#241 |
Postovi: 8,502
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 03.01.2023. u 16:40. |
#242 |
Postovi: 7,696
Opa, čestitke. Koji je kontroler na NVME? Da nije osakaćen novijom. Edit. Adata promjenila ambalažu sa crnog na crveni. ( moj je crni sa 512Gb) Zadnje izmijenjeno od: Dottore. 02.01.2023. u 14:58. |
#243 |
Postovi: 8,502
Silicon Motion SM2262G je na tom disku, ali namijenjen je za Ryzen 7 4750G backup konfiguraciju koja već ima jedan takav. Ovi diskovi koji su trenutno u pogonu za 5900X, idu dalje i za 7950X. ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#244 |
Lokacija: Zagreb, Črnomerec
Postovi: 2,636
https://wccftech.com/msi-asrock-roll...on-ryzen-cpus/ solidan agesa update ![]() a gledao sam taj bios na asrock site-u i mislim si ma neću dirat dok sve ovako dobro radi, neka to ljudi prvo malo isprobaju ![]() |
#245 |
Postovi: 8,502
AMD procesori iz Ryzen 7000 serije bazirani na Zen 4 arhitekturi se pretjerano griju, previše troše i općenito cijela AM5 platforma zahvaljujući suludim cijenama matičnih ploča košta taman toliko pretjeranu količinu novaca da se cijela stvar čini kao poprilično loša zajebancija na račun krajnjih korisnika. Ovo je otprilike inicijalni generalni dojam Interneta prije jedno tri-četiri mjeseca kad su službene Zen 4 recenzije ugledale svjetlo dana. Iako je skok u performansama bio i više nego osjetan, sve prije spomenuto uz temperature od 95°C, ne ulijeva povjerenje krajnjih korisnika, posebice kad AMD-ov marketing odrađuje turneju uvjeravanja kako je 95°C zapravo (novo) normalno - isto kao npr. 65°C.
![]() U međuvremenu se dosta toga već fino iskristaliziralo i kao što je Exy napomenul u svojem osvrtu, "hardkodirane" temperature od 95°C su sve samo ne uklesane u kamen i nije dugo trebalo da se recenzenti (nakon što se prašina slegla) osvrnu na zauzdavanje pretjerane potrošnje i zagrijavanja. Jedan od relativno friških materijala na tu temu je i AnandTechov pregled trenutne situacije za aktualnu high-end ponudu u vidu Intel Core-i9 13900K i AMD Ryzen 9 7950X modela. Kod mene je AMD Ryzen 9 7950X iskombiniran s tzv. budžet MSI MAG B650 Tomahawk Wi-Fi pločom i prilikom prvog paljenja s orginalnim v1.10 BIOS-om koji je došao s pločom nije bilo nekih problema, odnosno nema višeminutnih i općenito dugotrajnih boot i POST procedura. Sve u svemu kakvih dvadesetak sekundi, dok ploča ne skuži sve kak spada, odradi restart i to je to. BIOS je kasnije nadograđen na v1.21 verziju, a boot i POST su se dodatno skratili na kakvih 10 ili 15 sekundi. Nakon isprobavanja, provjeravnja i testiranja svih mogućih opcija naposljetku sam se odlučil za Tjmax 75°C, 105W TDP, 142W PPT uz negativni offset i curve optimizer (-20), tako da se sada CPU na 100% zauzeća zadržava na temperaturi od ~77°C i ~135W maksimalne potrošnje. be quiet! Pure Rock 2 Black cooler je sasvim solidan po tom pitanju, pa 7950X veselo žvače sve kaj se pred njega baci, bez nepotrebnog divljanja automatskih defaultnih postavki. Kaj se memorije tiče, mada je nativno prepoznata kao DDR5-3600 - uz XMP profil 4x16GB modula sada rade na DDR5-5200 bez problema i pri tome se na 1.25V fino griju na ~40°C do ~50°C, ovisno o zauzeću, tj. dvanaest istovremeno aktivnih virtualnih mašina zauzima ~85% RAM-a, pa su sukladno tome i temperature nešto više, ali ništa pretjerano. Kao što je bio slučaj s prijašnjom Ryzen 7 4750G iGPU + RX 580 dGPU kombinacijom, trenutni Ryzen 9 7950X iGPU + RX 6700 XT dGPU također mogu biti aktivni istovremeno. Obzirom da je iGPU baziran na RDNA 2 arhitekturi, samim time podržava hardversku akceleraciju (enkodiranje i dekodiranje) H.264, H.265/HEVC materijala, dok za AV1 nema enkodiranja (pošto je to omogućeno tek s novijom RDNA 3 arhitekturom), pa ostaje samo AV1 dekodiranje. Također, iGPU se pomoću Hybrid Graphics opcije (u BIOS-u) može upogoniti zajedno s klasičnom (dGPU) grafičkom karticom, tako da se nativno zapravo može koristiti samo iGPU, koji onda po potrebi (gaming, rendering, itd.) automatski uključuje i prebacuje sve na diskretnu grafičku karticu.
#247 |
Postovi: 12,613
I to ispod coolera od manje od 50€. ![]() Bomba. ![]()
#248 |
Postovi: 8,502
#249 |
Prvoklasni Krkan
Postovi: 5,360
Dakle zaključak je da na Zen4 doslovno sam biraš max temp, a time i nešto sitno performanse, rekao bi pi puta oko 5-7%. Nije loše, šteta što to nije default. A onda da postoji neki extreme mode i da se onda kuri na 95 stupnjeva i busta 100mhz više. |
#251 |
Postovi: 8,502
Nažalost (još) nije, mada bi trebalo biti, jer s tih 95°C su ispali ni vrit ni mimo. ![]()
#252 |
Datum registracije: Aug 2020
Postovi: 899
#253 | |
Postovi: 2,636
Fina recenzija, i čestitke na 32-cijevnom procu Exiled ![]() Zbilja je to AMD loše odigrao, a lijepo se vidi kako se uz manji tweaking dođe do fantastičnih rezultata. Smiješno je da bi to radilo tako čak i uz slabiji hladnjak, samo se stavi tmax na 85C umjesto na 75C i to je to ![]() Postigao si uz lagano tweakanje da ti proc sa 142W PPT-a radi identično kao na defaultu (koji je 230W). zbog curve undervoltinga vjerujem i bolje. Kad se gleda anandtech, tak postaje jasno kako je AMD to mogao dobro odigrati. Da su ga stavili na tih 120-130W defaulta i tmax na 75-80C i ostavili 200W+ kao neki super turbo mod za entuzijaste sa predimenzioniranim hlađenjem, naslovi bi bili kako je genijalan 7950X jer sa skoro duplo manjom potrošnjom od 13900X daje vrlo slične multithread rezultate. U stvarnosti smo dobili nešto drugo, nažalost. Citiraj:
Boosta više ako mu staviš curve optimizer negativni kao što je kolega napravio, ograničiš potrošnju i uključiš PBO nego kad ga držiš na defaultu gdje se bez razloga prži na 95C. Mislim da se sad lijepo vidi da oni koji su imali strahove od potrošnje i grijanja to ne moraju imati. Zen4 je jedan vrlo brz i efikasan proc sa vrlo loše namještenim defaultnim postavkama. Nemojte se bojati ga uzeti ali obvezno si dajte malo vremena i podesite tih par postavki u BIOS-u ako ćete uzimati, po meni je to čak nužno. P.S. ovo što kolega kaže o hybrid grafici vrijedi i za zen4+nvidia kombinaciju, isto mi je kao na laptopu sa Xe grafikom+nvidia, ili winsi automatski biraju koji gpu će vrtiti što ili ja to ručno podesim. |
#254 |
All-rounder
Datum registracije: Sep 2013
Postovi: 1,338
Zanima me da li je jednako jednostavno i u drugim pločama osim MSI? Ponekad mi se činid da oni imaju više opcija u BIOS-u od prosjeka za automatizirati taj postupak. Sve napisano stoji, stvarno nema potrebe da procevi gore na defaultu. |
#255 |
Dobro je sve.
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,512
Srića pa taj komad hardveja kupuju samo znalci i bios esl profi korsnici šta ce ovi jadni ostali korisnici(plug&play) ništa bar ce imat i još jedan izvor za grijanje zimi... Sent from my M2012K11AG using Tapatalk |
#257 |
Postovi: 8,502
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 09.01.2023. u 20:41. |
#258 |
Prvoklasni Krkan
Postovi: 5,360
TLDR: za sada isplativi ako X verzije opet poskupe tj vrate se na početne cijene. Razlika u perf 5% iliti zanemarivo. Još se čekaju ploče po pristupačnim cijenama. Tj jedino je 7900 jeftiniji 50$ od X verzije, dok su druga dva navodno 10-20$ razlike. |
#259 |
Postovi: 2,636
Ako ćemo iskreno, onaj tko gleda na 20-30 eura neće uzet ni zen4 niti raptora, odnosno prepakiranog aldera. Ako je išta iz ovog Stevičinog bencha: ![]() jasno, onda je to da je skoro pa svejedno koji proc imaš. Budget gaming ryzen 5600 i nemaš što mislit o zenu4, raptoru i sl. stvarima. Ako se ne gleda bang for buck onda je to čisto stvar osobne preferencije, AMD ili Intel. |
#260 |
Postovi: 899
Ma ovo mi je sve dosadno postalo, godinama je više manje isto, malo AMD bolji, malo Intel bolji, više me zanima mobilna kombinacija Zen 4 + rtx 4000, obje arhitekture su se pokazale dosta efikasnim i veselim se vidjet ih u prijenosnicima. |
#261 |
Postovi: 2,636
Što se zena4 tiče, lijepo je da i non-x 7600 model također veselo radi na 95C stupnjeva, što je vidljivo iz HU recenzije. Jedva čekam manje iskusne korisnike kad to vide pa počnu stavljati vodu, nabrijane Nocute i sl. ![]() ![]() Svaka čast AMD. Zadnje izmijenjeno od: Brko. 10.01.2023. u 17:27. |
#263 | |
Postovi: 2,636
Po meni je to iznimno loš savjet, ako je to stvarno rekao. Nema nikakvog smisla na taj mali procesorić stavljati vodene blokove uz koje onda radi na 78C . Ono što ima smisla je uzeti zračni hladnjak koji cijenom odgovara tom 6-core procu i podesiti njegove termalne limite i max temperaturu. Najgore što čovjek može napraviti je ostaviti ga na defaultu pa ga pokušavati ohladiti sa predimenzioniranim rješenjima..... |
#264 |
All-rounder
Postovi: 1,338
To su dvije opcije koje je testirao. Kaže da nema znaka throttlinga na Stealthu. Mislim da termalno ne možeš dalje ograničavati, ili nema smisla ići ispod 65W. Jedina fora kod ovih proceva jest da je Eco mod po defaultu uključen. Slažem se da bi neki tower s 12cm fanomm od 200-250kn bio idealan. Ja bi to svakako stavio zbog buke, nisam tvorničke coolere koristio zadnjih 15g... Mislim, nije to neki jak prigovor, da je besplatni cooler jedva dovoljan, kad nijedan drugi procesor ovog ranga ili jači ne dolazi s bilo kakvim coolerom uopće. |
#265 |
Postovi: 8,502
Koliko se može skužiti iz svih recenzija za obične (non-X) modele, oni samo uključe PBO i to je to, svi procesori imaju 88W PPT, pa fino i potroše ekstra, dok temperatura (opet) ide na 95°C, a taktovi su na kakvih 5.0GHz. ![]() Jebiga, gledaju skroz defaultne postavke, pa nitko ne dira negativni offset i curve optimizer, ali uz sve kaj su testirali, dovoljno bi bilo spomenuti te opcije i voljno.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 10.01.2023. u 10:21. |
#266 | |
Datum registracije: Jun 2010
Lokacija: grubišno polje
Postovi: 568
