Staro 29.10.2023., 19:41   #5431
domy_os
domy_os's Avatar
Postovi: 18,853
Nemam je, ali sam se sad sjetio da sam možda čak to instalirao kad sam se igrao Chromecastom, ili je to Google Home app bila, nemam pojma.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 06.11.2023., 13:22   #5432
marinnn
Datum registracije: Nov 2014
Lokacija: Dalmacija
Postovi: 4
Autor locks Pregled postova
Predinstalirana je na svakom Androidu, sad sam i ja ugasio...
Ne radi mi android auto bez nje, tako da ostavljan google virus:-)
marinnn je offline   Reply With Quote
Staro 06.11.2023., 15:14   #5433
strikoo
strikoo's Avatar
Postovi: 961
oćel biti kakvija akcija na izmjenu baterija opet?
strikoo je offline   Reply With Quote
Staro 06.11.2023., 20:55   #5434
domy_os
domy_os's Avatar
Postovi: 18,853
Autor marinnn Pregled postova
Vjerovati Ameru ili Kinezu, pitanje je sad...
"This security notification was not triggered by Google Play Protect and appears to be from a device that is not Play Protect certified and does not have access to officially download Google's core apps from Play. We recommend contacting the device manufacturer for further information. Google Play is the only app store where you can officially download Google's core apps for Android. All Google apps go through the same rigorous testing as all other apps on Google Play. These tests are designed to ensure that apps are safe, secure, and meet Google's quality standards." - Google spokesperson.
A proposed solution for disabling the "false alarm" is to go to Settings > Apps > Optimizer > App Info > Storage > Clear Cache / Clear Data and then reboot your device.
If that doesn't work, try to uninstall and reinstall the Huawei Optimizer app.
Staro 13.11.2023., 14:22   #5435
Postovi: 33,968
HarmonyOS neće podržavati Android appse
https://pandaily.com/huaweis-harmony...-android-apps/
Staro 13.11.2023., 14:45   #5436
locks
Datum registracije: Mar 2010
Lokacija: Vukovar
Postovi: 3,603
Harmony OS je i dalje bitan samo u Kini, tako da ima logike. Rade ekosustav koji se potpuno odvaja od Androida...
Vjerujem da EMUI ostaje za sva ostala tržišta.
Staro 14.11.2023., 09:49   #5437
Tualatin
Datum registracije: Aug 2023
Postovi: 441
Logičan potez i još jedan korak ka osamostaljenju. Ako ima uspije google bi konačno mogao imat konkurenciju.
Tualatin je offline   Reply With Quote
Staro 14.11.2023., 10:56   #5438
Postovi: 33,968
Ne znam baš kolika bi im to bila konkurencija. Android koriste milijarde mobitela, a HarmonyOS bi koristilo daleko daleko manje. Upitna bi bila isplativost appsa za programere na toliko maloj bazi.
Staro 14.11.2023., 11:18   #5439
Mar
Suit up!
Mar's Avatar
Postovi: 5,967
Autor coconut Pregled postova
Pa ne bih se baš kladio jer gledajući događaje na globalnoj razini mislim da velika količina zemalja se želi odvojiti od američke dominacije u tehnološkom sektoru, a širenje utjecaja Kine na Afriku i Južnu Ameriku će sigurno dovesti do promjena, Rusiju su već izgubili.
Ako gledamo obrnuto jedino Anglosaksonske zemlje, EU (za sad), Japan i J. Koreja su jedini koji će koristit Android sigurno, a to je manji dio populacije planeta.
- Barney Stinson
Staro 14.11.2023., 11:21   #5440
Postovi: 33,968
Kako je Android vezan na Google, nekako slutim da će HarmonyOS biti povezan na neki Huwaeiverse (ofkors kineski), a da to Zapadnjacima neće odgovarati. Ono: 'Bolje da o meni sve znaju Ameri nego Kinezi'.
Staro 14.11.2023., 11:52   #5441
locks
Lokacija: Vukovar
Postovi: 3,603
Harmony je već povezan s električnim automobilima, pametnim kućanskim aparatima, a primjenu će još proširiti. Trenutno su u Kini, ne bi čudilo da se prošire na Rusiju i još neke srodne zemlje. Radi se o stotinama milijuna korisnika...
Staro 15.11.2023., 08:35   #5442
Tualatin
Postovi: 441
Samo da osvoje kinesko tržište već su uspjeli.
Staro 21.11.2023., 10:04   #5443
locks
Lokacija: Vukovar
Postovi: 3,603
EMUI s podrškom za Android apps ostaje za sva ostala tržišta...
https://m.gsmarena.com/huawei_will_k...news-60644.php
Staro 23.11.2023., 10:12   #5444
ti.le
[CTN]Mr.Ti
ti.le's Avatar
Lokacija: Zg, Novi Zg
Postovi: 563
EMUI i mPBZ, rade vam OK notifikacije?
Imam Mate 50 PRO i mPBZ radi, ali ne dobivam nikakve notifikacije (uplata/isplata itd).
mPBZ atualizirana, obavijesti sve dozvoljene, battery managment na rucne da ne dira, dozvoljeno automatsko pokretanje, dane sve dozvole aplikaciji
Također mi ni top up na Revolut ne pokrece automatrski davanje privole iz aplikacije, možda povezano s ovim gore?
CPU: Ryzen 7 5700G / Noctua D15S; MBO: MSI B550 Tomahawk; RAM:Corsair Vengeance 2x16 3200MHz; GPU: XFX Merc 319 RX 6900 XT; HDD: 1. Samsung 970EVO 256 GB; 2. Crucial P2 500GB; PSU: EVGA Supernova G2 750; CASE: NZXT H440 White; MONITOR: Asus MG279Q; KEYBOARD: Roccat Vulcan 100; MOUSE: Razer ViperMini @ SteelSeries QCK mass; HEADPHONES: Kingston HyperX Cloud (I) - Superlux HD-681 EVO
ti.le je offline   Reply With Quote
Staro 23.11.2023., 13:50   #5445
locks
Lokacija: Vukovar
Postovi: 3,603
Na Nova 9 mHPB i Erste rade bez greške...
Zadnje izmijenjeno od: locks. 23.11.2023. u 14:18.
Staro 05.12.2023., 19:14   #5446
locks
Lokacija: Vukovar
Postovi: 3,603
Huawei se ne šali. Imaju 5nm čip - Kirin 9006C.
https://www.huaweicentral.com/huawei...06c-processor/
Staro 20.12.2023., 07:37   #5447
locks
Lokacija: Vukovar
Postovi: 3,603
Huawei opet ima akciju zamjene baterije već od 20€....
https://consumer.huawei.com/hr/support/battery-service/
Staro 20.12.2023., 08:05   #5448
strikoo
strikoo's Avatar
Postovi: 961
To sam čekao . hvala
Staro 22.12.2023., 11:51   #5449
dinos3
Dino Saur
dinos3's Avatar
Datum registracije: Jan 2012
Postovi: 940
Hvala za info
Bio jučer kod njih, u roku 2 sata promjenili bateriju.
Huawei P20 Pro- 29 eura
dinos3 je offline   Reply With Quote
Staro 22.12.2023., 12:38   #5450
locks
Lokacija: Vukovar
Postovi: 3,603
Autor dinos3 Pregled postova
Hvala za info
21€ za P30, stvarno jeftino....
Staro 22.12.2023., 12:47   #5451
hash
Postovi: 1,431
Mislim da je bilo rijeci u temi kako se gube IPXX certifikati, konkretno vodootpornost. Pitati, provjeriti, ne sjecam se detalja.
Staro 19.01.2024., 12:38   #5452
locks
Lokacija: Vukovar
Postovi: 3,603
Ovog puta ću pohvaliti Insignum. Prošli puta su mi iz nekog razloga više naplatili izmjenu baterije na P30. Ovog puta 21€ kako je i navedeno u promociji. Sve je bilo odrađeno za 4 dana. Bez troškova slanja i dostave. Svaka čast.
Staro 20.01.2024., 13:03   #5453
luka_os
Datum registracije: Mar 2009
Lokacija: osijek
Postovi: 86
4 god imam p30pro sa orginal baterijom koja traje do 6h surfanja. Koliko vama traje kad ju toliko cesto mijenjate?
luka_os je offline   Reply With Quote
Staro 20.01.2024., 13:14   #5454
locks
Lokacija: Vukovar
Postovi: 3,603
Ovo je drugi P30, star 4 godine.
Staro 26.01.2024., 16:26   #5455
Tualatin
Postovi: 441
krivo
Staro 26.01.2024., 16:35   #5456
domy_os
domy_os's Avatar
Postovi: 18,853
Tko ima kinesku P30 ili Mate 20 seriju, uskoro može očekivati upgrade na HarmonyOS 4. Pet godina stari modeli još uvijek dobivaju upgrade.
https://www.huaweicentral.com/huawei...ry-2024-patch/
Zadnje izmijenjeno od: domy_os. 26.01.2024. u 16:42.
Staro 29.01.2024., 14:49   #5457
Tualatin
Postovi: 441
Dobio sam Nova 10 SE na poklon, jel zna netko kako stavit Harmony OS na njega?
Staro 29.01.2024., 21:48   #5458
Star Fox
Datum registracije: Jan 2024
Postovi: 147
Autor Tualatin Pregled postova
Moraš staviti na My Huawei App regiju Hong Kong ili Kinu
Star Fox je offline   Reply With Quote
Staro 30.01.2024., 00:34   #5459
Tualatin
Postovi: 441
Probao sam. Neće. Samo mi vuče emui update. Pokušao sam i preko VPNa ista stvar.
Staro 30.01.2024., 19:13   #5460
Tualatin
Postovi: 441
Skinuo rom za Nova 10 SE Harmony os 2 međutim kod verifikacije mi izbaci system error.
