Staro 06.02.2006., 17:21   #1
zeus-horny
zeus-horny's Avatar
Lokacija: koprivnica
Postovi: 113
Lightbulb 2x1gb RAM-a ili 4x512gb RAM-a
Kaj je bolje imat :confused: :confused:
MBO:Epox 9npa3j
CPU :AMD 64,3000+
@2610MHz--290*9
RAM:2*512 G.E.I.L400
@480MHz--2,5-3-3-5
VGA:x1800xl 256mb@(570-1180mhz)
HDD:WD 120Gb 8mb
PSU :Tagan 430 easy con.
CASE:black delux with sensors(cpu,graf,itd.)
DVD-ROM :asus quickTrack ata100 16x
DVD/RW:asus 16x16
zeus-horny je offline   Reply With Quote
Staro 06.02.2006., 17:31   #2
domy_os
domy_os's Avatar
Postovi: 19,009
2 x 1 GB
CR 1T ne šljaka kod 4 x 512 MB
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 06.02.2006., 17:34   #3
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
2 x 1gb
.i.
Razer Blade 15
Staro 06.02.2006., 17:35   #4
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
jel ove nove ploče oće radit u dual chanellu ak imas 1 pločicu od 1GB i dvije od 512?
Nforce 2 je samo tak i radio
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 06.02.2006., 17:35   #5
atha
atha's Avatar
Postovi: 9,069
kako su dechki i rekli, 2x1gb svakako, bolje ce raditi,
a i da ne govorimo da cesh za godinu dana mochi ubosti josh dva takva pa sve skupa 4gb....
@bruno zg
probao sam jedan stick od 1gb i 2x256, ne rade u DC-u, tutto completo na single channel.
___________
Just atha
x
Staro 06.02.2006., 17:58   #6
BrunoZG
Junior Member
BrunoZG's Avatar
Postovi: 3,205
MIlsim da bi moralo bit 1 GB i 2x512.....
ili 1x512 i 2x256...Ista kolicina rama po kanalu
ELSA 7600GT
Staro 06.02.2006., 18:17   #7
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,328
Re: 2x1gb RAM-a ili 4x512gb RAM-a
imaš pm,inbox ti je pun
SetH je offline   Reply With Quote
Staro 06.02.2006., 19:18   #8
ivan OS
ivan OS's Avatar
Postovi: 910
Šljaka kod DFI Lanparty UT RDX200 CF-DR
ATI Radeon Xpress 200 CrossFire chipset
ivan OS je offline   Reply With Quote
Staro 06.02.2006., 19:36   #9
Wolverine
Wolverine's Avatar
Postovi: 12,433
Ma da si ziher?
Pa mem kontroler je u procu a ne na ploči!
jedino neki ali ponavljam neki FX57 mogu držat 4 dvostrana keksa na 1T
2x1GB je bolje od 4x512MB
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 06.02.2006., 20:01   #10
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Tako radi, svaki kanal mora imat istu kolčinu memorije.
žmnpp
Staro 06.02.2006., 22:47   #11
ivan OS
ivan OS's Avatar
Postovi: 910
Originally posted by BlackMack
Ma da si ziher?
Nismo uopće pričali o jednostranim i dvostranim memorijama,a ne moraš me učiti gdje je tu mem. kontroler
Ja sam se samo osvrnuo na 1T post,ne na izbor 2 x 1GB ili 4 x 512 MB
Naravno da je stvar i do proca ali:
"To DFI's credit, many of the features of their new RDX200 board seem to be geared toward an understanding of what it will take to succeed with their new ATI chipset motherboard. Crossfire dual-video is on the board, but the emphasis is on performance and features. DFI lavished all the adjustments and tweak options of their nForce4 board on the RDX200 and then went even further. Oscar Wu found out how to make 4DS DIMMs run at 1T Command Rate and launched that solution with this board. He also claims that he has a working CAS 1.5 on the ATI motherboard, and the options for CAS 1.0 and 1.5 are available in the BIOS. Memory voltage extends to 4.0V, so any memory is supported, but this is done without special jumpers or a heat-producing work-around."
http://anandtech.com/mb/showdoc.aspx?i=2572
Staro 06.02.2006., 22:58   #12
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
bolje je 2x1gb
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 07.02.2006., 00:42   #13
Wolverine
Wolverine's Avatar
Postovi: 12,433
[B]Nismo uopće pričali o jednostranim i dvostranim memorijama,a ne moraš me učiti gdje je tu mem. kontroler
ja tebe niti ne pokušavam nekaj učit
EDIT
nisam ''sredio post'' zbog informacije koja (da odmah kažem nema veze s ovim) nego ovo nije niti mjesto niti vrijema a ponajmanje mi se da sad s tobom tu navlačit
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Zadnje izmijenjeno od: Wolverine. 07.02.2006. u 00:52.
Staro 07.02.2006., 00:49   #14
ivan OS
ivan OS's Avatar
Postovi: 910
Vidim da si pročitao informaciju pa sredio post
Staro 07.02.2006., 00:49   #15
ivan OS
ivan OS's Avatar
Postovi: 910
@BlackMack
Pročitao sam i originalni post...
Staro 07.02.2006., 01:16   #16
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
To ti je otprilike ona narodna "pisalo na plotu p***a pa se netko našpranjio"
U praksi to baš i ne radi kako su si oni zamislili.
