#1 | |||||||
Postovi: 8,633
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX |
Prvoklasni Krkan
Postovi: 5,454
Postovi: 8,633
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 21.07.2024. u 23:16. |
#4 | ||
Postovi: 8,633
#5 | ||
Postovi: 8,633
Prvoklasni Krkan
Postovi: 5,454
AMD Ryzen 9 9900X appears to be slower than the 7800X3D in a lot of games in these first third-party gaming benchmarks Izvor je neki bzvz, pa ne znam koliko može biti dobar, ali veli jednaki su ili je 9900x sporiji, brži nije. Ako stvarno bude tako, jasne su mi onda one cijene. |
Prvoklasni Krkan
Postovi: 5,454
Za Intel zna nas par % tu sa foruma i entuzijasti općenito, tako da mi se čini da im to vj i dalje ne stvara baš neke probleme u prodaji. Tj najveće sranje im je tj biti će im kada im počnu otkazivati veliki korisnici sa serverima i slično. Za AMD po svemu nema zime. Zadnje izmijenjeno od: Disco. 24.07.2024. u 11:34. |
Lokacija: Zagreb, Črnomerec
Postovi: 2,704
NIšta neočekivano, nisu ni zen4 bili toliko puno brži od 5800x3D iako je razlika u taktu bila preko 1 GHz. A sad je zen5 brži od 7800x3D 500 MHz. AMD ima dedicated CPU za gayming tako da kome je to najbitnije neka čeka 9700X3D ili kako će se već zvati (iako ne znam u kojem to scenariju 7800x3D nije dovoljno brz u gaymingu). |
#10 | |
Postovi: 8,633
#11 | |
Datum registracije: May 2016
Lokacija: Velika Gorica
Postovi: 110
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,697
Ja čekam rezultate 9950X-a. Vrijeme je da se zamijeni stari prdonja - 9900K. Vidim da je MSI stavio službeni support za neke ploče do 256GB. Jel se zna kada bi trebali biti dostupni 4x64gb kitovi? Sada na 9900K imam 128GB i to zna biti nekad malo (obrada oblaka točaka i fotogrametrije). 192GB upgrade mi je tak tak... |
#14 | |||
Postovi: 8,633
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 24.07.2024. u 23:21. |
#16 | ||
Postovi: 8,633
Koliko god se činilo blesavo, ispalo bi puno gore da su to pustili u opticaj, pa nakon recenzija, povukli i onda sami sebe pokopali hrpom negativnog tiska, makar bi se inicijalno pokazalo da su procesori OK. Ajde, odgoda od tjedan dana za R5 i R7 modele, te dva tjedna za oba R9 modela nije tak strašno. Još se bude taman poklopilo s Intelovim dodatnim zakrpama, pa nek testiraju sve kak spada. ![]() Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 25.07.2024. u 00:38. |
#17 |
Prvoklasni Krkan
Postovi: 5,454
Meni je to malo čudno, oni će kao u 2 tj ispraviti HW grešku na svim do sada proizvedenim CPUima...rekao bi ja da oni riješavaju BIOS, a ne HW. Najvj ovo što je Stevo i spomenuo, možda im CPUi ne boostaju na reklamirane frekve kao što je zen2 u početku bio po 100+ mhz niže od reklamiranog. Pa ih je derbauer razapeo zbog toga. Voli AMD ove nebulozne poteze...sjetim se 5600 XT ili koja je ono točno bila gdje su u zadnji tren na brzinu izdali BIOS koji povećava brzinu VRAM-a jer im ga je gosn jakna metnuo. Pa pljuvanje na sva zvona na 4gb VRAM, da bi slijedeću gen izbacili grafe sa 4gb i pravili se grbavi... Imaju oni trenutaka i da ponovim, AMDova najslabija karika, tj čini mi se karika koju skoro pa uopće nemaju je marketing. Lijepo je za nas korisnike da se sva lova tuče u R&D, ali ipak treba nešto šuške dat i marketingu, pa Jobs je bio najbolji primjer koliko je marketing jak za prodaju. ![]() |
#18 |
Postovi: 8,633
Ukoliko je do stvarno do problematične I/O jezgre na nekolicini inicijalno poslanih modela, onda nemaju kaj puno ispravljati, kad ih istovremeno povlače i šalju friške koji su u međuvremenu proizvedeni. U tih tjedan-dva ionako ne mogu ništa konkretno napraviti, a koliko smo imali prilke vidjeti, ljudi su ih se već domogli i testirali konkretne primjerke.
#19 |
mag.math.
Datum registracije: Dec 2021
Lokacija: Daruvar/Zagreb, Republika Hrvatska
Postovi: 366
Kompletna IT industrija ima zajedničku boljku zadnjih 5-7 godina a to je Quality Assurance. Sve se lansira ishitreno i što prije i događaju se ovakve stvari, od igle do lokomotive s time da je zadnje 2-3 godine to baš izraženo da krajnji korisnik preuzima ulogu kupca i testera. |
#21 | |
Postovi: 8,633
Last Minute Problems! AMD Delays Ryzen 9000 - What We've Learned Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 25.07.2024. u 14:35. |
#22 | ||
Postovi: 8,633
![]() ![]() EDIT:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 28.07.2024. u 20:07. |
#23 |
Prvoklasni Krkan
Postovi: 5,454
Cinebench Scores for AMD Ryzen 9900X, 9700X, and 9600X Surfacehttps://www.guru3d.com/story/cineben...9600x-surface/ Na mobu je skoro pa nemoguće ovo dobro izvest ![]() |
#24 | |
Postovi: 8,633
#25 |
Lokacija: zg westside
Postovi: 626
Jel će i uz ove dijelit ram u Microcenteru pa će ih tamo lokalne prodane duše opet proglasit najboljim buyem mogućim na planeti? Ako ne, valjda će dić cijene Zenu 4 pa da ovaj izgleda kao dobar buy. Alternativno, kupit ćemo strgani Intel.
~Fury of the dwarves runs deep. |
#26 |
Postovi: 8,633
![]() Sve je moguće kak je krenulo, ali oba Zen 5 Ryzen 9 modela su prema ovome 100$ jeftiniji, nego je to bila situacija za Zen 4.
#28 |
smeghead
Postovi: 3,190
mislim da cu preskociti ovu generaciju zasada i ubost 7500f/7600. i kasnije u buducnosti uzet 9800x3d, naravno kada padne cijena za koju godinu. ali strpit se jos tjedan dana do testova ovih malisana |
#29 |
Postovi: 8,633
Da, a ukoliko stvarno prema najavama u rujnu/listopadu izbace Zen 5 3D modele zajedno s "novim" čipset 800 pločama, tj. nek 9800X3D bude kakvih 450$ i izađe taman prije, nego Intel pusti Arrow Lake u opticaj, onda AMD lako dodatno korigira cijene. Nažalost, za tjedan-dva su odgodili službenu prodaju i recenzije, inače bi od jučer i danas sve već bilo jasno po pitanju performansi i dostupno u dućanima.
#30 |
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,845
Nisu još izbacili Strix Halo? Neki Asrock mini PC s time bi bio top. |
