Staro 21.06.2022., 23:27   #5491
Mladenxy
Mladenxy's Avatar
Postovi: 4,528
Također svaki puta limited, pa prebacim ručno.
Staro 21.06.2022., 23:46   #5492
Postovi: 8,737
Sudeći prema Correcting HDMI Colour on nVidia and AMD GPUs članku, problem je tak jasno u šrot HDMI i DisplayPort standardima.
When a monitor with a resolution and refresh rate in common with TVs (e.g. 1920 x 1080 @60Hz) is connected to an Nvidia GPU by HDMI or DVI-HDMI cable, the GPU may to treat the screen as an ‘HDTV’ rather than a monitor. This is also quite common when using DP, even though that’s a PC-only connection. You can see how the graphics driver categorises things for the Full HD resolution as that shared with a TV by opening the Nvidia Control Panel and navigating to ‘Display’ – ‘Change resolution’. It will usually be listed under ‘Ultra HD, HD, SD’ as ‘1080p, 1920 x 1080 (native)’ as shown below. This first resolution list in Nvidia Control Panel lists resolution and refresh rate combinations which are listed in the EDID of the monitor as ‘TV’ resolutions rather than ‘PC’ resolutions. But the problem is not simply that the resolution is listed in the wrong way, it’s the effect that this can have on the colour signal that is important. The GPU may send out a ‘Limited Range RGB 16-235’ colour signal by default rather than the optimal ‘Full Range RGB 0-255’ signal.
Unlike when connecting a monitor to an Nvidia GPU using HDMI, connecting an AMD GPU via HDMI is usually less problematic when it comes to the colour signal. The image is not washed out and it looks very much as it should on most monitors. When using HDMI, the default behaviour of AMD GPUs may not be to use a ‘Limited Range RGB (16-235)’ signal like Nvidia GPUs, but rather to use a ‘YCbCr 444’ signal which is referred to by AMD as ‘YCbCr 4:4:4’. In our testing, the use of ‘YCbCr 4:4:4’ compared to ‘Full Range RGB (0-255)’ had a slightly more pronounced effect on white point, contrast and measured colour values on an AMD vs. Nvidia GPU. It is still nowhere near as pronounced as comparing Nvidia’s default ‘Limited Range’ signal with ‘Full Range’ on models which show clear ‘Limited Range’ issues.
We’re happy to see that since this article was first published, Nvidia have added that drop-down ‘Dynamic range’ option to the driver.
AMD usually always handles the signal correctly as ‘Full Range RGB’ by default in their more recent drivers.
Isti šrot video standardi i popratno kablovinje su bili razlog hajke na "sfušane" Radeon drivere za RX 5700 seriju koja se onda izbjegavala, samo da bi se naposljetku ispostavilo da je do HDMI/DisplayPort pizdarija.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750
Zadnje izmijenjeno od: The Exiled. 21.06.2022. u 23:54.
Staro 21.06.2022., 23:58   #5493
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
I dalje je to debelo preskupo za rabljenu karticu, ne vrijedi ni blizu 3000 kn.
Staro 22.06.2022., 00:09   #5494
spawn
spawn's Avatar
Postovi: 8,564
Da je u kablu sranje,možda jest,ali da je samo to u pitanju isto sranje bi se dešavalo i na Amdu što nije slučaj. Uglavnom, dobro da se može sredit.
Staro 22.06.2022., 00:12   #5495
Postovi: 8,737
Da, nije samo kabel, već cijela skalamerija očito, pa ako driver nešto prepozna kao TV rezoluciju, ode odmah i postavka na Limited, umjesto na Full range. Čušpajz sve u svemu.
‘Limited’ is used by default on Full HD monitors connected using HDMI and some connected using DisplayPort, when running at 60Hz.
Staro 24.06.2022., 17:59   #5496
Alfredo nr.3
Alfredo nr.3's Avatar
Lokacija: Požega
Postovi: 1,302
Ponukan raspravom o hlađenju odlučio sam maknuti prednji poklopac na kučištu Antec NX600 ispred kojeg rade tri ventilatora. Sada mogu neometano radit pošto im ne smeta RGB plastika. Uz to sam vratio stakleni bočni poklopac koji sam prethodno bio skinuo. Temp grafe su pale sa 73 na 65 i hotspot sa 86.1 na 77.8 u max loadu. Fan speed je pao sa 1735(59%) na 1335(41%).
Alfredo nr.3 je offline   Reply With Quote
Staro 24.06.2022., 19:57   #5497
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,520
Gledam ovo što spominjete za reprodukciju boja i čini mi se da ste mrvu fulali.
Čini mi se da se uvijek svi referiraju na video dio u driverima (''adjust video color settings'' tab pod ''video''), a to je izgleda samo za video, tj filmove ili štogod. Kod mene je npr pod ''Display'' pa ''change resolution'' tabom ispod odabira rezolucije uredno bilo stavljeno na full. Znam jer sam neki dan instalirao nove drivere, a prethodno stare uvijek mičem sa DDU.
I samo napomena, meni win update uvijek instalira drivere za monitor pa je možda do toga, ali uglavnom, meni je to već odabrano. Pod Video dijelom nije, e tu ga sam prebacim.
Inače imate i ovo za provjeru:
There's a test image online for confirming if your display is properly showing RGB Full range: http://www.lagom.nl/lcd-test/img/blacktest.png which is easy enough to verify, you set your source to Full, your display to Full (black level: normal etc) and confirm if you can see the first row of black squares.
I ako vidite prvi red, sve je OK, meni se recimo na monitoru uredno vidi dok na telki ne.
I to je normalno jer je većina telki limited, a većina monitora full.
Slobodno me dodajte na PSN
Staro 25.06.2022., 00:54   #5498
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,553
S obzirom da je RTX 20X0 tema zamrla, nadam se da je oke da tu pitam kad već pišete o tome.. Imam 2060 Gigabyte 6GB, vrijedi li da pričam po nekim postavkama? Nisam neki zahtjevan korisnik i ne igram neke prezahtjevne igre pa bi možda undervolta-o ili tako nešto?
Hala Madrid!
Staro 25.06.2022., 01:38   #5499
stitrek
Datum registracije: Feb 2021
Lokacija: TRPI
Postovi: 456
Ako ne igras zahtjevne igre i ako imas adekvatno hladenje kucista, onda nema smisla podesavati karticu, testiraj sa otvorenom bocnom stranicom kucista, mozda temperature budu jos nize
Staro 26.06.2022., 23:59   #5500
spawn
spawn's Avatar
Postovi: 8,564
Ja bih najprije probao igrati nešto s njom pa vidio kakve su temp.
Staro 27.06.2022., 10:46   #5501
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,553
Igrao sam LoL i ne prelazi 55C, ali se vjerojatno nije previše ni naprezala dok sam to igrao. Isprobam nešto zahtjevnije.
Hala Madrid!
Staro 27.06.2022., 12:21   #5502
spawn
spawn's Avatar
Postovi: 8,564
Ma ja ne bih cackao nista. Probaj jos neku jacu ugru, ako ne ide preko 65 ne trebas cackat nista. Cak i 70 je normalno osim ako zelis malo hladnije
Staro 02.07.2022., 16:00   #5503
jucca
jucca's Avatar
Postovi: 1,717
Nisam par dana palio komp, danas dodjem, instaliram Etype USB header na PCIE USB 3.1 adapter i nece da upali. Po kodovima ispada da ne prepoznaje GPU. Skinuo adapter, probao clearat CMOS, nista. Ventilatori se zavrte prilikom boota, no onda prestanu raditi i pocne "bipikat". Jedan dugi, tri kratka. Jel moguce da je adapter na neki nacin ubio GPU. Radi se o ovom:
https://www.amazon.de/-/en/gp/aw/d/B...?ie=UTF8&psc=1
Ostatak kompa
Asus 3070 dual OC 8GB
Asus Prime Z-690 D4 Wifi
12600k
2x16 GB Kingston Fury Beast DDR4
Asus TUF 750W
Sve staro par mjeseci.
https://youtu.be/DMsgODLOdFw
Sent from my SM-S908B using Tapatalk
Zadnje izmijenjeno od: jucca. 02.07.2022. u 16:12.
Staro 02.07.2022., 16:50   #5504
Postovi: 8,737
Probaj izvaditi GeForce GPU, pa ostavi samo Intel iGPU i podesi video-izlaze na matičnu.
Isto tak možeš GeForce, ako se ispostavi da Intel iGPU daje sliku, prebaciti u drugi PCI-E.
Staro 02.07.2022., 17:12   #5505
jucca
jucca's Avatar
Postovi: 1,717
Mislio sam da K procesori nemaju iGPU.
Probao bez nje, probao u drugi slot jos prije. Ista stvar.
Staro 02.07.2022., 17:18   #5506
Postovi: 8,737
F modeli nemaju iGPU, ali ako i iGPU ne prolazi onda možeš probati sve rastaviti, pa samo na stolu upogoniti CPU + iGPU, RAM, MBO i PSU, tak da eliminiraš ostale komponente.
I provjeri za svaki slučaj da ti je u BIOS-u podešeno da se koristi iGPU za video izlaze, da ne ispadne da sve radi bez GeForce GPU, samo je bilo do postavke u BIOS-u.
Možeš komotno i CPU izvaditi, pa Clear CMOS kad je sve na stolu rastavljeno, bez GeForce GPU-a, jer ako ni tada nemaš slike pomoću iGPU-a, onda je moguće ploča otišla.
Zadnje izmijenjeno od: The Exiled. 02.07.2022. u 17:37.
Staro 02.07.2022., 17:36   #5507
jucca
jucca's Avatar
Postovi: 1,717
Thx.
Skinuo sve, osim keksa memorije i proca, i opet isto.
Problem je što ne mogu ni do BIOS.a. ne daje sliku.
Staro 02.07.2022., 17:38   #5508
Postovi: 8,737
Nadopunil sam prethodni post, pa eventualno još da probaš ovaj dio s CPU-om, van iz socekta i nazad na mjesto uz Clear CMOS.
Staro 02.07.2022., 17:47   #5509
zig
zig's Avatar
Datum registracije: Jan 2010
Postovi: 395
Ekipa, koliko bih dobio prijelazom na RTX3050Ti, u odnosu na sadašnju GTX1660Ti ?
Kolika bi uopce bila iaplativa nadoplata ?
Zahvale unaprijed
zig je offline   Reply With Quote
Staro 02.07.2022., 17:53   #5510
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
RTX 3050 Ti ne postoji (za desktop), postoji samo RTX 3050 a po performansama je ista kao i GTX 1660 Ti.
Staro 02.07.2022., 17:56   #5511
zig
zig's Avatar
Postovi: 395
Uff, onda aam nešto pobrkao, hvala na odgovoru.
Staro 02.07.2022., 18:14   #5512
jucca
jucca's Avatar
Postovi: 1,717
Thx. Bas mi je i @Nikky spominjao maloprije za tu semu.
Probam prije karticu kod prike, i usput pastu uzet ako bude trebalo proc vadit.
Hvala ti 👍
Staro 03.07.2022., 16:22   #5513
jucca
jucca's Avatar
Postovi: 1,717
Rjeseno.
Probao grafu kod prike, radi sve.
Nakon sto je cijelu noc ploca bila bez baterije, upalila je i dala sliku na iGPU. Vratio karticu, sve radi.
Dodjem doma, ustekam monitor (43" Samsung UW CJ9), opet isto. No GPU detected.
Ustekam drugi monitor na drugi DP, napokon boota, i naživo spojim ponovo 43" Samsunga, i sad konacno, sve radi. Ne kuzim sta mu bi.
Staro 03.07.2022., 16:41   #5514
stitrek
Lokacija: TRPI
Postovi: 456
@jucca
Imao sam takav problem kad sam spajao DVI to HDMI adapter na R9 255, kad sam stavio kvalitetniji HDMI kabel proradilo je.
Staro 03.07.2022., 17:11   #5515
jucca
jucca's Avatar
Postovi: 1,717
Sta je najcudnije, sve se desilo nakon sto sam stavio USB header adapter. Monitore i kabele nije nitko dirao. Isti kabeli su i sad.
Staro 24.07.2022., 16:40   #5516
zig
zig's Avatar
Postovi: 395
Može vaše mišljenje, RTX3070 (Gigabyte Gaming OC ili MSI Gaming Z Trio) ?
Ako sam dobro shvatio, MSI je nešto hladnija i nešto tiša ?
Kakve su razlike po performansama ?
Možda više nekako naginjem ka MSI, ali koliko vidim registracijom direktno na Gigabyte, dobije se 4 godine jamstva, dok je na MSI 3 godine ako se ne varam ?
Btw., cijena je identična, sve ostalo nebitno.
Unaprijed hvala
Zadnje izmijenjeno od: zig. 24.07.2022. u 16:57.
Staro 24.07.2022., 17:56   #5517
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Autor zig Pregled postova
Unaprijed hvala
Razlike u performansama zanemarive.. Kolko para?
Staro 24.07.2022., 18:21   #5518
zig
zig's Avatar
Postovi: 395
Autor ansha Pregled postova
Napisao sam, cijena ista.
Staro 24.07.2022., 18:54   #5519
gazda099
gazda099's Avatar
Lokacija: Velika Gorica
Postovi: 175
što ti je važnije, garancija ili temp i buka?
gazda099 je offline   Reply With Quote
Staro 24.07.2022., 19:07   #5520
zig
zig's Avatar
Postovi: 395
Autor gazda099 Pregled postova
Temperatura, buka ako je razlika osjetna, a zanima me i razlika u performansama kakva je.
