Lokacija: Zd
Postovi: 4,775
AMD Ryzen "ZEN4" (7000 CPU / 8000G APU series) Info thread
Lokacija: Zd
Postovi: 4,775
Postovi: 8,667
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 26.09.2022. u 16:08. |
Lokacija: Poreč
Postovi: 69
Postovi: 228
Debelo ispod ocekivanja. |
Datum registracije: Aug 2020
Postovi: 900
Ništa ne kužim recenzije, jedni kažu najjači proizvod, drugi da je lošiji od Intela, šta je na kraju? |
Postovi: 8,667
Ne znam tko veli da je Zen 4 lošiji, ali s ovom AMD generacijom se Intelov tzv. hibridni big.LITTLE pristup još dodatno dovodi u pitanje.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX |
Retro hardware fan
Datum registracije: Apr 2022
Postovi: 95
Ovo drugo ![]() Ako zelis amd, jos uvijek je 5800x3d king, jeftinija am4 platforma, jeftiniji ram. Zadnje izmijenjeno od: sfc_PsychQ. 26.09.2022. u 17:25. Razlog: Dodana recenica |
Lokacija: Lawl
Postovi: 1,381
Zar nisi pisao na Intel temi da vi sa Buga volite argumentirati svoje postove? I sad kad je ispalo da je 7600X skoro jednak 12900K za puno manje para, možemo li napokon dobiti komentar? |
#12 | |
Lokacija: Poreč
Postovi: 69
As it stands at the time of writing, AMD's Ryzen 9 7950X is the clear leader in single-core IPC performance, with a pretty comprehensive increase in IPC performance over Zen 3. Although Intel's Alder Lake (12th Gen) provided gains over AMD's Ryzen 5000 series in a multitude of ways including frequency, optimizations, and its complex hybrid architecture. There is no doubt that the latest Zen 4 microarchitecture using TSMC's 5 nm node gives AMD the single-thread performance crown, and in terms of single-threaded applications, it's the most powerful x86 desktop processor right now. https://www.anandtech.com/show/17585...he-high-end/20 AMD has again taken the crown in overall CPU performance, so it's now Intel's turn to see how they respond. While it is expected that Intel will be retaliating in some shape or form, either that be through price cuts to its existing Alder Lake processors or the launch of its upcoming 13th Gen Core series (codenamed Raptor Lake), it has a lot of ground to make up in IPC and compute performance. At the time of writing, the AMD Zen 4 core is powerful and shows good performance efficiency at lower power levels. Anandtech je uvijek bio najrelevantniji što se tiče benchmarkanja compute snage procesora, jer se ne fokusiraju na gaming pa ti njihova recenzija daje odgovor na tvoje pitanje o kakvom se CPU-u radi. Što se gaminga tiče, vidiš da je 7600x u par FPS-a razlike u odnosu na 12900K pa možeš sam na temelju toga odlučiti je li bolji ili lošiji proizvod od Intela (pogotovo kada uzmeš jače Zen 4 SKU-ove od 7600x u obzir). |
#14 | |
Retro hardware fan
Postovi: 95
12600kf sa ddr4 platformom, bdie ram, kao što sam rekao u izravnom sučeljavanju dobija 7600x. 7600x je proc zategnut do ibera, dok se 12600kf itekako dobro kloka jer je hladniji ohoho. i5 12600kf ima 40% jači MT i jednak ST kao 7600x ali za debelo manje para. Ako vidimo cijenu jednog proca, ram i ploče vs drugog proca, ddra5 i am5, stvari su jednostavne. Da je intel izbacio proc sa ovakvim temperaturama bilo bi žestoko sprdanje. Kao sto sam rekao ako zelis amd i top performanse 5800x3d je isus bog za sve. |
#15 | ||
Postovi: 8,667
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: Brko. 26.09.2022. u 19:21. |
#16 |
Lokacija: Zd
Postovi: 4,775
Ukratko, 7600x je brutalan 6-core procesor, ispunio je moja očekivanja a vjerujem i većine ostalih... Odličan skok u performansama u odnosu na prijašnju generaciju (5600x), uz to još diše za vratom jednom 12900K, nuff said ![]() Zadnje izmijenjeno od: Sn4k3. 26.09.2022. u 18:00. |
#17 |
Prvoklasni Krkan
Postovi: 5,481
Pa ja bi se složio da je za gaming očito 5800X3D ''best buy''. Namjerno pod navodnike jer ni on nije jeftin, ali je koliko vidim jako blizu zen4. Jeftiniji je u kombinaciji sa pločom i RAMom, a i može ga se hladiti sa zračnim kulerom tj ne treba biti biti neka high end voda. RDNA2 integruše je vidim naštelana u mm da bude ista kao intelove integruše. Ovo je IMHO def za preskok. Vidjet ćemo z4x3d varijantu. |
#18 | |||
Lokacija: Lawl
Postovi: 1,381
https://www.techpowerup.com/review/a...5-7600x/7.html 12600K na Nabavi još uvijek košta cca 2700 kn. Nemoj krasti netočne postove od drugih sa Bug foruma pa nećeš ispadati smiješan. ![]() Citiraj:
![]() Citiraj:
![]() U istom tonu: ![]() Dakle, ti nemaš ni jednu originalnu misao koju si iznijeo, kopiraš postove od bota koji je na drugom forumu registrian prije 7 tjedana. Dolaziš na ovaj forum isključivo sa namjerom trolanja i poticanja flejma, i većina postova ti je od danas, kad su izašle recenzije Zena. |
#19 |
All-rounder
Datum registracije: Sep 2013
Postovi: 1,342
Ima na HU videu na 30:00 cost per frame analiza, uključuje mbo i ram. Da, 12600k je bolji, 5800x3D je mrvicu bolji, ali 5600x je najbolji ako je to metrika... Ja se slažem da je riječ o premalenom pomaku u odnosu na Zen 3 ako se radi o cistoj nadogradnji, bacanje novaca. Mbo i ddr5 cijene se moraju malo smiriti još. Ali da su performanse tu, jesu. Dobar release. |
#20 |
Postovi: 4,511
Po trenutnim cijenama svatko kome je bitno uloženo/dobiveno kupiti će ryzen 5600 i B550 ploču. Za cijenu Ryzena 7600X kupiš Ryzen 5600, B550 i 16 gb DDR4 govorim iz glave, nisam išao točno u kunu provjeravati cijene. Sve ukpno slabiji si u gamingu sa 177 fpsa u prosjeku naprema 211 fpsa. Minimumi 136 vs 166..ak imaš 144 hz monitor sa fresyncom ne vjerujem da buš skužio golim okom. A razliku u novcima uložiš u bržu grafu. |
#21 | |
Retro hardware fan
Postovi: 95
Ocito da ovdje vlada jednoumlje, tako da nema smisla komentirati uopce.. |
#22 | |
Prvoklasni Krkan
Postovi: 5,481
![]() Nisam gledao sve videe, ali jel more TLDR onog video od der8aurea ili tko je već napravio delid. Pretpostavljam da je bar 15+ stupnjeva dole. Vraćamo se u dobra stara vremena Athlona i Athlona XP Nabavit sheam i udaraj miško direkt po jezgri. |
#23 |
smeghead
Postovi: 3,195
Ispada jako dobar proc ovaj 7600x. Ali opet mislim da je bolja kombinacija 5600x i recimo 3080, nego 7600x i 3060ti sta dode isto cijenom. Ako se vec ima jaka grafa onda radije uzet 7600. Mislim da ce obicni 7600 biti opet super kupovina jednoga dana kada ga izbace, i do onda ce ddr 5 i maticne past u cijeni. Sent from my VOG-L29 using Tapatalk |
#25 | |
Lokacija: Lawl
Postovi: 1,381
Gdje je jedna činjenica u ovoj izjavi: Citiraj:
Niti ima 40% veći MT niti je debelo manje para. |
#26 | |
Postovi: 8,667
#27 |
Postovi: 900
Možemo se mi tu prepirati koliko god želimo, no gaming krunu će uzeti AMD sa svojim 3d modelima, 3dcache druge generacije u kombinaciji sa znatno višim taktom i raznim poboljšanjima u latenciji će lijepo šišati i Zen 4, i ADL, i RPL trošeći osjetno manje energije. |
#28 | |
Retro hardware fan
Postovi: 95
7600x 3000kn + 2700kn x670+ 1300kn 16GB ddr5 |
#29 |
Postovi: 4,511
#30 | |
Lokacija: Lawl
Postovi: 1,381
Ne znam uopće zašto stojiš iza netočne izjave koja uopće nije tvoja, izmišljanje i naštelavanja cijena ne pomažu. |
