Staro 03.06.2021., 21:11   #4561
Mladenxy
Mladenxy's Avatar
Postovi: 4,511
Nisam ni znao da postoji takav problem, nikad čuo ni vidio da netko ima problem sa gledanjem filma.
Ja bi na tvom mjestu format C:
To obično riješi svaki problem ako nije nešto stvarno pokvareno.
Staro 03.06.2021., 21:19   #4562
Dr. Strange
Datum registracije: Aug 2020
Postovi: 900
U igrama nisam primjetio rušenje pa se onda može prekrižiti hardverski problem?
Staro 03.06.2021., 21:22   #4563
Postovi: 8,669
U VLC opcijama (Tools) pod Video, pa Output prebaci s Automatic ili kaj već na Direct3D11 video output. U slučaju da bude i dalje problem, probaj MPC-HC.
BTW kaj se RTX 3080 Ti tiče:
nVidia is refreshing GA102 with the GeForce RTX 3080 Ti, which is a new expensive GPU that you still can't buy. The reasoning for this is simple, nVidia aims to make more money as long as this GPU boom lasts.
Now, if you don’t believe nVidia is selling GPUs directly to miners, which happens to be our opinion, then it’s AIBs and/or distributors who are selling to miners in volume.
Izvor: TechSpot/Hardware Unboxed
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750
Staro 03.06.2021., 21:31   #4564
Mladenxy
Mladenxy's Avatar
Postovi: 4,511
Autor Dr. Strange Pregled postova
a probaj neku open gl api igru pa vidi.
https://www.pcgamingwiki.com/wiki/List_of_OpenGL_games
99% da su driveri ili windowsi ili neka kombinacija. Ja bi format C: puknuo odma
Staro 03.06.2021., 21:48   #4565
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Autor The Fury Pregled postova
PartNumber DateEntered Notify Sent
12G-P5-3968-KR 6/3/2021 8:55:56 AM PT No
12G-P5-3967-KR 6/3/2021 8:52:57 AM PT No
Ja sam kliknuo nakon cca 3h kada je sve proradilo.
Loše stojim na listi?
tu sam i ja, jos 4 minute iza tebe...
Nego vidim sad, na listi jos stojim od 20.09.2020. za 3080 FTW3 Ultra pa mozda i to dode na red
Staro 03.06.2021., 23:07   #4566
exzzy
exzzy's Avatar
Datum registracije: Aug 2014
Postovi: 844
Sam kaj se tad nitko nije prijavljival skoro, pa jos se za 3060moglo normalno prijavit a eto sad pali serveri odma.
Staro 03.06.2021., 23:46   #4567
Mičkec
Datum registracije: Apr 2016
Postovi: 159
Autor zwer54 Pregled postova
cak sam dobar
12G-P5-3968-KR 6/3/2021 8:46:56 AM PT
12G-P5-3969-KR 6/3/2021 8:43:25 AM PT
Mičkec je offline   Reply With Quote
Staro 03.06.2021., 23:52   #4568
The Fury
The Fury's Avatar
Lokacija: Velika Gorica
Postovi: 178
Ako ništa drugo, dobivati ćemo ih u sličnim vremenima, a kada će to biti ...
Ljudi su počeli dobivati za 7:30 prijave notifikacije.
Zadnje izmijenjeno od: The Fury. 04.06.2021. u 00:02.
The Fury je offline   Reply With Quote
Staro 04.06.2021., 00:41   #4569
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Iako je site pao, vjerujem da je puno ljudi i bez elite accounta pokusavalo... I nije tim listama za vjerovati jer ja sam svoju 3090 dobio, a na listi me ni nema
Staro 04.06.2021., 00:53   #4570
The Fury
The Fury's Avatar
Postovi: 178
Ako ništa drugo, kada i ako dođete u mogućnost da kupite GPU, iskoristite 3% popusta od refferal programa, moj je: ZKPIIQQIOHAJWX0
To što sam spomenuo je bilo za US, za EU navodno sutra kreće mailovi prvim kupcima.
Staro 04.06.2021., 02:02   #4571
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
ugl, da se vratimo na nvidia temu... Upravo sam zakljucio da se pod hitno moram rijesit ove 3090 kartice. Ovo nisu istine kolko je vruce u sobi od kad sam ju stavio u komp... Prozor sirom otvoren i u sobi i dalje na rubu znojenja... (a vani cca 15 stupnjeva)
Staro 04.06.2021., 08:20   #4572
Daedalus
Sir Paški
Daedalus's Avatar
Postovi: 356
Pretpostavljam da zato sad ciljas na hybrid model?
Daedalus je offline   Reply With Quote
Staro 04.06.2021., 10:36   #4573
thunder11
thunder11's Avatar
Datum registracije: Dec 2013
Postovi: 1,699
Staro 04.06.2021., 11:12   #4574
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Autor Daedalus Pregled postova
Ma hybrid je majka, imal lmal sam i prije i puno tise radi.... samo nije bilo 3090 hybrid kad sam se ja prijavljivao na notify listu
Staro 04.06.2021., 16:37   #4575
Proudcroat
Proudcroat's Avatar
Datum registracije: Feb 2017
Postovi: 243
Zar ovo nije trebalo bit u 15 sati za evga kartice?
Proudcroat je offline   Reply With Quote
Staro 04.06.2021., 16:49   #4576
Šole
Šole's Avatar
Datum registracije: Aug 2009
Lokacija: Zürich
Postovi: 711
Jucer da
Šole je offline   Reply With Quote
Staro 04.06.2021., 17:43   #4577
exzzy
exzzy's Avatar
Postovi: 844
Autor Proudcroat Pregled postova
Jucer je za elite clanove bilo danas je za sve.
Staro 04.06.2021., 18:20   #4578
axo
Datum registracije: Sep 2017
Postovi: 1,442
Ma i to auto notify nek se hebu. Sjebali sve jucer, dosao na red nakon 3h i onda ameri dobivaju dok eu od pocetka je pusiona.
Realno stisni tipku i zaboravi na to
Probat jos na 3070ti i to je to.
Staro 04.06.2021., 18:33   #4579
Daedalus
Sir Paški
Daedalus's Avatar
Postovi: 356
Danas je u 18 po nasem navodno
Staro 04.06.2021., 18:37   #4580
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Autor axo Pregled postova
Kad god dode dobro dode jer stanje se nece tak skoro popraviti...
Staro 04.06.2021., 19:25   #4581
The Fury
The Fury's Avatar
Postovi: 178
Ako želite odprilike dobiti dojam kakvo je stanje na listi čekanje, provjerite ovo: https://docs.google.com/spreadsheets...W1w/edit#gid=0
Slobodno i sebe ubacite u listu.
Vidjeti ćete i mene na listi i ne stojim baš najbolje.
Staro 04.06.2021., 19:53   #4582
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Pa nije lista ni velika, fali tu bar 6 puta tolko... Biti oko 100. na listi i nije nesto, pa stancaju oni njih dosta brzo...
Staro 04.06.2021., 20:00   #4583
axo
Postovi: 1,442
Usporedi EU i USA listu pa ce ti biti jasno koja je razlika u isporukama.
Staro 04.06.2021., 20:12   #4584
sharyn
sharyn's Avatar
Datum registracije: Jun 2010
Lokacija: grubišno polje
Postovi: 569
mislim da možemo zaboravit cijelu 30x0 seriju, neće cijene dolje do iduće generacije.
jedino ako balon pukne pa hvatat na njuškalu itd.
sharyn je offline   Reply With Quote
Staro 04.06.2021., 21:18   #4585
Mičkec
Postovi: 159
mislio sam da je i gore.... sam da dođe nesto grafa i za EU.
po listama sam trenutno 114. , 15. , 30. i 11. na zadnjoj listi,
jedino copper gaming ak dobijem, ne znam kaj cu sa njime pošto nemam vodeno hlađenje, a ne vjerujem da bi ga baš puno ljudi kod nas kupilo.
Staro 04.06.2021., 21:27   #4586
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Autor Mičkec Pregled postova
uzmes neki radijator, flexi crijeva i tank sa pumpom, nije bas da je jeftino al nije tak ni skupo i onda barem imas kak spada i tiho... ili prodas meni po nabavnoj
Staro 08.06.2021., 20:37   #4587
dukee
dukee's Avatar
Lokacija: vz
Postovi: 466
Konacno su cijene pocele padat vani.
Cak i ima 3080ti na MFu vec drugi dan u slobodnoj prodaji.
dukee je offline   Reply With Quote
Staro 09.06.2021., 08:50   #4588
Šole
Šole's Avatar
Lokacija: Zürich
Postovi: 711
Autor dukee Pregled postova
Gdje, koliko, sto?
Staro 09.06.2021., 09:06   #4589
dukee
dukee's Avatar
Lokacija: vz
Postovi: 466
Mindfactory vec 3 dan ima grafi na lageru, Aternate npr vec 2 dana ima stock za evga 3080 za 1300 eura.
Staro 09.06.2021., 09:12   #4590
Šole
Šole's Avatar
Lokacija: Zürich
Postovi: 711
Meni pise da nije dostupno, ono sto je je cijena visoka.
