Staro 23.05.2023., 20:34   #1381
Postovi: 8,656
Autor ansha Pregled postova
Mozda, al svakako ne pomaze ni to sta 7900 XTX nije ni blizu 4090-ki, kao ni FSR DLSS-u....
Istina, ali nije baš toliko daleko kak se predstavlja, jer RX 7900 XTX je kakvih 15% do 20% slabija od RTX 4090, dok nudi ray-tracing performanse u rangu RTX 3090 (Ti) modela.
Kaj se FSR priče tiče, ko zna, možda i to poslože kak spada ...
FSR 3 will have a Frame Generation Ratio of up to 4 interpolated frames which means for each real frame, the technology can generate up to 4 interpolated frames. If FSR 3 does allow users or devs to modify the frame generation beyond 1 interpolated frame, then it would be interesting to see if the resultant image quality is good enough and pleasing to gamers or if it turns out to be a very broken mess in its first few months too. Besides this, it is also reported that AMD FSR 3 "FiedlityFX Super Resolution 3" might be integrated on the driver side. AMD has yet to officially release FSR 3 and since GDC 2023
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750
Staro 23.05.2023., 20:44   #1382
Mladenxy
Mladenxy's Avatar
Postovi: 4,510
Kad kažem da je DLSS i do neke mjere FSR super onda mislim na nas sirotinju koji kupujemo GPU od 400$. Korištenje tih tehologija na GPU od 1200 eura i 1800eura je udarac na ego. Ono pokreneš Cyberpunk na max RT i imaš 24 fpsa bez upscalinga i da ti je svaki treći frejm lažni a platil si grafetinu 1800 jureka ili ovaj jeftini AMD 1200 eura, ali sobzirom da je AMD jeftin onda možeš i pričekati FSR 3.0 koju godinu da ga slože...taman dok ne izađe nova generacija GPU-a.
Složil sam križ 2x2 da se branim od takvog marketinga.
Staro 23.05.2023., 20:50   #1383
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,477
Sada sam pogledao HU recenziju i baš ih dobro oprao i vidim da otvoreno traži ljude da bojkotiraju ovu skalameriju. I vidi se da će doći na naplatu ta 128bit sabirnica, a i samo 8 stazica za PCIe.
Nadam se da će 7600 biti brža i jeftinija, ali slabo će to biti ako bude samo 8gb model.
Slobodno me dodajte na PSN
Staro 23.05.2023., 20:52   #1384
Postovi: 8,656
Isto bude dočekana na nož, jedino, ako za RX 7600 XT slože 16GB, ali opet bude to ko i RTX 4060 (Ti) 16GB, sve ostalo je preslabo da bi ta količina memorije imala efekt.
Staro 23.05.2023., 21:16   #1385
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,536
90% populacije kad vidi ovu grafu za ove pare uzima ,platezna moc/glupost/neznanje ili samo cista nebriga tih ljudi je pobjeda koju nvidia odavno koristi .
Ostalih nebitnih 10% se grci i zgrazava po interljnjetu a za godinu dana ce je uzet polovnu jer nema se a mora se imat bar nesto.
Tako da nista novo nista novo ,svit se i dalje okrece a koznati novu jaknu obleće.
Sent from my SM-G985F using Tapatalk
Staro 23.05.2023., 22:02   #1386
Postovi: 8,656
JayzTwoCents now deleted RTX 4060 Ti review
StručLJak der8auer također misli da je ovo sasvim OK kartica, tak da ajde, sad je bar svima jasno tko recenzira (GN i HUB), a tko reklamira.
Staro 23.05.2023., 22:04   #1387
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,593
nastavno na iznad
Staro 23.05.2023., 22:04   #1388
Postovi: 8,656
Lik je prodana duša odavno, tak da nek sad ima ovakve reakcije.
Staro 23.05.2023., 22:04   #1389
Dr. Strange
Datum registracije: Aug 2020
Postovi: 900
https://imgur.com/a/fhsFq9F
Najjača grafička na tržištu nije sposobna ni u 60 FPS-a vrtiti igru sa uključenim RT-om, kakav veliki LoL. A ove fejk frejmove u DLSS 3.0 neću ni spominjati, originalni DLSS kojeg osobno ne preferiram je svemirski brod jer donosi stvarni boost i poboljšanje latencije, dok ovi lažni uglavnom dobiješ samo sirove brojke veće, a experience i ne toliko.
Staro 23.05.2023., 22:14   #1390
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,902
https://www.gpucheck.com/compare-mul...core-i9-10900k
nije rtx 4060 ti loša samo ima krivo ime,možda se sa serijom 5 vrate na stare staze,rtx 3060 ti je brža od rtx 2080, rtx 4070 je trebala bit/se trebala zvat 4060 ti i bit po perfmormansama ko rtx 3080,rtx 4060 je trebala imat 10 rama,4060 ti 12,4070/ti 16,4080 20 i rtx 4090 kolko sad ima.
rtx 4060 ti sa 16 će bit isto ko rtx 3060 sa 8 ili 16.
Staro 23.05.2023., 22:19   #1391
Postovi: 8,656
Na kraju je ispalo točno onak kak smo komentirali i nemre biti drugačije kad koriste dno-dna mobilne čipove po suludim mainstream cijenama.
Žalosna je cjelokupna situacija, a AMD i nVidia pripremaju 300$ - 350$ ili još skuplje RX 7600 i RTX 4060 verzije koje budu po svemu sudeći u rangu RX 6700 (XT) i RTX 3070 (Ti) modela.
Staro 23.05.2023., 22:23   #1392
Dr. Strange
Postovi: 900
AMD je imao izvrsnu priliku zapapriti Nvidiji jer im je srednji rang teška koma, no Lisu zaboli ona stvar za desktop GPU tržište, odlučili su slijediti Nvidiu i kupit njihove ostatke, ako išta ostane, šteta, a Intel se još traži, koma.
Staro 23.05.2023., 22:31   #1393
Postovi: 8,656
Tak svejedno, jer ih ionak nije vrijedno kupiti, a uz GN i HUB, KitGuru su također jedni od rijetkih i iskrenih koji su preporučili izbjegavanje u širokom luku.
Staro 23.05.2023., 22:34   #1394
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Autor Dr. Strange Pregled postova
Ja pretpostavljam da im nvidia diktira sta mogu i po kojoj cijeni...
Staro 23.05.2023., 22:36   #1395
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Nece ju ljudi izbjegavat jer nece biti alternative, kartica prosle generacije je sve manje a uskoro ih nece biti...
Staro 23.05.2023., 22:37   #1396
Postovi: 8,656
Kak ne, postoji alternativa ne kupiti išta, jer nisu (loše) igre i (skupe) grafičke kartice od životne važnosti.
Posebice kad je riječ o ovim tzv. budžet rješenjima koja nisu ništa bolja od prethodne generacije.
Jedino pozitivno u svemu ovome je da su sad svi plaćenici fino otkrili sa svojim "recenzijama".
Staro 23.05.2023., 22:48   #1397
Mladenxy
Mladenxy's Avatar
Postovi: 4,510
I kad pogledaš gameplay video od te igre i da već sad prije izlaska košta 27 eura sve ti je jasno. Drlog epskih razmjera.
Staro 23.05.2023., 22:58   #1398
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Vecina ljudi koji kupuju gaming kompove ne prate hardware ko mi, oni kazu budget je taj i taj slozi mi nesto.
Ovo je 1080p kartica i na toj rezoluciji je izjednacena sa rtx 3070, nesto je jeftinija, dosta manje trosi i nudi dlss3.
Nije to nista tragicno i nisu vecina placenici nego je vecina recenzija realna, kartica je osrednji release, a ovo dramljenje od strane nekih je cisti senzacionalizam i clickbaiting...
Staro 23.05.2023., 23:06   #1399
Postovi: 8,656
E jebiga, ali vidiš i sam da jedni naprave kao i svaki put detaljni osvrt od 30min, dok drugi snime PR video od par minuta i to je to. Jasno da budu ljudi poslušali takve i kupili kaj god im u dućanu slože. Većina ovih pozitivnih recenzija je sve na istu foru, svi redom ponavaljuju ono kaj im piše u press-kit materijalu, tak su svi fino sinkronizirani, a "recenzija" im nema veze s vezom. Kartica je bazirana na razvodnjenom mobilnom čipu, a izdana je samo reda-radi, jer nVidiji ovo sigurno ne treba da preživi kao firma. Uostalom, ono kaj smo pričali, izuzev RTX 4090 cijela serija je čušpajz. JayzTwoCents (koji je svoj video obrisal samo da mu ne kvari JubiTo statistiku i analitiku, a ne, jer ga briga kaj ljudi misle) i sl. su sad fino dobili porciju jezikove juhe od vlastitih fanova, mada sumnjam da ih previše dira, jer za razliku od HUB-a neće doći na nVidijinu crnu listu zbog toga, jer ne pričaju dovoljno o RT i DLSS mogućnostima. Odavno su sve te i takve recenzije zapravo plaćene reklame i onda kad se nađe GN, HUB, KitGuru, ComputerBase i sl., onda je u njima problem, jer svi ostali pričaju drukčiju (PR) priču.
Staro 23.05.2023., 23:12   #1400
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,712
A bilo je npr. Ati 9600 koja je bila jednaka ili sporija od Ati 9500 prethodna serija...bilo je još toga ali ovo mi prvo pada na pamet.
Pa i ne baš, 9700 i 9500 su bile high end kartice (9500 je isto baziran na 9700 čipu), 9600 nije nikad bio nasljednik 9500 nego nov proizvod za drukčiji price segment.
Autor Disco Pregled postova
Pa i neće baš, vidi ovdje:
AMD prihvaća igru i prodaje šrot. Ovo će bit ko 6600XT
Gle jedno je reć da su korisnici uglavnom neznalice i da kupuju po savjetu drugih, to je neosporno. Ali reć da je grafa koja je jednako brza kao prethodnik (3060Ti) "osrednji release", to je već malo previše. Što je onda po tebi loš release, da bude sporija od prethodnika?
Staro 23.05.2023., 23:18   #1401
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Vecina recenzija nije pozitivna nego je grafa ocijenjena osrednjom, u kontekstu novog normalnog sigurno nije tragicna kakvom je neki pokusavaju prikazati.
Ljudi su razocarani jer nema velikog napretka medju generacijama tj. za slicno novaca ko prije, sada se dobije malo brzu grafu. Al to je tako..
Sutra ce doci 7600 i ona ce isto biti razocaranje, to je vec poznato, al sta ce mi recenzije koje kazu da nista ne kupujem, kakve koristi od toga?
Staro 23.05.2023., 23:22   #1402
Postovi: 8,656
Evo, ja prvi "vjerujem" da JayzTwoCents ima najbolje namjere kad "recenzira" neki komad hardvera. Isto kak sam mu vjeroval kad je kad je dva-tri mjeseca prije RTX 4090 recenzije pričal da to ne bude još godinu dana na tržištu, dok je istovremeno ljude nazival idiJotima, ako ne kupe RTX 3000 seriju kojoj je cijena padala na dnevnoj razini. I nakon toga se raspal cijeli kripto, eVGA povukla s GPU tržišta. Majko Isusova, pa taj i takvi su još čak i gori od Linusa koji je sponzoriran od svih živih, glavno da idu pare. Ne kužim, ti onda hoćeš da se samo pozitivne stvari pričaju i da sve bude fino i krasno, jer nažalost tak stvari ne funkcioniraju. To je u rangu Elona Muska i sl. koji lažu kad zinu, pa cijelu stvar prezentiraju kao nešto pozitivno i hvalevrijedno, s tim da je on taj koji sve zna, otkril je AI i Internet, a svi koji se ne slažu s njim - sigurno lažu i samo su ljubomorni. Mislim, recenzije hardvera (ili bilo kakvog komada tehnike zapravo) su jednostavne za krajnje korisnike, u slučaju da valja - onda valja, a u slučaju da ne valja ili predstavlja loš izbor prilikom kupnje, onda se to fino naglasi i voljno. I to je točno kaj su RTX 4060 modeli i sutrašnji RX 7600.
Staro 23.05.2023., 23:25   #1403
Exy
Exy's Avatar
Postovi: 2,712
Po tvojem ispada da kakav god šrot bio, to se mora kupovat
Ne govore da se ne kupuje ništa nego da je value užasno loš. Pa onda pošto je kartica krš nećeš čut da "ništa ne kupuješ" nego da umjesto tog krša možeš uzet stariju generaciju rabljenu npr. 3060ti pa dobiješ isto uz uštedu. Ili uzmeš rabljeni 3080 za iste pare i imaš bolje od tog 128 bitnog krša. Ili uzmeš čuvenog AMD-a recimo 6700XT koji bi lako mogao kroz neko vrijeme ispast bolja opcija zbog više RAM-a iako nema dlss3 i nvidia reputaciju kod gaymera. Znači svašta možeš opet kupit a opet nazoveš stvari pravim imenom.
Ako kreneš u priče o dlssu3 i o jeftinijoj struji mi prepisuješ nvidia reklamne grafike a to mi zbilja ne treba.
Staro 23.05.2023., 23:25   #1404
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Autor Exy Pregled postova
To je prvenstveno 1080p grafa (zasto moramo davat preko 400€ za 1080p u 2023. godini?) i u toj rezoluciji je ipak 8-10% brza od 3060 Ti, dosta manje trosi i podrzava FG, neki mali napredak imamo
Release je osrednji u kontekstu cijele ove nove generacije grafa, sve su ili jako skupe ili nude nikakav napredak u odnosu na proslu generaciju.
Uostalom, pitajte AMD sta im je rekao koznati da ce se dogoditi ako se probaju igrat trzisne utakmice
I zadnje i najvaznije, imamo konzole, PS5 novi je 450€....
Staro 23.05.2023., 23:26   #1405
Mladenxy
Mladenxy's Avatar
Postovi: 4,510
Cijena im je bila podjednaka cc 200$ ATI 9500Pro i godinu dana kasnije ATI 9600Pro
s time da je 9600pro bila i sporija od starije serije
https://www.tomshardware.com/reviews...ati,618-4.html
Staro 23.05.2023., 23:27   #1406
Postovi: 8,656
Malo previše se oslanjaš na te nVidia PR fore, isto kak se Intel godinama oslanjal na svoje, pa su sad tu di jesu.
Staro 23.05.2023., 23:29   #1407
Mladenxy
Mladenxy's Avatar
Postovi: 4,510
Jako skupo sobzirom da ne pokriva Microsoft igre, PC igre i Nitendo emulator. Ta konzola je 1/3 gaminga
Staro 23.05.2023., 23:31   #1408
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Sta fali nizoj potrosnji? U najmanju ruku imat ces manju buku...
A DLSS3 je super, to je cinjenica. AI kerefeke su buducnost 3D-a, to je bar jasno, to je i razlog zasto nvidia ima AMD u saci. Brute force pristup je krajnje idiotski...
Staro 23.05.2023., 23:32   #1409
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Onda kupuj grafe i ne kmeci
Staro 23.05.2023., 23:33   #1410
Postovi: 8,656
Ma sve je super, a još kad se skine bočna stranica, to je to, milina od kartice, čisti plug'n'play uz GeForce prestiž, samo se malo poslože boje i vozi Miško.
Nadam se da se zajebavaš, jer 400$ budžet gaming RTX 4060 sljedeće godine više ni 1080p neće moći vrtjeti kak spada bez DLSS-a.
I u tome je problem s ovim recenzijama koje ljudima pričaju bajke kak je kartica sasvim OK.
