Staro 21.02.2021., 13:19   #26311
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,228
you've accepted the events leading up to the close out you pretty much have to accept anything can happen, at any time, with little or no rhyme or reason, evidence or justification. If you can take it for what it is and don't try to examine its flaws too deeply, can wallow in its shallows recognising that certain genres that have been milked close to extinction can still give rise to originality - you'll be thoroughly entertained, albeit feeling a little short changed when the credits begin to roll at the end.
I Care a Lot 2020 6.5/10 ... u biti film je ok , ali mi je radnja tj njen prikaz cak i malo osvježavajuci u odnosu na standardnu holivudsku rutinu/šablonu od (protiv) koje nismo cjepljeni.
Ako vam šta znaci u filmu glume Rosamund Pike ... nestala ženska iz Gone Girl 2014 i Peter Dinklage patuljak / kepec iz Game of Thrones-a.
The Call 2020 7/10 ; vuce mi malo na/ala/ kao ...Korejski Deja Vu 2006 sa Denzelom
- citao sam malo komentare jedni kažu nabolje je prekinuti film odma poslije odjavne špice prije nego nego pokažu credits da vam ne pokvari kraj ...
Uglavnom prekinuo film odma na kraju, da ne vidim dodatnu scenu nakon kraja filma.
There's a few added scenes during the credits which SHOULD NOT be there, please trust me and switch off when they roll.
If you do, you will have a cracking movie that will have you glued to the set til the end.
- drugi pak govore dodatna scena nakon kraja filma ima smisla
Ending Makes Perfect Sense...
... because without it you can't make Call 2, 3 and 4 - and if
/connect 185.107.96.125:28990
server rcon: oldschool
Zadnje izmijenjeno od: Blue Spirit. 21.02.2021. u 13:40.
Staro 21.02.2021., 14:05   #26312
dada-as
Bot Maker
dada-as's Avatar
Postovi: 2,741
Hunter Hunter 10x bolji od Monster Hunter. U Hunter Hunter je barem pravi monster!!!
Staro 21.02.2021., 14:48   #26313
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 4,037
Dobro si ovaj call prodao. Treba mi nešto da mi popravi loš okus od blissa koji mi je ostao od jučer. Taj film je kao skoro OK, ali jednostavno ne.
mkey je online   Reply With Quote
Staro 21.02.2021., 15:40   #26314
Blue Spirit
Postovi: 2,228
sprecavanja događaja koji se trebaju dogodit
tako da nisam puno fulao.
Ispravak / lažem mislio sam na Frequency 2002 , ali opet ima dodirnih situacija sa Deja Vu radi
Staro 21.02.2021., 15:46   #26315
Postovi: 17,143
Pogledao na Netflixu još jedan interaktivni film (na foru Black Mirror movie), s Bear Grillsom.
Animals on the Loose: A You vs. Wild Interactive Movie
Zanimljiv mi je taj koncept, dosta je naivan i namješten previše, ali nekako mislim da bi za klince bio idealan.
Uglavnom, zanimljiva fora, film ispod prosjeka.
Staro 21.02.2021., 18:40   #26316
mkey
Lokacija: tu
Postovi: 4,037
E, ovo je jedan iritantan uradak. Mogu se samo nadati da će biti krvi do koljena prije odjavne špice.
Staro 21.02.2021., 18:44   #26317
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,591
Soul
vrhunski, VRHUNSKI crtić, na više razina odličan
Staro 21.02.2021., 22:10   #26318
Neo-ST
Neo-ST's Avatar
Postovi: 8,727
Autor Alph4Dawg Pregled postova
Nisu mi nikako jasne ovakve izjave jer ne znam sto bi to tocno Mortal Kombat trebao biti nego bas to sto si i sam napisao.
Krivo sam se izrazio, u pravu si šta se toga tiče.
Mislio sam više na to kako bi MK-u bolje pristajalo da ga radi neki brutalniji studio od WB, tipa neki korejski. Ono, bez glupih američkih shema, lošeg humora i skrivenih poruka.
Mislim da zaslužuje brutalnu, krvavu atmosferu kakvu ameri ne znaju napraviti.
Njima je sve puno efekata, slow motiona, klišeja i epic muzike, šta je ok, ali je to samo šlag na torti. Problem je šta im obično torta bude sranje.
Ne znam jel kužiš šta hoću reći.
Pogledao sam par korejskih/kineskih filmova šta je ovde netko preporučio i to je brutala, nekako su više "raw", bez šminke.
Inače zbog MK su se lomile tastature 90ih...
Staro 21.02.2021., 23:32   #26319
tizhu
Datum registracije: Sep 2014
Postovi: 777
Soul
+1
Staro 22.02.2021., 13:42   #26320
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Autor Neo-ST Pregled postova
Ma kuzim sve, brate!
Vidjet cemo, rekli su slijepci. :P
Da, azijski filmovi su zbilja neka druga dimenzija pocevsi sa I saw the devil, RAID, Chaser i ostala kompanija. Nista, ostaje nam da cekamo i vidimo u kojem smjeru ce novi MK ici s obzirom da je film australske produkcije (barem mislim jer znam da je snimano na lokacijama u Australiji i redatelj je Australac).
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 22.02.2021., 18:20   #26321
mkey
Lokacija: tu
Postovi: 4,037
Autor mkey Pregled postova
E pogriješio sam, nisam izdržao do kraja Kada je "junjakinja" izvršila otmicu patuljastog Ruskog mafijaša, jednostavno sam morao odustati. I to je bilo odustajanje drugo po redu, ali i konačno.
Prvo me izbacila iz takta ta spika sustavnog "otimanja" baba, mogu se samo nadati da su to skroz izmilsili i da nema nikakvog uporišta u stvarnosti. Ali ako malo razmislim, jasno je da je ovo segment tržišta kojeg bi netko mogao htjeti uprazniti.
Kako bilo, kada su se pojavili mafijaši (gdje je jedan komentator kazao kako se ruska mafija žalila da ih se spominje u ovom filmu ) rekoh, konačno će doći stvari na svoje, ali džaba. Junjakinja postaje superjunjakinja i ošlo sve na kvasinu. Ajde da su stavili da ima neku vojnu ili kakvu god pozadinu, ovako je samo dobro motivarana psihopatkinja, što je, smatram, ipak nedovoljno.
Staro 22.02.2021., 18:22   #26322
Psycho
Master Of Disaster
Psycho's Avatar
Datum registracije: Nov 2002
Postovi: 1,282
I Care a Lot 2020 sta je napisao Blue spirit - slozio bi se sa njegovom ocjenom. generalni 6.5, dok bi dao i 7 u trenutnoj covid induciranoj situaciji u moru nedavno losih filmova.
Yin-Yang Master (2020)
kineski film, CGI dosta dobar iako je u djiru njihovih Monkey King filmova. Prica je dobra, izvedba sa dosta patetike ali toga ce uvijek biti u kineskim filmovima. Ne mogu bez toga. Sve u svemu gledljivih 5.5/6 kad fali nekog normalnog fantazia. Najveci problem mi je gluma izmedju dva glavna glumca koja granici sa cistim pederlukom jer mislis da ce se povaliti u iducoj sceni. Naravno kako je ipak to film iz PRC-a to se nece desiti. Ali upravo to pokazuje tu razinu dizanja njihove patetiku u glumi jer je to njihova glumska skola
Staro 22.02.2021., 21:07   #26323
mkey
Lokacija: tu
Postovi: 4,037
Izbor deset hiljada filmova na Archive.org.
https://archive.org/details/feature_films
Staro 22.02.2021., 23:21   #26324
Trbonja
Postovi: 311
Zadnje izmijenjeno od: Trbonja. 23.02.2021. u 12:50.
Trbonja je offline   Reply With Quote
Staro 25.02.2021., 09:55   #26325
Trbonja
Postovi: 311
Staro 25.02.2021., 15:39   #26326
Postovi: 17,143
Jel netko pogledao The Peanut Butter Falcon?
Prošao mi ispod radara, a volim takvu tematiku.
Vrijedi?
Staro 25.02.2021., 20:18   #26327
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,194
Vrijedi
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 25.02.2021., 20:24   #26328
stops
stops's Avatar
Datum registracije: Feb 2013
Postovi: 351
Da, bas je dobar film, preporuka
stops je offline   Reply With Quote
Staro 25.02.2021., 20:55   #26329
mkey
Lokacija: tu
Postovi: 4,037
Homesman mi je bio pristojan. Bolji nego što ocjena sugerira, ali to bi spadalo u jednu, pretpostavljam, dosta off stream kategoriju post vesterna pa to onda i ocjena vjerojatno reflektira.
Staro 25.02.2021., 22:50   #26330
Psycho
Master Of Disaster
Psycho's Avatar
Postovi: 1,282
Vrijedi?
definitivno vrijedi pogledati
Staro 26.02.2021., 00:22   #26331
Blue Spirit
Postovi: 2,228
Stojim mi na hardu od 14.12.2020
Hvala kaj ste me podsjetili da pogledam.
Staro 26.02.2021., 01:26   #26332
Revolver3844
Datum registracije: Apr 2017
Lokacija: SB
Postovi: 719
Soul
Stvarno odličan
Ali Coco mi je još koplje iznad.
Revolver3844 je offline   Reply With Quote
Staro 26.02.2021., 09:41   #26333
Max_Damage
Max_Damage's Avatar
Lokacija: Krapinske Toplice
Postovi: 959
Autor Revolver3844 Pregled postova
Stvarno odličan
Da, Coco i Up su stvarno nadnaravni crtići..
Max_Damage je offline   Reply With Quote
Staro 26.02.2021., 11:04   #26334
Postovi: 10,414
Dodao bi jos i Klausa kojeg sam nedavno pogledao.
https://www.imdb.com/title/tt4729430/
Tesko da bi to nazvao crticima. Prije animiranim filmovima za odrasle
Dok sam gledao Soula bas smo si mislili kako djeca to vide i shvacaju, ako uopce dopiru te poruke do njih. Je gledao netko s klincima, kako oni to vide?
Staro 26.02.2021., 11:35   #26335
Postovi: 17,143
I How to train your dragon.
Meni možda i najbolji.
Staro 26.02.2021., 12:05   #26336
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,194
Ako niste, pogledajte Inside Out, uz Up i Coco mi je definitivno pri vrhu
LCD: BENQ PD3200Q
Staro 26.02.2021., 12:51   #26337
Max_Damage
Max_Damage's Avatar
Postovi: 959
Meni i djeci nikad nije sjeo. Niti jedan nastavak. Ne znam zakaj
Staro 26.02.2021., 14:08   #26338
spawn
spawn's Avatar
Postovi: 8,525
Ja sam s klincima gledao Abominable, Over the moon, onward, frozen 1 i 2, how to train a dragon, princeva strana price, ukradena princeza, auti 1,2,3 , balerina i viktor i jos par da ne nabrajam. Sve meni osobno super crtici, ali se vidi da poanta tih prica vise prodire do curica nego do djecaka. Decki su tudumi, tek kad prodju 6-7-8 godina mogu skuziti poantu dok me curica od 4.5god vec pita sve o crticu sta i kako i vise razumije. Uglavnom, svi ovo crtici koje sam gledao su mi super, ali abominable i onward su oba klinca gledala s gustom
Staro 26.02.2021., 14:21   #26339
tizhu
Postovi: 777
Decki su tudumi...
EPIC
najgore od svega što si u pravu hahahahaa
OT: peanut butter falcon je odličan
Staro 26.02.2021., 14:40   #26340
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
https://www.imdb.com/title/tt0101410/
Barton Fink (1991)
?/10 , mislim da cu morat jos jednom pogledat ,al za par mjeseci da mi bolje legne. Iskreno , nemam pojma sto s ovim filmom braca Coen zele rec..
