Staro 13.06.2022., 12:40   #1201
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,503
Vjerojatno bila cijena bez pdva pa ispravili
Takve stvari ne pitaš nego narucis ako ti treba grafa. 2060 je starija ali jača od 3050 koja je dosta skuplja . Iako je to vjerojatno bila greška a ne nekakva akcija.
A jbg kad se ne razumijem, ali naručio sam po toj “akcijskoj” cijeni. Sad je pitanje hoće li otkazati.
Hala Madrid!
Staro 13.06.2022., 14:05   #1202
spawn
spawn's Avatar
Postovi: 8,490
Nema tu puno filozofije. Na brzinu yt 2060 vs neka novija i nabava da vidis ostale cijene i to je to. . Naravno ako ti treba. Bila je ta grafa i za 2250kn, isto dobra cijena.
Staro 13.06.2022., 15:33   #1203
darkijas
darkijas's Avatar
Postovi: 1,809
Jel se isplati dati 300kn vise za rtx 2060 12gb u odnosu na rtx 2060 6gb
darkijas je offline   Reply With Quote
Staro 13.06.2022., 18:46   #1204
spawn
spawn's Avatar
Postovi: 8,490
Ovisi koliko novaca ces dati za tu grafu i sta igras. Ako za jos malo vecu razliku mozes dobit nesto bolje s 8gb onda radije to.
Staro 29.06.2022., 18:40   #1205
Postovi: 8,555
Scammers may have found a way to hide defective memory on used mining GPUs
As anyone could have predicted, cryptocurrency miners are looking to unload their used GPUs now that it may no longer be profitable to mine Ethereum and other blockchain assets. Before you buy a card at a potentially steep discount, though, be aware that you might not end up getting what you thought you were purchasing. That's true in any situation in which you've decided to buy a used GPU (or anything preowned), but you should be especially cautious now that the cryptocurrency market is tumbling.
While large scale mining operations can afford to ride out the downturn in hopes of a recovery, casual miners and medium sized mining outfits are flooding the market with used GPUs. Plus there's the looming switch to Ethereum 2.0, which could drastically drop the demand for GPUs among miners. It's no coincidence that GPU prices continue to fall in general—as we wrote about earlier this week, Radeon graphics cards have plunged below MSRP in some markets, and GeForce cards are not far behind. This is not solely because of crypto, but the correlation over time (and particularly more recently) is certainly hard to ignore. Here's where things get tricky, though. You never know exactly what you're getting when you purchase a used graphics card, and there are reports that miners are scamming people by somehow masking defective memory on their GPUs.
These reports all seem to trace back to an Chinese forum post, in which in the OP warns, "Don't buy a mining card," according to a Google translation. The poster claims they bought a used MSI GeForce RTX 3080 Suprim X for around half the retail value, and then discovered that 2GB of GDDR6 memory was defective. In normal situations, defective VRAM would prevent a graphics card from running. But according to the poster, the card was modified to essentially mask the defective memory and continue to function with 8GB of GDDR6 instead of 10GB.
There's a Chinese-language video at Bilibili that purportedly shows this mod, and from what we can gather, it's a matter of pulling the card's BIOS and tweaking it to ignore the memory addresses for the dead RAM. Note that we're not 100 percent that this is what's going on, that's just what it looks like from what we can glean from the video. Another explanation posed in the thread is that it's a fake card and/or a GeForce RTX 3070 Ti modded to be recognized as a GeForce RTX 3080. However, the OP claims to have confirmed that it is actually a GeForce RTX 3080 with 2GB of defective memory.
Buying a previously owned card that was used to mine crypto doesn't necessarily mean you're getting a defective unit or one that can't perform as well as new. In many cases, the GPU is actually running under spec, because that's not the component that does the heavy lifting. It's mostly about the memory. At this point, it's probably better to wait for the next-gen models anyway, if for no other reason than to see what impact they have on prices for current-gen cards. If you do buy a used card, though, you might want to give it a good cleaning (dust off those fan blades and vents) and reapply the thermal paste, if you're comfortable doing that.
Izvor: HotHardware
Staro 29.06.2022., 22:27   #1206
spawn
spawn's Avatar
Postovi: 8,490
U prijevodu, sve više ljudi će lagati da se kartica koristila za mining. Lažu i sad, ali bit će toga i više i kod nas.
Staro 30.06.2022., 00:59   #1207
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,503
S obzirom da cijene novih padaju, ne vidim razlog zašto bi kupovao polovnu grafu više.
Hala Madrid!
Staro 30.06.2022., 01:01   #1208
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,623
Ako je nova 8k, a polovnu dobiješ recimo za 5-6k onda ne vidim razloga zašto ne
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 30.06.2022., 02:03   #1209
stitrek
Datum registracije: Feb 2021
Lokacija: TRPI
Postovi: 456
Autor maXonja Pregled postova
Kod skupih kartica je garancija dosta bitna, zato nije pametno kupovati polovne skupe kartice kojima brzo istice garancija ili je uopce nemaju, jedino ako se poznaje prodavatelj te dali je sa karticom rudareno.
Uz to brzo ce doci nove generacije kartica, tako da ce trziste biti prepuno i cijene polovnih ce jos vise ici dolje svaki mjesec.
Staro 30.06.2022., 07:27   #1210
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,623
Većina kartica ima garanciju još 1.5-2 godine, neke i više ako tvornički dolaze sa više od 3 god tako da što se toga tiče nije problem
Kad bi tako razmišljao onda nebi nikad kupio karticu jer kad izađe nova generacija onda će biti skupo, kad malo padnu cijene onda će većbiti staro i izlazit će nova generacija itd.
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 01.07.2022., 15:24   #1211
gazda099
gazda099's Avatar
Lokacija: Velika Gorica
Postovi: 170
koji je sirac ovim našim dućanima, oni još žive u 2021g
gazda099 je offline   Reply With Quote
Staro 01.07.2022., 19:06   #1212
R3nchi
R3nchi's Avatar
Datum registracije: Dec 2009
Postovi: 447
kako uopce idu sad 3070 i 3060ti po oglasima?
R3nchi je offline   Reply With Quote
Staro 01.07.2022., 19:07   #1213
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,623
3060 Ti idu po 3000kn (dobro, to je bio samo 1 oglas di je lik nekoliko komada prodavao, ostalo nema baš ispod 3500) pa naviše, 3070 4000kn naviše
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 02.07.2022., 13:27   #1214
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,309
Vidio ja danas jednu 3070 po 3600 kuna na njuški
Chuby je offline   Reply With Quote
Staro 02.07.2022., 14:08   #1215
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Yep, svi sa iole novijom grafom, bolje pričekati novi spike mini ga.
Staro 02.07.2022., 14:25   #1216
Le0n
Groarrr
Le0n's Avatar
Postovi: 438
Po 500Eur sam više puta naletio na 3060TI novu na Amazon/Ebay (Inno3D i sl.). Ne isplati se sada davat za to preko 2000kn rabljeno.
Staro 02.07.2022., 14:26   #1217
spawn
spawn's Avatar
Postovi: 8,490
Tko želi sada igrati, nema šanse da nađe za 2000kn rabljeno. To može neki preprodavač čekati jer mu nije hitno
Staro 02.07.2022., 15:21   #1218
gazda099
gazda099's Avatar
Postovi: 170
Autor Le0n Pregled postova
na mindfactory.de inno3d 3060ti 500 eura
Staro 02.07.2022., 15:28   #1219
R3nchi
R3nchi's Avatar
Postovi: 447
Ja sam mislio da ce cifre i vise padat
Staro 02.07.2022., 15:49   #1220
Le0n
Groarrr
Le0n's Avatar
Postovi: 438
Rabljeno tj. 2 godine stara tehnologija vrijedi 50% cijene novoga. Drugi neka plaćaju kako žele
Staro 02.07.2022., 16:03   #1221
gazda099
gazda099's Avatar
Postovi: 170
ima i tu istine, ali s obzirom na cijene do sada ovo i nije tako loše, makar mislim da je mudrije sačekati jesen
Staro 15.07.2022., 22:21   #1222
Wiz3m4n
Wiz3m4n's Avatar
Datum registracije: Apr 2009
Lokacija: Bjelovar
Postovi: 244
Od previše čekanja te samo bole noge ili guzica
Uvijek se može čekati nešto novije da se kupi, ili da ovom aktualnom padnu cijene onda no tada provedeš vrijeme u čekanju...iz iskustva sve preko 2000kn nebih kupovao bez garancije no danas je podosta toga sa još 1g. barem iste, mislim na kartice tipa rx 6600xt za kojih 2500kn ili koja 2060 super i sl. po 2000kn koje su dobra kupovina ako se naleti na takvo što....od rudarenih ne zazirem ako su ventilatori na mjestu i bios originalan
Wiz3m4n je offline   Reply With Quote
Staro 19.07.2022., 13:51   #1223
tomycrosound
Datum registracije: Jan 2010
Lokacija: Vinkovci
Postovi: 307
Pozdrav!
Klinci gejmaju na PC. 1050TI.
Palo mi na pamet mijenjati karticu, neku best buy varijantu, s najmanje para dobiti sto vise fps. Igra se na 1080p, ne planiram mijenjati monitor. (do 120fps)
Gledam 1660Ti. Nisam u toku.
Grafička kartica GAINWARD Pegasus GeForce GTX 1660Ti, 6GB GDDR6
Palit GTX1660Ti StormX, 6GB GDDR6, DVI, HDMI, DP, NE6166T018J9-161F
Jedna košta 4000, druga 2500, razlicite trgovine.
Je li ova skuplja stvarno bolja za tu razliku u cijeni?
“isplati” li se s 1050TI na 1660TI?
tomycrosound je offline   Reply With Quote
Staro 19.07.2022., 14:00   #1224
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,142
Autor tomycrosound Pregled postova
Pozdrav!
Za 1080p 1660Ti je dan danas sasvim dobra kartica.
I ja je imam i obzirom na monitor (1920x1200) nemam je namjeru mijenjati, igram na njoj povremeno već 2 godine. Moj put je bio 1050Ti->1060 3Gb ->1060 6Gb ->1660Ti (vjerojatno su ovi među koraci bili i bespotrebni ali bilo je prilika pa ajde)
Ali za 4000kn kupovati novu 1660Ti ipak ne. Ili nova za 2500kn (kako i spominješ) jer za 4000kn kupiš polovnu 3060Ti.
pogi je online   Reply With Quote
Staro 19.07.2022., 14:03   #1225
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,390
Ili im za 3500 uzmeš novu RTX 3060 ili RX 6600xt i neka peglaju u miru.
Osjetno jače grafe od 1660Ti za tu cijenu.
Slobodno me dodajte na PSN
Staro 19.07.2022., 14:14   #1226
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,841
Kupiš rabljenu za osjetno manje. Imaš kod kolege 6600xt na tržnici za 2500kn. Vjerojatno imaš još dobrih ponuda.
Staro 19.07.2022., 14:24   #1227
tomycrosound
Lokacija: Vinkovci
Postovi: 307
Koju Nvidia grafičku karticu kupiti - 5. dio
Cijene užasno različite, za istu oznaku karte... Očita razlika u proizvođaču, sve ostalo mi se čini isto. Ništa mi nije jasno.
Na pijaci navodno nova 3060 za 3200kn. Neotvorena.
Ne kontam, što je kupio ako nije ni otvorio.
Zadnje izmijenjeno od: tomycrosound. 19.07.2022. u 16:19.
Staro 19.07.2022., 23:34   #1228
spawn
spawn's Avatar
Postovi: 8,490
Pozdrav!
Preporucuje se 6600xt i 3060 ali imaj na umu da sa ryzenom 2600 ne budes uspio iskoristiti te grafe. Isprobao sam 6600xt,6650xt i 3050xt sa ryzen 2600,i3 10100f i i9 10850k zadanjih 10ak dana. 6600xt,6650 xt prodišu sa i9. a sa i3 10100f i ryzen 2600 su ok, ali fps je manji 20-30% kako u kojoj igri. Ako ćeš nadograđivat proc jednog onda ok, ali mislim da 1660ti,3050 su grafe za tvoj komp na 1080p. Čak je i 3050 sa i9 izvukla dosta vise fpsa na 1080p. Ima i 2060 negdje sam vidio za 1900kn plus mozes koristit dlss.
Zadnje izmijenjeno od: spawn. 20.07.2022. u 00:46.
Staro 20.07.2022., 08:27   #1229
markecSMB
Lokacija: Cro
Postovi: 1,041
Ja ne kužim kakve to vi cijene savjetujete, što nitko ne prati cijene?
Evo jučer nova u €u RTX 3080 12 GB 799€ s 19% njemačkog pdv.
Dakle s našim 839€
na amazon it RTX3080 x trio 12GB 929€
Kasni malo €u za padom cijena al i ovo je sve po meni prenapuhano, i pitanje je tjedna kad će još znatno pasti kod nas.
https://www.njuskalo.hr/graficke-kar...oglas-37510615
Majstor traži 10k, jučer nova 969€ na amazon.de
Piše i pička na zidu pa nitko ne jebe zid.
Što bi ja dao, kod maks, za grafičku s garancijom rabljenu:
RTX 3090ti 1k€
RTX 3090 900€
RTX 3080ti 550€
RTX 3080 12 GB 500€
RTX 3080 10 400€
RTX 3070ti, bi dao 350€
3070 300€
3060ti 250€
3060 200€
Ove nebi ni kupio zbog premalo rama
Staro 20.07.2022., 09:09   #1230
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,183
Po tim cijenama neces kupiti ni za 3g
Sent from my VOG-L29 using Tapatalk
