Staro 02.11.2022., 12:13   #361
Dominus
Datum registracije: Oct 2022
Lokacija: Jura
Postovi: 28
Mislim da nisi nekaj u MSI dobro napravio ili enejblao i snimio postavke da spremi to kaj si podesio.
Ažuriraj ju na Aorus Master BIOS
Dominus je offline   Reply With Quote
Staro 02.11.2022., 13:48   #362
lajchi
Postovi: 506
Citaj par postova prije, probao bez afterburnera isto. Uglavnom nema smisla da se ventovi ne gase nakon reboot-a (a onda nema sanse da je afterburner kontrolira..)
lajchi je offline   Reply With Quote
Staro 02.11.2022., 14:10   #363
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 5,029
šalji na garanciju.
Staro 02.11.2022., 16:47   #364
lajchi
Postovi: 506
Vratio amazonu danas posto od njih uzeo, ali naci novu nece biti jednostavno.
Staro 04.11.2022., 17:32   #365
Postovi: 8,818
RTX 4090 woes get worse: Native 16-pin reportedly melts as well
By now, you may have read many horror stories about nVidia's 16-pin power adapter melting on the GeForce RTX 4090. However, the terror doesn't stop there. A GeForce RTX 4090 owner has reported the first alleged case of a 12VHPWR power connector meltdown from a native ATX 3.0 power supply. According to the Facebook post, the owner used an MSI GeForce RTX 4090 Gaming X Trio 24G graphics card and MEG Ai1300P power supply. Having read about the frightening user feedback with the 16-pin power adapter, the user opted for an ATX 3.0 power supply with a native 12VHPWR power connector. Unfortunately, the photographs showed that the power connector had started to melt. A couple of the ports already looked disfigured. Although he didn't share any pictures of his system, the Facebook user claimed he didn't bend the cable excessively. MSI has reached out to him to replace the graphics card and power supply.
Izvor: Tom's Hardware
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750
Staro 04.11.2022., 18:05   #366
Dr. Strange
Datum registracije: Aug 2020
Postovi: 901
Toliko su overpriceali karticu i na kraju svi ti problemi i limiti poput DP 1.4, za tu cijenu očekujem savršenstvo, sve pomno istestirano, vrhunski quality control itd. Nvidia se zbilja opustila, ne ustručavaju se pljuvat po kupcima, nadam se da će im se to obit o glavu, i da je unlaunch 12gb verzije i EVGA-ino povlačenje samo početak problema. I poručio bih nešto kožnatom: proklet bio na Božić 2022 .
Staro 04.11.2022., 18:11   #367
Postovi: 8,818
Nekaj je očito sfušano s tim 12VHPWR konektorima i kablovima, koliko god se trudili cijelu stvar prikazati kao nekolicinu izdvojenih slučajeva.
Staro 04.11.2022., 18:17   #368
Dr. Strange
Postovi: 901
Cijela ta serija je sfušana, čeka se rtx 5000.
Staro 04.11.2022., 18:27   #369
SlavoS
Datum registracije: May 2003
Postovi: 1,116
Zna li neko, koliki bi koeficijent sigurnosti trebao biti na tom i sličnim konektorima ?
SS
SlavoS je offline   Reply With Quote
Staro 04.11.2022., 18:31   #370
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,412
Brijem da ako budem uzimao takvu grafu skoro narucit cu Corsairov kabel umjesto koristenja ovih sa 4 konektora njihov izgelda bolje te ide direkt u PSU.
https://www.corsair.com/us/en/Catego...e/p/CP-8920274
Staro 04.11.2022., 19:42   #371
Postovi: 8,818
Pričekaj čisto da vidiš daljnji razvoj situacije, jer ako se počinju gomilati i slučajevi s kablovima direktno iz napajanja, poput ovog MSI ATX 3.0 primjera, onda više ništa nije sigurno.
Staro 04.11.2022., 19:45   #372
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,412
To svakako, nemislim kupovat ove godine, eventulano uzeti jos koju RTX 3090 ali 4090 za sad ne.
Staro 05.11.2022., 08:01   #373
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,873
Bahatost u kombinaciji sa rjecju opustili su se, docekat ce ih posljedice, prije ili kasnije, uzeli su maha da ne mare za nista, trziste bi ih moglo kazniti odnosno kupci, sve ima svoje granice, a oni su upravo na rubu ili se priblizavaju rubu, pitanje je samo, koliko ce ljudi biti strpljivo s nevidijom.
Nekak me sve podsjeca kao na intel pricu..
Staro 05.11.2022., 11:15   #374
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Mislim da tome ne treba pridavati previse pozornosti niti izvlacit neke zakljucke, jedan jedini slucaj koji je lako moguce iz razno-raznih razloga fejkan je u najmanju ruku nebitan...
Staro 05.11.2022., 13:44   #375
SlavoS
Postovi: 1,116
Autor ansha Pregled postova
Pa čak da i je tako. i dalj stoji, ako se ne varam, preporuka/upozorenje o broju uštekavanja konektora, na 30 puta.
Pardon na "perjanici ponude" od 15000kn, neko je ušparao cca 47lp ili koliko got
SS
Staro 05.11.2022., 15:04   #376
Postovi: 8,818
Gamers Nexus Heavy Metal Steve je u njihovom testiranju napomenul nek se ljudi ne čude ako i kad se pojave nativni kablovi koji idu direktno u napajanje, a imaju isti problem kao i ovi sfušani čang-šlang adapteri.
Staro 05.11.2022., 15:35   #377
SlavoS
Postovi: 1,116
Ok, ugradit 2 x 16pin konektora i nema brige.
Vjerujem da bi kupcima draža bila kartica s dva konektora od kartice s jednim i protupožarnim aparatom u paketu
SS
Staro 05.11.2022., 18:09   #378
Postovi: 8,818
  • [1] - User is using ATX 3.0 PSU and not using the supplied adapter. PSU is MSI MEG Ai1300P
  • [2] - User is using ATX 3.0 PSU and not using the supplied adapter. PSU is MSI MPG A1000G
I tak, evo i drugi slučaj s nativnim 12VHPWR konektorom.
Staro 05.11.2022., 18:41   #379
jucca
jucca's Avatar
Postovi: 1,720
Do MSI.a je 😀
Sent from my SM-S908B using Tapatalk
Staro 06.11.2022., 09:33   #380
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,558
Samo napomena, tih 30 puta za uštekavanje i ištekavanje vam važi i za 8pin koji sada imamo, pa vi vidite koliko to znači.
A i realno, mislim da je mojkabel u posljednjih 12ak godina uštekan i ištekan 4-5 puta, ali ja nisam baš neki totalno moderan i up to date momak.
Ali ovo sa topljenjem kablova je malo jači problemčić, ja to ne bi za sada uzimao ni pod razno, ali tko je avanturističkog duha slobodno neka proba i javi rezultate.
Slobodno me dodajte na PSN
Staro 07.11.2022., 12:04   #381
Postovi: 8,818
  • nVidia GeForce RTX 4080 Graphics Card Benchmark Leaks Out, Up To 15% Faster Than RTX 3090 Ti
  • nVidia GeForce RTX 4080 Custom Models Listed Online, Preliminary Prices Close To RTX 4090
Staro 07.11.2022., 13:20   #382
piydek
piydek's Avatar
Postovi: 375
ako je stvarno "up to 15%", brza od 3090ti, cak i kad bi to bila prosjecna razlika, a ne "up to" - to je ništa napretka za "pravu" verziju 4080 kartice. Nikakav napredak nove generacije. Stvarno se nadam da će ih AMD pomesti u ovom rangu ispod 4090, a sljedeće godine i 4090.
piydek je offline   Reply With Quote
Staro 07.11.2022., 13:32   #383
Postovi: 8,818
Ne bi bilo ništa čudno da tak ispadne, kad je RTX 4090 "samo" 45% jača od RTX 3090 Ti.
For a majority of gamers, the "classic" raster performance is very important though—highest settings, RT off, DLSS off—so we made sure to extensively test this scenario using 25 games at three resolutions.
The GeForce RTX 4090 achieves incredible performance results here: +45% vs RTX 3090 Ti. Yup, 45% faster than last generation's flagship—this is probably the largest jump Gen-over-Gen for many years.
Where RTX 4090 can flex its muscle is with ray tracing enabled. While previously enabling RT at 4K always meant some compromises—either upscaling or reduced settings—the RTX 4090 will give you 60 FPS with RT active in nearly all titles.
Staro 07.11.2022., 14:19   #384
Antony
Lokacija: Poreč
Postovi: 69
Našao si najretardiraniji review 4090 koji postoji, čestitke
Grafu koja je žešće CPU bottleneckana su genijalci testirali na dvije godine starom Zen 3 5800X CPU-u (dakle pričamo o običnom modelu bez 3D VCache).
Prema HUB recenziji koja je koristila 5800X3D 4090 je 58% jača od 3090 Ti, a sa Zen 4 ili Raptor Lake CPU-om je ta razlika još i veća (oko 65% jača u prosjeku cca).
https://static.techspot.com/articles...Average_4K.png
Antony je offline   Reply With Quote
Staro 07.11.2022., 14:29   #385
jucca
jucca's Avatar
Postovi: 1,720
Dajte preimeujte temu, u pljucanje u Nvidii, AMD je bolji, moj tata je jači
Staro 07.11.2022., 14:37   #386
Dr. Strange
Postovi: 901
Autor jucca Pregled postova
Jensen Huang je taj koji se s ovom generacijom žestoko popišao po nama, najskuplja kartica s abnormalnom cijenom dolazi s defektom, a da ne pričam o displayportu 1.4, zaslužuju svako pljucanje. Ako tebi to smeta, a nemaš free proizvode od njih, dionice, ili bilo kakve financijske koristi onda imaš problema.
Staro 07.11.2022., 15:04   #387
jucca
jucca's Avatar
Postovi: 1,720
Otkad nas zabrinjavaju par desetaka, ili stotina NOK kartica? Tj kabela?
Staro 07.11.2022., 15:06   #388
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Autor Dr. Strange Pregled postova
Defekt ne postoji, a ako nemam apsolutno nikakve koristi od novijeg DP standarda, sta bi mi trebalo smetati tocno?
Staro 07.11.2022., 15:08   #389
jucca
jucca's Avatar
Postovi: 1,720
Defekt ne postoji, a ako nemam apsolutno nikakve koristi od novijeg DP standarda, *sta bi mi trebalo smetati tocno*?
Ali AMD ima...
Staro 07.11.2022., 15:12   #390
Dr. Strange
Postovi: 901
Kad kupujem karticu iz tog ranga po toj cijeni očekujem sve najnovije standarde i maksimalnu kvalitetu, u slučaju da mi nešto zaista ne treba kupit ću karticu iz nižeg ranga po manjoj cijeni. I također za tu cijenu ne želim da mi se kabel topi, ili da se uopće priča o tome. Znam, nisam normalan, kako se usudim nešto tako tražiti od gospodara Jensena.
