#1021 |
Postovi: 19,015
Pa zar nemaš weekly crontab task za TRIM? Imao sam ga na Mintu, imam ga i sad na Fedori. Ili mislimo na nešto drugo? EDIT: Zapravo nije crontab nego systemd timer... Code:
[domy@Domy-NB etc]$ systemctl status fstrim.timer
● fstrim.timer - Discard unused blocks once a week
Loaded: loaded (/usr/lib/systemd/system/fstrim.timer; enabled; vendor preset: enabled)
Active: active (waiting) since Tue 2021-03-02 17:46:58 CET; 1 weeks 2 days ago
Trigger: Mon 2021-03-15 01:07:20 CET; 3 days left
Triggers: ● fstrim.service
Docs: man:fstrim
ožu 02 17:46:58 Domy-NB systemd[1]: Started Discard unused blocks once a week.
Zadnje izmijenjeno od: domy_os. 11.03.2021. u 21:48. |
#1023 |
Postovi: 19,015
#1024 | |
Postovi: 3,554
EDIT: I dalje jubuntu pokreće trim na svakom bootu. Ovo je isti komp, s Crucial MX, samo to nije problem jer traje 10s, a ne 10 min kao sa starom Adatom. Kako je stroj upaljen 24/7 ne zamaram se time ali dobro je znati ![]() Code:
uptime
07:01:33 up 34 days, 17:09, 2 users, load average: 0,72, 0,87, 0,75
systemd-analyze blame
11.503s fstrim.service
3.138s NetworkManager-wait-online.service
2.222s sendmail.service
1.257s nfs-server.service
696ms media-multimedia-swapfile.swap
674ms dev-sda1.device
465ms udisks2.service
435ms vboxdrv.service
374ms plymouth-quit-wait.service
Code:
journalctl -u fstrim -- Logs begin at Wed 2018-10-24 17:53:32 CEST, end at Fri 2021-03-12 07:00:01 CET. -- velj 01 00:00:01 witch64 systemd[1]: Starting Discard unused blocks... velj 01 00:00:10 witch64 fstrim[17846]: /: 16,2 GiB (17413054464 bytes) trimmed velj 01 00:00:10 witch64 systemd[1]: Started Discard unused blocks. -- Reboot -- velj 08 00:00:01 witch64 systemd[1]: Starting Discard unused blocks... velj 08 00:00:31 witch64 fstrim[3896]: /: 385 GiB (413389037568 bytes) trimmed velj 08 00:00:31 witch64 systemd[1]: Started Discard unused blocks. velj 15 00:00:01 witch64 systemd[1]: Starting Discard unused blocks... velj 15 00:00:11 witch64 fstrim[12679]: /: 18,5 GiB (19819356160 bytes) trimmed velj 15 00:00:11 witch64 systemd[1]: Started Discard unused blocks. velj 22 00:00:01 witch64 systemd[1]: Starting Discard unused blocks... velj 22 00:00:08 witch64 fstrim[2467]: /: 13,4 GiB (14421602304 bytes) trimmed velj 22 00:00:08 witch64 systemd[1]: Started Discard unused blocks. ožu 01 00:00:01 witch64 systemd[1]: Starting Discard unused blocks... ožu 01 00:00:12 witch64 fstrim[19984]: /: 18,4 GiB (19718438912 bytes) trimmed ožu 01 00:00:12 witch64 systemd[1]: Started Discard unused blocks. ožu 08 00:00:01 witch64 systemd[1]: Starting Discard unused blocks... ožu 08 00:00:13 witch64 fstrim[11994]: /: 23,9 GiB (25658396672 bytes) trimmed ožu 08 00:00:13 witch64 systemd[1]: Started Discard unused blocks. https://askubuntu.com/questions/1165...high-boot-time https://forums.linuxmint.com/viewtopic.php?t=289947 Zadnje izmijenjeno od: c-shadow. 12.03.2021. u 08:04. |
#1027 | ||
Postovi: 19,015
Ma da, ali mislim da ovim malo naprednijim sustavima tipa BTRFS/XFS/ZFS niti ne treba discard jer se sam FS brine o tome.
#1029 |
Postovi: 19,015
#1030 |
White Rabbit
Postovi: 5,551
Discard je zastarjela opcija - nije ju preporucljivo vise imati u fstabu bas iz razloga sto vecina distri po defaultu imaju ukljuceni cronjob za fstrim. Sto se opcija na FS-ovima tice - kod svih sljaka fstrim. |
#1031 | ||
Lokacija: Velika Gorica
Postovi: 1,540
No, Windowsi recimo odmah rade i discard. Nego.. bas malo procitao, i eto.. prije je discard bio problem jer je bio non-queued command, kasnije je queued. Samim time vise nema neke bas penalizacije da se koristi discard i u fstabu, dok je na starim SSD-ovima to mogao biti jako veliki penalty kod brisanja (u rangu 50x i vise sporije). Inace, ovo za Windowse sam siguran - najbolji test je kad kreiram iSCSI disk, nesto pobrisem na Windowsu i vidim da se disk usage smanji na Linuxu gdje se image nalazi.
Idiocracy. Kad satira postaje stvarnost. |
#1032 |
Postovi: 2,071
Izbrisoa sam Wine kompletno sa Minta. Ali kada upišem u search wine, nudi mi install wine ovaj paket, install wine onaj paket makar ništa nije instalirano. Kako da maknem i to kompletno, te wine pakete u u searchu?
Thinkpad T430 running |
#1033 |
Postovi: 8,650
Mislim da ti to automatski povlači iz službenih repozitorija, pa se pojavljuje, mada zapravo nije na tvojem računalu. Slično imaju i ostale distribucije. Ili kroz Synaptic odabereš Completely Remove za Wine, ako ga još uvijek drži. Zadnje izmijenjeno od: The Exiled. 16.03.2021. u 16:58. |
#1037 |
Postovi: 7,729
Na W530 vrtim Pop os distru. Ne znam kako, ali šljaka podmazano unatoč 24gb ram i 512gb Sandisk ssd. Sve radi "automaČki" i full stabilno. Secure boot je oduvijek isključen u biosu i nakon updatea firmwarea od Lenova ostaje dalje isključeno. Nije ni imao problema sa wifi modulom. Отправлено через iPhone
__________________ |
#1038 |
Postovi: 19,015
#1039 | |
PRO
Postovi: 4,912
#1042 | |
PRO
Postovi: 4,912
Koliko ga održavaš, toliko će brzo raditi. Kod linuxa je dobro što zaista možeš raditi tuning i održavanje, za razliku od Windowsa, iako, osobno, meni Fedora nije ništa usporila, a bome je koristim svakodnevno već mjesecima.
#1043 |
Lokacija: Home
Postovi: 2,186
Ovaj tjedan distro hopping na dva prijenosnika. jedan c2d, drugi i5-8320u. Na zalost napustio sam Manjaro na c2d zbog nvidia g210m, na i5 zbog toga sto ima drugaciju namijenu i treba mi nesto stabilniji citaj pouzdaniji os. Na kraju je na oba zavrsio Linux Mint Cinnamon. Radi besprijekorno, sve je hassle free i najjednostavnije i najbrze sam dosao do istih stvari naspram drugih distri. Nekada davno dok sam ga vozio je bilo usporavanja vremenom. Vidjet cemo sada kako ce se ponasati. i3wm je na i5. Obozavam taj wm. Zadnje izmijenjeno od: Mihael. 18.03.2021. u 15:20. |
#1044 |
jedan i jedini :D
Lokacija: novi zagreb
Postovi: 5,305
Ja stavio na x230 mxlinux 19.3 (xfce). Zasad super dojmovi, vecina postavki ide preko gui-ja, za pocetnike odlicno. Dosad sam vrtio lubuntu 16.04 sa lxde-om, ali obzirom da je lxde napusten potrazio sam nesto novo. Xfce mi je uvijek vise odgovarao od kde i gnomea. |
#1045 |
Datum registracije: Mar 2010
Postovi: 2,067
LM 20.1 Cinnamon koristim na X230 s time da sam prije par godina napravio frišku instalaciju 19.1, potom napravio upgrade na 19.3 pa potom upgrade na 20.0, pa ponovno upgrade na 20.1 i tako će ostati dok ne dođe 20.3 (nisam praznovjeran ali sam imao loša iskustva sa verzijama xx.2). Usporavanje ili probleme za ovih par godina nisam imao. PS. Ovako izgleda zadnjih par mjeseci radi posla jer su me počeli već umarati sa pričama (iako ih nisam ništa pitao) kako je Linux bez veze i kako su penđeri jedini pravi OS za posao. |
#1046 |
Postovi: 23,675
Tema je super, dobro da nema (glupih) pitanja kako sad XP, di je W10 ?? ![]() ![]() |
#1047 |
Postovi: 2,067
Ima, ali onda kažem da je to W10 sa XP skinom i to je prihvatljivo pa ne pitaju dalje. Da ne misliš da se zaje**** , prije xy vremena smo dobili nove kompove sa MS (ne Microsoft nego baš MS šrotex periferijom u vidu miša i tipkovnice po 35 kn) i kako je tipkovnica koma donesem od doma IBM model M i nakon par dana mi šef vidi tipkovnicu i mrtav ozbiljan kaže da je moram maknuti jer sa ne fiminim hardverom mogu zaraziti PC ![]() |
#1048 |
Postovi: 23,675
Blago budalama, njihovo je kraljevstvo nebesko. Nevjerojatno kako takvi (skoro u pravilu) postanu nekakvi šefovi ... ![]() |
#1050 | |
Postovi: 3,554
Na xfce mi oduvijek nedostajalo pretraživanje datoteka iz file managera (thunar), kao što to ima recimo stari gnome ili nemo. Onaj njihov dodatni poluproizvod programček (zaboravio kako se zove) ne računam ![]() |
