Staro 27.04.2021., 10:50   #4141
Dottore
Dottore's Avatar
Postovi: 7,735
Imam iWatch 3 + iPhone XS. Nadograđen ios 14.5 i watch os 7.4 , funkcionira face id preko maske. Jednostavno podigneš /tapneš zaslon i najprije zavibrira sat pa otključan iPhone.
Ima još jedan feature, ako netko dira vaš iPhone , sat zavibrira/zvoni i na njemu piše zaključati iphone. Potvrdiš to i zaključa se natrag. Nakon toga na iPhoneu treba upisati pin/Face ID. Zgodno.
P.S. Nemam problema sa signalom i dalje piše LTE. U parking garaži na -2 level pisalo 3G.
Drugi iPhone XS koristim za test 14.6 beta 1, prilično stabilno i bez bugova.
Отправлено через iPhone
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Dottore je online   Reply With Quote
Staro 27.04.2021., 14:00   #4142
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Autor Dottore Pregled postova
Što u opcijama imaš? 3G, LTE ili samo LTE?
žmnpp
Staro 27.04.2021., 14:19   #4143
Dottore
Dottore's Avatar
Postovi: 7,735
#zivotjednogsegrta
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 27.04.2021., 14:22   #4144
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Poslao sam mail A1 da se očituju, jer ak mi vele da ću na mjestima di nema LTEa imat Edge ne bu dobro
žmnpp
Staro 27.04.2021., 14:25   #4145
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,611
zake bi imo edge, pa nije da sad u opcijama možeš odabrat EDGE
nemožeš odabrat ni 3G ni EDGE, spustit će te na 3G ako nebude LTE
Staro 27.04.2021., 15:02   #4146
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Tak je rekao striček na SZK, nije da mu vjerujem samo prenosim
Spuštanje na 3G mi je logičan slijed ali obzirom da se nerijetko nađem na mjestima sa katastrofalnim LTE signalom (mlado od ubijanja baterije) želim i dalje moć izabrat 3G ako mi treba.
žmnpp
Staro 27.04.2021., 17:56   #4147
Franzek
Datum registracije: Mar 2014
Postovi: 96
Očito profili nisu isti na svim mrežama, na A1 nije moguće odabrati 3G. Ne znam kako je na drugim mrežama?
Franzek je offline   Reply With Quote
Staro 28.04.2021., 08:54   #4148
salvarez
salvarez's Avatar
Postovi: 273
Ja imam preko A1 e-sim, isto mi prikazuje ko slika od Dottore-a (mob je XS Max).
Nadam se da ce tako i ostati jer radim u Sloveniji i cim mi ostane na 4G, mobilni podaci mi ne rade kak se spada radi rominga.
salvarez je offline   Reply With Quote
Staro 28.04.2021., 09:10   #4149
Postovi: 17,143
Autor bigAdvance Pregled postova
kroz neke naocale ide*
meni s wayfarericama radi mozda 5-10% vremena. Vjerojatno je do okvira.
Čekaj, ha?
Nosim wayferer, nosim dipotrijske, nosim Hugo Boss sunčane, od kada imam iphone X i 11, ni jednom mi se nije desilo da mi ne učita i ne otključa odmah.
Staro 28.04.2021., 10:06   #4150
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Je ima netko iphone 12 i tcom sa iosom 14.5 da veli kaj ima od opcija?
žmnpp
Staro 28.04.2021., 10:12   #4151
Hrconja
Hrconja's Avatar
Postovi: 1,628
Autor buljo Pregled postova
12 Pro
Hrconja je offline   Reply With Quote
Staro 28.04.2021., 11:03   #4152
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,611
isto sve ko kolega iznad
Staro 28.04.2021., 12:12   #4153
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Divno.
I koga sad upucat? 💣
žmnpp
Staro 28.04.2021., 12:17   #4154
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,611
nikog, meni ne smeta fakat
stalno sam na wifi negdje, a ovo malo kaj sam na zračnom netu, može i 6G bit
Staro 28.04.2021., 12:30   #4155
dadoremix
dadoremix's Avatar
Postovi: 4,779
ja svog stalno drzim na 3g/2g .. jer 4g debelo se pozna da papa bateriju
isto je bilo i 2g na 3g kad se u to ulazilo .. al ajd .. bio je i osjetni skok u brzini
A sad bi reko da namjerno štopaju 3g .. samo da uključiš 4g
nekad je u mom kvartu 3g išao 20-30 mbit samo tako .. sad je maximala 3 mbit
a 4g leti .. mada mi nit više ne treba
Staro 29.04.2021., 16:45   #4156
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Ok, zvali me iz A1 vele to je do iosa, zovem apple podrsku vele taj dio odredjuje operater.
Navodno ce ovaj iz apple podrske jos provjeriti pa zvat sutra.
Kaj napravit? Kog krivit? Kog trazit da mi bude vidljiva ta opcija?
žmnpp
Staro 29.04.2021., 17:22   #4157
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,194
Apple iOS - info, pitanja, jailbreak, downgrade, unlock, FAQ
Ništa. Sam si si kriv. Mogao si pričekati da vidiš dojmove nakon updatea a ne grlom u jagode
Dobiješ otključavanje od sata, uzmu ti 3G… win some, lose some…classic Apple.
Ako sam nešto naučio od komunikacije s njihovim supportom oko opcija koje su nestale, a prije su bile tamo je to da se ništa neće promijeniti. Zaboravi 3G i vozi dalje, nema druge
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 29.04.2021., 17:28   #4158
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Autor 1v@n Pregled postova
Niti se prije u betama pričalo o tome niti se poslije priča o tome, od svih na forumu samo se (osim mene) jedan kolega žalio tak da i da sam čekao to bi prošlo ispod radara.
Večini je to jedna sasvim nebitna stvar.
A otključavanje sa satom je puno veći plus od ovog.
žmnpp
Staro 30.04.2021., 13:43   #4159
zgking
Postovi: 83
Ekipo koliko ja vidim na starijim modelima iphonea 6s ( Ž1 mreža —oli ti A1 ) i iphonea 7 ( bonbon ) nije se ništa promjenilo kaj se tiče 3G i 4G mreže što je i razumljivo jer isti ne podržavaju 5G. Evo i slika koje govore više od riječi
https://ibb.co/6PDnV1q
https://ibb.co/MDhMy5n
https://ibb.co/bK1mkz0
https://ibb.co/8BZGCCf
Koliko vidim za sada su stabilni , a potrošnja baterije je solidna , vidjeti ću nakon par dana koliko se to sredilo na bolje
zgking je offline   Reply With Quote
Staro 30.04.2021., 14:46   #4160
Igorr
Flajing super šiiiip
Igorr's Avatar
Lokacija: Zd -- Zg
Postovi: 1,722
Ja na HT sa 12 pro i iOS 14.5 imam samo 5G (On i Auto) i 4G opciju za odabrati, ali mi se uredno prebacio na 3G kad nije bilo 4G, što je bilo i za očekivati.
Osobno nemam problema s tim, ali vjerujem da je problem nekima kome brzina neta nije toliko bitna a vole da im baterija traje što dulje, malo njesra da nema eksplicitne opcije za forceanje 3G moda :/
5.1.4 setup:
Zvučnici - 2x Arendal 1723 S monitors, 1x 1723 S center, 4x 1961 height, 2x 1961 surround, XTZ 12.17 EDGE
Amps - Marantz Cinema 40 + ROTEL RMB-1585
Igorr je offline   Reply With Quote
Staro 30.04.2021., 19:32   #4161
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,641
*#*#4636#*#* i onda to promijenite. Ako imate tu opciju na Antonija ajfonu
Sent from my Moto Z3 Play using Tapatalk
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
LAcy je online   Reply With Quote
Staro 24.05.2021., 23:32   #4162
Dottore
Dottore's Avatar
Postovi: 7,735
Staro 28.05.2021., 23:20   #4163
zgking
Postovi: 83
Ahoj !
Kak ste ? Jel se počelo šta roštiljati ili je još prehladno za tu rabotu? ....ovih dana tražim po app storeu bluetooth daljinski upravljač sa kojima se može upravljati sa više uređaja , a ne samo sprecijaliziranih tipa Samsung i ostali veliki proizvođači. Naime nabavio sam box q , to je android TV box , ali mi fale na daljinskom oni gumbi sa četiri boje . Molim vas za pomoć , jer taj detalj jako fali da mogu ispobati granice TV boxa .
Staro 05.07.2021., 22:11   #4164
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,222
Mogu li se na iphone lokacijske usluge iliti gps staviti na pocetni zaslon na ON OFF? Trebam precac a ne nalazim opciju hvalaa
Staro 05.07.2021., 22:11   #4165
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,611
shortcuts
Staro 08.07.2021., 20:33   #4166
Dottore
Dottore's Avatar
Postovi: 7,735
Riješeno. Ubacio Covid propusnicu u e-wallet.
Otvorim mobilni novčanik i dopustim da netko skenira QR kodove. Riješio papire i plastike.
Staro 09.07.2021., 00:02   #4167
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,520
Probao sad, ne radi. Mogu jedino kreditne kartice dodati. Kako si tocno dodao?
Staro 10.07.2021., 23:46   #4168
Hrconja
Hrconja's Avatar
Postovi: 1,628
Autor imaticx Pregled postova
Ja sam rijesio sa Stocardom kojeg i inace koristim za sve kartice svijeta. Ima COVID kartica za dodati. Pa onda add to apple wallet.
Staro 11.07.2021., 08:16   #4169
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,520
Autor Hrconja Pregled postova
Da, Stockard, jako korisna aplikacija. Sve sam unutra potrpao kartice, jedino moram jos nositi osobnu, vozacku i zdravstvenu. Ostalo sve Stockard i Apple wallet za banku. Hvala
Staro 12.07.2021., 15:28   #4170
Dottore
Dottore's Avatar
Postovi: 7,735
Otvoriš Safari preko iphone i ubaciš link https://covidpass.marvinsextro.de/ i potraži "browse" da ubaciš pdf koju si dobio preko covid potvrde. Potvrdiš OK i pojaviti će pop-up prozor za pitanje da ubaci tvoj wallet. Naravno da potvrdiš OK i pojaviti će pitanje koju boju pozadine kartice želiš.
Ništa lakše.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
