#56341 |
Freelancer
Lokacija: Bilje (Osijek)
Postovi: 5,362
#56342 | ||
Postovi: 12,433
Dosta mi je da me jednom posere ![]()
#56343 | |
Freelancer
Postovi: 5,362
.A i hrpa ljudi nezna sta radi, carly te prije svakog kodiranja trazi da napravis backup modula tako da mozes vratiti settingse i upute su prilicno jasne ali ljudi rade svasta i ne postuju proceduru oko gasenja/paljenja/kontakta.... Da mi je samo kuna za svaki krivi video tutorijal koji sam pogledao na youtube gdje ljudi koji snimaju govore krive informacije ili neznaju sta rade ali to ih ne sprijecava da snime video i objave a drugi povjeruju u tu proceduru .P.S. Meni je crko nekoliko WDa, nekoliko Seagateova, 1 IBM/HGST, Jedan Quantum, jedna Toshiba, jedan Samsung tako da tesko da bi imao sta kupit danas da tako gledam na stvari .BTW jel neko popratio ovog mahera sto je slozio Xantiu ![]() https://revijahak.hr/2021/08/22/poli...udija-i-bmw-a/
RS1 - MB: WS X299 Asus Sage, CPU: i7 9800X, RAM:128GB, GPUs: 3*RTX 3090 24GB RS2 - MB:Asus X99-E WS, CPU: i7 6850K, RAM:128GB, GPUs: 2*RTX 4090 24GB Zadnje izmijenjeno od: Lewis. 22.08.2021. u 23:47. |
#56344 |
Datum registracije: Aug 2014
Postovi: 2,953
Činjenica je da je carly puno modula sjebao ali ne svojom krivicom koliko sam upoznat. Navodno ode eprom na modulu i sve je ok dok ne pokušava programirati modul. Onda ispadne da je crko zbog Carly a zapravo je bio pred crkavanjem. Takodjer, backup ne možeš tada vratiti. Samo promijeniti FRM Official carly odgovor "We actually have some experience with this: About a year ago we had the same issue with two FRMs (E90). We sent the defective control units for analysis to a specialized ECU development company in Switzerland. There they found out that the internal memory had a hardware failure which resulted in a boot-lock. The error has nothing to do with the coding (it wasn’t even located in the coding memory), but was due to a broken memory unit which was responsible for part of the boot sector. The app cannot even access this part of the memory. The coding and diagnostics memory was still intact when we isolated it from the rest of the ECU. Since the FRM (and also many other ECUs) have to be restarted to apply the settings, it looked as if the app had something to do with the broken FRM at first. However, because of this very reason the same would have happened via conventional PC-coding. You can actually find quite a couple of threads in many forums about broken FRMs after coding with PC. You can actually compare this issue to a conventional PC: If an error in the MBR (master boot record) happens, while your PC is running, there is no immediate effect. However, as soon as the PC is restarted (e.g. after an update) the PC doesn’t start anymore and shows a blue screen. It now looks like the update has caused the problem, even if in fact it is something completely else. Since last year we talked with many professional coders and researched this issue on the internet and it seems that mainly FRM control units are affected by this bug. I've heard that BMW is very well aware of that problem and even had some callbacks for these FRM versions. We're already looking into this to find out which versions were called back, so we can identify them within the app itself."" https://www.e90post.com/forums/showthread.php?t=1176695 |
#56346 | |
Yugokiller
Postovi: 649
Nedavno sam bio u nabavci istog, i realno suženi izbor je pao na S-max ili Grand C4. VW nije bio opcija, Peugeot se smanjio i postao bezobrazno skup(za moj pojam). Na kraju odluka je pala na C4 Grand, jednostavno nisam u stanju progutat fordovu unutrašnjost. Iz vana je ok i moderan, ali unutra za moj pojam preplastičan. Tu je i famozni fordov powershift, hvala, ali ne hvala. Da, više je sportski auto nasprem C4, ali prošlo me hvatanje zavoja, uostalom treći klinac/ka je na putu. Na papiru i Kia ima svojeg konja za trku, ali jednostavno ne prati nove kia modele, prezastario je...
#56347 |
Lokacija: KR
Postovi: 1,176
Ovaj Hyundai izgleda poprilično futirističko za serijski "kombi" . Baš dobro izgleda zato. Ima samo čudnu bočnu liniju radi ogromnih šajbi, da im je donja linija viša, vjerovatno bi izgledao klaustrofobično. Od iza me svjetla podsjetila na Mitubishi Grandis I servisi su vjerojatno skupi, jer ispod prednje haube je mali otvor. Tak da su vjerojatno zahvati kompliciraniji (veća satnica) |
#56348 | |
Lokacija: Stuttgart
Postovi: 1,602
Nakon par odlazaka na godisnji sa F11 i kad sam skuzio kako taj auto proguta 1300km u komadu bez da se itko u njemu umori, mislim da cu ga zadrzati neko vrijeme. Stvarno sam iznimno zadovoljan sa autom. Kada dodje vrijeme za zamjenu, onda definitivno neki SUV, vjerojatno opet iz pogona "velike trojke", mada ni ostali nisu iskljuceni. Sada sam vise fokusiran na motore tako da mi je auto samo prevozno sredstvo i dok nema nekih vecih kvarova necu ga ni mijenjati. Gesendet von meinem SM-G991B mit Tapatalk |
#56351 | |
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Konkretno ovo vezano za spuštanje desnog retrovizora kada ubaciš u rikverc postoji mogućnost. Imaju dva puta do toga. 1. Ako imaš elektrificirano vozačevo sjedište sa memorijom pozicije onda je znatno lakše. Retrovizor ima puno veći hod. 2. Ako nemaš elektrificirano vozačevo sjedište sa memorijom pozicije onda je malo bezveznije rješenje, ali i ono dobro dođe. Desni retrovizor u tom slučaju ima manji hod i povremeno mu se zna desiti da se ne vrati nazad u istu poziciju sa koje je krenuo prema dole. U mom slučaju je ova druga opcija i uključio sam spuštanje desnog retrovizora kada se ubaci u R. Bude korisno kada se parkiraš baš blizu ivičnjaka. A to što se retrovizor ne vraća uvijek u istu početnu poziciju kompenzuješ ručno i to je to. Još jedna dobra opcija je "skandinavsko zadnje poziciono svjetlo". Kada ti prekidač svjetala na AUTO modu, poziciona svjetla imaš uključen asamo naprijed (DRL), dok su zadnja potpuno isključena. U slučaju sumaglice i magle si nevidljiv sa zadnje strane što povećava mogućnost da ti se neko instalira zguza. ![]() Kada uključiš opciju "skandinavska zadnja svjetla" onda imaš zadnju poziciju i dok je prekidač u AUTO modu. Sve zavisi šta imaš od opcija trenutno "otključano" i šta bi ti želio. Kontrola prozora preko ključa, pamćenje nivoa grijanja grijača u sjedištima, broj blinkanja žmigavaca u taster modu, isonemogućavanje start/stop sistema, prepoznavanje znakova ako imaš prednju lane assist kameru i minimalno amundsen infotainment, canton ekvilajzer ako imaš minimalno amundsen infotainment (a ne posjeduješ canton set zvučnika), podešavanje nivoa sušenja kočionih diskova kada voziš po kiši, podešavanje XDSa i još brdo toga. Sve zavisi šta te usrećuje.
Lenovo ThinkPad W530 - Core i7 3840QM, 32 GB RAM, SSD Samsung 512 GB, nVidia Quadro K1000M 2 GB, 15.6" 1920x1080 IPS, baterija 9 ćelija |
#56352 |
Lokacija: Munich
Postovi: 2,222
Sto kupiti u DE do 5-6 k €? Moze i domace ako mislite da nema razlike u cijeni prevelike! Mami i tati treba nesto pouzdano, gradska voznja tu i tamo do ZG. Hvala. |
#56353 | |
Lokacija: KR
Postovi: 1,176
Npr https://www.njuskalo.hr/auti/hyundai...oglas-35247127 https://www.njuskalo.hr/auti/kia-rio...oglas-35173417 Zadnje izmijenjeno od: lowrider. 23.08.2021. u 18:23. |
#56355 | |
Pod naletima kopita zla
Lokacija: SMB / ZGB
Postovi: 7,736
To je odgovor kojeg sam čekao! Moja situacija je kao i tvoja tj. pod brojem 2. Onemogućavanje start stop sistema bi bilo jako cool, nemam prednju lane assist kameru ( ), sušenje kočionih diskova...fml nisam ni znao da to postoji. I ovo skandinavski mod se čini jako cool. Mogao bi si ja to kupiti pa se malo poigrati. ![]() p.s s koliko kredita je terba uzeti? To mi je malo nepoznanica. Koiko kredita košta neki fičur? Svaki je neki X ili je svaki 1 kredit? Vidim da ih prodaju sa 100 ili sa 200 kredita. Ima dodatno ultimate i pro pretplata... |
#56356 | |
Lokacija: Munich
Postovi: 2,222
Hvalaaa. Pogledao sam te skode to je stvarno super, cak se protegnuti i do Rapida nije lose. Jel li istina da se ne moze uvesti auto stariji od 10 godina po novom? |
#56357 | |
Adrenaline junkie
Postovi: 3,593
![]() Taman da vidiš kako to sve radi, pa vidi hoćeš li sebi kupivati jedan da imaš za "po kući".
#56359 |
Adrenaline junkie
Postovi: 3,593
Will be in touch. Ima tu jos par sektaša koje bih volio vidjeti poslije nekoliko godina. Nešto se dogovaramo, možete biti moji gosti u VIP loži. Samo navuci neku uvjerljivu plavu vlasulju i neki uzak minić da lakše opravdam tvoje prisustvo. ![]()
#56360 | |
Brat od Đon Vejna
Lokacija: zg-vg
Postovi: 1,204
Može se uvesti sve iznad Euro3 norme, pitanje je isplativosti. Ja se nadam uvesti Octaviu MK2 RS karavana kroz neko vrijeme, na auto od cca 3000-3500€ su davanja jos 2000€ prije registracije...
#56361 |
Lokacija: Bec
Postovi: 1,205
Wolv, molim te nemoj bogohulit ![]() Utvrdili smo da se škoda za tu lovu ne uzima. Eventualno ako je besplatna, onda se isplati. Evo mog prijedloga u duhu foruma: https://suchen.mobile.de/fahrzeuge/d...e-326ea37549b6 Nakon sto se poplacaju davanja ostane i za cevape a bogami je i selo zadovoljno ![]() |
#56362 | |
Lokacija: KR
Postovi: 1,176
#56363 |
Lokacija: Novi Zagreb
Postovi: 979
Ja stvarno nisam netko tko pati na high end materijale, i ne smeta mi "plasticky" osjecaj u autima nize kategorije, ali Rapid... prvi put u zivotu da sam imao osjecaj da sjedim u jednokratnom autu. Ono, kad ispraznis tank, kupujes novi, takav je osjecaj. Uz to su me uzasno furstrirala vrata. ![]() Rijetko kad se vide ovako lose slozena vrata. Da taj dio nisu mogli bolje izdizajnirat da nema tog ostrog kuta. Kuzio bi da je gore frameless staklo, ali ovako, katastrofa. Poogotovo ako se izlazi/ulazi negdje gdje nema previse prostora za otvoriti vrata. Majca/jakna easy zapnu sa to smece. |
#56364 | |
Lokacija: KR
Postovi: 1,176
![]() Tak da neće ostati ništa od buđeta |
#56367 |
Postovi: 10,368
To je na kraju i jedino bitno Ako i nakon 10 zdravomarija prije unosa kola zafali para za nedajbozegluhobilo neki servis, uzmes malo od djecjeg doplatka i jos malo dodas od onoga sto si prekjucer digo na kladusi i opet prst u uho - selo to niti ne mora znati ![]()
#56370 |
Datum registracije: Sep 2002
Postovi: 2,722
Takvi i nece Skode ![]() Znam jednog koji nema prebite kune, duzan je "cijelom gradu", pljuje po BMWima koji nemaju M paket, vozio je Octaviju (novu) iz rent a cara, popljuvao je je zestoko i sad vozi C klasu iz rent a cara i prica da je prodao prosli auto i kupio novi. Rvatski mentalitet mojeg malog mista. |
