#1862 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,725
#1863 |
Lokacija: Zabok
Postovi: 3,419
Ekipica, jel zna netko zašto kod nas nema Kingston HyperX (non-RGB) DDR4 kitova od 64/128GB? Slažem home workstation za virtualizaciju pa bih trebao nakrcati više memorije. Što uopće gledati, a da je stabilno u tom kapacitetu? Za divno čudo ima ih 1x32, što je isto opcija, ali bih rađe u kitu . |
#1864 | |
Lokacija: Zagreb, Črnomerec
Postovi: 2,678
Nisam siguran ali moguće je da search radiš sa hyperX uključenim, a tu marku je kingston prodao prije par godina ako se ne varam. Traži kingston fury 2x32, ima ih masa. |
#1866 | ||
DIY DILETANT
Postovi: 3,725
#1868 |
Prvoklasni Krkan
Postovi: 5,394
Mislim da sam našao zamjenu za svoj 3600 ![]() Disclaimer: Ništa za nas jarane iz EU izgleda: AMD is announcing the Ryzen 5 5600X3D -- except the launch is being handled entirely by Microcenter, including distribution of news, press releases, review samples, and handling of the product. The R5 5600X3D is a peculiar launch: It will be exclusive to Microcenter and, from what the retailer told us, it will be in-store only. Supply is expected to last maximally 3-6 months. The 5600X3D is likely the final AM4 chip that will ever launch, technically extending the platform's life into 2023. |
#1869 |
Postovi: 8,566
Imam 5900X viška, ako stvarno tražiš zamjenu za svoj aktualni CPU. ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#1870 |
Prvoklasni Krkan
Postovi: 5,394
A to mi je kao da kupim kombi ili kamiončić za đir do grada. Ali čisto da znam šibni mi cijenu na PM, ako već nisi oglasio na tržnici. Ovaj 5600x3d bi mi bio relativno napet za 250ak€, ali inače sam razmišljanja kao Mamutarka, radije ću promjeniti sve. Npr pređem na Zen5 i opet sam miran 4-5godina (trenutnu konfu imam 4g, grafu ne računam). |
#1871 | |
Postovi: 7,706
Ja još neću preći na AM5 dok ne izađe novi modeli CPU sa doradom. Jedina mana preskupa cijena ploče. |
#1872 |
..starija garda
Postovi: 3,281
Ma kakvi disco, ne postoji overkill, r9 5900 ja više dozivljavam kao neku bmw 5icu, dok ti je r5 2600 danas u toj usporedbi više kao renault clio.. Overkill može biti samo cijena, iako je i to relativno.. ljudi ne vole trošiti na komp, al ja ti na to gledam ako koristis puno i raznovrsno pc, svakodnevno jel, neka ti ne bude žao dati malo više.. uštediti se može na drugim stvarima, na kojoj kavi ili cevapima kroz mjesec i to je to.. nisu te cifre za taj proc toliko visoke danas kad pogledaš kroz prizmu vremena i načina korištenja.. Ako doslovno ga malo koristis i to samo za "dir do grada", tipa surfanje ili gledanje filmova, onda ti ne treba ni taj r5.. ..ali cim sepočnu palit igre i druge stvari, naravno da je feeling uvjek bolji na novijem i jačem i tu nema dileme da bi bio zadovoljniji svaki dan s bmwom bio to samo djir do grada ili put do vladivostoka i nazad.. Problem s tim auto usporedbama je sto bmw ili renault, nisu jeftine stvari ni za kupit ni za održavati i to ljudi s razlogom razbijaju glavu što da rade.. Procesor od ca 250 eur je daleko od nekog takvog iznosa , a život ljudima kojima svaki dan bar 3-4 sata provedu za kompom čini puno ljepšim ![]()
#1873 |
Prvoklasni Krkan
Postovi: 5,394
Ja imam 3600, ne 2600. Ma ja se igram i tu i tamo prekodiram neš sa Handbrakeom. Većinom prduckam po forumima i YT. I kod mene je problem kao kod Mladena, iz principa neću preplatit nešto što mi ne treba. A taj mali 5600x3d bi pretpostavljam bio super za igre, premda ja vj ne bi osjetio neku razliku sa svojim 1080/60 monitorom. Monitor bi trebao prvo promjeniti, a dok se to desi (kako sam krenuo), eto nama i zen5. ![]() Nego i taj potez sa ekskluzivom za amere, i to samo za 1 dućan i to samo za fizičku kupnju u dućanu....WTF?! EDIT: Čitam malo komentare na techpowerupu i vele neki da se da naći 5800x3d za 240$, e pa u usporedbi sa time, ovaj mališan je jako skup za 230$. Ali pričekajmo recenziju US Stiva. Pretpostavljam da će biti za mrvu sporiji od R5 7600.Zadnje izmijenjeno od: Disco. 30.06.2023. u 21:28. |
#1874 |
Postovi: 4,475
Nema valjda puno tog "škarta" od 5800X3D sa par neispravnih jezgri, pa to neš kaj ima ide tam kam ide...bez veze, ali bit će popularan s obzirom da je rijedak i debelo neisplativ. IMO tak brzi gaming procesori su za ljude kaj žele ray tracing na skupim grafama pa to jedno vuče drugo uz monitore sa puno herca...ray tracing je CPU zahtjevan za popizdit. Skroz sam odhebao ray tracing i jednostavno ga ugasim u bilo kojoj igri, a ovaj ryzen 5700X tjera Battlefield 2042 128 mape bez pol frke na 120 i više fpsa, i to je procesorski najzahtjevnije kaj igram. Za sve ostalo dobar je CPU ako daje više od 60 fpsa IMO. A sobzirom da sad svakih par godina lete nove platforme nemam motiva ulagati novce...vratili smo se u vremena kad si kupil PC i čim si izašel i dućana postao je stara kanta. Tak da umjereno...tješim samog sebe ![]() |
#1875 |
..starija garda
Postovi: 3,281
X3d se osjeti manje nego obicni.. Niži takt.. Ima smisla nama običnom puku samo u igrama i to ajmo reći ako imaš jaku grafu i kako kaze Mladen uz RT i sl.
#1876 |
Lokacija: Zabok
Postovi: 3,419
Eh, da si prije rekao ... jučer ga naručio. Jel se smije znati cijena? Za sad:
Ryzen bude zamjena za Xeon x5680 koji je do sad bio u konfi sa 48GB rama. Gore ide Fedora workstation, vagrant i kvm. Proc budem undervoltal kroz PBO. Zadnje izmijenjeno od: stef. 01.07.2023. u 00:22. |
#1877 | |
Dobro je sve.
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,525
Sent from my SM-G985F using Tapatalk |
#1879 |
Datum registracije: Feb 2021
Lokacija: TRPI
Postovi: 456
5600X3D je vjerovatno nastao od 5800X3D kojemu ne rade 2 jezgre, nakon duzeg vremena se nakupio određeni broj procesora te su napravili ugovor sa Micro Centrom da ih prodaju, tako su mogli zavrsiti i u Oem racunalima jer je mali broj primjeraka. |
#1882 |
Datum registracije: Dec 2022
Lokacija: Mordor
Postovi: 78
Trenutno njihov TOP model Thermalright Frost Spirit 140 Ili mrvicu slabiji Thermalright Peerless Assassin 120 SE ARGB Izašao je nedugo i nasljednik Peerless Assassina zvan Thermalright Phantom Spirit sa jednom toplovodnom cijevi više i sa hlađenjem u rangu ovog iznad navedenog Frost Spirit modela ali ga još nema po EU ili tu i tamo ako bude koji je cijena neisplativa. Ovdje ti je recenzija gdje možeš vidjeti performanse sva 3 modela u duelu protiv ostatka konkurencije |
#1883 |
Datum registracije: Sep 2019
Lokacija: Mostar
Postovi: 364
#1884 |
Lokacija: Zd
Postovi: 4,761
#1885 |
Lokacija: Mordor
Postovi: 78
To hlađenje je jedno od najgorih na tržištu, bučno ko raketa a i pumpa im brzo prozuji. Cijena mu je skroz fulana i precijenjena što novih gdje je puno bolja konkurencija za iste pare, pa do ove polovne opcije za 60e šta ne vrijedi, em kaj su ovi zračnjaci za 40e gore u rangu tih performansi a puno tiši i jeftiniji i nemaju rizik da procure |
#1886 | |
Lokacija: Zd
Postovi: 4,761
#1888 |
Postovi: 2,327
Ima netko na forumu 5800x3d proc? Zanima me dal je temp 90c normalna u cinebenchu r23? Ono kaj je cudno da proc boosta sve jezgre na 4500 Mhz pri toj temperaturi bez pol frke i tak drzi stalno. Cooler je Dark Rock 4 Poslano sa mog REA-NX9 koristeći Tapatalk
#1889 | |
Datum registracije: Apr 2015
Postovi: 16
Iman ga ja. Meni amo rec bude oko 82-83 temp sad kad je lito. (Ok 26 u kuci prosjek). Peerless Assasin 120 cooler. Ono sta mi je skroz cudno kod tvoga je da drzi 4500 MHz jer on na oko 78-80 pocinje vec downclockat? Cime gledas takt? Ako koristis HWinfo64 gledaj effective clock. I udri mu Curve optimizer da spustis temperature (kreni sa -30 pa odvriti par testova sa y-cruncher, OCCT etc.. da vidis jel koji core crasha) Zadnje izmijenjeno od: Tehpowa. 17.09.2023. u 20:57. |
#1890 |
Postovi: 2,327
Curve optimizer -30 stavljen u biosu. Temp manje za 15c a boosta vise. Lol. Predobra stvar. Sve ostalo na defaultu u biosu. Isprobao sa cinebenchom i u igrama i ne rusi se ništa. Poslano sa mog REA-NX9 koristeći Tapatalk
