#42571 |
PRO
Postovi: 4,889
Bok ekipa, imam felticu 7 sixty. Bicikla mi je super, paše mi rama, pa je ne bih minja, a tija bi je pretvoriti u cestovnu. na nju sam već stavija cestovne gume (marathon plus), sad mi ostaje zamjena volana. Tija bi staviti volan sa rogovima (ne znam kako se zove). E to povlači sa sobom mehanizam za mijenjanje brzina i ručica kočnice. Da li netko ima savjet da li je to moguće i kako to napraviti?
#42572 | |
Datum registracije: Oct 2014
Postovi: 79
Koliko vidim ovoj je baterija punjiva, ali nisam našao je li npr. 18650 pa da je možeš mijenjati ili se ne vadi? Htio bi imati rezervnu bateriju, često mi se dogodilo da se usred vožnje isprazni jer sam zaboravio nadopuniti. |
#42573 | |
Slobodan leni seronja
Postovi: 852
Volio bih apgrejdati na neki veci hod... Hvala! ![]() |
#42574 |
Varilnik
Postovi: 1,648
#42575 |
Suit up!
Postovi: 5,975
Taj 35 je govno žešće. Ne odgovaraju mu opruge od Pikea i nije u stvarnosti Debonair jer ima drugačiji shaft koji nije šupalj. Ode ga je tip rastavija i vidiš što je unutra. https://www.mtbr.com/threads/rocksho...nside.1142709/ TLDR on this fork: Edit. This may well be the worst fork currently marketed by SRAM due to design and manufacturing shortcuts such as cheap, narrow bushings held in place by glue - that fails. If you're spending your own money, never ever buy this fork. At the same MSRP the Marzocchi Bomber Z2 is a far better option. It's basically an upsized Recon RL with Rockshox' most basic Motion Control damper and seals, and a port orifice rebound damper. Not a shim in sight. Edit. But the Recon is built better. It is incompatible with the internals of current and previous 35mm Pike, Revelation, Yari and Lyrik models. Edit. See this and this. The fork uses very narrow bushings - 10mm upper and lower - that are glued in place with epoxy and this glue seems prone to failure. If this epoxy fails the affected bushing will move (with associated negative outcomes - "notchy" travel from uneven bushing alignment, stanchion play, or the bushing will squeeze around the stanchion ever tighter until it barely moves). This is a possible repair to re-align bushings whose glue failed. The fork's stanchion walls are thicker and the ID is smaller than other Rockshox 35mm aluminium forks. This means 35mm parts from other forks, like shimmed rebound dampers from the Revelation or Yari for example, doesn't physically fit in the fork. Edit. See post 86 for a modification to a shimmed Yari rebound damper that works. SRAM uses a new ~M32/M31.8 x 0.8mm top cap thread for both air and damper top caps. This sits between the non-boost Pike (1mm) and their other 35mm forks (0.5mm). You cannot install a charger damper from any other Rockshox fork. The air spring is not really Debonair. It's a standard Rockshox Solo Air spring that uses plastic seal heads, high friction O-Rings and transfers air between positive and negative chambers using a spring loaded check valve in the air spring head which opens at top-out. When you get this fork it will most likely feel harsh at any speed, with loads of stiction and spiking. Servicing this fork with high quality lubes and installing low friction dust wipers is the best thing you can do for it's stiction. A shim to adjust the Motion Control damper's floodgate can be used to address excessive spiking at high speed impacts. The air spring can be tuned with bottomless tokens, but it takes 2 maximum and you must use the 32mm tokens (part # 11.4018.032.003) not the regular Rockshox 35mm tokens.
#42576 |
Varilnik
Postovi: 1,648
35-ica je ništa drugo nego socijalna verzija boljih vilica kao što su pike, yari, lyrik... Onaj tko želi ozbiljniju vilicu bi svakako trebao uzeti nešto drugo no nažalost dosta tih 35-ica danas dolazi stock i na čak mrvu ozbiljnijim bajkovima, no za nezahtjevnog vozača će biti ok. |
#42577 | |
Suit up!
Postovi: 5,975
Drop volan ti zahtjeva nove ručice kočnica i mjenjača ($$$). Ako ti već odlično paše ne diraj puno jer ćeš sa drop volanom dobiti na dužini što ti možda neće odgovarati.
#42578 |
PRO
Postovi: 4,889
sa užim volanom mi počnu trnuti ruke, šta mi nikako ne odgovara. uzima sam rogove, šta mi je super za dulje vožnje, ali nemam direktan pristup kočnicama, što me par puta zamalo koštalo. Koliko bi koštale te ručice kočnica i mjenjača, imaš li neku procjenu?
#42579 | |
Postovi: 852
I mislio sam da nije pravi Debonair unutra, jer sam negdje procitao podatak da je Solo Air unutra. Ispada da je bio u pravu. A Debonair logo nisam uspio nigdje naci na vilici. Ionako cu vozat taj bicikl jos iducu godinu, pa se nadam nekom fullyu u neko skorije vrijeme |
#42580 |
bok, koliko volti treba biti žaruljica za prednje svijetlo kod starijih bicikla koji imaju Iskra dinamo ? 6 v ? imam trenutno neke koje rade na 8v.. pa sad ne znam dali ih mogu iskoristit ? |
#42586 | |
Suit up!
Postovi: 5,975
Sviđa mi se što ima gore i dolje portove za podmazivanje bushinga što nema niti jedna druga vilica koliko znam i ne bi treba imati problema s krckanjem krune kao dosta Foxova i poneki RS.Na kraju krajeva, damper je lako sam servisirati bez specijalnog alata i košta upola od drugih high end vilica. Sad jedva čekam da mi stigne shock da mogu voziti. ![]() Složio sam ga ovako: Rama: Turbo Levo Expert Vilica: Suntour Durolux EQ RC2 160mm Shock: RS Deluxe Select+ Prijenos: Shimano XT 12s i 36t lančanik Kočnice: Formula Cura sa Hayes D Series 203mm rotorima Dropper: Specialized Command Post IIRC 160mm sa ZTTO daljincem Kotači: Giant TRX1 carbon sa Magic Mary / Hans Dampf iako su mi baš jučer došla dva Assegaija. Volan i lula: Pivot Phoenix carbon 780mm i Syncros XM1.5 50mm Još samo da isprintam planetarni hack za dizanje speed limita na 55-60kmh i to je to ![]()
#42587 |
Postovi: 17,143
Kako to da si prešao na struju? |
#42588 |
Suit up!
Postovi: 5,975
Nisam prešao, ostavio sam i Trance. Mogu se popeti 2-3x više u isto vremena pa to znači i više spuštanja, a iz vikendice mogu doći do staze isto tako skoro duplo brže što znači dosta, a i usponi postaju zabavni na ebikeu.
#42589 |
Lokacija: Podravina
Postovi: 1,096
Garmin Edge 530 za 177€ s dostavom ako kome treba. https://www.amazon.de/gp/product/B07...4d2e5f02d94b62 |
#42590 |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,559
Odlican popust al' probao sam i ne svidja mi se. Navigacija i mape su za q, nema touchscreen, napikavanje tipkama je pain. Vjerojatno je super za training, povezivanje sa senzorima.
#42592 |
Varilnik
Postovi: 1,648
Tranz x, brand x, rfr, xlc, sdg, ks... sve su to ok dropperi koji se nađu do 200 eura, za primjer: https://www.bike24.com/p2198005.html ako ti se ne da čekati izvana imaš ih i u keindlu https://keindl-sport.hr/proizvodi/?s...+cijev+sjedala Svi ti jeftiniji dropperi su ti ok i kad ti ode kartuša lako ju zamijeniš. |
#42593 |
Suit up!
Postovi: 5,975
Brand X Ascend XL je jako dobar, koristio sam ga neko vrijeme dok je moj Revive bio na nadogradnji i servisu. Mislim da je jedan od boljih općenito.
#42594 |
Postovi: 454
Brand-X ASCEND II vozim vec 4 sezone. Napravljen samo jedan servis u tom periodu i to reda radi (ociscen i podmazan), radi besprijekorno glatko, pouzdan i jeftin - i ne smrzava se na minusima kao prosli KS.Kad se samo sjetim da sam ga kupio iz zahebancije za 115€, nakon sto sam se vozio godinu dana bez droppera, i fino se celicio po alpama. Stanga je do sada dobila malo lufta, nista cudno s obzirom da ja rijetko padam ispod 100kg, iskreno, pravo cudo da do sada vec nije pokleknula. |
#42595 |
Datum registracije: Mar 2013
Postovi: 1,391
Hvala momci, gledam sad malo po bike 24 ako bi ga ubrao za tih 100+-€ bomba ja imam 60+kg tako da mislim da neće biti problema. vidim da kad ga uguglam kod nas nista ne izbacuje doduse ni na bike24. nemam vise zivaca stalno silaziti sa bicikla i podesavati to rucno. 🥲 A bilo mi je mrsko davati neku vecu svotu novaca na dropper za bajk mog ranga. |
#42598 |
Postovi: 454
Prije 10 godina sam kao jedan od prvih mojih videa snimio spust stazama 18-20. Bilo je smijeha, i bilo je zabavno. Danas uz preuranjeni snijeg, spust malo modificiranom rutom - ulaz preko Kolorada, i dalje direkt po origigi 18-ici pa na 20-ku. I danas je bilo zabavno i bilo je smijeha, samo kaj nije bilo stare ekipe s kojom sam poceo svoju MTB karijeru. Isplatilo se danas potegnuti na breg, gore je prava idila, iako ispod 700mnv uopce nema snijega, a od 750mnv ga pak ima u izobilju. Uzivajte! Zadnje izmijenjeno od: Nik. 04.12.2021. u 22:47. |
#42599 |
Suit up!
Postovi: 5,975
#42600 | |
Postovi: 495
Prekrasno! |
