E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,817
Nvidia Quadro/RTX series
Samo kratak info, prije izvjesnog vremena ubacio sam dva fantasticna nVidia produkta, low-end Quadroice bazirane na Pascalu, P400 (najslabija) verzija, puta dva. Cijenom su mi bile i vise nego pogodne, ne trose skoro nista, i ne cuju se kada ne treba. 3x mini DP, gutaju i DP, i DVI (pa samim time i HDMI), i VGA. Samo malo podataka, fotki i slicno. ![]() ![]() Code:
hashcat (v3.40) starting in benchmark mode...
* Device #1: Not a native Intel OpenCL runtime, expect massive speed loss
You can use --force to override this but do not post error reports if you do so
* Device #2: WARNING! Kernel exec timeout is not disabled, it might cause you errors of code CL_OUT_OF_RESOURCES
See the wiki on how to disable it: https://hashcat.net/wiki/doku.php?id=timeout_patch
* Device #3: WARNING! Kernel exec timeout is not disabled, it might cause you errors of code CL_OUT_OF_RESOURCES
nvmlDeviceGetPowerManagementLimit(): Not Supported
OpenCL Platform #1: Advanced Micro Devices, Inc.
* Device #1: Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz, skipped
OpenCL Platform #2: NVIDIA Corporation
* Device #2: Quadro P400, 512/2048 MB allocatable, 2MCU
* Device #3: Quadro P400, 512/2048 MB allocatable, 2MCU
Hashtype: MD4
Speed.Dev.#2.....: 2477.6 MH/s (54.07ms)
Speed.Dev.#3.....: 2537.5 MH/s (52.73ms)
Speed.Dev.#*.....: 5015.2 MH/s
Hashtype: MD5
Speed.Dev.#2.....: 1448.5 MH/s (92.54ms)
Speed.Dev.#3.....: 1484.5 MH/s (90.22ms)
Speed.Dev.#*.....: 2933.0 MH/s
Hashtype: Half MD5
Speed.Dev.#2.....: 958.8 MH/s (69.91ms)
Speed.Dev.#3.....: 979.8 MH/s (68.32ms)
Speed.Dev.#*.....: 1938.6 MH/s
Hashtype: SHA1
Speed.Dev.#2.....: 531.1 MH/s (63.08ms)
Speed.Dev.#3.....: 545.0 MH/s (61.40ms)
Speed.Dev.#*.....: 1076.1 MH/s
Hashtype: SHA256
Speed.Dev.#2.....: 206.2 MH/s (80.94ms)
Speed.Dev.#3.....: 211.6 MH/s (78.76ms)
Speed.Dev.#*.....: 417.8 MH/s
Hashtype: SHA384
Speed.Dev.#2.....: 69899.6 kH/s (59.85ms)
Speed.Dev.#3.....: 71274.8 kH/s (58.65ms)
Speed.Dev.#*.....: 141.2 MH/s
Hashtype: SHA512
Speed.Dev.#2.....: 70650.4 kH/s (59.15ms)
Speed.Dev.#3.....: 73033.5 kH/s (57.21ms)
Speed.Dev.#*.....: 143.7 MH/s
Hashtype: SHA-3(Keccak)
Speed.Dev.#2.....: 57256.0 kH/s (73.06ms)
Speed.Dev.#3.....: 58897.1 kH/s (70.92ms)
Speed.Dev.#*.....: 116.2 MH/s
Hashtype: SipHash
Speed.Dev.#2.....: 1896.7 MH/s (70.62ms)
Speed.Dev.#3.....: 1951.1 MH/s (68.53ms)
Speed.Dev.#*.....: 3847.9 MH/s
Hashtype: Skip32
Speed.Dev.#2.....: 396.0 MH/s (42.16ms)
Speed.Dev.#3.....: 421.0 MH/s (39.66ms)
Speed.Dev.#*.....: 816.9 MH/s
Hashtype: RipeMD160
Speed.Dev.#2.....: 315.9 MH/s (52.82ms)
Speed.Dev.#3.....: 320.7 MH/s (51.32ms)
Speed.Dev.#*.....: 636.5 MH/s
Hashtype: Whirlpool
Speed.Dev.#2.....: 16698.8 kH/s (125.49ms)
Speed.Dev.#3.....: 17245.2 kH/s (121.42ms)
Speed.Dev.#*.....: 33944.0 kH/s
Hashtype: GOST R 34.11-94
Speed.Dev.#2.....: 15845.2 kH/s (132.27ms)
Speed.Dev.#3.....: 16316.1 kH/s (128.31ms)
Speed.Dev.#*.....: 32161.3 kH/s
Hashtype: GOST R 34.11-2012 (Streebog) 256-bit
Speed.Dev.#2.....: 3311.2 kH/s (312.83ms)
Speed.Dev.#3.....: 3416.5 kH/s (303.09ms)
Speed.Dev.#*.....: 6727.6 kH/s
Hashtype: GOST R 34.11-2012 (Streebog) 512-bit
Speed.Dev.#2.....: 3314.6 kH/s (312.51ms)
Speed.Dev.#3.....: 3419.2 kH/s (302.86ms)
Speed.Dev.#*.....: 6733.7 kH/s
Hashtype: DES (PT = $salt, key = $pass)
Speed.Dev.#2.....: 1322.2 MH/s (50.44ms)
Speed.Dev.#3.....: 1362.6 MH/s (48.95ms)
Speed.Dev.#*.....: 2684.8 MH/s
Hashtype: 3DES (PT = $salt, key = $pass)
Speed.Dev.#2.....: 38603.4 kH/s (54.24ms)
Speed.Dev.#3.....: 39880.5 kH/s (52.38ms)
Speed.Dev.#*.....: 78483.9 kH/s
Hashtype: phpass, MD5(Wordpress), MD5(phpBB3), MD5(Joomla)
Speed.Dev.#2.....: 454.7 kH/s (70.54ms)
Speed.Dev.#3.....: 475.2 kH/s (67.92ms)
Speed.Dev.#*.....: 929.9 kH/s
Hashtype: scrypt
Speed.Dev.#2.....: 57169 H/s (17.23ms)
Speed.Dev.#3.....: 58609 H/s (16.67ms)
Speed.Dev.#*.....: 115.8 kH/s
Hashtype: PBKDF2-HMAC-MD5
Speed.Dev.#2.....: 503.0 kH/s (63.43ms)
Speed.Dev.#3.....: 518.9 kH/s (61.71ms)
Speed.Dev.#*.....: 1021.9 kH/s
Hashtype: PBKDF2-HMAC-SHA1
Speed.Dev.#2.....: 222.5 kH/s (60.58ms)
Speed.Dev.#3.....: 228.4 kH/s (58.87ms)
Speed.Dev.#*.....: 450.9 kH/s
Hashtype: PBKDF2-HMAC-SHA256
Speed.Dev.#2.....: 81696 H/s (45.39ms)
Speed.Dev.#3.....: 84643 H/s (83.97ms)
Speed.Dev.#*.....: 166.3 kH/s
Hashtype: PBKDF2-HMAC-SHA512
Speed.Dev.#2.....: 30476 H/s (62.56ms)
Speed.Dev.#3.....: 31386 H/s (60.69ms)
Speed.Dev.#*.....: 61861 H/s
Hashtype: Skype
Speed.Dev.#2.....: 851.0 MH/s (78.77ms)
Speed.Dev.#3.....: 874.4 MH/s (76.56ms)
Speed.Dev.#*.....: 1725.3 MH/s
Hashtype: WPA/WPA2
Speed.Dev.#2.....: 27359 H/s (74.44ms)
Speed.Dev.#3.....: 28183 H/s (72.29ms)
Speed.Dev.#*.....: 55542 H/s
Hashtype: IKE-PSK MD5
Speed.Dev.#2.....: 114.4 MH/s (73.16ms)
Speed.Dev.#3.....: 119.7 MH/s (69.99ms)
Speed.Dev.#*.....: 234.0 MH/s
Hashtype: IKE-PSK SHA1
Speed.Dev.#2.....: 52769.0 kH/s (78.94ms)
Speed.Dev.#3.....: 54724.6 kH/s (76.38ms)
Speed.Dev.#*.....: 107.5 MH/s
Hashtype: NetNTLMv1-VANILLA / NetNTLMv1+ESS
Speed.Dev.#2.....: 1433.4 MH/s (93.54ms)
Speed.Dev.#3.....: 1476.4 MH/s (90.77ms)
Speed.Dev.#*.....: 2909.7 MH/s
Hashtype: NetNTLMv2
Speed.Dev.#2.....: 107.6 MH/s (77.82ms)
Speed.Dev.#3.....: 110.7 MH/s (75.56ms)
Speed.Dev.#*.....: 218.4 MH/s
Hashtype: IPMI2 RAKP HMAC-SHA1
Speed.Dev.#2.....: 114.3 MH/s (73.29ms)
Speed.Dev.#3.....: 117.1 MH/s (71.48ms)
Speed.Dev.#*.....: 231.4 MH/s
Hashtype: Kerberos 5 AS-REQ Pre-Auth etype 23
Speed.Dev.#2.....: 19158.7 kH/s (54.47ms)
Speed.Dev.#3.....: 20104.2 kH/s (104.11ms)
Speed.Dev.#*.....: 39262.8 kH/s
Hashtype: Kerberos 5 TGS-REP etype 23
Speed.Dev.#2.....: 19133.2 kH/s (54.55ms)
Speed.Dev.#3.....: 20077.4 kH/s (104.26ms)
Speed.Dev.#*.....: 39210.5 kH/s
Hashtype: DNSSEC (NSEC3)
Speed.Dev.#2.....: 223.0 MH/s (74.84ms)
Speed.Dev.#3.....: 230.4 MH/s (72.31ms)
Speed.Dev.#*.....: 453.5 MH/s
Hashtype: PostgreSQL Challenge-Response Authentication (MD5)
Speed.Dev.#2.....: 389.0 MH/s (86.08ms)
Speed.Dev.#3.....: 401.2 MH/s (83.43ms)
Speed.Dev.#*.....: 790.2 MH/s
Hashtype: MySQL Challenge-Response Authentication (SHA1)
Speed.Dev.#2.....: 155.0 MH/s (53.97ms)
Speed.Dev.#3.....: 160.1 MH/s (52.12ms)
Speed.Dev.#*.....: 315.2 MH/s
Hashtype: SIP digest authentication (MD5)
Speed.Dev.#2.....: 130.1 MH/s (64.38ms)
Speed.Dev.#3.....: 134.0 MH/s (62.40ms)
Speed.Dev.#*.....: 264.1 MH/s
Hashtype: SMF > v1.1
Speed.Dev.#2.....: 453.1 MH/s (73.95ms)
Speed.Dev.#3.....: 465.4 MH/s (71.88ms)
Speed.Dev.#*.....: 918.5 MH/s
Hashtype: vBulletin < v3.8.5
Speed.Dev.#2.....: 456.2 MH/s (73.46ms)
Speed.Dev.#3.....: 469.5 MH/s (71.26ms)
Speed.Dev.#*.....: 925.7 MH/s
Hashtype: vBulletin > v3.8.5
Speed.Dev.#2.....: 316.3 MH/s (52.74ms)
Speed.Dev.#3.....: 325.3 MH/s (51.20ms)
Speed.Dev.#*.....: 641.6 MH/s
Hashtype: IPB2+, MyBB1.2+
Speed.Dev.#2.....: 327.7 MH/s (50.90ms)
Speed.Dev.#3.....: 336.2 MH/s (49.50ms)
Speed.Dev.#*.....: 663.9 MH/s
Hashtype: WBB3, Woltlab Burning Board 3
Speed.Dev.#2.....: 89235.4 kH/s (93.83ms)
Speed.Dev.#3.....: 91825.6 kH/s (91.09ms)
Speed.Dev.#*.....: 181.1 MH/s
Hashtype: OpenCart
Speed.Dev.#2.....: 140.3 MH/s (59.70ms)
Speed.Dev.#3.....: 144.1 MH/s (58.03ms)
Speed.Dev.#*.....: 284.4 MH/s
Hashtype: Joomla < 2.5.18
Speed.Dev.#2.....: 1446.5 MH/s (92.68ms)
Speed.Dev.#3.....: 1489.0 MH/s (89.97ms)
Speed.Dev.#*.....: 2935.5 MH/s
Hashtype: PHPS
Speed.Dev.#2.....: 456.7 MH/s (73.37ms)
Speed.Dev.#3.....: 470.0 MH/s (71.21ms)
Speed.Dev.#*.....: 926.7 MH/s
Hashtype: Drupal7
Speed.Dev.#2.....: 3739 H/s (67.66ms)
Speed.Dev.#3.....: 3856 H/s (65.61ms)
Speed.Dev.#*.....: 7594 H/s
Hashtype: osCommerce, xt:Commerce
Speed.Dev.#2.....: 849.4 MH/s (78.84ms)
Speed.Dev.#3.....: 873.5 MH/s (76.62ms)
Speed.Dev.#*.....: 1722.9 MH/s
Hashtype: PrestaShop
Speed.Dev.#2.....: 565.2 MH/s (59.29ms)
Speed.Dev.#3.....: 580.4 MH/s (57.65ms)
Speed.Dev.#*.....: 1145.5 MH/s
Hashtype: Django (SHA-1)
Speed.Dev.#2.....: 452.9 MH/s (73.95ms)
Speed.Dev.#3.....: 465.7 MH/s (71.85ms)
Speed.Dev.#*.....: 918.6 MH/s
Hashtype: Django (PBKDF2-SHA256)
Speed.Dev.#2.....: 4100 H/s (50.60ms)
Speed.Dev.#3.....: 4237 H/s (49.05ms)
Speed.Dev.#*.....: 8337 H/s
Hashtype: Mediawiki B type
Speed.Dev.#2.....: 421.9 MH/s (79.44ms)
Speed.Dev.#3.....: 434.3 MH/s (77.13ms)
Speed.Dev.#*.....: 856.2 MH/s
Hashtype: Redmine Project Management Web App
Speed.Dev.#2.....: 183.1 MH/s (91.14ms)
Speed.Dev.#3.....: 188.6 MH/s (88.38ms)
Speed.Dev.#*.....: 371.8 MH/s
Hashtype: PunBB
Speed.Dev.#2.....: 183.1 MH/s (91.16ms)
Speed.Dev.#3.....: 188.6 MH/s (88.43ms)
Speed.Dev.#*.....: 371.7 MH/s
Speed.Dev.#2.....: 1447.3 MH/s (92.62ms)
Speed.Dev.#3.....: 1487.0 MH/s (89.98ms)
Speed.Dev.#*.....: 2934.3 MH/s
Hashtype: MSSQL(2000)
Speed.Dev.#2.....: 546.9 MH/s (61.24ms)
Speed.Dev.#3.....: 562.4 MH/s (59.50ms)
Speed.Dev.#*.....: 1109.3 MH/s
Hashtype: MSSQL(2005)
Speed.Dev.#2.....: 546.5 MH/s (61.31ms)
Speed.Dev.#3.....: 562.5 MH/s (59.49ms)
Speed.Dev.#*.....: 1109.0 MH/s
Hashtype: MSSQL(2012)
Speed.Dev.#2.....: 67866.2 kH/s (61.64ms)
Speed.Dev.#3.....: 69676.9 kH/s (59.98ms)
Speed.Dev.#*.....: 137.5 MH/s
Hashtype: MySQL323
Speed.Dev.#2.....: 3165.3 MH/s (84.71ms)
Speed.Dev.#3.....: 3262.1 MH/s (82.08ms)
Speed.Dev.#*.....: 6427.4 MH/s
Hashtype: MySQL4.1/MySQL5
Speed.Dev.#2.....: 248.0 MH/s (67.27ms)
Speed.Dev.#3.....: 254.8 MH/s (65.43ms)
Speed.Dev.#*.....: 502.8 MH/s
Hashtype: Oracle H: Type (Oracle 7+)
Speed.Dev.#2.....: 67205.6 kH/s (62.06ms)
Speed.Dev.#3.....: 68921.7 kH/s (60.41ms)
Speed.Dev.#*.....: 136.1 MH/s
Hashtype: Oracle S: Type (Oracle 11+)
Speed.Dev.#2.....: 529.6 MH/s (63.26ms)
Speed.Dev.#3.....: 546.2 MH/s (61.26ms)
Speed.Dev.#*.....: 1075.8 MH/s
Hashtype: Oracle T: Type (Oracle 12+)
Speed.Dev.#2.....: 7506 H/s (67.94ms)
Speed.Dev.#3.....: 7707 H/s (66.18ms)
Speed.Dev.#*.....: 15212 H/s
Hashtype: Sybase ASE
Speed.Dev.#2.....: 19181.3 kH/s (53.92ms)
Speed.Dev.#3.....: 19626.6 kH/s (52.67ms)
Speed.Dev.#*.....: 38807.9 kH/s
Hashtype: EPiServer 6.x < v4
Speed.Dev.#2.....: 457.9 MH/s (73.19ms)
Speed.Dev.#3.....: 465.8 MH/s (71.86ms)
Speed.Dev.#*.....: 923.8 MH/s
Hashtype: EPiServer 6.x > v4
Speed.Dev.#2.....: 185.9 MH/s (89.79ms)
Speed.Dev.#3.....: 189.3 MH/s (88.13ms)
Speed.Dev.#*.....: 375.2 MH/s
Hashtype: md5apr1, MD5(APR), Apache MD5
Speed.Dev.#2.....: 684.8 kH/s (94.01ms)
Speed.Dev.#3.....: 697.8 kH/s (92.17ms)
Speed.Dev.#*.....: 1382.7 kH/s
Hashtype: ColdFusion 10+
Speed.Dev.#2.....: 121.1 MH/s (69.21ms)
Speed.Dev.#3.....: 122.6 MH/s (68.29ms)
Speed.Dev.#*.....: 243.6 MH/s
Hashtype: hMailServer
Speed.Dev.#3.....: 189.3 MH/s (88.11ms)
Hashtype: SHA-1(Base64), nsldap, Netscape LDAP SHA
Speed.Dev.#2.....: 535.7 MH/s (62.48ms)
Speed.Dev.#3.....: 546.3 MH/s (61.24ms)
Speed.Dev.#*.....: 1082.1 MH/s
Hashtype: SSHA-1(Base64), nsldaps, Netscape LDAP SSHA
Speed.Dev.#2.....: 535.6 MH/s (62.49ms)
Speed.Dev.#3.....: 545.6 MH/s (61.22ms)
Speed.Dev.#*.....: 1081.2 MH/s
Hashtype: SSHA-256(Base64), LDAP {SSHA256}
Speed.Dev.#2.....: 208.0 MH/s (80.21ms)
Speed.Dev.#3.....: 212.0 MH/s (78.58ms)
Speed.Dev.#*.....: 420.0 MH/s
Hashtype: SSHA-512(Base64), LDAP {SSHA512}
Speed.Dev.#2.....: 71706.9 kH/s (58.33ms)
Speed.Dev.#3.....: 73173.3 kH/s (57.08ms)
Speed.Dev.#*.....: 144.9 MH/s
Hashtype: LM
Speed.Dev.#2.....: 1331.4 MH/s (50.10ms)
Speed.Dev.#3.....: 1358.9 MH/s (48.99ms)
Speed.Dev.#*.....: 2690.3 MH/s
Hashtype: NTLM
Speed.Dev.#2.....: 2492.5 MH/s (53.74ms)
Speed.Dev.#3.....: 2540.2 MH/s (52.67ms)
Speed.Dev.#*.....: 5032.6 MH/s
Hashtype: Domain Cached Credentials (DCC), MS Cache
Speed.Dev.#2.....: 724.5 MH/s (92.52ms)
Speed.Dev.#3.....: 737.1 MH/s (90.77ms)
Speed.Dev.#*.....: 1461.6 MH/s
Hashtype: Domain Cached Credentials 2 (DCC2), MS Cache 2
Speed.Dev.#2.....: 22367 H/s (71.31ms)
Speed.Dev.#3.....: 22907 H/s (69.84ms)
Speed.Dev.#*.....: 45274 H/s
Hashtype: MS-AzureSync PBKDF2-HMAC-SHA256
Speed.Dev.#2.....: 783.8 kH/s (69.42ms)
Speed.Dev.#3.....: 803.7 kH/s (67.87ms)
Speed.Dev.#*.....: 1587.6 kH/s
Hashtype: descrypt, DES(Unix), Traditional DES
Speed.Dev.#2.....: 65275.8 kH/s (63.99ms)
Speed.Dev.#3.....: 66420.0 kH/s (62.63ms)
Speed.Dev.#*.....: 131.7 MH/s
Hashtype: BSDiCrypt, Extended DES
Speed.Dev.#2.....: 102.4 kH/s (105.83ms)
Speed.Dev.#3.....: 104.4 kH/s (103.91ms)
Speed.Dev.#*.....: 206.8 kH/s
Hashtype: md5crypt, MD5(Unix), FreeBSD MD5, Cisco-IOS MD5
Speed.Dev.#2.....: 685.9 kH/s (93.95ms)
Speed.Dev.#3.....: 697.9 kH/s (92.23ms)
Speed.Dev.#*.....: 1383.7 kH/s
Hashtype: bcrypt, Blowfish(OpenBSD)
Speed.Dev.#2.....: 1030 H/s (30.14ms)
Speed.Dev.#3.....: 1053 H/s (29.46ms)
Speed.Dev.#*.....: 2083 H/s
Hashtype: sha256crypt, SHA256(Unix)
Speed.Dev.#2.....: 25854 H/s (62.61ms)
Speed.Dev.#3.....: 26386 H/s (61.36ms)
Speed.Dev.#*.....: 52239 H/s
Hashtype: sha512crypt, SHA512(Unix)
Speed.Dev.#2.....: 11094 H/s (74.29ms)
Speed.Dev.#3.....: 11329 H/s (72.76ms)
Speed.Dev.#*.....: 22423 H/s
Hashtype: OSX v10.4, v10.5, v10.6
Speed.Dev.#2.....: 456.5 MH/s (73.42ms)
Speed.Dev.#3.....: 466.3 MH/s (71.80ms)
Speed.Dev.#*.....: 922.8 MH/s
Hashtype: OSX v10.7
Speed.Dev.#2.....: 63220.5 kH/s (66.20ms)
Speed.Dev.#3.....: 64304.7 kH/s (64.92ms)
Speed.Dev.#*.....: 127.5 MH/s
Hashtype: OSX v10.8+
Speed.Dev.#2.....: 873 H/s (67.77ms)
Speed.Dev.#3.....: 898 H/s (66.31ms)
Speed.Dev.#*.....: 1771 H/s
Hashtype: AIX {smd5}
Speed.Dev.#2.....: 685.1 kH/s (93.94ms)
Speed.Dev.#3.....: 697.6 kH/s (92.12ms)
Hashtype: AIX {ssha1}
Speed.Dev.#2.....: 3177.0 kH/s (72.84ms)
Speed.Dev.#3.....: 3239.7 kH/s (71.40ms)
Speed.Dev.#*.....: 6416.7 kH/s
Hashtype: AIX {ssha256}
Speed.Dev.#2.....: 1143.5 kH/s (53.71ms)
Speed.Dev.#3.....: 1168.1 kH/s (52.58ms)
Speed.Dev.#*.....: 2311.6 kH/s
Hashtype: AIX {ssha512}
Speed.Dev.#2.....: 460.3 kH/s (67.42ms)
Speed.Dev.#3.....: 469.1 kH/s (65.92ms)
Speed.Dev.#*.....: 929.4 kH/s
Hashtype: Cisco-PIX MD5
Speed.Dev.#2.....: 1070.5 MH/s (62.58ms)
Speed.Dev.#3.....: 1091.9 MH/s (61.35ms)
Speed.Dev.#*.....: 2162.4 MH/s
Hashtype: Cisco-ASA MD5
Speed.Dev.#2.....: 1091.0 MH/s (61.43ms)
Speed.Dev.#3.....: 1111.0 MH/s (60.25ms)
Speed.Dev.#*.....: 2202.0 MH/s
Hashtype: Cisco-IOS SHA256
Speed.Dev.#2.....: 208.2 MH/s (80.17ms)
Speed.Dev.#3.....: 212.2 MH/s (78.57ms)
Speed.Dev.#*.....: 420.4 MH/s
Hashtype: Cisco $8$
Speed.Dev.#2.....: 4156 H/s (50.04ms)
Speed.Dev.#3.....: 4218 H/s (49.06ms)
Speed.Dev.#*.....: 8374 H/s
Hashtype: Cisco $9$
Speed.Dev.#2.....: 886 H/s (576.93ms)
Speed.Dev.#3.....: 905 H/s (565.10ms)
Speed.Dev.#*.....: 1791 H/s
Hashtype: Juniper Netscreen/SSG (ScreenOS)
Speed.Dev.#2.....: 842.4 MH/s (79.56ms)
Speed.Dev.#3.....: 859.7 MH/s (77.86ms)
Speed.Dev.#*.....: 1702.1 MH/s
Hashtype: Juniper IVE
Speed.Dev.#2.....: 684.8 kH/s (93.98ms)
Speed.Dev.#3.....: 698.0 kH/s (92.07ms)
Speed.Dev.#*.....: 1382.8 kH/s
Hashtype: Android PIN
Speed.Dev.#2.....: 370.4 kH/s (87.33ms)
Speed.Dev.#3.....: 378.0 kH/s (85.47ms)
Speed.Dev.#*.....: 748.5 kH/s
Hashtype: Citrix NetScaler
Speed.Dev.#2.....: 495.5 MH/s (67.61ms)
Speed.Dev.#3.....: 505.5 MH/s (66.28ms)
Speed.Dev.#*.....: 1001.0 MH/s
Hashtype: RACF
Speed.Dev.#2.....: 179.6 MH/s (93.32ms)
Speed.Dev.#3.....: 184.5 MH/s (90.73ms)
Speed.Dev.#*.....: 364.1 MH/s
Hashtype: GRUB 2
Speed.Dev.#2.....: 3058 H/s (67.66ms)
Speed.Dev.#3.....: 3132 H/s (66.32ms)
Speed.Dev.#*.....: 6191 H/s
Hashtype: Radmin2
Speed.Dev.#2.....: 534.4 MH/s (62.71ms)
Speed.Dev.#3.....: 546.4 MH/s (61.22ms)
Speed.Dev.#*.....: 1080.8 MH/s
Hashtype: SAP CODVN B (BCODE)
Speed.Dev.#2.....: 175.7 MH/s (94.96ms)
Speed.Dev.#3.....: 178.8 MH/s (93.23ms)
Speed.Dev.#*.....: 354.5 MH/s
Hashtype: SAP CODVN F/G (PASSCODE)
Speed.Dev.#2.....: 76288.3 kH/s (109.84ms)
Speed.Dev.#3.....: 77884.3 kH/s (107.55ms)
Speed.Dev.#*.....: 154.2 MH/s
Hashtype: SAP CODVN H (PWDSALTEDHASH) iSSHA-1
Speed.Dev.#2.....: 415.4 kH/s (77.83ms)
Speed.Dev.#3.....: 423.5 kH/s (76.26ms)
Speed.Dev.#*.....: 838.9 kH/s
Hashtype: Lotus Notes/Domino 5
Speed.Dev.#2.....: 14385.8 kH/s (143.79ms)
Speed.Dev.#3.....: 14503.5 kH/s (144.50ms)
Speed.Dev.#*.....: 28889.4 kH/s
Hashtype: Lotus Notes/Domino 6
Speed.Dev.#2.....: 4764.0 kH/s (109.91ms)
Speed.Dev.#3.....: 4861.6 kH/s (107.62ms)
Speed.Dev.#*.....: 9625.6 kH/s
Hashtype: Lotus Notes/Domino 8
Speed.Dev.#2.....: 45594 H/s (71.07ms)
Speed.Dev.#3.....: 46485 H/s (69.70ms)
Speed.Dev.#*.....: 92080 H/s
Hashtype: PeopleSoft
Speed.Dev.#2.....: 552.0 MH/s (60.69ms)
Speed.Dev.#3.....: 562.5 MH/s (59.47ms)
Speed.Dev.#*.....: 1114.5 MH/s
Hashtype: PeopleSoft PS_TOKEN
Speed.Dev.#2.....: 217.4 MH/s (76.78ms)
Speed.Dev.#3.....: 221.4 MH/s (75.29ms)
Speed.Dev.#*.....: 438.8 MH/s
Hashtype: 7-Zip
Speed.Dev.#2.....: 625 H/s (49.15ms)
Speed.Dev.#3.....: 653 H/s (95.37ms)
Speed.Dev.#*.....: 1278 H/s
Hashtype: WinZip
Speed.Dev.#2.....: 75944 H/s (49.01ms)
Speed.Dev.#3.....: 77390 H/s (48.06ms)
Speed.Dev.#*.....: 153.3 kH/s
Hashtype: RAR3-hp
Speed.Dev.#2.....: 2487 H/s (51.21ms)
Speed.Dev.#3.....: 2578 H/s (49.33ms)
Speed.Dev.#*.....: 5065 H/s
Hashtype: RAR5
Speed.Dev.#2.....: 2512 H/s (50.04ms)
Speed.Dev.#3.....: 2570 H/s (48.98ms)
Speed.Dev.#*.....: 5082 H/s
Hashtype: AxCrypt
Speed.Dev.#2.....: 7716 H/s (215.85ms)
Speed.Dev.#3.....: 7903 H/s (211.04ms)
Speed.Dev.#*.....: 15620 H/s
Hashtype: AxCrypt in memory SHA1
Speed.Dev.#2.....: 514.1 MH/s (65.13ms)
Speed.Dev.#3.....: 524.9 MH/s (63.80ms)
Speed.Dev.#*.....: 1039.0 MH/s
Hashtype: TrueCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit
Speed.Dev.#2.....: 18724 H/s (51.93ms)
Speed.Dev.#3.....: 19111 H/s (50.90ms)
Speed.Dev.#*.....: 37834 H/s
Hashtype: TrueCrypt PBKDF2-HMAC-SHA512 + XTS 512 bit
Speed.Dev.#2.....: 28810 H/s (61.42ms)
Speed.Dev.#3.....: 29390 H/s (60.22ms)
Speed.Dev.#*.....: 58199 H/s
Hashtype: TrueCrypt PBKDF2-HMAC-Whirlpool + XTS 512 bit
Speed.Dev.#2.....: 2382 H/s (211.55ms)
Speed.Dev.#3.....: 2441 H/s (206.38ms)
Speed.Dev.#*.....: 4823 H/s
Hashtype: TrueCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit + boot-mode
Speed.Dev.#2.....: 35678 H/s (48.85ms)
Speed.Dev.#3.....: 36387 H/s (47.91ms)
Speed.Dev.#*.....: 72064 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit
Speed.Dev.#2.....: 31 H/s (53.17ms)
Speed.Dev.#3.....: 31 H/s (52.12ms)
Speed.Dev.#*.....: 62 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-SHA512 + XTS 512 bit
Speed.Dev.#2.....: 31 H/s (67.16ms)
Speed.Dev.#3.....: 62 H/s (65.82ms)
Speed.Dev.#*.....: 93 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-Whirlpool + XTS 512 bit
Speed.Dev.#2.....: 0 H/s (213.33ms)
Speed.Dev.#3.....: 0 H/s (208.71ms)
Speed.Dev.#*.....: 0 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit + boot-mode
Speed.Dev.#2.....: 93 H/s (53.19ms)
Speed.Dev.#3.....: 93 H/s (52.15ms)
Speed.Dev.#*.....: 186 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-SHA256 + XTS 512 bit
Speed.Dev.#2.....: 62 H/s (53.25ms)
Speed.Dev.#3.....: 62 H/s (52.14ms)
Speed.Dev.#*.....: 124 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-SHA256 + XTS 512 bit + boot-mode
Speed.Dev.#2.....: 186 H/s (53.24ms)
Speed.Dev.#3.....: 186 H/s (52.09ms)
Speed.Dev.#*.....: 372 H/s
Hashtype: Android FDE <= 4.3
Speed.Dev.#2.....: 56209 H/s (71.96ms)
Speed.Dev.#3.....: 57411 H/s (70.51ms)
Speed.Dev.#*.....: 113.6 kH/s
Hashtype: Android FDE (Samsung DEK)
Speed.Dev.#2.....: 20298 H/s (49.02ms)
Speed.Dev.#3.....: 20761 H/s (47.94ms)
Speed.Dev.#*.....: 41060 H/s
Hashtype: eCryptfs
Speed.Dev.#2.....: 928 H/s (66.52ms)
Speed.Dev.#3.....: 962 H/s (65.21ms)
Speed.Dev.#*.....: 1890 H/s
Hashtype: MS Office <= 2003 MD5 + RC4, oldoffice$0, oldoffice$1
Speed.Dev.#2.....: 15138.0 kH/s (69.09ms)
Speed.Dev.#3.....: 15438.3 kH/s (67.63ms)
Speed.Dev.#*.....: 30576.4 kH/s
Hashtype: MS Office <= 2003 MD5 + RC4, collision-mode #1
Speed.Dev.#2.....: 21390.5 kH/s (97.77ms)
Speed.Dev.#3.....: 22107.0 kH/s (94.63ms)
Speed.Dev.#*.....: 43497.5 kH/s
Hashtype: MS Office <= 2003 SHA1 + RC4, oldoffice$3, oldoffice$4
Speed.Dev.#2.....: 20085.4 kH/s (104.20ms)
Speed.Dev.#3.....: 20547.2 kH/s (101.77ms)
Speed.Dev.#*.....: 40632.5 kH/s
Hashtype: MS Office <= 2003 SHA1 + RC4, collision-mode #1
Speed.Dev.#2.....: 22165.4 kH/s (94.51ms)
Speed.Dev.#3.....: 22632.7 kH/s (92.42ms)
Speed.Dev.#*.....: 44798.2 kH/s
Hashtype: Office 2007
Speed.Dev.#2.....: 8994 H/s (74.23ms)
Speed.Dev.#3.....: 9153 H/s (72.81ms)
Speed.Dev.#*.....: 18147 H/s
Hashtype: Office 2010
Speed.Dev.#2.....: 4483 H/s (74.27ms)
Speed.Dev.#3.....: 4553 H/s (72.80ms)
Speed.Dev.#*.....: 9035 H/s
Hashtype: Office 2013
Speed.Dev.#2.....: 622 H/s (66.16ms)
Speed.Dev.#3.....: 625 H/s (64.81ms)
Speed.Dev.#*.....: 1247 H/s
Hashtype: PDF 1.1 - 1.3 (Acrobat 2 - 4)
Speed.Dev.#2.....: 22742.7 kH/s (91.99ms)
Speed.Dev.#3.....: 23266.0 kH/s (89.89ms)
Speed.Dev.#*.....: 46008.7 kH/s
Hashtype: PDF 1.1 - 1.3 (Acrobat 2 - 4) + collider-mode #1
Speed.Dev.#2.....: 24669.3 kH/s (84.89ms)
Speed.Dev.#3.....: 25201.8 kH/s (82.99ms)
Speed.Dev.#*.....: 49871.1 kH/s
Hashtype: PDF 1.4 - 1.6 (Acrobat 5 - 8)
Speed.Dev.#2.....: 1111.7 kH/s (57.00ms)
Speed.Dev.#3.....: 1134.8 kH/s (55.71ms)
Speed.Dev.#*.....: 2246.4 kH/s
Hashtype: PDF 1.7 Level 3 (Acrobat 9)
Speed.Dev.#2.....: 207.7 MH/s (80.32ms)
Speed.Dev.#3.....: 212.1 MH/s (78.57ms)
Speed.Dev.#*.....: 419.8 MH/s
Hashtype: PDF 1.7 Level 8 (Acrobat 10 - 11)
Speed.Dev.#2.....: 2390 H/s (356.64ms)
Speed.Dev.#3.....: 2480 H/s (343.69ms)
Speed.Dev.#*.....: 4870 H/s
Hashtype: Password Safe v2
Speed.Dev.#2.....: 20188 H/s (24.34ms)
Speed.Dev.#3.....: 19148 H/s (25.96ms)
Speed.Dev.#*.....: 39336 H/s
Hashtype: Password Safe v3
Speed.Dev.#2.....: 81584 H/s (49.86ms)
Speed.Dev.#3.....: 83242 H/s (48.85ms)
Speed.Dev.#*.....: 164.8 kH/s
Hashtype: Lastpass
Speed.Dev.#2.....: 157.5 kH/s (51.02ms)
Speed.Dev.#3.....: 159.4 kH/s (50.38ms)
Speed.Dev.#*.....: 316.9 kH/s
Hashtype: 1Password, agilekeychain
Speed.Dev.#2.....: 223.8 kH/s (71.42ms)
Speed.Dev.#3.....: 229.8 kH/s (69.70ms)
Speed.Dev.#*.....: 453.6 kH/s
Hashtype: 1Password, cloudkeychain
Speed.Dev.#2.....: 742 H/s (67.54ms)
Speed.Dev.#3.....: 777 H/s (66.16ms)
Speed.Dev.#*.....: 1519 H/s
Hashtype: Bitcoin/Litecoin wallet.dat
Speed.Dev.#2.....: 309 H/s (66.54ms)
Speed.Dev.#3.....: 311 H/s (65.21ms)
Speed.Dev.#*.....: 620 H/s
Hashtype: Blockchain, My Wallet
Speed.Dev.#2.....: 5500.4 kH/s (23.63ms)
Speed.Dev.#3.....: 5639.9 kH/s (23.20ms)
Speed.Dev.#*.....: 11140.3 kH/s
Hashtype: Keepass 1 (AES/Twofish) and Keepass 2 (AES)
Speed.Dev.#2.....: 9148 H/s (152.05ms)
Speed.Dev.#3.....: 9353 H/s (148.80ms)
Speed.Dev.#*.....: 18500 H/s
Hashtype: ArubaOS
Speed.Dev.#2.....: 457.6 MH/s (73.23ms)
Speed.Dev.#3.....: 465.9 MH/s (71.77ms)
Speed.Dev.#*.....: 923.5 MH/s
Started: Fri Mar 24 15:59:50 2017
Stopped: Fri Mar 24 16:15:15 2017
Datum registracije: Mar 2010
Postovi: 2,068
To je uvod u review ili ... ? |
8-bit Gen.
Lokacija: Giethoorn - ZG
Postovi: 3,167
Jucer pitam u generalnoj temi za mini DP adaptere na DVI/VGA koje trebam NVS i Quadro, jer nisam mogao naci kutiju, pa malocas sam sebi odgovaram u istoj. Te me iznenadi da ime Quadro proizvoda nestade iz oznacavanje Pro Nvidia kartica. Sve isto samo bezlicne oznake. Detaljnije : Nvidia Quadro is Gone - No More Quadro - Quadro is Retired! Znam, nije ispod cekica, ali nisam uopce znao do danas, te je bas bezveze potez. NVIDIA confirmed to drop Quadro designation The main reason is that currently NVIDIA graphics are starting to be used in more and more segments. The number of graphics cards of the company for computing tasks have increased in quantity very noticeably. Dobri komentari : More On NVIDIA Quadro Brand Retirement: Embracing the Graphics and Compute Overlap ... |
Postovi: 215
Tko kaže da nema više Quadro? https://quadro.com.hr/web/en/brand/3-quadro Ima svega od TV-a do Toaster-a. ![]() Možda je NVidia izgubila pravo na navedeni brand, kao i Toblerone na Matherhorn. |
#5 | |
...samo te gledam...
Postovi: 2,838
Postovi: 23,702
Zaboravljaš: - naravno da je lakše za proizvodnju kada je razlika samo pozicija otpornika i eventualno drugi bios - po defaultu su profi Quadro kartice x puta skuplje |
Postovi: 2,838
Jesu skuplje, ali koja korist kad im je pala prodaja. Ne gledaš samo trošak proizvodnje u cijeloj priči, gledaš konačnu zaradu. EDIT= Da nadopunim: Što Nvidia radi s neprodanim Quadro karticama? Snizi cijenu ako je u pitanju starija generacija? Transportira natrag u tvornicu da ih preprave u klasične gamerske kartice i prepakiraju u drugu ambalažu? Koliki je gubitak novca u svemu tome? Zadnje izmijenjeno od: Sinac. 12.03.2023. u 10:23. |
Lokacija: Zagreb, Trešnjevka
Postovi: 5,778
Ni meni nije ni najmanje cudno da su ih maknuli. Jos jedan razlog je sto je lakse zamagljivati brojeve na investor callovima, bez da netko analizira podjele izmedju mininga, gaminga, AI-ja i slicnog. |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,697
Pa nije da su nestale. Sta nisu samo rebrandirane? https://www.nvidia.com/en-us/design-...ktop-graphics/ |
#10 | |
8-bit Gen.
Postovi: 3,167
![]() ![]() Citiraj:
![]() Nije Quadro umirovljena kao linija proizvoda, vec je samo naziv Quadro maknut kao (do sada) prepoznatljivi naziv. Identicne kartice su samo izgubile ima Quadro u oznacavanju. No, ako se pogleda u ponude po webu, pa cak i (pojedinih) nasih trgovcaca i dalje se koriste naziv Quadro kao kategorija. Navika je razumljiva. U drugi dio o pretvorbi necu, jer cemo otici u tri nove teme. Velim, datumski me mimoisla promjena pa sam pozelio komentirat. Nvidia Architecture Generation ... |
#11 | ||
Postovi: 2,838
Zadnje izmijenjeno od: Sinac. 12.03.2023. u 15:14. |
8-bit Gen.
Postovi: 3,167
Kolega Sinac, ma na ide posebno tebi, ostali su se nadovezali, pa sam tebe prvog citirao. Velim, vjerovao netko u Quadro selekciju, testiranje, drivere... ali te karte ostaju u identicnom procesu validacije i cijene, samo su makli ime. Takve odluke su (meni blesave) no vidjene cesto u industriji danas, ali dobro... |
#14 | |
Postovi: 2,838
Quadro kartice imaju optimizirane drajvere za CAD/CAM/3D pa čak i 2D aplikacije koji omogućuju višestruko brži rad u pojedinim dijelovima (ne svim) izvođenja programa nego klasične grafičke kartice. To se pogotovo odnosi na pomicanje slike (pan) i skrolanje, zumiranje, rotaciju itd. gdje je bitna brzina ponovnog iscrtavanja ekrana jer Quadro kartice znaju to izvesti višestruko brže nego njihov generacijski pandan među klasičnim grafičkim karticama. Obrati pažnju da nisam isticao razliku u hardveru, to je siva zona za koju ćeš naći različite informacije jer službene nisu dostupne i Nvidija ih skriva ko zmija noge. Zadnje izmijenjeno od: Sinac. 12.03.2023. u 18:00. |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,697
Za autocad imas brdo pluginova koji iz pointclud-a rade as-built solid modele. Ja sam prije dobivao takve modele i high end gtx kartice (tipa 1080ti) kakvu sam ja koristio su se gusile u takvim .dwg-ovima, makar su imali svega par mb. S druge strane, ta ista kartica je bila sposobna vrtiti point cloud od stotina milijuna tocaka. |
#16 |
8-bit Gen.
Postovi: 3,167
Baci oko na tekst, pa onda kontroverzu komentara ispod, koju uvijek izaziva tema. Slicne rasprava je prije izazivala Radeon / FirePro tematika. Evo, bas gledam, nisam ni znao da se FirePro isto preimenovala, te je sad Radeon Pro. ... |
#17 | |
Postovi: 2,838
I opet ponavljam, uz sve dijagrame mi ne znamo koja je zapravo realna razlika između klasične i profi kartice zasnovane na istom grafičkom procesoru. Ako pogledamo napredak grafičkih kartica, sjetimo se da je prije RTX serije bio san imati gamersku grafičku karticu koja ray tracing izvodi on-fly u igrama. |
#19 |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Jedina hardverska razlika je bila u tome što su Quadro kartice ponekad imale više VRAM-a, sve ostalo je isto GeForce modelima. Quadro su dolazile s "certificiranim" driverima za neke programe koji su to znali iskoristiti i zato su bile brže.
#20 |
Kostolomac
Postovi: 1,582
Sjećam se da sam soft-modao staru Nvidia 6800 u Quadro 4000 i dobivao bolje performanse u OpenGL igrama. |
#21 |
Prečupavi mod
Postovi: 9,140
ECC memorija na Quadricama je isto nezanemariva razlika ![]()
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
#22 |
Postovi: 5,778
Aha, znaci samo se ime mijenja, ali i dalje ce biti drukcije i imenom i izvedbom od geforcea. Onda, ono, koga briga ![]() |
#23 |
Xulos :)
Postovi: 7,581
Pa da, sve ostaje isto, nije vise quadro nego je RTX Axxx , tipa RTX A6000 Full lineup: https://www.nvidia.com/en-us/design-...ktop-graphics/ |
#24 |
Postovi: 34,137
Bilo bi zanimljivo kada bi netko napravio usporedbu gamerske grafe i RX pandana, kako u igrama tako i u profi programima pa da vidimo imaju li one uopće smisla i da li performanse opravdavaju znatno višu cijenu.
#25 | |
Postovi: 2,838
https://www.cgdirector.com/pro-vs-consumer-gpus/ Za profi aplikacije - definitivno da. Za mješovitu upotrebu - definitivno ne. |
#26 | |
Xulos :)
Postovi: 7,581
#27 |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,697
ima materijala na yt-u: https://www.youtube.com/watch?v=HEagFvmjW4w https://www.youtube.com/watch?v=EDwNZXVGR3w https://www.youtube.com/watch?v=xtN9dX0oWzY Zaključak: ovisno o aplikaciji koja se koristi, Za allroundere definitivno nije. |
