Povratak   PC Ekspert Forum > Računala > Kriptovalute
Staro 16.05.2023., 20:28   #181
Neo-ST
Neo-ST's Avatar
Postovi: 8,590
Nakon nenamjernog curenja podataka o korisnicima Ledger.com stranice, stiže još jedan fail, ali ovaj puta namjeran.
https://twitter.com/Ledger/status/1658458714771169282
https://twitter.com/Mudit__Gupta/sta...68265687556097
https://www.reddit.com/r/CryptoCurre...ing_to_happen/
Staro 16.05.2023., 20:47   #182
Postovi: 8,565
  • In a nutshell, it’s an ID-based key recovery service that backs up users’ seed phrases. To use the service, users must provide a passport or national identity card to confirm their identity.
  • While this service requires users to opt-in and pay a $9.99 monthly fee, some are concerned that this could even pose a security risk for those who don't opt in.
Jao, ovo su već malo žešće gluposti i to u rangu LastPass pizdarija gdje se isto tražilo/prisililo korisnike na plaćanje "sigurnosnog rješenja", samo da bi sve skupa kasnije u potpunosti hakirali.
Staro 16.05.2023., 21:42   #183
Neo-ST
Neo-ST's Avatar
Postovi: 8,590
Staro 18.05.2023., 19:10   #184
AndroiOs
AndroiOs's Avatar
Datum registracije: Jan 2018
Lokacija: KA
Postovi: 609
Nema nista sigurnije od tog ledgera neki govorili
Sad ni to ne valja...taj kripto je prevara samo takva
AndroiOs je offline   Reply With Quote
Staro 18.05.2023., 21:36   #185
Postovi: 8,565
Jebiga, kripto kao takav nije ništa kriv, ali kak to obično ide i u ovom slučaju se radi o hrpi mutnih likova koji koriste kripto kao priliku da zarade besplatne nofce i usput zajebu što više ljudi.
While answering queries about the firm's new wallet recovery service, Ledger Support sent a couple of tweets that likely did little to assuage its users' concerns, suggesting that it could make its customers' assets vulnerable in any way it wanted to, but has – thus far – not done so. "Technically speaking it is and always has been possible to write firmware that facilitates key extraction. You have always trusted Ledger not to deploy such firmware whether you knew it or not," Ledger said earlier on a now-deleted tweet. Crypto wallet maker Ledger dug itself into a deeper public relations hole on Wednesday when its support team said in a now-deleted tweet that "technically speaking it is and always has been possible to write firmware that facilitates key extraction," thus allowing the company to extract its users' keys. After erasing the tweets, Chief Technology Officer Charles Guillemet tweeted in an attempt to clarify the situation and downplay the initial tweets.
Staro 19.05.2023., 13:33   #186
Night
Lokacija: Dbk
Postovi: 1,327
To je neka stara verzija koda koliko vidim iz odgovora, u novoj verziji nema toga : https://github.com/LedgerHQ/app-boil...t_public_key.c
A ovo sa backupom recoverya je žešći idiotizam, napravili su cold wallet i onda nude uslugu koja potpuno ubija smisao cold walleta
Staro 19.05.2023., 13:41   #187
Javorko
Postovi: 144
Znači li to da ne bismo trebali kupovati Ledger HW wallet?
Recimo onaj Stax izgleda prelijepo i čini mi se dobar.
Imam 10ak valuta, 300+ eura gore i čini mi se da je vrijeme za kripto wallet.
Javorko je offline   Reply With Quote
Staro 20.05.2023., 10:54   #188
Neo-ST
Neo-ST's Avatar
Postovi: 8,590
Staro 20.05.2023., 12:12   #189
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,843
Sve jasno. Dobru si je Ledger kašu skuhao s tim recovery sustavom.
Prvo su se revno reklamirali da seed nikada ne može napustiti uređaj jer je unutar "secure element" koji je hardwareski dio. Sa novim sustavom su prvo priznali da su lagali cijelo vrijeme, a drugi im je promašaj što sve forsiraju da instaliraju taj firmware.
Da su ostavili mogućnost ažuriranja firmware-a bez tog recovery elementa, mislim da bi galama bila puno manja.
Neki zagovaraju poseban uređaj za recovery mogućnost, ali po meni su mogli samo ostaviti jedan firmware za one koji ne žele recovery i isti taj + recovery element za one koji se pretplate na recovery.
Staro 20.05.2023., 13:45   #190
dzajko
dzajko's Avatar
Lokacija: Ehhhh
Postovi: 498
Jeli update obavezan ili se moze normalno koristit i sa starim softwearom?
dzajko je offline   Reply With Quote
Staro 20.05.2023., 19:08   #191
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,843
Može se normalno koristiti.
Staro 24.05.2023., 17:04   #192
jucca
jucca's Avatar
Postovi: 1,708
Ekipa, sta se sa Ledgerom dogadja, dogodilo?
Vidim po Twitteru da ga ljudi "bacaju".
https://twitter.com/austin_bbytes/st...0ydP48JUw&s=19
Sent from my SM-S908B using Tapatalk
Staro 24.05.2023., 17:06   #193
Postovi: 8,565
Staro 24.05.2023., 19:14   #194
jucca
jucca's Avatar
Postovi: 1,708
Krasni momci
Ja sam zd dvoumio izmedju Ledgera, i Trezor Model T, pa sam na kraju ipak Trezor uzeo.
Staro 24.05.2023., 19:45   #195
AndroiOs
AndroiOs's Avatar
Lokacija: KA
Postovi: 609
Autor jucca Pregled postova
Krasni momci
Cool..drugo ime, isto sranje..
Staro 24.05.2023., 19:53   #196
PR3DA70R
PR3DA70R's Avatar
Lokacija: Yautja Prime
Postovi: 1,227
Staro 24.05.2023., 23:43   #197
Neo-ST
Neo-ST's Avatar
Postovi: 8,590
Staro 25.05.2023., 22:05   #198
jucca
jucca's Avatar
Postovi: 1,708
Autor AndroiOs Pregled postova
A bas.
Na kraju najbolje slozit komp samo za crypto.
Staro 11.12.2023., 16:32   #199
Postovi: 8,565
Friški nastavak Ledger priče ...
Sleuths have discovered a vast data harvesting operation by the world’s largest hardware wallet manufacturer, Ledger. For reasons that are difficult to comprehend, Ledger Live software transmits information about clicks, page visits, redirects, crypto transactions, page scrolls, numbers of accounts, crypto asset names, session durations, hardware device types, and firmware versions to Ledger’s analytics provider. Ledger Live is the official software for interfacing with any Ledger hardware wallet. The vast majority of PC users download this software in order to set up their hardware wallet and sign transactions.
Although Ledger Live doesn’t send private keys or recovery phrases to segment.io, it sends plenty of information about a user that could subject users to extortion attacks. Any segment.io hacker, for example, could easily identify any user with substantial crypto holdings — including timestamps of crypto activities and other terrifyingly detailed information about assets. In summary, Ledger is tracking user data, possibly for its own UI/UX workers, or to profit from resale. Luckily, users have alternatives, including tracker-free forked versions of the software, or using the hardware wallet itself without installing Ledger Live software at all.
Izvor: Protos
Staro 11.12.2023., 19:32   #200
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,761
Ja sam nedavno uzeo Tangem (v2.0), nije ni on savršen al za moje potrebe odličan...
Staro 14.12.2023., 19:58   #201
Psycho
Master Of Disaster
Psycho's Avatar
Datum registracije: Nov 2002
Postovi: 1,271
Staro 14.12.2023., 20:21   #202
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,725
karma is a bitch
koji diletanti svi po spisku na kraju Big Daddy morao intervenirati
Zadnje izmijenjeno od: kopija. 14.12.2023. u 20:35.
Staro 19.03.2024., 18:10   #203
dzajko
dzajko's Avatar
Lokacija: Ehhhh
Postovi: 498
Iman problem s ledger nano S. Dugo vremena ga nisam koristio i danas ga idem prikljuciti vidim da se nista ne događa. Nisam siguran jeli samo lcd otišao ili kompletan uređaj. Dali je netko narucivao slucajno nekakv zamjenski lcd?
Staro 19.03.2024., 18:45   #204
radi.neradi
Datum registracije: May 2023
Lokacija: Mrkopalj
Postovi: 90
provjerit cu kroz koji dan, imam viska neispravan ledger, ekran ispravan.
radi.neradi je offline   Reply With Quote
Staro 19.03.2024., 19:15   #205
dzajko
dzajko's Avatar
Lokacija: Ehhhh
Postovi: 498
Probao sam popraviti uz ledger live. Uopce mi ga ne želi prepoznati kada prikljucim usb. Probao držati tipku i onda ga priključiti međutim izbaci mi gresku 0x6984. Zatim ponovo spajao i odspajao "stick" pa mi je izbacio da mora odradit update, ali ni od toga pomoci. Sve ovo više putao probao, ali nikakvih pomaka nema.
EDIT: Mislim da je ledger "krepao". Probao na 3 razlicita racunala, više razlicitih kabela, ali niti jedno računalo ga ne prepozna kada se priključi niti sam ledger pokaziva ikakve znakove života. Tako da ce jedino rješenje očito biti narudzba novoga..
Zadnje izmijenjeno od: dzajko. 20.03.2024. u 14:48.
Staro 20.03.2024., 20:57   #206
domy_os
domy_os's Avatar
Postovi: 18,955
Koliko je realno prodavati Ledger Nano S? Nisam ga koristio jako dugo, a nije da imam neke milijune da mi treba hardware wallet.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 21.03.2024., 09:58   #207
Night
Lokacija: Dbk
Postovi: 1,327
Autor domy_os Pregled postova
Osobno ne bih nikad kupio polovni wallet jer nikad ne znaš je li manipulirano njime. I od Ledgera da dobijem otvorenu kutiju vratio bih je nazad.
Staro 22.03.2024., 14:23   #208
dinos3
Dino Saur
dinos3's Avatar
Datum registracije: Jan 2012
Postovi: 941
Ja sam svoj prodao na njuškalu http://forum.pcekspert.com/showthread.php?t=314838
Ali isto kao kolega @night nikad nebi kupovao rabljeni hardware wallet, očito ima ljudi koji bi
dinos3 je offline   Reply With Quote
Staro 22.03.2024., 14:32   #209
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,468
ima ljudi koji kupuju i polovne cipele, vjerovali il ne, tak da... svaka roba ima svpg kupca.
ja isto nebi ni nakraj pameti kupio polovni wallet.
Staro 22.03.2024., 15:55   #210
fler
These go to 11
fler's Avatar
Lokacija: Czarnia
Postovi: 1,859
Također, nema šanse.
Mislim ono, poanta je walleta sigurnost -
kupovina polovnog doslovno poništava sam koncept.
Ali gle, @domy_os,
stavi u prodaju pa vidi hoće se tko javiti.
