Staro 19.11.2022., 09:42   #5971
Roberto
Roberto's Avatar
Postovi: 2,654
Savrseno jasan pokazatelj gdje GSW ima najveci problem - second unit:
The starting unit is holding opponents to 104.8 points per 100 possessions in non-garbage time — equivalent to the best defense in the league. Their 92.2 points per 100 possessions allowed in the half court is equivalent to third in the league. All other lineup combinations haven’t been as stingy — far from it, to be quite frank: 116.0 points per 100 possessions allowed, equivalent to the fourth-worst defense in the league; 99.4 points per 100 possessions allowed in the half court, equivalent to third worst in the league.
Takodjer sma engdje naletio na podatak da prva postava ima ukupno +70 napad, uvjerljivo najbolja prva petorka u ligi, a sve ostale petorke su cini mi se -50
Utah jase i dalje tankiranje nula bodova Markannen rastura.
Lakersi dosta bolji bez Lebrona zadnje tri tekme, 2:1
Roberto je online   Reply With Quote
Staro 19.11.2022., 21:35   #5972
keyser_s()ze
Postovi: 590
Dwight Howard dominira (Tajvan): https://www.youtube.com/watch?v=NkU_PPvxVLQ
keyser_s()ze je offline   Reply With Quote
Staro 19.11.2022., 23:47   #5973
Dottore
Dottore's Avatar
Postovi: 7,706
Bome se namučio više nego u Lakersima sa manjom minutažom.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 28.11.2022., 01:14   #5974
Roberto
Roberto's Avatar
Postovi: 2,654
Gleda li tko ovu rasturačinu Zubca?
31 koš i 29 skokova
Staro 28.11.2022., 02:59   #5975
d0X
Kostolomac
d0X's Avatar
Postovi: 1,562
Autor Roberto Pregled postova
31 koš i 29 skokova
Bome ih je razvalio
PSN Steam
d0X je online   Reply With Quote
Staro 28.11.2022., 17:39   #5976
DiTech
DiTech's Avatar
Postovi: 346
Falio mu 1 reb da udje u 30/30 history, jedino Lowe imao vise od 1982. Odlican bio, al bas se vidi kako bi ga i inace mogli tako koristiti, ali ne bitnije je dati kos sam.
DiTech je offline   Reply With Quote
Staro 29.11.2022., 00:02   #5977
keyser_s()ze
Postovi: 590
Pogledao replay. Zubac na jednom kraju radi bananu, trči na drugi kraj i zakucava... A da stvar bude intrigantnija izgleda kao šeprtlja među baletanima jer je visok i krakat (čak i za NBA pojmove).
Vidi se da ovakav performans podiže ekipu među oblake i kad gledam ove koji čekaju da se riješe tih ozljeda (ako do toga uopće dođe), bude ovo zanimljiva ekipa u play offu.
Balmerovo slavlje naravno neprocjenjivo. Čovjek je kao na lansiranju windowsa 95...
Staro 29.11.2022., 09:29   #5978
Roberto
Roberto's Avatar
Postovi: 2,654
Ne volim nikako te Clipperse, al mogli bi biti zanimljivi. Kawhi muku muči s oporavkom i vrlo je ušitno hoće li biti onaj stari, a i PG je svako malo out, al svejedno dobro stoje izgledaju.
Zubac ove sezone igra 30 minuta u prosjeku, Lue mu vjeruje i daje mu dobru minutažu, i to se vidi, double double prosjek, 4 skakač i 6. bloker lige.
Bit će i dalje tu tekmi gdje će imat manju minutažu jer će suparnici igrati small ball u kojem će njegove vrline postati mane, ali generalno dobro igra i dobro se snalazi.
Staro 29.11.2022., 09:57   #5979
adaksinjo
adaksinjo's Avatar
Datum registracije: Dec 2011
Lokacija: Virje
Postovi: 601
Markkanen 32, Porzingis 41, Durant 45 poena, većina je iz šuta, dobar dio su trice. nema mi boljega nego kad netko od 210cm ima takav šut i još kad ulazi, milina za gledati kako nitko ne može do te lopte kad šutiraju.
Staro 29.11.2022., 10:14   #5980
Roberto
Roberto's Avatar
Postovi: 2,654
Haha, šta je ovo bilo s Lakersima, izgubili dobivenu tekmu
Odoh na poso kad su vodili 17 razlike u Q4, pogledam sad rezultat, izgubili
Neki rookie pogodio tricu preko Jamesa za pobjedu
Staro 29.11.2022., 10:26   #5981
adaksinjo
adaksinjo's Avatar
Lokacija: Virje
Postovi: 601
prethodnih 5 napada Ciglić uzima odgovornost, šutira, ulazi, ni jedna lopta na Jamesa osim doslovno zadnjeg njihovog koša.
Davis je jednostavno mrtav u q4, vuče se od jednog koša do drugog, na kraju pokuša pomoći, skočiti, blokirati, ali ga 20cm niži igrači izvozaju ko mladog majmuna. ne kritiziram, cijelu tekmu daje sve od sebe, nije ni čudo da u zadnjih 5 minuta nema sape.
Staro 29.11.2022., 11:37   #5982
Ante M
Ante M's Avatar
Datum registracije: Oct 2016
Lokacija: Svemir
Postovi: 714
Nema veze, bitno da su našamarali Spurse 2 puta u manje od 24 sata, a i to na njihovom terenu
Još malo takvih i playoff je tu .
Ante M je offline   Reply With Quote
Staro 29.11.2022., 12:37   #5983
kiki86
Tehničar
Postovi: 1,096
utah nazalost pocela tonut zesce...
Staro 29.11.2022., 12:38   #5984
adaksinjo
adaksinjo's Avatar
Lokacija: Virje
Postovi: 601
@Ante - imaš vrlo istančane obrambene mehanizme, sigurno si bio dobar u obrani (ako si igrao košarku)
mi tebe argumentima, ti nas s potpuno nebitnim usporedbama Spursi tankaju, pola ekipe su djeca s potencijalom, a druga polovica igraju samo da im neko popuni roster.
teško mi je to reći, ali biti sretan nakon pobjede protiv Spursa ove godine, a i nekoliko narednih baš i nije neki argument
ako Lakersi uopće uđu u playoff, ispat će u prvom krugu, dam ruku u vatru da bu tak
Staro 29.11.2022., 12:56   #5985
Ante M
Ante M's Avatar
Lokacija: Svemir
Postovi: 714
Uh znal sam dobro ugrist kad je trebalo, i dan danas isto makar na terminu. Iako sam po vokaciji shooting guard, znam i bananu udijeliti nerijetko :kava:
Staro 29.11.2022., 15:13   #5986
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,525
Autor kiki86 Pregled postova
nisu bullsi su bolji
n1
Staro 30.11.2022., 05:11   #5987
Ante M
Ante M's Avatar
Lokacija: Svemir
Postovi: 714
Dončić 41-12-12 za pobjedu Mavsa nad GSW. Curry prvo napravio korake pri šutu za pobjedu, pa onda Klay promašio otvorenu tricu za overtime haha 😆
A jesu mi i to neki prvaci, na strani uspili dobiti samo Rocketse valjda 😆
Kemba potpisao za Mavse vezano uz ovu pobjedu, pitanje je koliko će koljena izdržati, ali bilo bi dobrodošlo malo pomoći Luki, sve mora sam kao i goat 🐐 Lebron, nije to lako.
Staro 30.11.2022., 07:58   #5988
Roberto
Roberto's Avatar
Postovi: 2,654
Čudna tekma, ali dobra, isplatilo se pratiti
GSW katastrofalno krenuo u tekmu, gubili su 15 razlike u prvoj, i u biti su ih rezerve odležale u tekmi i spasile stvar. Prvo Curry a onda Green u Q2 s rezervama su vratili stvari u egal. Klay prve koševe u Q3 zabio, općenito su tricu očasjno gađali. Tekmu su izgubili cca 2,5 minute prije kraja kad su prešli u vodstvo i onda u dva napada zaredom bez primljenog koša fulali ukupno 5 šuteva.
Čudno zvuči, ali bez obzira na poraz GSW je dobro izgledao noćas, a i u zadnjih par tekmi. Rezerve polako love ritam i uhodavaju se, daju kakav takav doprinos i u obrani i u napadu i ne ispadaju onako naivno ko na početku. 8-4 zadnjih 12 tekmi.
Luka, šta reći, vrhunski igra cijelu sezonu, iako su većinu tekme Wariorsi puštali Luku 1 na 1 bez udvajanja, dobar dio vremena ga je čuvao Kuminga. Fali kvalitete oko njega, tu se puno nije promijenilo, dapače čak je i gore bez Brunsona. Po meni neće tu Kemba puno promijeniti, al isecond unit b is njim trebao malo lakše disati.
Cobar pokušaj da LeBrona unaciš u razgovor Ante, ali na loš način. Prozirna laž o LeFlopu kao one man bandu. One man band kkoj ije otiš u u momčdas s titulom i ufržio se s drugim zvijezdama kad je vidio da ne može do titule drugačije, pa onda i u Cavsim a s 2 AST igrača, a o Lakersima da ne pričam gdje je naslov potpisan od strane Davisa
Zubac double double noćas, 12k + 13s, ali i uvjerljivo najgori plus minus u ekipi
Staro 30.11.2022., 08:00   #5989
adaksinjo
adaksinjo's Avatar
Lokacija: Virje
Postovi: 601
prvo sam mislio da pišeš od Durantu, ali i Lebron ima zmijske krvi
Staro 30.11.2022., 08:01   #5990
Roberto
Roberto's Avatar
Postovi: 2,654
Ugledao se Durantula na njega
Staro 30.11.2022., 13:19   #5991
Ante M
Ante M's Avatar
Lokacija: Svemir
Postovi: 714
Koliko se bojite 🐐 Lebrona samo, evo Robertu su se počeli tresti ruke od same pomisli na njega pri pisanju ulomka, počeo je virtualno zamuckivati 😆 😆
Clippersi bome dobili, a gubili cijelu tekmu. Česta pojava u NBA, u Europi se to manje viđa.
Staro 30.11.2022., 17:31   #5992
Roberto
Roberto's Avatar
Postovi: 2,654
Jes jes. Tolko je strasan lebron da u zadnje vrijeme i rookieji pisaju po njemu
Aha, sad vidim kak sam pisao. A tak je to kad si cijelu noc budan a onda ujutro ides radit
Zadnje izmijenjeno od: Roberto. 30.11.2022. u 17:42.
Staro 30.11.2022., 19:26   #5993
adaksinjo
adaksinjo's Avatar
Lokacija: Virje
Postovi: 601
trebamo vas obući u dresove GSW-a i Lakersa i napraviti natjecanje u tricama. onaj koji dobije ima doživotno pravo u ovoj temi pisati tko je goat
napisao sam to, ima više od godinu dana, ali nikako da realiziramo. skupimo se, iznajmimo neku dvoranu na par sati i ko-šar-ka.
Staro 03.12.2022., 15:45   #5994
Ante M
Ante M's Avatar
Lokacija: Svemir
Postovi: 714
Ma jeste li samo gledali veliku pobjedu 🐐 Lebrona i Lakersa kod jedne od najjačih ekipa lige Bucksa kojima se usto još vratio i Middleton ?? Kako su lijepo igrali, momčadski, svi su dali svoj doprinos, perfektna pobjeda i tekma za gledati.
Slabašni Bullsi primili još jedan lijepi šamar od gsw.
Prekrasna, baš prekrasna NBA večer.
Staro 03.12.2022., 16:48   #5995
d0X
Kostolomac
d0X's Avatar
Postovi: 1,562
Interesantno mi je bilo bananiranje Jamesa i Davisa od strane Giannisa i Lopeza. Odlična tekma, Lakersi počeli igrati napokon. Samo da Davis ostane zdrav, bit će veselo.
PSN Steam
Staro 03.12.2022., 16:55   #5996
Ante M
Ante M's Avatar
Lokacija: Svemir
Postovi: 714
Ma da, pa njima je to ključna stvar, kad su u zoni ono baš svakog mogu razvaliti. Loš početak sezone je baš zbog tih propuštanja utakmica njih dvojice, ali bome u 9 utakmica su sad na omjeru 7:2 , a i od toga je jedan poraz čudnim šitom u zadnjoj desetinki protiv Pacersa.
Povratak Schroedera je tu isto jako bitan, Westbrick izgleda jako ozbiljno i podređen ekipi uz manje ispade, kako je jučer samo fino razigravao sve, pa rola Walkera ubacio 4,5 trica zaredom u trećoj četvrtini.
Ne znam koliko imaju prostora da se još pojačaju trejdovima, ali i ovakvi kad igraju svi mogu svakako razvalit bilo koga. Opet ih se svi boje
Staro 08.12.2022., 10:04   #5997
Roberto
Roberto's Avatar
Postovi: 2,654
Epsko prosipanje Warriorsa
U 13 sekundi Klay ostavlja Beasleya samog na trici,pa Poole gubi loptu čim ju je uzeo i ode 4 poena prednsoti samo tako
Ok, bili su bez Currya, Greena i Wigginsa, ali opet, upropastili su dobivenu tekmu
Staro 11.12.2022., 21:41   #5998
Roberto
Roberto's Avatar
Postovi: 2,654
Suns vs Pelicans u 21:30. Prva i treća ekipa zapada.
Pogledah par tekmi Pelicansa, Zion igra vrlo dobro- Malo obranu zaboravlja pokoji put ali šta sad
Izgleda kao da je par kila viška na njemu , ali kad krene prema košu ne smeta mu nimalo
Noćas Warriorsi prvu ekipu lige podsjetili kako je finale završilo
Staro 11.12.2022., 22:47   #5999
adaksinjo
adaksinjo's Avatar
Lokacija: Virje
Postovi: 601
misliš 20:30, tekma je počela cijela dvorana huče svaki put kad Paul primi loptu...
Šarić u petorci, drago mi je da se konačno vraća nakon ozljede.
btw nisam htio ništa pisati za Boston da ne uznemirim duhove u ovoj temi, al džabe im najbolji omjer lige na kraju sezone, ne kaže se bezveze da prava košarka kreće tek u playoffu.
Zadnje izmijenjeno od: adaksinjo. 11.12.2022. u 22:53.
Staro 11.12.2022., 23:34   #6000
Roberto
Roberto's Avatar
Postovi: 2,654
Uh, fulao vrijeme. Kako bi Dalic rekao: prebacilo me
Na istoku se par ekipa odvojilo krlti na vrhu, al daleko je jos PO.
Na zapadu skoro svaka tekma je derbi izravnih PO konkurenata
Solidan Saric
