Staro 31.07.2024., 18:05   #31
Postovi: 8,655
Autor Libertus Pregled postova
Nisu još izbacili Strix Halo? Neki Asrock mini PC s time bi bio top.
Nisu još, taj veliki APU stiže nakon ovih desktop Zen 5 modela, ali sigurno bude raznih mini-PC izdanja.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750
Staro 01.08.2024., 07:26   #32
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,475
Ima malo i o Intelu...
Slobodno me dodajte na PSN
Staro 01.08.2024., 09:21   #33
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,849
Jel ima neki AI da te davež video uratke sumira u 5 smislenih rečenica?
Staro 01.08.2024., 09:41   #34
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,475
TLDR: Nije zbog krivog natpisa na IHS, već je AMD navodno uveo strože alate za provjeru na kojem su novi ryzeni pali.
Navodno nije kao ništa strašno i kao nema šanse da netko naleti na problem, ali su zbog događaja sa Intelom odlučili to odmah riješit.
Staro 01.08.2024., 10:21   #35
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,849
Zahvaljujem na TLDR, ali stvarno, da li ima neki AI kojem možeš dati link youtube videa da ti sumira što su trkeljali cijeli video?
EDIT: Ima
Kraće
In the "AMD Zen 5 Validation Failures Leak | Intel Raptor Lake Instability Update" YouTube video, the speaker discusses validation failures in AMD's higher-end Zen 5 parts, leading to a delay in the Ryzen 9000 series release. AMD discovered a handful of parts that did not meet validation and retested existing yields to ensure quality. This issue is not a flaw with TSMC's 7nm process overall but rather an issue with early yields. Intel's Raptor Lake CPUs continue to face instability issues, causing frustration for their partners. Intel is reportedly withholding information from their partners about the manufacturing issue, leading to potential legal problems and imminent lawsuits. Moriz, the creator, believes AMD's issues are due to validation failures, while Intel's instability issues are causing delays. He encourages viewers to support his channel for more tech updates.
Ili duže:
00:00:00 In this section, a YouTube content creator explains that AMD's delay of the Ryzen 9000 series was not due to a typo, as some speculated, but rather because of validation failures in higher-end Zen 5 parts. AMD recently updated their testing methodology and discovered a handful of parts that did not meet validation, leading them to retest existing yields to ensure quality. The creator emphasizes that this is not a flaw with TSMC's 7nm process overall, but rather an issue with early yields. AMD is taking an abundance of caution to avoid any comparison to Intel's instability issues and may need to downgrade some processors or save top yields for future models. The creator also mentions that validation methodology changes frequently at AMD and it was unexpected that these issues were discovered during production.
00:05:00 In this section of the YouTube video titled "AMD Zen 5 Validation Failures Leak | Intel Raptor Lake Instability Update," the speaker discusses the ongoing instability issues with Intel's Raptor Lake CPUs and the frustration felt by Intel's partners. The speaker divides the people at Intel into two camps: those who downplay the issue and those who recognize the severity of the situation. The latter group is reportedly stonewalling their partners and refusing to admit anything is wrong beyond what has already been said publicly. The speaker also clarifies that oxidation is not the major cause of Raptor Lake desktop chip failures and that the ongoing issue is a legal problem, as Intel may have lied by omission to their partners about the manufacturing issue. The speaker also mentions that lawsuits are imminent and could be severe.
00:10:00 In this section of the YouTube video titled "AMD Zen 5 Validation Failures Leak | Intel Raptor Lake Instability Update," the creator, Moriz, shares some updates on the delays with AMD Ryzen 9,000 and Intel Raptor Lake processors. Moriz expresses his belief that AMD's issues are due to validation failures, while Intel's instability issues are causing delays. He encourages viewers to support his channel through subscribing, liking, sharing, and joining his Discord community or becoming a patron for additional perks.
https://www.summarize.tech/www.youtu...?v=Nh1hiIJFA2o
Staro 01.08.2024., 11:01   #36
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,342
7nm? Moriz? Treba taj AI još žganaca jesti. Inače nije loše. Svejedno mu ne vjerujem.
Sad onda jedino što ne znamo jest koliko je ozbiljan problem, iako vjerojatno nije ništa posebno. Bilo je problema s reklamiranim frekvencijama i na Zen 3 čini mi se, ali tih zadnjih 100mhz ionako nitko ne osjeti. Opet, pošten potez. Prvoproizvedeni silikon je uvijek najlošiji.
Staro 01.08.2024., 11:09   #37
Postovi: 8,655
IMHO na kraju bi moglo ispasti da je stvarno bilo do nekolicine I/O jezgri koje su se potkrale, pa su na temelju toga brzo povukli sve do onda izdano i odmah poslali friške primjerke.
Kak god se okrene, ništ previše strašno s tih tjedan-dva odgode, ali moglo je biti i gore.
Staro 03.08.2024., 18:07   #38
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,185
Je, bilo je problem i sa Zen3. Ali ne sa 100MHz, nego sa 50MHz. Cijeli 486 procesor! Samo sa "malo" boljim IPC-om
Staro 04.08.2024., 08:30   #39
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,475
Ma sa Zen2 je bilo to da ne dostiže reklamirane frkve.
Zen3 je zato ako se dobro sjećam išao cca 50mhz preko, kao iskupili se.
I Zen4 isto ide malo preko šta ne?
Staro 04.08.2024., 12:48   #40
Postovi: 8,655
Da, bilo je vezano za Zen 2 i to je ujedno bil početak der8auerovog (1 - 2) sada već dugogodišnjeg izvještavanja o AMD-ovom lažljivom marketingu. Roman der8auer Hartung je kao što znamo izuzetno objektivan (1 - 2 - 3 - 4 - 5 - 6) u svojim AMD tehničkim osvrtima, posebice kad mu dva glavna sponzora (Intel + ASUS) imaju probleme i u negativnom kontekstu se javno povlače diljem on-line medija, društvenih mreža i Interneta općenito - ne treba dugo čekati i der8auer začas slaže video u kojem nam skreće pažnju na AMD probleme zajedno s popratnim lažljivim marketingom koji prakticiraju. Posljednji od der8auerovih tehničkih osvrta se dogodil na sam dan kad su svi ostali imali izvještaje s AMD Zen 5 Tech Day događanja i gle čuda, der8auer u isto vrijeme izbacuje video inače orginalnog naslova AMD CPU Overheating u kojem skreće pažnju da opet ima problema s AMD proizvodima.
Nažalost nije mu baš prošlo po planu, a i valjda nije računal da su ljudi s godinama skužili koliko je proziran, pa je u komentarima tog videa, masakriran s upitima da kakvo je to neadekvatno hlađenje, kakav je on to inženjer koji nije voljan testirati i provjeriti sve kak spada, zašto nije ovo, zašto nije ono, zbog čega sad priča o tome, dok svi ostali pričaju o Intel Raptor Lake problemima, itd., dok se nisu počela i postavljati konkretna pitanja o još jednom montiranom videu kojem je jedina namjera skrenuti pažnju na problematičan AMD. Jedno vrijeme je čak pokušaval spriječiti navalu negativnih komentara, samo da bi naposljetku kompletno odustal i tjedan dana kasnije snimil nastavak u kojem priznaje da nije sve odradil kak spada i još je k tome šrot AMD CPU tretiran tekućim metalom, a kao treba mu za jako bitne poslove editiranja/renderiranja videa za njegov YouTube kanal.
Kasnije je reda-radi, kad je i za to naveliko prozvan, snimil video o aktualnim Intel problemima, a obzirom da se bliže Zen 5 recenzije, uopće nema sumnje kako će der8auer u sljedeća dva tjedna opet imati neki problem s AMD proizvodima, jer ko zna, možda u odlasku do dućana ugane gležanj, a taman je u prolazu navratil do bankomata, koji gle čuda koristi neki embedded AMD i paf - evo materijala za video - taman u vrijeme kad svi ostali imaju Zen 5 recenzije, der8auer slaže tehnički osvrt kako ga je AMD skoro koštao života i njihovi proizvodi su opećnito opasni po zdravlje.
Staro 05.08.2024., 09:39   #41
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,475
Sve 5, samo problem sa lažno oglašeno frekvom za zen2 stoji, nije izmišljen, bio je stvaran.
Kasnije su to popravili, ali da dostigne barem na par sekundi reklamiranu frekvu.
Nije ni AMD zlato.
Staro 05.08.2024., 09:44   #42
Postovi: 8,655
Jasno, sve to treba javno prozvati, samo jedno je kad to objektivno rade GN i HUB, a sasvim drugo kad dolazi od der8auera koji u pozadini ima Intel + ASUS mašineriju.
EDIT:
AMD Ryzen 9000 "Zen 5" desktop processor pricing and availability confirmed
AMD confirmed the pricing and availability of its new Ryzen 9000 "Granite Ridge" desktop processor models. These were supposed to launch on July 31, but faced a delay, and are now facing a staggered launch. The 8-core Ryzen 7 9700X and 6-core Ryzen 5 9600X will be available from tomorrow, August 8, 2024. The flagship 16-core Ryzen 9 9950X and 12-core Ryzen 9 9900X follow a week later, on August 15. The company also confirmed pricing of the four chips in USD SEP. The Ryzen 9 9950X is confirmed with a $650 price, followed by the Ryzen 9 9900X at $500, the Ryzen 7 9700X at $360, and the Ryzen 5 9600X at $280. These are slightly cheaper than their predecessors, with the 7950X, 7900X, 7700X, and 7600X, launching at $700, $550, $400, and $300, respectively.
Izvor: TechPowerUp
Zadnje izmijenjeno od: The Exiled. 07.08.2024. u 13:21.
Staro 07.08.2024., 16:01   #43
Postovi: 8,655
Zadnje izmijenjeno od: The Exiled. 07.08.2024. u 16:29.
Staro 07.08.2024., 16:44   #44
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,475
Au, koji je ovo kuki...?!
Pogledao sam samo HWU recenziju.
Ovo kao hladan tuš.
U prosjeku 15-20w manja potrošnja i egal performanse.
Ovo izgleda kao rebrand zen4 u zen5.
I cijene su katastrofalne kad se sve uzme u obzir.
znači da će ili za X3D izmislit neko čudo ili ćemo isto dobit 3% brži proc.
EDIT: Sada vidim naslov Kitguru recke, to je sarkazam sa njihove strane ili si ih stavio da se vidi kako oni ''recenziraju'' ?
Zadnje izmijenjeno od: Disco. 07.08.2024. u 16:50.
Staro 07.08.2024., 16:51   #45
Postovi: 8,655
Ili su se totalno sjebali ili nisu ništ napravili, jer ova dva Zen 5 modela na 65W imaju iste performanse ko Zen 4 ekvivalenti na 105W, a opet izgleda da negdje ipak ima konkretnog porasta peformansi. Na kraju bude ispal tipičan AMD čušpajz, pa se budu ponovno u sljedećim tjednima i mjesecima povlačili po netu s kojekakvim BIOS + AGESA objašnjenjima kaj točno se tu desilo.
Autor Disco Pregled postova
Ne, ozbiljno je, njihov 9600X je sasvim OK ispal, isto ko i Phoronix verzija. Ko zna, možda su na kraju neki recenzenti dobili one sfušane primjerke.
Staro 07.08.2024., 16:59   #46
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,710
Kakav užas. A ja pripremio novi bios za ploču, reko uzet ću 9600X reda radi. Ako je 15% brži i nešto manje troši, to mi je dovoljno opravdanje za potpuno nepotrebnu kupnju . Ali kad sam ovo vidio, užas
Staro 07.08.2024., 17:01   #47
Postovi: 8,655
Staro 07.08.2024., 17:01   #48
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Nije dobio naziv zen4+ jer su puno sarafili po njemu, a realno i to bi bilo pretjerano ovako na prvu
MojSkuter
Staro 07.08.2024., 17:06   #49
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,193
opet stagnacija s procesorima
bice kao s starim 2500k, kupis 7800x3d i koristiti 10g
Staro 07.08.2024., 17:11   #50
Postovi: 8,655
Za kasnije obične 9700 i 9600 modele su mogli staviti 65W TDP, jer s ovim X izdanjima su se samo sjebali, kad su 7700X i 7600X imali 105W i nikome ništ.
Staro 07.08.2024., 18:08   #51
BinaryJesus
Datum registracije: Feb 2021
Lokacija: Sveti Petar
Postovi: 313
Pa i zen4 je bio razočaranje samo po pitanju IPCa ali su s njime dosta digli clockove plus brži ddr5 pa je to onda sve skupa u kompletu ispalo dobro u odnosu na zen3.
Sada sa zen5 kada je tu samo IPC bump to ispada ovako razočaravajuća.
BinaryJesus je online   Reply With Quote
Staro 07.08.2024., 18:17   #52
Postovi: 8,655
Razočaravajuće je kad su odlučili limitirati X modele na 65W TDP, a prijašnji su imali 105W, tak da su za ove nove komotno mogli složiti 95W TDP i opet bi mogli reći da imaju manju potrošnju i sve ostalo kaj ide s tim kroz marketing. Zen 5 65W ima iste performanse ko Zen 4 105W modeli, a kad se izjednače po TDP/PPT pitanju onda se dobi onih 15% do 20% u napretku za Zen 5, samo jebiga, bajni AMD marketing udara opet i po zna koji put. Za Zen 4 su imali problem da su prvi dojmovi bili kako se grije i troši, jer nikome nisu rekli da postoji ECO mode, a sad imaju suprotnu stvar - za Zen 5 su s ova dva manja modela pretjerali po pitanju šparnosti, toliko da se uopće nema dojam ikakvog napretka.
Staro 07.08.2024., 19:51   #53
Taproot7
mag.math.
Taproot7's Avatar
Datum registracije: Dec 2021
Lokacija: Daruvar/Zagreb, Republika Hrvatska
Postovi: 366
Ajme meni kakav jad jadni od lansiranja nove mikroahritekture. Ovo može biti nadogradnja samo onima koji imaju 11th Gen procesor od Intela, 3000 seriju Ryzena ili starije od toga. Svi koji imaju modernije procesore i platforme od 2020 na ovamo, ovo nije vrijedno pijeska utrošenog za jezgre ispod te fancy kape. Umjesto da AMD sad poentira i iskoristi trenutak Intelove krize, oni poentiraju sebi u svoj gol. GG AMD.
Taproot7 je offline   Reply With Quote
Staro 07.08.2024., 20:00   #54
Postovi: 8,655
Nek se sramote i objašnjavaju kak je moguće da mobilni Zen 5 ima osjetni porast performansi, dok ista arhitektura u desktop izdanju nema, jer su ograničili TDP/PPT uz kontra efekt.
AMD has set a 65W TDP for the Ryzen 7 9700X, which matches the Ryzen 7 7700 non-X and is considerably lower than the 105W setting on the 7700X.
Combined with the enhancements in microarchitecture and the 4nm production process, this design makes the Ryzen 7 9700X a remarkably energy-efficient design.
Staro 07.08.2024., 20:40   #55
Mladenxy
Mladenxy's Avatar
Postovi: 4,509
Procesori su dobri, cijena treba biti niža. Performanse su već godinama odlične, pa ne znam do kada mogu konstantno samo rast i rast...Nek spuste cijenu što prije ak im TSMC daje prostora i super procesori sa malom potrošnjom. Da li su bili potrebni? Ne ali uz ponavljam dobru cijenu što manji TDP to bolje.
To da je tržište zasićeno i većina nas ni sama ne zna kaj bi više vjerojatno je veći problem od ovog sidegradea
Još bolje bi bilo da maknu iz ponude 6/12 i kao početni model nude 8/16 po 279$, i to bi bio korak naprijed.
Ali tehnološki procesori su bonbon.
Staro 07.08.2024., 20:43   #56
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,534
Autor Gemmy Pregled postova
Pa štaće kad se natjecu sami sa sobom ako i imaju nesto sa velikim skokom cuvaj za crne dane kad i ako se intel vrati sa necim vridno spomena.
Sent from my SM-S918B using Tapatalk
Staro 07.08.2024., 20:56   #57
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,475
Apropos 65W TDP, ima recenzija gdje je upaljen PBO jer AMD to sada gura za zen5, ali nema nekih pomaka. E sada ne znam da li PBO kompletno ''oslobađa'' proc ili ne.
Hajde da vidimo kroz tjedan-dva da li će se AMD oglasiti i riješit ovo čudo BIOSom.
Za sada ovo izgleda baš jako loše. 9700X je 360€ tj vj malo više, a 7800X3D je 380€, nema se što razmišljati, 7800X3D je šparniji, brži koštaju skoro isto.
Ovo skoro pa ispada kao da nisu ni testirali prije izbacivanja.
Mislim ima tu i tamo negdje napretka u IPCu, ali u globalu je to prdac u prazno.
Kako su kolege rekli, ovo je AMDov Ivy bridge.
Staro 07.08.2024., 21:07   #58
Mladenxy
Mladenxy's Avatar
Postovi: 4,509
I onda BSOD valjda opet porođajni RAM problemi. 16:30
Staro 07.08.2024., 21:44   #59
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,475
Ovom junaku bas vjerujem, cekam da Tech Jesus to ispita pa javi.
Staro 07.08.2024., 21:51   #60
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Zen 5%
Stvarno skoro nikakav napredak, steta sta vise nemaju konkurenciju...
