#5821 | ||
Postovi: 8,546
![]() Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#5822 |
Lokacija: rijeka
Postovi: 3,882
ja sam ovo zapamtio Digital Linear Voltage Regulator (DLVR) is an Intel technology that reportedly has the potential to reduce power consumption by up to 25%. Although the technology was present on pre-release Raptor Lake CPUs, Intel disabled it on retail hardware. Per MLID, if DLVR makes its way into RPL-R, it could give Intel some much-needed power headroom to push performance even further 25% manja potrošnja ne znači 25% viši takt,ćemo vidjet,mislim da 13900k/s neće moć iznad 6,5 ghz jer da bude 25% porat performansi na 6 ghz bi značilo 7,5 ghz takt. |
#5823 | |||
Postovi: 8,546
Da, DLVR je nastavak FIVR-a koji je implementiran u Haswell eri, ali ga do Skylakea više nije bilo, tak da lako moguće da Intel opet implementira takvo rješenje. 10nm desktop Ice Lake je trebal vratiti FIVR, a znamo kak je to završilo. Citiraj:
EDIT:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 24.03.2023. u 11:39. |
#5824 | |
Postovi: 8,546
Novi planovi koji će se bez ikakve dvojbe obestiniti uz minimalne odgode i potencijalna otkazivanja kompletnih proizvodnih linija, jer Intel sve ovo zapravo već ima spremno. ![]() ![]() Citiraj:
#5826 |
Datum registracije: Aug 2020
Postovi: 899
Just wait. |
#5827 | ||
Postovi: 8,546
![]() Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 29.03.2023. u 19:31. |
#5828 | ||
Postovi: 8,546
Intel exiting the server business selling to MiTAC ![]() Citiraj:
#5829 | ||||
Postovi: 8,546
Na serverskom polju i dalje sve ide po planu i programu, dok se za desktop možda čak i posloži slabiji Meteor Lake CPU, tak da im baš ne propadnu sve jezgre inicijalno namijenjene isključivo mobilnom izdanju. ![]() Citiraj:
#5830 |
Postovi: 899
https://wccftech.com/intel-posts-its...-sinking-ship/ Ouch, to je rezultat svih tih promašaja od proizvoda, odgoda, puno obečanja i pričanja, malo dela itd. |
#5831 | |
Postovi: 8,546
IMHO sve je to samo manji dio unaprijed pomno zacrtanog, ali itekako većeg procesa kodnog naziva P.L.A.N._i_P.R.O.G.R.A.M. ![]() , pa iako se čini da je firma u krugovima stručLJaka poznata po rekordnim zaradama u nekoj vrsti financijske nedaće - ne treba vjerovati ovim zajedljivim bombastičnim naslovima diljem Interneta, jer Intel samo čeka pravi trenutak da se iz sjene kao narodCki heroj vrate kak i priliči, te obrišu pod sa svom zapravo nebitnom konkurencijom. Možda se čini da je Intel kao firma lagano izgubila kompas, ali to je zapravo njihova strategija iskovana još tamo davne 2017., a prvi plodovi se upravo naziru, jer neprijatelj nikad ne spava i uvijek treba očekivati neočekivano. I onda kad se najmanje nadamo, Intel će kad za to stigne pravi trenutak, svima pokazati i dokazati tko je najboljiJi ikad u povijesti, samo treba imati strpljenja, jer gdje ima volje ima i načina.![]() ![]() Citiraj:
#5832 |
Postovi: 899
Možemo mi mrziti Jensena, no on je direktor svemira za ove mamlaze iz Intela. |
#5833 | ||
Postovi: 8,546
Da, nije uopće sporno, a kak je krenulo još bude Intel divizija unutar nVidije. EDIT:Jebeno, čak i kad stjuniraju brojke izgleda loše, a kamoli da stvari prikažu kak spada. ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 28.04.2023. u 12:11. |
#5834 |
Postovi: 899
#5835 |
Prvoklasni Krkan
Postovi: 5,383
#5836 |
Postovi: 8,546
Intel vode PR, marketing i ekonomisti, dok im se aktualni direktor sjeća kak je to bilo biti inženjer prije 30 godina. nVidia i AMD su pod palicom konkretnih tehnički potkovanih ljudi.
#5837 |
Postovi: 899
To se i vidi po rezultatima, Intelu je nekad moglo prolaziti oslanjanje na marketinški tim, blaćenje AMD-a itd, no s probuđenim AMD-om to više ne mogu, sada se moraju osloniti na inženjerski tim, a to nije lako, traži vremena kojeg nestaje jer AMD ne usporava. |
#5838 | ||
Postovi: 8,546
Nastavno na temu odličnog marketinga, Intel stručLJaci sve skupa pojačavaju na 11 i nema nikakve greške u tom naumu. ![]() Citiraj:
#5839 |
Postovi: 899
Kakav je A380 u usporedbi s radeon 680m? MTL iGPU će kako god imati dobar boost u performansama, no i RDNA 2 je daleko ispred njihovog trenutnog rješenja, a kamoli RDNA 3. |
#5840 |
Postovi: 8,546
U najboljem slučaju Intel A380 i Radeon 680M iGPU su tu negdje, ali zajeb je u tome da A380 svakak treba ReBAR, makar kak god se okrene RDNA 3 780M iGPU je sasvim druga galaksija u odnosu na A380.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 01.05.2023. u 18:48. |
#5841 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,718
Ajebemti pa šta je i theregister spao na klikbejtanje. Šta sve neću doživit.... |
#5842 | |
Postovi: 8,546
U međuvremenu je dodatno potvrđeno. Ostaje za vidjeti kaj točno budu složili za Intel Core Ultra Turbo Mega Extra Pro Super Meteor Lake.![]() Citiraj:
#5844 | |
Postovi: 8,546
Intel "Emerald Rapids" doubles down on on-die caches, divests on chiplets ![]() Citiraj:
#5845 |
Lokacija: rijeka
Postovi: 3,882
#5846 | ||
Postovi: 8,546
Novi otkazi i rezanja u Intelu, ko zna možda bude der8auer za koji dan imal kakav "nekaj ne štima s AMD proizvodima" video. ![]() Citiraj:
#5847 | ||
Postovi: 8,546
P.L.A.N._i_P.R.O.G.R.A.M. ![]() ![]() Citiraj:
Za razliku od Intelovih CPU + GPU pokušaja, AMD MI300 i nVidia Grace Hopper su konkretno realizirani i idu u pogon tijekom druge polovice ove godine, tako da će Intel kad-tad morati nadoknaditi još veću razliku. Čekamo der8aurea da ublaži udarac s nekim "tehničkim osvrtom". ![]()
#5849 |
Postovi: 8,546
Da, koga god da nađu kao zamjenu za aktualno vodstvo, jer očito je da im ne ide, a oni i dalje samo pričaju u prazno. Sad više i ne pokušavaju skrivati da zaostaju u svim segmentima.
