Povratak   PC Ekspert Forum > PC Ekspert > Članci
Staro 02.05.2023., 20:07   #1
krešo
Administrator
krešo's Avatar
Datum registracije: Sep 2002
Lokacija: PCE Lab
Postovi: 3,959
Sonos Era 100 recenzija
Testirali smo novi Sonosov zvučnik - Era 100.
krešo je offline   Reply With Quote
Staro 03.05.2023., 12:19   #2
Matijac
Matijac's Avatar
Postovi: 851
Čuje li se razlika ako je spojen samo beam i beam + 2 x era 100?
Staro 03.05.2023., 13:47   #3
krešo
Administrator
krešo's Avatar
Lokacija: PCE Lab
Postovi: 3,959
Autor Matijac Pregled postova
Ima razlike, da. Nisam imao spojena dva Era zvucnika, nego Era + One + Beam i oni zajedno ljepse ispune prostoriju zvukom. Testiram u prostoru od oko 60 kvadrata s kosim krovom (potkrovlje). Cak i kada se doda Move cuje se razlika.
Staro 03.05.2023., 20:36   #4
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,108
Era je stereo, One je mono.
Na papiru zvuči ogromna razlika.
Svrbi me da utopim bookshelfe i uzmem jedan.
Ovo je dosta bitno, prije zaletavanja
Era 100 is not supported for surrounds on a PlayBar or PlayBase.
Era 300 is not supported for surrounds on PlayBar, PlayBase or Beam Gen1.
Line in is only supported with an adapter from Sonos, via the USB-C port.
When using Era 100 or 300 as surrounds, BlueTooth and Line in are disabled.
Neither Era has an Ethernet port, but you can add one via the Sonos combo adapter.
Looks like the Era 100 and 300 do not support SonosNet. They need to connect to WiFi or Ethernet (with adapter):
PRODUCTS THAT DON’T SUPPORT THE DEDICATED SONOS WIRELESS NETWORK
The following products must either be connected to your home WiFi network in a wireless setup or connected via Ethernet, if supported.
Era 100
Era 300
Move
Roam
Roam SL
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
