#241 |
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,228
MSI’s Next-Gen MEG Power Supply Lineup Is ATX 3.0 Standard Ready, Designed To Sustain 3x ‘Power Excursions’ For Next-Gen GPUs https://wccftech.com/msi-next-gen-me...n-gpus/?beta=1 Cudi me da Seasonic i Corsair nisu među prvima koji su izbacili nova ATX 3.0 napajanja... https://twitter.com/g01d3nm4ng0/stat...xt-gen-gpus%2F ![]()
/connect 185.107.96.125:28990 server rcon: oldschool COD2 PCekspert ekipa https://discord.com/invite/zZ4PeqVpBv Zadnje izmijenjeno od: Blue Spirit. 26.06.2022. u 14:41. |
#242 | ||||
Postovi: 8,657
Nastavno na priču o povećanoj potrošnji s nadolazećim GPU generacijama, novi GeForce RTX 4000 i Radeon RX 7000 modeli su po svemu sudeći samo početak puno veće priče koja je već počela u HPC svijetu i s vremenom će doći do prosječnog korisnika. FSR 2.0 je svega par dana nakon što je pušten u open-source opticaj i neslužbeno pripasan u poprilično razvikan naslov, pa ne bude čudno kad/ako na isti/sličan način sve više igara prigrli FSR uz DLSS i svi sretni i zadovoljni. ![]() Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX |
#243 |
Postovi: 2,228
Ray Tracing support with Lumen Hardware Ray Tracing: Standalone Ray Tracing features are being deprecated in Unreal Engine 5 . However, the engine's ability to compute these lighting effects is not being removed, since Lumen covers these lighting features. https://docs.unrealengine.com/5.0/en...gration-guide/ |
Epyc je odlucio ne koristit RTX u Unreal Enginu 5 jer je RTX previše performance taxing ; u kojem je napravio i implementirao svoju metodu LUMEN koja dosta ili probližno dobra a bez gubitka perfomasi.
https://docs.unrealengine.com/5.0/en...worthyChanges/ ![]() |
#244 |
Datum registracije: Feb 2021
Lokacija: TRPI
Postovi: 456
Sto kazete na na novu entry Gtx 1630? Cijene se krecu od 170-200$ te je slabija od 1050Ti koja je izasla 2016. za 140$, uz to 1630 koristi 6pin konektor na trenutnim modelima koji su u ponudi. |
#245 | |
Lokacija: Cro
Postovi: 1,045
Problem je što režu proizvodnju (AMD također), novih generacija jer znaju da će bit flod od majning kartica. Govore i o odgodi nove generacije. Sve da samo zadrže cijene na koje su se sad naviknuli. Štoviše pojavljuje se i downsizing, tako se nagađa da će RTX 4080 imat sabirnicu od samo 256 bita, kao i RTX 4070 od samo 160bita i samo 10GB rama. Manja sabirnica je znatno jeftinija (manje stazica, jeftinije i brže štampanje kartice) Da su im (AMD i NVIDIA) buduće generacije znatno bolje od trenutnih ne bi to radili... Meni osobno nije problem dat ni lovu u peaku cijene, al odbijem davat lovu iznad moje neke psihološke granice. Naprimjer za RTX 4080 ne namjeravam dat više od 9k. Vjerujem da će kad izađu bit RTX 3080 12GB i RTX 3080ti za 4xxx kn. Realno i stari pascal 1080ti može uz manje detalj gurat sve novo sljedeće dvije godine u 1440p. Tako da će od mene dobit k ako seru s cijenama. Zamjeniš pastu/padove, isprintaš nosače za 2 noctue i miran si. |
#246 |
Lokacija: TRPI
Postovi: 456
@markecSMB Da, high end kartice postaju nesto kao hyper automobili, ogromne cijene a performanse i nisu toliko bolje od nekih srednjih kartica. 4080 po nikakvoj logici nebi smjela ici preko 1000 Eur, jer ako uhvate taj trend i 1500 Eur ce postati standard ubrzo za Rtx xx80. Rtx 3070-3080 su sasvim dovoljne za visoke detalje 1440p gaming slijedecih 5 godina. |
#247 | ||
Postovi: 8,657
Kaj se tiče "rezanja sabirnice", AMD za RDNA 3 kao i za RDNA 2 prije toga, koristi (povećani) Infinity Cache tak da na kraju s užom/manjom sabirnicom dobe (još) bolje performanse. Primjera radi, 256-bit GTX 1080 i 192-bit + 96MB Infinity Cache RX 6700 XT koje se bez problema (u tom trenutku) nose s prethonicima koji su pak imali 512-bit, 384-bit ili 2048-bit i 4096-bit sabirnice. Arhitektura je tu bitnija stavka i očito je da nVidia za RTX 4000 seriju sprema po svega više, tako da će na kraju jedna RTX 4060 sasvim lako imati performanse u rangu npr. RTX 3070/3080 sa samo 128-bitnom sabirnicom. Po pitanju performansi, nova RTX 4000 i RX 7000 generacija budu svakak bolje od ovih aktualnih, možda ne budu duplo brže u svemu, ali skok bude osjetan. Nažalost, potrošnja, zagrijavanje i cijena, posebice kod nVidia modela, budu taj skok u performansama pratili u stopu. Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 04.07.2022. u 17:53. |
#248 | |
mag.math.
Datum registracije: Dec 2021
Lokacija: Daruvar/Zagreb, Republika Hrvatska
Postovi: 366
#249 | |
Lokacija: Cro
Postovi: 1,045
To što imam staro 5g je iz par razloga. Kad je izašao RTX 2080ti, bio je samo 25% brži, i smatram da je to premalo pa sam preskočio. 3080 dok još nije bilo TI sam htio kupit no onda je bila fama s kondenzatorima i nestabilnosti. Kasnije sam odbio kupit po smješnim cijenama. GTX 1080ti koju sam kupio je tad kad sam kupio bila najskuplja na tržištu za 850€. Ako klasu (80 u odnosu na TI) manje ne mogu dobit za 50% više love sad dakle nekih 1250€ cca 9kkn, onda nek odjebu. Zašto bi nužno morao bit osjetno veći porast performansi, nije bio na RTX 2xxx u odnosu na GTX 1xxx? https://www.youtube.com/watch?v=ivCv...nnel=Benchmark |
#250 |
Postovi: 8,657
Da, Turing nije imal osjetno veći porast u performansama, a kad se k tome doda ionak odlična Pascal arhitektura u kombinaciji s rabljenim GTX 1000 modelima, većina ljudi je kao i ti, fino preskočila Turing seriju. I onda je stigel Ampere i jedna RTX 3070 je nudila performanse RTX 2080 Ti za manje novaca, bar dok se kripto društvo i COVID-19 nisu pobrinuli za nestašicu svega uz sulude cijene. Sudeći prema svim dosad procurenim potencijalnim specifikacijama, nadolazeći Ada Lovelace RTX 4000 modeli će za svoj mid-range nuditi performanse sadašnjih high-end Ampere modela i stvarno ne bude čudno, ako jedna RTX 4060 ima performanse u rangu sa RTX 3070/3080. Na kraju dana, kak god okreneš i koju god novu karticu odlučil kupiti, vrlo vjerojatno budeš moral mijenjati kompletnu platformu, jer se 8700K već danas malo teže nosi s Ampere modelima, a kamoli kad stigne RTX 4000 i RX 7000 serija.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 04.07.2022. u 23:32. |
#251 | |
Lokacija: Cro
Postovi: 1,045
Kupujem na firmu, i bitno mi je da bude na stanju ove godine, da mi ide u trošak ove godine. Sad se nagađa da će odgodit, što mi ne odgovara nikako. Ne znam baš kako bi me porezna gledala na grafičku samo da kupim. Kakve će performanse bit to će se vidjet, al da imaju oboje neku radikalnu arhitekturu nebi dizali toliko TDP. Između GTX 1 i RTX 2 je bio poerformance/W pomak za istu klasu, al između 2 i 3 nije bio. Moje mišljenje je da neće bit pomak, tak da će bit pomak koliki je u TDP razlici, dakle neki 30%, više manje koliki je bio pomak u zadnje dvije generacije. Smatram da je glupo bilo dat 1200€ za pomak od 25-30%, uz istu količinu rama, i nisam bio jedini. Potrošnja. Jedne godine me toliko živcirala buka, da sam 980ti zamjenio za 1070, koja je bila marginalno sporija al znatno manje bučna (250W, naspram 170W). Kasnije sam kupio 1080ti i ovu dao sinu. 1080ti je 250W, i kupio sam najtišu koju sam mogao kupit, sad mi je na 200W. Uopće ne mogu zamislit 420W, to ekspresno ide undervolt i underclock na 300 il manje. 100 ljudi sto ćudi, 100 žena 200 sisa, svako ima svoju filozofiju |
#252 |
Postovi: 8,526
Mislim da je promjena platforme danas najmanji problem. Jedan i5 12gen se nosi s bilo kojom 3000 grafom, a vjerojatno ce i 4000 osim mozda one najjace. A i wattaza nece biti povezana s bukom. Cisto sumnjam. |
#253 | |
Postovi: 8,657
Da, Alder Lake/Raptor Lake i Ryzen 5000 serija budu još jedno dulje vrijeme aktualni, tu nema brige. Citiraj:
Po pitanju odgađanja, nVidia se tu očito preračunala, pa čak i ako izdaju nešto u jesenskom periodu, vrlo vjerojatno budu to RTX 4090 modeli, pune recenzije gaming crown natpisa po prije spomenutoj računici od 10% boljih performansi uz 150W višu potrošnju u odnosu na konkurenciju.
#255 |
Postovi: 8,657
I to kaj veliš, a cijene su za obje opcije sad donekle i koliko-toliko normalne, pa ako se tak nastavi još nekoliko mjeseci, dobro bude. ![]()
#256 |
Lokacija: rijeka
Postovi: 3,902
https://wccftech.com/nvidia-geforce-...-75-ghz-rumor/ mhhm,mislio da će na gtx 4060 stavit 10 rama ne 8, 4070 ima 10 a trebalo bi bar 12-14. |
#258 | |
Lokacija: Cro
Postovi: 1,045
Imao sam prije 900 serije, neku uber total high end radeon s dva čipa na kartici. I to je bilo najgore govno ikad, a dao sam bijesnu paru za to. Tako da me to podsjeća na to. Drajveri su bili za kurac, taj crosfire nije radio kako spada u većini igri, totalni promašaj. To tajlanje je samo da im je jeftinije. TAj crosfire i SLI (imao i to) nikad nije radio kako spada, microstutteri i sranja. Ne impliciram da će nužno to bit tako, no potencijalno postoje problemi. ------------------------------------------------------------------------------------ Što se tiče W i buke, pa to je jasna korelacija. Ak se nešto znatno više grije, onda treba više buke da se ta topllina odvede. Volio bi da postane standard 2x 12CM ventilatora s malim RPM, što je asus napravio s noctuom. Odlično rješenje, ako će bit nešto takovo to mi je prioritet i nije mi žao dat ekstra lovu za to. |
#260 | |
bu
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,631
Chiplet dizajn nije isto što i Crossfire kada su 2 odvojena grafička čipa spojena na neki način ![]()
#261 |
Postovi: 8,657
Da, to je bilo onda, SLi i CrossFire su zajedno s dual-GPU rješenjima imali kojekavih problema, ali chiplet dizajn koji AMD prakticira već nekoliko generacija, sad ide za sve, neovisno o kojoj firmi je riječ, jer lagano svi skupa udaraju u zid, a očekuje se porast performansi iz generacije u generaciju. nVidia dulje od AMD-a radi na svojim chiplet/tiles GPU rješenjima, ali negdje je zapelo, pa ih još uvijek nema na tržištu, mada čim i to poslože, idu nove nVidia kartice u tom smjeru. AMD ima sreću u nesreći, pa im sva prijašna rješenja koja su na ovaj ili onaj način podbacila sada dolaze kao škola koju su prošli, dok Zen, CDNA i RDNA arhitekture bazirane na chiplet dizajnu - kad su u pitanju performanse rade kao da riječ o monolitnim rješenjima, dok se u pozadini kriju LEGO kockice koje se bez problema slažu i skaliraju po potrebi. U toj priči je jedino još Intel izgubljen u vlastitoj magli, jer njihovi ARC GPU modeli budu im stigli prekasno u odnosu na ovo kaj nVidia i Radeon već imaju spremno.
#262 | |
Lokacija: Cro
Postovi: 1,045
Ako radiš veliki čip s integriranom sabirnicom, postoji velika šansa da će dio bit sjeban....tak i segmentiraju. Ovo da gradiš od kockica malih, pa povezuješ s nekom sabirnicom, mora bit neki delay kad informacija ide s modula na modul. |
#263 | |
mag.math.
Postovi: 366
#264 | |
Postovi: 8,657
nVidia Hopper je najbolji pokazatelj što se može očekivati s nadolazećim RTX 4000 modelima i kad-tad budu baš kao i AMD i Intel morali preći na chiplet rješenja. Ne možemo unedogled imati ogromne monolitne GPU čipove, jer ni sad nismo daleko od 1kW čudovišta.
#265 |
Datum registracije: May 2003
Postovi: 1,116
SS |
#266 |
Postovi: 8,526
Da ali grijanje same grafe nije čista kalkulacija. Tu je kvalitetna materijala hladnjaka, kvaliteta izrade, kvaliteta ventilatora itd. Dobar proizvođač će riješiti pitanje tihog hlađenja, kao i uvijek dosad. |
#268 |
Prvoklasni Krkan
Postovi: 5,477
Majko mila više sa tom štednjom RAM-a. IMHO bi samo entry lvl trebao imat 8gb, a sve ostalo 12+. Pa pomalo 8gb nije dosta više ni za 1440p. Doduše, vj će zeleni ovime natjerati devove da optimiziraju igre za manje RAM-a, a i držat će rudare pod kontrolom...valjda. ![]() Ugl užas, ne izgleda mi ovo uopće privlačno. Mislim da se Jakna još dan danas lupa po glavi zbog njihove ''najveće greške'' zvane Pascal i mislim da nikada nećemo vidjet takav skok u perf/potrošnji. ![]() |
#269 |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Više W apsolutno znači veće grijanje. Ono što ti želiš reći je da više W ne znači veće temperature grafičke. To opet ne znači da će RTX 4070 s TDP-om od 300 W magično manje zagrijavati ostatak komponenti u kućištu i okolno prostor u odnosu na RX 580 s TDP-om od 150 W.
#270 |
Lokacija: Cro
Postovi: 1,045
Ono što meni nije jasno na ovoj slici i nema mi smisla je. 60% više FP32 jedinica, 50% više memorije i samo 10% veća potrošnja od 4090 u odnosu na 4080 (450W u odnosu na 420W). Nema mi to smisla. Generalno ne vjerujem previše ovome. |
