Staro 02.01.2023., 12:00   #241
Postovi: 8,650
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750
Zadnje izmijenjeno od: The Exiled. 03.01.2023. u 16:40.
Staro 02.01.2023., 14:51   #242
Dottore
Dottore's Avatar
Postovi: 7,733
Opa, čestitke.
Koji je kontroler na NVME? Da nije osakaćen novijom.
Edit. Adata promjenila ambalažu sa crnog na crveni. ( moj je crni sa 512Gb)
Zadnje izmijenjeno od: Dottore. 02.01.2023. u 14:58.
Staro 02.01.2023., 15:08   #243
Postovi: 8,650
Silicon Motion SM2262G je na tom disku, ali namijenjen je za Ryzen 7 4750G backup konfiguraciju koja već ima jedan takav.
Ovi diskovi koji su trenutno u pogonu za 5900X, idu dalje i za 7950X.
Staro 07.01.2023., 23:43   #244
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,710
https://wccftech.com/msi-asrock-roll...on-ryzen-cpus/
solidan agesa update
a gledao sam taj bios na asrock site-u i mislim si ma neću dirat dok sve ovako dobro radi, neka to ljudi prvo malo isprobaju
Staro 07.01.2023., 23:51   #245
Postovi: 8,650
Arrow AMD Ryzen 9 7950X + MSI MAG B650 Tomahawk Wi-Fi
MotherboardMicro-Star International Co., LtdMAG B650 TOMAHAWK WIFI (MS-7D75) (BIOS version1.21)
ProcessorAMD Ryzen 9 7950X 16-Core Processor 32 logical CPUs
Available memory
(MB): 64672
Operating system
Microsoft Windows 10
Number of cores            16 (max 16)
Number of threads        32 (max 32)
Number of CCDs            2
    Manufacturer            AuthenticAMD
    Name                    AMD Ryzen 9 7950X
    Codename                Raphael
    Specification            AMD Ryzen 9 7950X 16
-Core Processor
    Package                 Socket AM5
(LGA1718)
CPUID                    F.1.2
    Extended CPUID            19.61
    Core Stepping            RPL
-B2
    Technology                5 nm
    TDP Limit                170.0 Watts
    Tjmax                    95.0 °C
    Core Speed                5347.3 MHz
    Multiplier x Bus Speed    53.5 x 99.9 MHz
    Base frequency
(cores)    99.9 MHz
    Base frequency
(mem.)    99.9 MHz
    Instructions sets    MMX
(+), SSESSE2SSE3SSSE3SSE4.1SSE4.2SSE4Ax86-64AMD-VAESAVXAVX2AVX512FFMA3SHA
    Microcode Revision        0xA601203
    L1 Data cache            16 x 32 KB
(8-way64-byte line)
L1 Instruction cache    16 x 32 KB (8-way64-byte line)
L2 cache                16 x 1024 KB (8-way64-byte line)
L3 cache                2 x 32 MB (16-way64-byte line)
Max CPUID level            00000010h
    Max CPUID ext
level    80000028h
    FID
/VID Control            yes
# of P-States            2
P-State                    FID 0x8B4 VID 0xC9 (45.00x 1.256 V)
P-State                    FID 0x878 VID 0x79 (30.00x 0.756 V)
Min Frequency        400 MHz
    Max Frequency        5850 MHz
    PBO Scalar        1
    Package Power Tracking
(PPT)        Current 142.0 Wfused 230.0 W
    Thermal Design Current
(TDC)        Current 110.0 Afused 160.0 A
    Electrical Design Current
(EDC)        Current 170.0 Afused 225.0 A
AMD procesori iz Ryzen 7000 serije bazirani na Zen 4 arhitekturi se pretjerano griju, previše troše i općenito cijela AM5 platforma zahvaljujući suludim cijenama matičnih ploča košta taman toliko pretjeranu količinu novaca da se cijela stvar čini kao poprilično loša zajebancija na račun krajnjih korisnika. Ovo je otprilike inicijalni generalni dojam Interneta prije jedno tri-četiri mjeseca kad su službene Zen 4 recenzije ugledale svjetlo dana. Iako je skok u performansama bio i više nego osjetan, sve prije spomenuto uz temperature od 95°C, ne ulijeva povjerenje krajnjih korisnika, posebice kad AMD-ov marketing odrađuje turneju uvjeravanja kako je 95°C zapravo (novo) normalno - isto kao npr. 65°C.
U međuvremenu se dosta toga već fino iskristaliziralo i kao što je Exy napomenul u svojem osvrtu, "hardkodirane" temperature od 95°C su sve samo ne uklesane u kamen i nije dugo trebalo da se recenzenti (nakon što se prašina slegla) osvrnu na zauzdavanje pretjerane potrošnje i zagrijavanja. Jedan od relativno friških materijala na tu temu je i AnandTechov pregled trenutne situacije za aktualnu high-end ponudu u vidu Intel Core-i9 13900K i AMD Ryzen 9 7950X modela. Kod mene je AMD Ryzen 9 7950X iskombiniran s tzv. budžet MSI MAG B650 Tomahawk Wi-Fi pločom i prilikom prvog paljenja s orginalnim v1.10 BIOS-om koji je došao s pločom nije bilo nekih problema, odnosno nema višeminutnih i općenito dugotrajnih boot i POST procedura. Sve u svemu kakvih dvadesetak sekundi, dok ploča ne skuži sve kak spada, odradi restart i to je to. BIOS je kasnije nadograđen na v1.21 verziju, a boot i POST su se dodatno skratili na kakvih 10 ili 15 sekundi.
Nakon isprobavanja, provjeravnja i testiranja svih mogućih opcija naposljetku sam se odlučil za Tjmax 75°C, 105W TDP, 142W PPT uz negativni offset i curve optimizer (-20), tako da se sada CPU na 100% zauzeća zadržava na temperaturi od ~77°C i ~135W maksimalne potrošnje. be quiet! Pure Rock 2 Black cooler je sasvim solidan po tom pitanju, pa 7950X veselo žvače sve kaj se pred njega baci, bez nepotrebnog divljanja automatskih defaultnih postavki. Kaj se memorije tiče, mada je nativno prepoznata kao DDR5-3600 - uz XMP profil 4x16GB modula sada rade na DDR5-5200 bez problema i pri tome se na 1.25V fino griju na ~40°C do ~50°C, ovisno o zauzeću, tj. dvanaest istovremeno aktivnih virtualnih mašina zauzima ~85% RAM-a, pa su sukladno tome i temperature nešto više, ali ništa pretjerano.
Kao što je bio slučaj s prijašnjom Ryzen 7 4750G iGPU + RX 580 dGPU kombinacijom, trenutni Ryzen 9 7950X iGPU + RX 6700 XT dGPU također mogu biti aktivni istovremeno. Obzirom da je iGPU baziran na RDNA 2 arhitekturi, samim time podržava hardversku akceleraciju (enkodiranje i dekodiranje) H.264, H.265/HEVC materijala, dok za AV1 nema enkodiranja (pošto je to omogućeno tek s novijom RDNA 3 arhitekturom), pa ostaje samo AV1 dekodiranje. Također, iGPU se pomoću Hybrid Graphics opcije (u BIOS-u) može upogoniti zajedno s klasičnom (dGPU) grafičkom karticom, tako da se nativno zapravo može koristiti samo iGPU, koji onda po potrebi (gaming, rendering, itd.) automatski uključuje i prebacuje sve na diskretnu grafičku karticu.
PHP kod:
Available memory
(MB): 64672
Operating system
Number of CCDs            2
    Codename                Raphael
-Core Processor
    Package                 Socket AM5
(LGA1718)
CPUID                    F.1.2
    Core Stepping            RPL
-B2
    Technology                5 nm
    Tjmax                    95.0 °C
    Base frequency
(cores)    99.9 MHz
    Base frequency
(mem.)    99.9 MHz
(8-way64-byte line)
    Max CPUID ext
level    80000028h
    FID
/VID Control            yes
# of P-States            2
    PBO Scalar        1
Staro 08.01.2023., 11:11   #246
Mladenxy
Mladenxy's Avatar
Postovi: 4,506
Super CPU, toliko jezgri, sve boostaju preko 5 ghza na zračnom hlađenju bez problema uz ugodnu temperaturu. Zbilja vrhunska stvar tko ga treba i ima sa čime uposliti.
Staro 08.01.2023., 11:22   #247
nino
nino's Avatar
Postovi: 12,613
I to ispod coolera od manje od 50€.
Bomba.
Staro 08.01.2023., 19:29   #248
Postovi: 8,650
Autor nino Pregled postova
Bomba.
Da bi reč rekel, cooler je stvarno vredu, čak i kad se ovaj "mini Threadripper" malo jače optereti.
Staro 08.01.2023., 19:49   #249
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,472
Dakle zaključak je da na Zen4 doslovno sam biraš max temp, a time i nešto sitno performanse, rekao bi pi puta oko 5-7%. Nije loše, šteta što to nije default. A onda da postoji neki extreme mode i da se onda kuri na 95 stupnjeva i busta 100mhz više.
Slobodno me dodajte na PSN
Disco je online   Reply With Quote
Staro 08.01.2023., 20:02   #250
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,427
Sta nije sad Eco mode default?
Staro 08.01.2023., 20:31   #251
Postovi: 8,650
Nažalost (još) nije, mada bi trebalo biti, jer s tih 95°C su ispali ni vrit ni mimo.
Staro 08.01.2023., 20:59   #252
Dr. Strange
Datum registracije: Aug 2020
Postovi: 900
Kolega čestitam na mrcini od procesora a.k.a sapunatora, discord družina na aparatima .
Staro 08.01.2023., 22:17   #253
Exy
Exy's Avatar
Postovi: 2,710
Fina recenzija, i čestitke na 32-cijevnom procu Exiled
Zbilja je to AMD loše odigrao, a lijepo se vidi kako se uz manji tweaking dođe do fantastičnih rezultata. Smiješno je da bi to radilo tako čak i uz slabiji hladnjak, samo se stavi tmax na 85C umjesto na 75C i to je to
Postigao si uz lagano tweakanje da ti proc sa 142W PPT-a radi identično kao na defaultu (koji je 230W). zbog curve undervoltinga vjerujem i bolje.
Kad se gleda anandtech, tak postaje jasno kako je AMD to mogao dobro odigrati. Da su ga stavili na tih 120-130W defaulta i tmax na 75-80C i ostavili 200W+ kao neki super turbo mod za entuzijaste sa predimenzioniranim hlađenjem, naslovi bi bili kako je genijalan 7950X jer sa skoro duplo manjom potrošnjom od 13900X daje vrlo slične multithread rezultate. U stvarnosti smo dobili nešto drugo, nažalost.
Autor Disco Pregled postova
Čak i gore od toga, bilo je recenzenata koji su testirali na defaultu što je ostavljalo ogroman prostor za potrošnju struje što je dizalo voltaže i temperature do te razine da se prelazilo i 95C što je vodilo thermal throttlingu i spuštanju performansi. Nevjerojatno ali istinito.
Boosta više ako mu staviš curve optimizer negativni kao što je kolega napravio, ograničiš potrošnju i uključiš PBO nego kad ga držiš na defaultu gdje se bez razloga prži na 95C.
Mislim da se sad lijepo vidi da oni koji su imali strahove od potrošnje i grijanja to ne moraju imati. Zen4 je jedan vrlo brz i efikasan proc sa vrlo loše namještenim defaultnim postavkama. Nemojte se bojati ga uzeti ali obvezno si dajte malo vremena i podesite tih par postavki u BIOS-u ako ćete uzimati, po meni je to čak nužno.
P.S. ovo što kolega kaže o hybrid grafici vrijedi i za zen4+nvidia kombinaciju, isto mi je kao na laptopu sa Xe grafikom+nvidia, ili winsi automatski biraju koji gpu će vrtiti što ili ja to ručno podesim.
Staro 09.01.2023., 00:32   #254
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,342
Zanima me da li je jednako jednostavno i u drugim pločama osim MSI? Ponekad mi se činid da oni imaju više opcija u BIOS-u od prosjeka za automatizirati taj postupak.
Sve napisano stoji, stvarno nema potrebe da procevi gore na defaultu.
Staro 09.01.2023., 03:49   #255
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,534
Srića pa taj komad hardveja kupuju samo znalci i bios esl profi korsnici šta ce ovi jadni ostali korisnici(plug&play) ništa bar ce imat i
još jedan izvor za grijanje zimi...
Tajl3r je online   Reply With Quote
Staro 09.01.2023., 03:54   #256
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,427
Zbog takvih je Eco mode trebao biti default. Nažalost je Zen4 išao nakon Intela pa je letvica već bila postavljena dost visoko.
Staro 09.01.2023., 18:58   #257
Postovi: 8,650
Zadnje izmijenjeno od: The Exiled. 09.01.2023. u 20:41.
Staro 09.01.2023., 19:08   #258
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,472
TLDR: za sada isplativi ako X verzije opet poskupe tj vrate se na početne cijene. Razlika u perf 5% iliti zanemarivo. Još se čekaju ploče po pristupačnim cijenama.
Tj jedino je 7900 jeftiniji 50$ od X verzije, dok su druga dva navodno 10-20$ razlike.
Staro 09.01.2023., 21:05   #259
Exy
Exy's Avatar
Postovi: 2,710
Ako ćemo iskreno, onaj tko gleda na 20-30 eura neće uzet ni zen4 niti raptora, odnosno prepakiranog aldera. Ako je išta iz ovog Stevičinog bencha:
jasno, onda je to da je skoro pa svejedno koji proc imaš. Budget gaming ryzen 5600 i nemaš što mislit o zenu4, raptoru i sl. stvarima. Ako se ne gleda bang for buck onda je to čisto stvar osobne preferencije, AMD ili Intel.
Staro 09.01.2023., 22:02   #260
Dr. Strange
Postovi: 900
Ma ovo mi je sve dosadno postalo, godinama je više manje isto, malo AMD bolji, malo Intel bolji, više me zanima mobilna kombinacija Zen 4 + rtx 4000, obje arhitekture su se pokazale dosta efikasnim i veselim se vidjet ih u prijenosnicima.
Staro 10.01.2023., 00:28   #261
Exy
Exy's Avatar
Postovi: 2,710
Što se zena4 tiče, lijepo je da i non-x 7600 model također veselo radi na 95C stupnjeva, što je vidljivo iz HU recenzije. Jedva čekam manje iskusne korisnike kad to vide pa počnu stavljati vodu, nabrijane Nocute i sl.
Svaka čast AMD.
Zadnje izmijenjeno od: Brko. 10.01.2023. u 17:27.
Staro 10.01.2023., 00:40   #262
Odinarius
All-rounder
Postovi: 1,342
Kaže HU da s vodom 7600 ode na 78C, pa to i nije nužno loš savjet Taj Wraith Stealth je očito tu kao prva pomoć. 7700 sa Wraith Prism se drži na 78C.
Staro 10.01.2023., 00:44   #263
Exy
Exy's Avatar
Postovi: 2,710
Po meni je to iznimno loš savjet, ako je to stvarno rekao. Nema nikakvog smisla na taj mali procesorić stavljati vodene blokove uz koje onda radi na 78C . Ono što ima smisla je uzeti zračni hladnjak koji cijenom odgovara tom 6-core procu i podesiti njegove termalne limite i max temperaturu. Najgore što čovjek može napraviti je ostaviti ga na defaultu pa ga pokušavati ohladiti sa predimenzioniranim rješenjima.....
Staro 10.01.2023., 00:52   #264
Odinarius
All-rounder
Postovi: 1,342
To su dvije opcije koje je testirao. Kaže da nema znaka throttlinga na Stealthu. Mislim da termalno ne možeš dalje ograničavati, ili nema smisla ići ispod 65W. Jedina fora kod ovih proceva jest da je Eco mod po defaultu uključen. Slažem se da bi neki tower s 12cm fanomm od 200-250kn bio idealan. Ja bi to svakako stavio zbog buke, nisam tvorničke coolere koristio zadnjih 15g...
Mislim, nije to neki jak prigovor, da je besplatni cooler jedva dovoljan, kad nijedan drugi procesor ovog ranga ili jači ne dolazi s bilo kakvim coolerom uopće.
Staro 10.01.2023., 09:54   #265
Postovi: 8,650
Koliko se može skužiti iz svih recenzija za obične (non-X) modele, oni samo uključe PBO i to je to, svi procesori imaju 88W PPT, pa fino i potroše ekstra, dok temperatura (opet) ide na 95°C, a taktovi su na kakvih 5.0GHz.
Jebiga, gledaju skroz defaultne postavke, pa nitko ne dira negativni offset i curve optimizer, ali uz sve kaj su testirali, dovoljno bi bilo spomenuti te opcije i voljno.
Zadnje izmijenjeno od: The Exiled. 10.01.2023. u 10:21.
Staro 10.01.2023., 13:42   #266
sharyn
sharyn's Avatar
Datum registracije: Jun 2010
Lokacija: grubišno polje
Postovi: 569
Autor Dr. Strange Pregled postova
ma uzmeš šta ti se svidi i šta ti odgovara buđetom, to je sve svakako u 5grama
sharyn je offline   Reply With Quote
Staro 11.01.2023., 15:09   #267
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Mislite da bi r9 7900 mogao pomirisati rang cijene 3600kn? Čini mi se ako tu negdje dođe čak kao kandidat
MojSkuter
Staro 11.01.2023., 15:54   #268
Exy
Exy's Avatar
Postovi: 2,710
Eno ti ga za 525 EUR.
Vidim da ti fali više kućica u task manageru
Staro 11.01.2023., 21:09   #269
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Fali fali, ali ako cijena bude niža
Vidjeti ćemo, čekam x3d predstavljanje još
MojSkuter
Staro 11.01.2023., 21:32   #270
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,534
zasto cekat samo se jednom živi
