Staro 23.03.2022., 11:33   #3181
ibme74
ibme74's Avatar
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,632
ma ovaj i5 to vozi bez beda
ibme74 je offline   Reply With Quote
Staro 23.03.2022., 12:59   #3182
Cilim
Cilim's Avatar
Postovi: 1,542
Autor ibme74 Pregled postova
ja bi tu rađe išao na 12400 i stavio RTX3060Ti, najbolji omjer uloženo dobiveno, pogotovo za 1080p.
Za vodeno hlađenje stvarno nema potrebe osim zbog šminke:
1 * Intel Core i5 12400f, 2,5/4.4GHz,6C/12T,LGA1700 BX8071512400F
Šifra: int-ald-i5-12400f
1 * Hladnjak ID-Cooling SE-213 Rainbow, 120mm, PWM
Šifra: SE-213 RAINBOW
1 * GIGABYTE Mainboard Desktop B660 DS3H DDR4 (Socket 1700, 4xDDR4 up to 128GB, 1x PCI-E x16x16, 2x PCI-E x1, 2x M.2, 4x SATA, 5x USB 3.2 Gen 1, 6x USB 2.0/1.1, 1x USB Type-C, 1x HDMI, 2x DP, 2.5Gbe LAN,
Šifra: B660M DS3H DDR4
1 * Crucial Ballistix 2x8GB (16GB Kit) DDR4 3200MT/s CL16 Unbuffered DIMM 288pin Black RGB EAN: 649528824288
Šifra: BL2K8G32C16U4BL
1 * GIGABYTE Video Card NVIDIA GeForce RTX 3060 Ti EAGLE OC 8G (LHR), GDDR6 8GB/256bit, PCI-E 4.0 x16, 2xHDMI, 2xDP, WINDFORCE 2X, RGB Fusion 2.0, Retail, LITE HASH RATE
Šifra: GV-N306TEAGLE OC-8GD 2.0
1 * SSD 1TB ADATA XPG GAMMIX S5 PCIe M.2 2280 NVMe AGAMMIXS5-1TT-C
Šifra: 0141176
1 * Corsair PSU, 650W, TX-M Series
Šifra: COR-CP-9020132-EU
1 * ZALMAN Z8 Mid Tower PC CASE Z8
Šifra: 4031824
Sveukupno s popustom: 10.747,30 Kn (-2%=10.532kn)
Besplatno slaganje i dostava
Postovani @ibme74, pitam, dali bi se eventualno moglo uz ovakvu konfiguraciju koristiti ovo postojece napajanje XFX TS Series P1 550S XXB9 550W...
https://www.newegg.com/xfx-ts-series...82E16817207013
Cilim je offline   Reply With Quote
Staro 23.03.2022., 14:03   #3183
ibme74
ibme74's Avatar
Postovi: 1,632
moze
Staro 23.03.2022., 21:20   #3184
gogoklepci
Datum registracije: Sep 2019
Lokacija: Mostar
Postovi: 365
moze
Ja ne bih stavio PSU star 8 godina koje je Tier D i ima UVP probleme jer je ovo kopija seasonic S12II. Seasonic S12II Bronze and related units have or had UVP issues.
https://linustechtips.com/topic/1116...-tier-list-40/
gogoklepci je offline   Reply With Quote
Staro 02.04.2022., 19:46   #3185
Yaxyo
Dok je nama nas :)
Yaxyo's Avatar
Postovi: 369
Pozdrav,
moze prijedlog konfe do cca. 15kkn? Racunalo ce se koristiti za sve osim gaming.
Bitno je da je tiho. Vodeno hladenje ne zelim.
Hvala!
Yaxyo je offline   Reply With Quote
Staro 03.04.2022., 01:45   #3186
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 728
Preširoko pitanje, ovisi o namjeni, softveru koji će se koristiti, jer za isti iznos možeš imati jači procesor + slabiju grafičku i obrnuto.
Tišinu ćeš uvijek postići sa velikim hladnjacima tipa Noctue D14/D15, BeQuiet DarkRock 4 Pro, Scythe Fuma2/Ninja5 i sl. u dobrom kućištu.
Generalno za jače procesore, AMDovi su trenutno bolji izbor jer se manje griju i troše od usporedivih Intela, posebno sad kad su im skresane cijene za 20-25% (5900X/5950X).
Što se tiče RAMa, novi DDR5 je još preskup pa je bolje ostati na DDR4 posebno ako ti treba više (neki sweet spot je 16GB ili 32GB na 3600MHz).
Zadao si veliki budget pa dio možeš usmjeriti i u storage, npr ako radiš sa puno virtualki ili velikim fileovima (grafika, CAD) onda je važan i što veći NVMe SSD za rad.
Staro 03.04.2022., 11:02   #3187
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Autor Yaxyo Pregled postova
Pozdrav,
Hvala!
Što je to sve točno?
Netko sve radi i na konfi od 3k kn....
To je sa monitorom i ostalim, ili samo kutija?
Staro 03.04.2022., 11:04   #3188
nino
nino's Avatar
Postovi: 12,613
@Yaxyo
AMD Ryzen 9 5950X procesor
Scythe Fuma 2
MSI MAG X570S TORPEDO MAX
Kingston FURY Beast 32GB (2x16GB) DDR4 3600 MHz
SAMSUNG SSD 980 PRO 1TB M.2 NVMe PCIe
Grafička kartica Asus DUAL GTX 1650 4GB GDDR5
SEAGATE HDD Desktop IronWolf Pro 3.5'/ 4TB
PHANTEKS Eclipse P400 Black Window Tempered Glass
Corsair RM650 W
Cijena sa popustom = 14.500,00kn
Staro 03.04.2022., 13:13   #3189
ibme74
ibme74's Avatar
Postovi: 1,632
1 * Intel Core i9 12900k, 3,2/5.2GHz,16C/24T,LGA1700 BX8071512900K
Šifra: int-ald-i9-12900k
1 * Vodeno hlađenje za procesor Arctic Liquid Freezer II - 360 ACFRE00068A
Šifra: 0001216626
1 * GIGABYTE Mainboard Desktop Z690 UD (S1700, 4xDDR5 up to 128GB, 1xPCIEX16x16 5.0, 1xPCIEX16x4 3.0, 1xPCIEX16x1 3.0, 2xPCIEX1, 6xSATA, 3xM.2, 4xUSB3.2 Gen1, USB3.2, USB2.0, USB Type-C, 1xHDMI, 1xDP, 2.5
Šifra: Z690 UD
1 * Kingston DDR5 FURY Beast, 4800 MHz, 2x16, 32GB KF548C38BBK2-32
Šifra: king-d5-48k2-32gb
1 * Palit GF GTX1650 GamingPro, 4GB GDDR6 NE6165001BG1-1175A
Šifra: pal-1650-gap-4g
1 * SAMSUNG SSD 980 1TB M.2 NVMe PCIe MZ-V8V1T0BW
Šifra: 4118608
1 * Tvrdi Disk Toshiba P300 4TB 3.5" HDWD240UZSVA
Šifra: 0141288
1 * Kućište BE QUIET Pure Base 500, ATX, crno, bez PS BG034
Šifra: 052.600.310
Sveukupno s popustom: 15.019,30 Kn (-2%=14.718kn)
Staro 03.04.2022., 17:25   #3190
Yaxyo
Dok je nama nas :)
Yaxyo's Avatar
Postovi: 369
Jasno mi je da se moze raditi i na jeftinijim konfama no kad je budzet takav onda ga zelim iskoristiti da rad bude sto ugodniji.
Isao bih na varijantu jaci CPU a slabiji GPU. I cifra je bez monitora.
S obzirom na prijedlog da se ide na AMD zbog cijene/zagrijavanja, ninova konfa mi se cini prikladnijom.
Hvala vam svima na prijedlozima.
Staro 03.04.2022., 21:07   #3191
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Naravno, rad ti nece biti nista ugodniji nego sa drasticno jedtinijim procesorom, al kad treba iskoristit budzet
Zadnje izmijenjeno od: coconut. 03.04.2022. u 22:02.
Staro 03.04.2022., 21:38   #3192
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 728
... kad je budzet takav onda ga zelim iskoristiti da rad bude sto ugodniji.
Ne znam što tako tajnoga radiš pa ne otkrivaš namjenu, ali može se budget usmjeriti i na bolji/veći(e) monitor(e).
Nekad su 2 ili 3 monitora korisnija nego jača konfa, npr. puno ugodnije je raditi CAD/3D kad imaš sve nacrte ili fotke po kojima radiš na oku, bez gubljenja vremena na skakanje među prozorima.
Staro 04.04.2022., 09:12   #3193
ibme74
ibme74's Avatar
Postovi: 1,632
1 * CPU AMD Ryzen 9 5950X 100-100000059WOF
Šifra: 0001194274
1 * Cooler BE QUIET Dark Rock 4, s. 1150/1151/1155/1156/1366/2011-3/2066/AM2+/AM3+/AM4/FM1/FM2+, crni BK021
Šifra: 050.903.378
1 * Matična ploča Asus PRIME X570-P 90MB11N0-M0EAY0
Šifra: 0202255
1 * Corsair 2x16GB DDR4 3600 RGB PRO
Šifra: COR-CMW32GX4M2D36C18
1 * Samsung SSD 980 Evo 1TB M.2 PCIE Gen 3.0 NVME PCIEx4, 3500/3000 MB/s, 600TBW, 5yrs, EAN: 8806090572210
Šifra: MZ-V8V1T0BW
Šifra: 0141288
Šifra: 052.600.310
Sveukupno s popustom: 13.913,59 Kn (-2%=13.634kn)
Staro 13.05.2022., 15:29   #3194
kimaniFriend
Datum registracije: May 2022
Postovi: 1
1 * Intel Core i9-11900KF 3.5GHz LGA1200, BX8070811900KF
šifra: 091.900.042
1 * Noctua NH-D15
šifra: 093.100.079
1 * MSI Z590 Pro WIFI, s.1200, Intel Z590, 7D09-001R
094.900.100
1 * Gigabyte RTX3080 EAGLE 12G, 12GB GDDR6X, LHR, GV-N3080EAGLE-12GD
šifra: 097.100.1010
1 * DDR4 32GB (2x16) Corsair 3600MHz LPX Black, CMK32GX4M2D3600C18
šifra: 096.100.835
1* Samsung SSD 1TB 980 PRO M.2, PCIe 4.0 x4, MZ-V8P1T0BW, 600TBW
šifra: 098.700.137
1 * Fractal Design Meshify 2 Compact Black Solid, FD-C-MES2C-01
šifra: 100.300.644
1* Napajanje Seasonic 1000W PRIME GX 1000, 80 PLUS Gold , Modular, PRIME-GX-1000
šifra: 101.100.307
_______________________
Sveukupno s popustom = 23.892,15kn (-10% jednokratno plaćanje: 21.502,94kn)
Prijedlozi dobrodošli. Prvi put pokušavam složit neki gaming beast pa ne bi volio da od šume ne vidim drvo. Unaprijed hvala
Zadnje izmijenjeno od: kimaniFriend. 13.05.2022. u 16:29.
kimaniFriend je offline   Reply With Quote
Staro 13.05.2022., 17:15   #3195
nino
nino's Avatar
Postovi: 12,613
Scythe Fuma 2
MSI Z590 Plus Wifi
Corsair Vengeance LPX 32GB (2x16GB) 3600MHz
Inno3D GeForce RTX 3080 iChill X3, 10GB, GDDR6
SAMSUNG SSD 980 PRO 1TB M.2 NVMe PCVIe
PHANTEKS Eclipse P400A
EVGA 1000 GQ 80+ GOLD 1000W
Ukupno za gotovinu sa 3% pce popustom = 19.700 kn
Staro 13.05.2022., 17:28   #3196
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Cemu 11900 pored 12700? Alder je znacajno brzi a sami procesor kosta isto.
Kad je vec budzet solidan, uzmi jos jedan ssd, 1tb je stvarno malo dan danas.
Preporucam ti FD Torrent Compact, bolji airflow od Meshify-a, a meni bolje i izgleda...
Staro 14.05.2022., 10:49   #3197
ibme74
ibme74's Avatar
Postovi: 1,632
1 * Intel Core i7 12700k, 3,6/5.0GHz,12C/20T,LGA1700 BX8071512700K
Šifra: int-ald-i7-12700k
1 * Hladnjak DeepCool AS500, ARGB, 120mm, PWM
Šifra: COLDEEAS500
Šifra: Z690 UD
1 * Kingston DDR5 FURY Beast, 5600 MHz, 2x16, 32GB KF556C40BBK2-32
Šifra: king-d5-56k2-32gb
1 * MSI Video Card Nvidia RTX 3080 GAMING Z TRIO 10G LHR (RTX 3080, 10Gb GDDR6X 320bit, 1xHDMI, 3xDP 1.4a, 3x8 pin, Mystic Light RGB, 370W) Low Hash Rate!
Šifra: RTX 3080 GAMING Z TRIO 10G LHR
1 * SSD 2048 GB KINGSTON KC3000, SKC3000S/2048G, M.2/NVMe, 2280, maks 7000/7000 MB/s SKC3000D/2048G
Šifra: 051.400.767
1 * Napajanje 850W CORSAIR RM850x CP-9020200-EU, ATX v2.4, 135mm vent., 80+ Gold, modularno CP-9020200-EU
Šifra: 052.700.375
1 * Kućište BE QUIET Pure Base 600, ATX, prozor, crno-narančasto, bez PS BGW20
Šifra: 052.600.250
Sveukupno na rate: 23.496,06 Kn (-2%=23.024kn)
Sveukupno s popustom za keš: 21.146,45 Kn (-2%=20.723kn)
Staro 14.05.2022., 20:35   #3198
yellowT84
yellowT84's Avatar
Datum registracije: Oct 2015
Lokacija: Vrbovec
Postovi: 11
Poštovani,
2016. godine na forumu sam zatražio prijedlog konfiguracije i gospoda iz UZI shopa su mi složili stroj koji je dogurao do danas i iako je danas još ok u planu mi je uzimanje novog stroja do 20 000 kuna i to samo kanta plus punjenje sve ostalo imam (mislim monitor, miš, tastatura, zvučnici i tako to) ... jedino neki uvjet bi bio GTX 3070 Ti, procesor i9 ili možda ako nema potrebe i i5 ili i7 najnovije generacije, solidno kućište sa prozirnom bočnom stranom (puno ventilatora u istom) i napajanje da je barem 80 gold ... ako bude i manja cijena nije problem samo da sve fercera kako treba ... zahvaljujem unaprijed
yellowT84 je offline   Reply With Quote
Staro 15.05.2022., 02:27   #3199
nino
nino's Avatar
Postovi: 12,613
Intel Core i9-12900KF
Noctua NH-D15 Chromax Black, CPU cooler (black)
ASROCK Z690 PHANTOM GAMING 4
Patriot Viper Elite II 32GB (2x16GB) DDR4 4000 MHz
Gainward GeForce RTX 3070 Ti Phoenix
EVGA SuperNOVA 750W GT Gold
Fractal Meshify 2 Black TG
Sa pce popustom = 19.300,00 kn
Verzija sa i7-12700K + 32Gb DDR5 = 18.100,00 kn
Staro 15.05.2022., 10:01   #3200
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Autor yellowT84 Pregled postova
Poštovani,
Ako je u pitanju gaming, daleko bolje je uzet 3080-ku u kombinaciji sa i5/i7.
Koja je rezolucija i rr monitora?
Staro 15.05.2022., 10:55   #3201
gogoklepci
Lokacija: Mostar
Postovi: 365
cpu 12700f
MSI MAG B660M Bazooka
DDR4 64GB (4x16) G.Skill 3200MHz Ripjaws
Noctua mounting kit NM-i17xx-MP83
Noctua NH-D15S
Gigabyte RTX3070Ti EAGLE OC 8GB
Napajanje Corsair 750W RM750
Lian Li LANCOOL 205 MESH ATX
Ja bih ovako cijena je oko 19000 kn adm.hr
Staro 15.05.2022., 11:36   #3202
yellowT84
yellowT84's Avatar
Lokacija: Vrbovec
Postovi: 11
Zahvaljujem Nino i Gogoklepci na prijedlogu,
Ansha uglavnom gaming, ali za ono što ja igram i 3070TI je svjetlosnim godinama ispred, a vezano uz monitor imam dva monitora - prvi Samsung Odyssey 2K i drugi Dell P2417H.
Nisam naveo da od grafičkih možda radije dolazi u obzir ASUS ili MSI kao proizvođač, te da imam već 1 SSD i 2 HDD u kućištu tako da bi možda radije uzeo manji SSD novije generacije od recimo 500 GB
Staro 15.05.2022., 13:22   #3203
nino
nino's Avatar
Postovi: 12,613
Onda ovako nekako:
Intel Core i7-12700F box
Scythe Fuma 2
MSI PRO Z690-A DDR5
SSD Western Digital Black™ SN850 NVMe M.2 500GB
MSI Video Card Nvidia RTX 3070 Ti VENTUS 3X
Corsair iCUE 465X RGB
EVGA SuperNOVA 750 GT 750W Gold
Sa pce popustom = 17.900,00 kn
Mislim da je 64gb rama overkill.
Staro 15.05.2022., 17:27   #3204
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
3080 je 20-25% brza i stane ti u budzet, od i9 naspram i7, pa i i5, nemas apsolutno nista...
Staro 16.05.2022., 08:34   #3205
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
1 * Intel Core i7 12700kf, 3,6/5.0GHz,12C/20T,LGA1700
Šifra: int-ald-i7-12700kf
1 * Vodeno hlađenje ARCTIC Liquid Freezer II 240, Intel/AMD + S.1700 adapter
Šifra: 051.000.057-99160
1 * MSI PRO Z690-A, 4xDDR4, s.1700
Šifra: msi-pro-z690-a-d4
1 * Patriot Viper Blackout, 3200Mhz, (2x16GB),32GB C16
Šifra: pat-vb432g32-32g
1 * Kućište Lian Li LanCool 205 MESH, black
Šifra: LL-LC-205MB
1 * NVMe SSD SAMSUNG 980 1TB M.2 NVMe PCIe, MZ-V8V1T0BW
Šifra: 4118608
1 * GIGABYTE Video Card NVIDIA GeForce RTX 3080 EAGLE (LHR) 12GB GDDR6X 384bit, PCI-E 4.0 x16, 2xHDMI, 3xDP, WINDFORCE 3X, RGB Fusion 2.0, Retail
Šifra: GV-N3080EAGLE-12GD
1 * Napajanje Thermaltake Toughpower GF1 850W Gold
Šifra: 0001210482
Sveukupno:*22.432,45 Kn
Sveukupno s popustom: 20189,21 Kn
Staro 16.05.2022., 11:28   #3206
ibme74
ibme74's Avatar
Postovi: 1,632
Šifra: COLDEEAS500
1 * MBO 1700 AS PRIME Z690-P 90MB19Q0-M0EAY0
Šifra: 0001238534
1 * Samsung SSD 500GB M.2 PCI-E NVMe Gen4 980 PRO
Šifra: SAM-MZ-V8P500BW
Šifra: 052.700.375
Šifra: 052.600.250
Sveukupno s popustom: 19.619,00 Kn (-2%=19.226kn)
Staro 27.06.2022., 13:41   #3207
njohi
Postovi: 8
Pozdrav ekipa rijesio sam se "starog" kompa i uzeo Macbook i da izvinete pojeo onu stvar kako se kaze u narodu.
Stoga trebam prijedlog za konfu (samo kućište) imam 2 monitora na stolu tako da nema potrebe za tim (HP 27mx)
Cijena odnosno novci sa kojima se raspolaže je 2500E (300E +-)
Komp sluzi za dizanje VM-ova na njemu tako da je pozeljno minimalno 32gb rama, m2 diskovi da su unutra, sto se tice gaminga upali se jednom u mjesec dana Dota 2, koja se uredno vrti i na RX580 tako da grafa ne mora ubijati, no kako su cijene pale ne bih bjezao ni tu od 3080 ili nesto u tome rangu.
Hvala puno, ako treba sta jos od detalja tu sam.
Btw komp gasim jednom u godinu dana cisto da propusem prasinu iz njega ili kad nestane struje, tako da mi treba i preporuka za dobar case da ne bude kao grijalica u njemu stalno.
njohi je offline   Reply With Quote
Staro 27.06.2022., 14:42   #3208
nino
nino's Avatar
Postovi: 12,613
Evo jedne fine kombinacije:
Gigabyte Z590 D
Corsair Hydro Series H100x
Patriot Memory Viper Steel 64GB (2x32GB) DDR4 3200 MHz
Sapphire NITRO+ Radeon RX 6900 XT Special Edition AMD 16 GB GDDR6
SAMSUNG SSD 980 PRO 1TB M.2 NVMe PVIe
Kingston NV1 NVMe 2TB
PHANTEKS Eclipse P400A Tempered Glass - Black
20.000kn sa pdv! Dostava i sastavljanje free!
Staro 27.06.2022., 20:22   #3209
Postovi: 17,143
Ja bi svakako gledao ddr5 za 20+ tisuća kuna.
Staro 28.06.2022., 09:46   #3210
ibme74
ibme74's Avatar
Postovi: 1,632
1 * INTEL Core i9-12900F 2.4GHz LGA1700 Box BX8071512900F
Šifra: 4341737
Šifra: COLDEEAS500
1 * Gigabyte Z690 GAMING X, DDR5, s1700 Z690 GAMING X DDR5 G10
Šifra: gig-ga-z690-gx-d5
1 * CRUCIAL 64GB Kit (2x32GB) DDR5-4800 UDIMM CL40 (16Gbit)
Šifra: CT2K32G48C40U5
1 * GIGABYTE Video Card NVIDIA GeForce RTX 3080 GAMING OC 10GD 2.0 GDDR6X/320bit (LHR), PCI-E 4.0 x16, 2x HDMI, 3x DP, WINDFORCE 3X, RGB Fusion 2.0, Retail, LITE HASH RATE
Šifra: GV-N3080GAMING OC-10GD 2.0
1 * SAMSUNG SSD 980 PRO 1TB M.2 NVMe PVIe MZ-V8P1T0BW
Šifra: 4028193
1 * Kingston NV1 NVMe 2000GB,R2100/W1700, M.2 2280 SNVS/2000G
Šifra: king-snvs-2000g
1 * Fractal Ion Gold 850W, 80+ Gold, modularno FD-P-IA2G-850-EU
Šifra: frac-psu-ion-850w
1 * PHANTEKS Eclipse P300A Mesh Edition ATX Tempered Glass - black
Šifra: CAPH138
Sveukupno s popustom: 22.241,30 Kn (-2%=21.796kn)
