:
Imao je TechJesus već video o tome koliko vrijedi broj X-eva u nazivu proizvoda (ne mogu ga sada naći jer je vj bio neki rivju, mislim da RX 7900 XTX )!
Ali to je to, kako zen4 ne gubi kada se malo ograniči, e tako ni zen5 ne dobiva kada se razmaše. Ponašaju se identično po tom pitanju.
A za non X čekaju još veći škart od ova dva modela i to ti je to, isti TDP, samo nekih 100-200mhz niži takt. Dobit ćeš gotovo isti CPU, samo sa najvj npr gorim IMCom i slično.
@Exiled: A Desktop je server škart i zato se ponaša tako kako se ponaša, plus loš IMC tj identičan iz zen4.
A Intel je znači genijalno usrao motku ako je ovo o TDPu istina, još i te glasine da će možda i AL biti pogođen sa tim sranjem u proizvodnji koje ima RL.
Ako sam dobro skužio GN je dao nekoj firmi da dobro ispita da li ti CPUi imaju HWu grešku u proizvodnji (ne mogu se sjetit kako se to čudo zove )...i napeto čekam taj video.
Zadnje izmijenjeno od: Disco. 13.08.2024. u 14:24.
Staro 13.08.2024., 14:20   #102
Odinarius
All-rounder
Postovi: 1,340
Bio je XFX RX7900 XTX
Jest, AMD je imao niz odličnih launcheva iz tehničke perspektive u sva ta tri tržišta, već generacijama. Išlo ih je i s arhitekturom i s proizvodnim procesom, dok je Intel imao problema s oboje, naročito s proizvodnjom. Bilo je vrijeme da malo zajebu jedno... Barem su mobilci bomba. Ako i serveri budu dobri, a vidimo da će biti, i 2 od 3 su ok rezultat.
Non-X su petljali s SMT-om i s mobilnim APU arhitekturama, nisu konzistentni jer mijenjaju što koje ime znači po generacijama, pa treba biti oprezan.
Staro 13.08.2024., 14:26   #103
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
A mogu zeznuti samo kompletno neupućene, gora stvar je ovo što nV radi po ne znam koji put. Sada su tu pak 4070 vulgaris sa GDDR6 umjesto GDDR6X, dok je na kutiji...naravno, isti naziv.
Staro 13.08.2024., 14:40   #104
Postovi: 8,530
Da, pa sad imaju situaciju da se napredak u Zen 5 arhitekturi nikak ne preslika u toliko bitnim igrama, dok je sve ostalo ispalo vredu.
Je, rekel je Heavy Metal Steve da slijedi nastavak, ali sad kak svi recenziraju Zen 5, Intel priča je malo na čekanju. Kaj se tiče problema u proizvodnji, mada su to sve Intelove službene izjave, pa ne znače baš previše po pitanju kredibiliteta, ali recimo da Arrow Lake ne bude imal problema. Makar sudeći po ovim Raptor Lake pizdarijama za koje su znali od skoro samog početka, tj. dvije godine prije, nego je sve dospjelo u javnost - Intel za Arrow Lake može reći i obećati kaj god ih volja, jer više ni sami ne vjeruju u to kaj plasiraju u eter.
Staro 14.08.2024., 06:48   #105
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
Efkasnost :
Staro 14.08.2024., 14:18   #106
Postovi: 8,530
Lagano im je već pun kufer AMD-a, testiranja i nadobunih komentara.
Staro 14.08.2024., 15:16   #107
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
A vidio to.
Back to you Steve!
Staro 14.08.2024., 15:21   #108
Postovi: 8,530
Došlo je do toga, da ljudi unaprijed traže "Thanks Steve" i "Back to you Steve" svaki put kad se pruži prilika.
Heavy Metal Steve je u posljednjem HW News videu složil Slipknot - Duality referencu, tak da su ljudi zadovoljni.
EDIT:
Zadnje izmijenjeno od: The Exiled. 14.08.2024. u 16:01.
Staro 14.08.2024., 16:00   #109
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
Po TPU rezultatima sa pompoznim naslovom, nema apsolutni nikakvog smisla testirat sa ugašenim HT/SMT. Da bi to išta vrijedilo, moraju IHMO onda sve procove istetirati bez toga...i onda bi svi opet bili jednako brži i sporiji i sve 5. Mlaćenje prazne slame.
Zen5 nije proc za igre i to je to, neće tu pomoći ništa.
Stevo je već dodao i da neće ništa pomoći nove ploče sa novim čipsetima u vidu veće brzine RAMa jer je IMC u CPU.
Ljudi sa internetova svim silama žele da zen5 bude top u igrama, ali ne ide koliko god oni to željeli....ne kužim takav nastup.
Ja se nadam da će apropos ovoga pojeftiniti CPUi i bok.
A usput nam stiže i 5500X3D, boost 4ghz, 6/12 je.
AMD je odlučio da se ništa ne baca od AM4 škarta, IMHO bi trebali dobiti nagradu za ekologiju.
Staro 14.08.2024., 16:02   #110
Postovi: 8,530
Staro 14.08.2024., 16:05   #111
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
Izgelda i da su i veliki ''opaki'' kao i mališani...
EDIT: Samo sam nabrzinu izvrtio slideove sa TPU i situacija identičan sa ovim velikim u odnosu na mališane.
E sada je samo problem ako AMD ''istrijebi'' zen4, onda nema više biranja. Trenutno je bilo što od zen4 X puta bolja vrijednost za lovu.
Zadnje izmijenjeno od: Disco. 14.08.2024. u 16:15.
Staro 14.08.2024., 16:20   #112
Postovi: 8,530
Da, sve recenzije su s istim ili sličnim zaključcima, nema tu nekog napretka u odnosu na Zen 4.
Staro 14.08.2024., 16:23   #113
sinkee
sinkee's Avatar
Datum registracije: Mar 2011
Postovi: 57
možda bude nekaj ako skrešu cijene
sinkee je offline   Reply With Quote
Staro 14.08.2024., 19:17   #114
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,657
Možda bi i mogli, da i dalje ne održavaju na životu AM4 . Čini mi se da je za njih najbitnije kolike su zalihe zena4 kod retailera, ako mogu brzo izbacit sa tržišta zen4 moći će relativno bezbolno pogurati zen5, s obzirom da su manje više ista stvar
Baš loš launch, ne znam kad je zadnji put predstavljen ovakav proizvod bez ikakvih pomaka u odnosu na prethodnu generaciju, i to nakon 2+g razvoja.
Inače, sad se ujedno lijepo vidi vrijednost onih "ekspertnih" yt kanala tipa moore law is dead koji su potrošili 10.000 sati na laprdanje o tome dal će zen5 bit 15% brži ili 20% brži.
Staro 14.08.2024., 19:35   #115
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,183
Sada se izvlaci da je pogodio, je je mislio mt boost od 15%
Poslano sa mog SM-S908B koristeći Tapatalk
Staro 14.08.2024., 19:36   #116
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
Autor Exy Pregled postova
Ti nisi čuo za intel 11-e generacije?
Ne da nije napredovao, nego je bio sporiji.
ML se prvi odmah pohvalio kako je u jednom videu od prije rekao da bi zen5 mogao biti puno manje brz nego što se očekuje.
Ali on je npr RDNA3 najavljivao kao drugi Zen trenutak za AMD, pa smo vidjeli i što se tu desilo...
Staro 14.08.2024., 19:39   #117
Postovi: 8,530
IMHO za Moore's Law is Dead se ponavlja ista priča kakvu smo gledali sa Škotom, odnosno AdoredTV, ali ovaj MLID Tom ima žešćih problema s egom, jer ne može pustiti išta u eter, a da se ne referencira na samog sebe u trećem licu i obavezno naglasi da je on prvi imal određenu informaciju. Kaj se današnjih recenzija tiče, nekaj su u AMD-u fino sfušali barem kad je Windows OS u pitanju, jer Linux testiranja opet pokazuju 15%, 20%, pa i veći porast performansi u odnosu na Zen 4. I još k tome sad na neku foru Windows OS tretira 9950X i 9900X kao da riječ o 3D cache modelima, makar opet ta stvar funkcionira za 7950X3D i 7900X3D, dok za ove nove Zen 5 modele ide u rikverc.
Staro 15.08.2024., 07:32   #118
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
AMD Rumored to Increase TDP of 65W Ryzen 7 9700X and Ryzen 5 9600X to 105W
Ne znam čemu ovo kad je pokazano da samo troši više, a za igre nije nešto brže.
Ove mališane čisto sumnjam da itko kupuje za radit nešto ozbiljnije na njima...
A evo nam i Tomota (nisam još poslušao):
Staro 15.08.2024., 11:11   #119
Postovi: 8,530
IMHO ne moraš ni slušati, jer tip samo dodatno potvrđuje da je egocentrični seronja, pa otvara video sa "aha, jesam vam rekel, upozoraval sam na ovo mjesecima, cijelu godinu vam pričam da Zen 5 ima probleme na Windows OS-u, kasnilo je sve, krivo su postavili arhitekturu, itd." Jad i bijeda od lika i djela, a za dobru mjeru i dokaz vlastite umišljenosti, skriva se iza Wendellovih testiranja, dok AMD-u daje savjete kako popraviti sve kaj je pošlu po zlu sa Zen 5.
EDIT:
Windows Bug Found, Hurts Ryzen Gaming Performance
Zadnje izmijenjeno od: The Exiled. 15.08.2024. u 14:14.
Staro 16.08.2024., 13:27   #120
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Ja to nisam tako dozivio.
Skot mi je uvijek bio bolji, bolje analize isl. Ali uvijek je imao potrebu se pravdati.
MLID je tu mudriji, i lakse se nosi sa kritikama.
Budimo realni, svi smo ocekivali vise od ZEN5, jer smo razmazeni zadnjih godina finim skokovima.
A opet svi znamo zasto se govori uvijek na kraju pricekajmo reviewe.. evo zasto
MojSkuter
