Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,614
RX6700 Undervolt & Overclock
Prije nekih mjesec i pol dana uzeo Sapphire RX6700 10GB, na jednom drugom forumu sam već podjelio iskustva i gain undervolta ove kartice pa evo da podjelim i ovdje pa ako nekom pomogne oko izbora grafe ili undervolta spomenute super ![]() Za početak specke grafe: GPU: AMD RX6700 7nm GPU AMD RDNA™ 2 Architecture Engine Clock: Boost Clock Up to 2495 MHz; Game Clock Up to 2330 MHz Stream Processors: 2304 Infinity Cache: 80MB Ray Accelerators: 36 Memory Size/Bus: 10GB GDDR6 Memory Clock: 16 Gbps Effective Displays: Maximum 4 Displays Resolution: HDMI™: 7680×4320; DisplayPort1.4: 7680×4320 Interface: PCI-Express 4.0 x16 Output: 1x HDMI; 3x DisplayPort BIOS Support: UEFI Game Index: 4K Sapphire Features: Premium Digital Power Design; Fuse Protection; Dual-X Cooling Technology; Intelligent Fan Control; Precision Fan Control; Metal Backplate; Two-Ball Bearing Fans; Integrated Cooling Module; TriXX Supported; TriXX Boost; AMD Features: AMD RDNA™ 2 Gaming Architecture; DirectX® 12 Ultimate; Hardware Raytracing; Smart Access Memory; Infinity Cache; 7nm GPU; PCI® Express 4.0 Support; AMD FreeSync™ Technology; DisplayPort™ 1.4 with DSC; HDMI™ 2.1 VRR; Video Streaming up to 8K; Radeon™ VR Ready Premium; AMD FidelityFX; Radeon™ Image Sharpening; Radeon™ Anti-Lag; Radeon™ Software; Game Driver Optimizations; Cooling: Dual Fans Form Factor: 2.2 slot, ATX; Dimension: 260(L)X 119.85(W)X 49(H)mm Power Consumption: 220W (Board Power) OS: Linux®, Windows® 7* and Windows® 10/11, 64-bit operating system required *Does not support all features including but not limited to Hardware Raytracing System Requirement: Minimum 650 Watt Power Supply; 1 x 8-pin Power Connector; PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard; Minimum 8GB of system memory. 16GB recommended. Prvo savjet za sav software koji ćete trebati za testiranje praćenje i stabilnosti: HWMonitor - za praćenje min/max klokova, voltaže, okretaja ventilatora, temp i slično FurMark - stress test za testiranje stabilnosti grafe nakon svakog tweakanja Unreal Heaven Benchmark - još jedan stress test za stabilnost grafe nakon tweakanja Ovdje ću napisati step by step kako sam i što radio te na kraju linkati video usporedbu stock vs uv&oc na Assassins Creed Valhalla benchmarku. Za početak pokrenuti AMD Control Panel, otići pod tuning i prvo što sam uradio je omogućio sve postavke za tweakanje, dakle: GPU Tuning - Enabled Advanced Control - Enabled (ovo je jako bitno jer ako je isključeno Mhz i Mv će biti prikazani kao postotak) VRAM Tuning - Enabled Advanced Control - Enabled Fan Tuning (ako se želi namještati fan ručno, to ostavljam svakome na svoj izbor jer nismo svi isti po pitanju buke/temperature s time da je po defaultu kartica dosta tiha i ima zbilja okej temperature, pogotovo nakon UV-a) Power Tuning - Enabled. Preskočio sam jednu stavku - AMD SmartAccess Memory ali o tom ću pisati nešto kasnije. Nakon što ste sve to "omogućili" stisnite "apply changes" i možemo početi: Korak 1: Power Limit gurnuti slidere do kraja. Korak 2: Namještanje Min i Max frekvencije: min 2550MHz max 2650MHz, tu se možete dodatno igrati sa dodavanjem i spuštanjem ali meni osobno je ovo optimalno. Korak 3: Voltaža (mV), po defaultu je na 1.200mV, ja sam krenuo sa 1.100mV, odvrtio stress test (AMD ima svoj stress test ali nije pouzdan kao FurMark ili Heaven pa preporučam njih) na 10 minuta zatim spuštao po 10mV,ponovno vrtio stress test dok nisam došao do najstabilnijih 1050mV. Ovdje će rezultati varirati u odnosu sreće pri "izvlačenju karti" tako da će neko možda morati ići na veću voltažu a neko možda uspije dobiti stabilno i na još nižoj. Korak 4: jedini OC koji sam radio u ovoj prvoj fazi je OC memorije (jer mi je prvi cilj vidjeti koliko mogu skinuti potrošnju i temp bez da gubim na performansama u odnosu na stock postavke). Memoriju sam sa default 2000MHz dignuo na 2100Mhz te memory timing postavio na "Fast timing". Nakon toga sam odvrtio turu FurMarka 20 minuta i Heavena 20 minuta bez crashanja. REZULTAT: Test je odvrtit u Assasins Creed Valhalla benchmarku sa svim postavkama na max. MONITOR: ASUS VG279Q 27" 1080p 144Hz IPS CPU: AMD Ryzen 5 3600 6c/12t (stock postavke + PBO ON) COOLER: Arctic Freezer 34 eSports DUO MBO: MSI B450 Tomahawk MAX (stavljen zadnji BIOS 7C02v3F AGESA ComboAm4v2PI 1.2.0.7. - 2022-08-12) RAM: Patriot Viper RGB 2x8GB (16GB) DDR4 3600MHz CL16 GPU: Sapphire Pulse Gaming OC RX6700 10GB (stock vs uv&oc postavke od gore) sa zadnjim Driverom Revision Number: 22.Q4 (Release Date 15/11/2022). PSU: Riotoro Enigma G2 650W 80+ Gold OS: Windows 10 Pro 64-bit (sa svim ažuriranjima) AMD Smart Access Memory: ON Link na video Iz priloženog se vidi pad od cca 30w u potrošnji te nekih cca 10c temperature bez pada u performansama. Sada se vraćam na preskočenu stavku AMD Smart Access Memory. Prvo što se tiče podrške za AMD SAM: PLOČE: 400 i 500 serija ploča GPU: 6000 i 7000 serija grafi CPU: 7000 serija, 5000 serija procesora te određeni procesori iz 3000 serije (proguglati koji, ali koliko znam samo su APU procesori nepodržani dok ostatak 3000 serija ima podršku za SAM) Prvi korak je odlazak u BIOS, zatim OC postavke - PCI sub system ili Settings - Advanced - PCIE - PCI sub system settings (ovisno od modela do modela ploče i proizvođača). Tamo treba omogućiti dvije postavke 4G Decoding i Re-Size BAR support. Spremiti promjene i rebootati PC. Nakon ulaska u Windows, otići u AMD kontrol panel, pod tuning tabom bi sada trebala biti "AMD SmartAccess Memory" stavka koju treba staviti na enable ako nije već automatski i to je to. Za dodatnu provjeru dali je SAM uključen može se otići Device Manager, pod Display Adapters stisnuti desni klik na grafu (u ovom slučaju RX6700), Properties i ako pod Resources tabom ima "Large Memory Range" AMD SAM je uspiješno omogućen. VAŽNO Ako spomenutih postavki nema u BIOS-u a ploča i procesor podržavaju SAM potrebno je ažurirati BIOS na AMD AGESA 1.1.0.0 ili noviji. I to je to za ovu prvu fazu, kada uhvatim još vremena doma još ću se malo poigrati sa overklokom pa da se dođe na neku zlatnu sredinu potrošnja - performanse, nadam se da je nekom sve ovo pomoglo ako je uzeo RX6700 i želi se malo poigrati sa undervoltanjem. Par slika potrošnje i temperature sa undervoltanim postavkama u Far Cry 6 max postavke klik |
Lokacija: Zagreb, Črnomerec
Postovi: 2,611
Lijepo napisano, fino se da srezat potrošnja. Znači li ovo "min 2550MHz max 2650MHz" da onda kartica i kad je u idle na spušta takt? |
Prvoklasni Krkan
Postovi: 5,333
Fino, samo IMHO previše nebitnih podataka(npr ovaj masivni dio kopi/pejstan sa stranice proizvođača grafe ). Ispravak netočnog navoda, i serija 300 chipseta podržava ReBar, bitno je samo imati zen2 ili novije. |
Postovi: 1,614
A dobro kome se ne čita taj dio preskoči ![]() Ma ovo je "official" podrška koju je AMD objavio i tu kaže da je 400 i 500 chipset podrzan, znam da i većina 300 ploča ima podršku ali ne sve. Također i Zen+ podržavam ReBar iako AMD to ne navodi klik , ali kažem pisao sam samo za ono što SLUŽBENO podržava SAM. ![]() Zadnje izmijenjeno od: ibme74. 14.01.2023. u 09:25. |
Postovi: 994
odlično ! već dugo ganjam xfx 6700 10gb Ali nikako sa mi cijena bude po chefu |
Postovi: 1,614
ne znam dali ti je opcija kupnja u njemačkoj pa da ti neko od rodbine/frendova "ponese" doma jer tamo ih imaš po cca 2.700kn što je jako dobra cijena za karticu ovih performansi. |
Postovi: 994
u DE i gledam. Čekam da bude 330€ s dostavom. Već bi uzeo 6650xt,ali imam pcie gen3 riser kabel. |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,087
Nije ista grafa, ali ja sam svoju RX6800XT skresal na 980mV sa istom frekvencijom. Potrošnja mi je oko 50W manji a temperature oko 10ak stupnjeva. Tipičan AMD,i CPU i GPU sam undervoltal i radi ko singerica
Postovi: 375
Dobar opis svega. Jedno pitanje samo - kako točno funkcionira ovo s "power limit-om"? To znači da će kartica moći povući više kada bude trebala? Ili će stalno više vući? I što bi bila posljedica toga da npr. u svojem setupu sve ostaviš ovako kako si napisao, ali power limit ostaviš na "0"? Da li bi tada možda bilo neke nestabilnosti u tom undervoltu od 1050mV koje ovako nema? |
#12 | |
Postovi: 2,611
Ovo što si prvo napisao, ako joj je potrebno uzet će nešto više od defaultnog maximuma. Obično možeš oko 10% više od defaulta staviti, ponekad i više. Neće biti nestabilnosti ako ostaviš na manje, jednostavno će boostati na niže taktove jer joj neće bit dopušteno ići iznad određene potrošnje. |
Postovi: 1,614
To je više stavka za overklok nego za ovo što sam ja radio ali imam običaj uvijek taj slider povući do kraja (navika). Uglavnom, proizvođač kartice s time ograničava potrošnju, npr ako je potrošnja ograničena na 180w i kartica dosegne tu potrošnju klokovi će se automatski spustiti kako bi potrošnja ošla dolje što rezultira u fps dropu tokom gaminga. I ne, neće uvijek vući više nego ako joj zatreba, ali u ovoj situaciji je potrošnja kartice i još manja nego na default postavkama (peak je nekakvih 115w) tako da ako i ne diraš taj slider neće biti razlike i neće biti nestabilna, problem bi bio u slučaju ekstremnog overkloka gdje bi kartica lako mogla udariti u taj limit potrošnje koju je proizvođač ograničio. Također različiti modeli iste kartice imaju različite limite, lošiji modeli će češće imati manji limit tipa da ne možeš gurnuti slider više od 5% ili 10%, bolji modeli će imati do 15% ili čak više. |
#14 | ||
Postovi: 375
¯\_(ツ)_/¯
Lokacija: Sibenik
Postovi: 1,156
Uz sve podatke bi bilo dobro dadati i da je stock power limit ove kartice vrlo niskih 158W i bez undervolta u par igara koje sam probao je konstantno na 100% power-a... |
