Staro 07.02.2006., 00:14   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Neki temperature monitor...
Trebam neki temperature monitor program, sto vise funkcija samo da podrzava ocitanja iz hard diskova...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 07.02.2006., 00:21   #2
Virus7
Datum registracije: Jul 2003
Postovi: 800
Speedfan
Virus7 je offline   Reply With Quote
Staro 07.02.2006., 00:30   #3
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
everest
.i.
Razer Blade 15
Staro 07.02.2006., 00:35   #4
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
Uz te dobar je još i MBM al nisam ziher dal ima za hard temp...
žmnpp
Staro 07.02.2006., 00:40   #5
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Ima al se mora staviti jedna jedinica u config file
Staro 07.02.2006., 00:47   #6
Panzer
Panzer's Avatar
Postovi: 1,814
Hvala... Evo skidam MBM i SpeedFan, pa cu vidjet koji mi je bolji... Everest je odlican, samo ne u trial verziji, kad mi na pol toga (i na hdd temp) pise TRIAL VERSION umjesto temperature...
UPGRADED...
Staro 07.02.2006., 01:33   #7
Panzer
Panzer's Avatar
Postovi: 1,814
MBM
Evo, koristit cu MBM, Dajte mi samo recite kak odabrat kaj da imam u dashboardu jer imam hrpu nepotrebnih stvari a, temp od recimo harda nemam. I kak da stavim na digitalno, ovo s vumetrima mi se ne svida?
Inace stavio sam jedinicu za hardove u C:\Program Files\Motherboard Monitor 5\Data i MBM 5 file sam otvorio, tam sam izmijenio HDD Scan=1, jel dobro tak? Jel ima neka caka da se upale od grafe senzori?
EDIT: Nasao za odabrat kaj ce mi bit u dashboarud i stavio sve na digitalno...
UPGRADED...
Zadnje izmijenjeno od: Panzer. 07.02.2006. u 02:23.
Staro 08.02.2006., 20:37   #8
Tooma
Tooma's Avatar
Datum registracije: Aug 2003
Lokacija: malo st, malo vz
Postovi: 2,043
di?
Untitled Document
2x IBM Deskstar 40 GB
Pioneer DVD+-RW DVR-107D
Cretaive Live Player 5.1
Staro 08.02.2006., 21:10   #9
Vuco
Vuco's Avatar
Postovi: 9,505
Originally posted by Tooma
di?
Pa u config fajlu...
Salim se:
Ja sam ti to nasao u Help-u od MBM-a...to di trebas staviti 0 i 1 za hard...
Tako da najbolje da tamo pogledas za tocan odgovor jer ja nemam instaliran MBM...
Dalje dolje u tom fajlu imas i za staviti kolko da ti bude razmak u sekundama, za ocitavanje te temperature...al opet, neznam tocno di pa ces morat malo prosnjofat po Help-u
Staro 08.02.2006., 21:28   #10
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
A šta će ti uopće temp monitor???
Kad nađeš na kojem clocku ti je sustav 100% stabilan pogledaš i temperature ako nisi zadovoljan njima, poboljšaj hađenje ili smanji clock.
Ti programi samo zauzimaju resurse, gledaš u njig par dana i onda ih uninstaliraš...
Nemam više lema!!!
Staro 08.02.2006., 22:57   #11
Panzer
Panzer's Avatar
Postovi: 1,814
Neznam, tak da vidim kakva jr temperatura, a sad me zanimalo zbog diskova... Jer sam stavio vent da roka po njima... I hladni su...
Znam na kojem mi je clocku sustav 100% stabilan, na 2500 mhz, tj 4% max. overclock kak pise u biosu -> Intel ploca...
UPGRADED...
Zadnje izmijenjeno od: Panzer. 08.02.2006. u 23:07.
