#841 | |
Datum registracije: Dec 2012
Lokacija: Vž
Postovi: 270
https://pureinfotech.com/bring-back-...nu-windows-11/ https://github.com/valinet/ExplorerP...1.62.2_9b68cc0 |
#843 | ||
Postovi: 8,207
![]() ![]() Citiraj:
Secure Boot + TPM 2.0 mogu uključiti kad god, ako se baš zainate, ali nekak se čini da budu još više forsirali Microsoft account, AI i ostala veselja.
#845 |
Postovi: 8,207
Jasno, makar koliko god da oni sjebu Windows kao OS, ionak sve ostalo imam prebačeno na Linux uz dodatnu Fedoru za ovaj glavni stroj, tak da nemam brige. ![]()
#846 |
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,384
Ja sam ih otkačio prvenstveno zato što smatram da bi OS trebao biti alat koji radi ono što želim. Kao što očekujem da mi se bušilica neće sama paliti kada njoj dođe da se upali ili da mi se auto neće sam od sebe preparkirati na mjesto na suncu ![]() Konstantna borba s nekime tko me želi zajebat nije podloga za plodonosnu suradnju. Ali čestitke svima ovdje na upornosti. |
#847 |
Postovi: 18,847
The February 2024 security update might fail to install Status Confirmed Affected platforms Client Versions Message ID Originating KB Resolved KB Windows 11, version 23H2 WI719612 KB5034765 - Windows 11, version 22H2 WI719613 KB5034765 - Windows 11 devices attempting to install the February 2024 security update, released February 13, 2024 (the Originating KBs listed above) might face installation failures and the system might stop responding at 96%. Resulting from this error, the following message might be displayed: • “Something didn’t go as planned. No need to worry – undoing changes. Please keep your computer on”. This issue might be reflected in the Windows Event Viewer with error code ‘0x800F0922’. Workaround: This issue can be prevented by deleting the hidden folder C:$WinREAgent. A restart might be required. After following these steps, installing the February 2024 security update should succeed.
#849 |
PRO
Postovi: 4,719
evo da se posujem pepelom: nakon šta sam tu napisa da mi je sleep radio bez problema već godinama, nakon updatea mi je - krepa. kad se probudi iz sleepa ili se ne probudi ili se neka HW komponenta ne probudi (wifi, bluetooth, grafička...) uopće mi se neda debugirati ![]()
#851 |
Datum registracije: Jan 2024
Postovi: 147
Na PC-u moći će se koristiti kamera mobitela kao webcam https://blogs.windows.com/windows-in...dows-insiders/ |
#854 |
Postovi: 147
Microsoft je najavio da ukida podršku za android aplikacije i igre na Windows 11, a podrška će potrajati sve do 5.3. 2025. Microsoft is ending support for the Windows Subsystem for Android™️ (WSA). As a result, the Amazon Appstore on Windows and all applications and games dependent on WSA will no longer be supported beginning March 5, 2025. Until then, technical support will remain available to customers. https://learn.microsoft.com/en-us/windows/android/wsa/ |
#855 |
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,038
Uf... ajme meni što je ogavan UI kod W11, ni W10 nije nešto ali je bolji. Užasno mi fali što su title bar maknuli pa onda one grozne ikone za copy/paste/cut...
tomek@vz: ajd nemoj | Mali Čile SAD Češka Peru | Windows Free |
#856 |
Lokacija: Chakovec
Postovi: 385
#857 |
Datum registracije: Sep 2011
Postovi: 1,109
Došao laptop sa windowsima. Stavili neku šifru na admin account. Zaboravili šifru. PRegledao sve google upute kako maknuti šifru,instalirao sve programe za bypass šifre, svi su ili plaćeni, ili neki malware. Postoji li neko prokušani besplatni način da se remova user bez reinstalacije windowsa? |
#859 |
Lokacija: Sesvete
Postovi: 1,038
Probaj sa strelecom
#860 |
Postovi: 18,847
Ako imaš Windows setup DVD/USB stick, onda... - Otiđi u recovery i C:\Windows\system32\Utilman.exe preimenuj u Utilman1.exe, a cmd.exe u Utilman.exe - Na login screenu Ease of Access tipka ti sada otvara Command Prompt - Utipkaj net user za ispis svih usera - Utipkaj net user Korisnik * (zamijeni Korisnik sa svojim userom) - Utipkaj novi password dva puta - Vrati se u recovery i C:\Windows\system32\Utilman.exe preimenuj u cmd.exe, a Utilman1.exe u Utilman.exe
#862 |
Lokacija: Jug
Postovi: 497
https://wholsalekeys.com/ Odavde sve uzimam zadnjih par godina. Sent from my SM-G996B using Tapatalk |
#863 |
The mighty pirate
Lokacija: London
Postovi: 9,066
https://royalcdkeys.com Uzeo 11 Pro Retail za 3.99€ Instant isporuka, aktivacija uredno prošla. Preporuka
#865 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,543
Desetka je EOL krajem iduće godine, osim LTSC verzije koja ima support do kraja desetljeća. Tak da fino instaliraš LTSC iduće godine i miran si. |
#866 |
I encompass, and I eclips
Datum registracije: Jul 2010
Lokacija: Plazikur
Postovi: 1,024
aha okej, znači moram kupit taj key isključivo za taj long time? a po tebi, jesi ti na 10 ili 11? grozim se onih glupih izmjena realno, i samo me zanima jesu bolji za gejming a vidim da je isti klinac
#867 |
Datum registracije: Feb 2021
Lokacija: Sveti Petar
Postovi: 282
Izgleda da windows počinje blokirati StartAllBack: https://www.neowin.net/news/microsof...-startallback/ |
#868 | |
DIY DILETANT
Postovi: 3,543
Nemreš kupit LTSC, osim ako nisi velika firma, to je enterprise verzija. Ako je gaming u pitanju, nebih preporučio jer sve više igara zahtijeva najnovije verzije Windowsa, a LTSC je iz 2021. Napravi upgrade na W11 za godinu dana i mirna bosna. |
#869 |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,049
Guraj 10 do listopada sljedeće godine kad prestaje support i onda se prebaci na 11. Ako trebaš nekaj kaj znaš da bude radilo, jel... Ak se hoćeš igrati i ak ti se da delati clean install i modifikacije, onda instaliraj LTSC
#870 |
Postovi: 33,942
Negdje sam pročitao da bi do kraja godine trebao izaći W12. I ja sam još uvijek na W10. Za W11 moram kupiti nove komponente (CPU+mbo+RAM). Čekam BF za šoping. A razmišljam i o tome da za 200-tinjak € kupim neki kineski Mini PC (npr. Intel N95, 16/512) jer većina zadovoljava moje potrebe (office).
"Dvije stvari su beskonačne - svemir i ljudska glupost. Za svemir nisam siguran." A. Einstein Zadnje izmijenjeno od: coconut. 05.04.2024. u 15:29. |
