Staro 24.11.2020., 20:50   #841
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Autor Sn4k3 Pregled postova
Ima ih i kod nas, navodno u Protisa ima zaliha... Ja sam svog narucio u eKupi - cijena je bila predobra za propustiti, sutra bi trebao stici.
Bas me zanima sto cu dobiti, pretpostavljam novi kontroler Iako realno, performanse su jako slicne, tako bar govore interneti...
Ssd stigao danas, dobih ENG verziju, guess i was lucky . Za 470kn koliko me ispao, ja sam zadovoljan...
Kad zavrsim sredjivati windoze, izvrtit cu crystal disk mark...
Edit: isprike zbog okrenutih slika
ID:	22964   Click image for larger version
ID:	22965   Click image for larger version
Staro 01.12.2020., 09:56   #842
Postovi: 16,664
Brza provjera, pošto sam na prošloj matičnoj imao problema.
MSi B450 TOMAHAWK i SSD Crucial P2 1000GB M.2, NVMe PCIEx4, 80mm Micron, 3D NAND, 2300/1150 MB/s, kompatibilnost?
To radi bez jebemti, ne?
Staro 01.12.2020., 10:35   #843
NightWalker
NightWalker's Avatar
Datum registracije: Feb 2010
Lokacija: PGŽ
Postovi: 226
yep plug n play
NightWalker je offline   Reply With Quote
Staro 01.12.2020., 21:13   #844
veve
woot!!!
veve's Avatar
Postovi: 2,493
veve je offline   Reply With Quote
Staro 01.12.2020., 21:27   #845
Dottore
Dottore's Avatar
Postovi: 7,613
Gdje misliš ubosti? U drugi slot? Vozi dalje
Отправлено через SM-N986B
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 02.12.2020., 08:32   #846
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Koji smradovi
Ovo bi trebalo kažnjavat nekako. Istu stvar sam doživio davnih dana s Kinstonom V300, a ovaj sad SX8200 nisam ni gledao, mislim da je ova prva verzija pošto je već dugo imam
Autor Dottore Pregled postova
Kaj nema Tomahawk samo jeadan slot za nvme? Ili ja nešto propuštam?
Staro 02.12.2020., 08:49   #847
Postovi: 16,664
Koji drugi slot?
Imam 1 M.2 Slot.
A ova 2 SSD-a koja imam su SATA.
Staro 02.12.2020., 08:59   #848
emilblomsky
emilblomsky's Avatar
Lokacija: karlovac
Postovi: 2,073
Ima jedan dupli!
Phil of the future!
Staro 02.12.2020., 09:34   #849
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,779
Koji smradovi
To najbolje consumer rjesava, bojkot proizvoda samo svi ce na kraju uzet nesto od adate za 100 kn manje
Staro 02.12.2020., 09:42   #850
tomov
tomov's Avatar
Datum registracije: Feb 2011
Postovi: 591
Bait and switch!
Isto tako sam ja naletio na memoriju koja je u prvoj seriji išla sa Samsung B-Die chipovima dok su u mojoj Odronix-Par-Excellance chipovi.
Istina radi na deklariranim brzinama no nisam to ciljao s kupovinom iste.
tomov je offline   Reply With Quote
Staro 02.12.2020., 16:38   #851
Sokios
Sokios's Avatar
Datum registracije: Mar 2008
Postovi: 94
Pozdrav!
Molim malu pomoć.
Mogu li ja u ovu matičnu :
https://www.asus.com/Motherboards-Co...PRIME-H310M-A/
staviti ovaj SSD:
https://www.moduldevet.hr/ssd-500gb-...m_medium=click
Hoće li to raditi sporije ili neće uopće raditi?
Sokios je offline   Reply With Quote
Staro 02.12.2020., 17:10   #852
veve
woot!!!
veve's Avatar
Postovi: 2,493
Možeš, ali radit će sporije.
Note
*1 When a device in SATA mode is installed on the M.2 socket, SATA_2 port cannot be used.
Due to the Chipset limitation, when a M.2 device is installed in PCIe mode, the socket is set
to PCIe 2.0.
Staro 03.12.2020., 23:25   #853
Dottore
Dottore's Avatar
Postovi: 7,613
Koji drugi slot?
Imam 1 M.2 Slot.
my bad. Nisam skužio preko tapatalka.
Kako imam B450m ploči i znam da ima dva m.2 utora. Prelaskom na X570 i opet imam dva M.2 utora.
Staro 07.12.2020., 18:31   #854
passko
passko's Avatar
Postovi: 31
Koji SSD Disk od 1 TB.
Pozdrav,
Trebam preporuku za SSD od 1 TB - NVME ili M2 (nisam siguran )
Trenutna konfa:
AB 350 Gaming 3 (Ona veća verzija) https://www.gigabyte.com/Motherboard...ng-3-rev-1x#kf
Ryzen 3 2200G
Gigabyte GTX 1660 Super
2 x Western Digital Cavier Black 1 TB (Non raid)
1 x SSD Samsung EVO 200 GB
Razlog novog diska je što mi je 200 GB premalo za dual boot. (Linux i Win10, Win10 odmah pojede svoju particiju)
Namjena je light gaming.
Držao bi Linux na SSDu od 200 GB, a Win10 i Steam igre na novom SSDu pa neka Win10 papa.
Koliko sam istražio neke real world performanse u odnosu na SATA 3 SSD nema, ali nema mi smisla kupovat stariju tehnologiju po skoro pa istoj cijeni.
Price range bi bilo idealno od 100€ do 1000kn.
Spreman sam pljunuti i više ako je dobar SSD (npr radije platim 1200kn za "marku" koja ce trajati 5 godina, nego 700 kn za SSD koji ce za 2 godine mozda krepati)
Ukoliko ne postoji neki kvalitetni SSD u tom price rengu, može i preporuka za 500/750GB.
passko je offline   Reply With Quote
Staro 07.12.2020., 18:43   #855
DSA
Lokacija: Sarajevo
Postovi: 280
Kingston A2000
DSA je offline   Reply With Quote
Staro 07.12.2020., 18:45   #856
veve
woot!!!
veve's Avatar
Postovi: 2,493
Po meni ti je bestbuy trenutno Kingston A2000 1TB.
A do nedavno ti je bio Adata SX8200 Pro 1TB, ali... više nisu otkad su u tišini izbacili nove verzije s drugim kontrolerom koji je srozao performanse.
Više o tome, ako želiš pročitaj na linku
E sad, ako imaš volje probaj se raspitati da li još netko u trgovini ima Adata SX8200 Pro, ali stariju verziju.
Staro 07.12.2020., 20:06   #857
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Nakon instalacije windowsa i steama...
Ne znam jel bitno ali pod settings nisam upalio opciju nvme ssd vec ostavio na defaultu.
Name:	Screenshot 2020-11-24 210536.png‎
Staro 07.12.2020., 21:15   #858
passko
passko's Avatar
Postovi: 31
Autor veve Pregled postova
Da, pročitao sam par stranica unazad i vidio da se bahate sa jeftinijim dijelovima, bojkot takve proizvode odma
Hvala na sugestijama, čini se ok za cijenu ovaj Kingston (jedino što je plavi, a cijela unutrašnjost cejsa mi je crno/crvena )
No, ionako mi to dođe negdje ispod grafičke pa se neće vidjeti.
Još jedno pitanjce, ako spojim novi SSD sa 4x brzinom, navodno, gubim 2 ASATA utora.
"When the M.2 slot is populated with a PCIe-based M.2 drive, two SATA 6.0 Gb/s ports are disabled"
Trenutno koristim 3 SATA utora, 2 za HDD i 1 za SSD.
To znači da u slučaju kupnje novog ssda moram jedan hard umirovit?
I dali se taj hard spaja na ovo crveno sa slike?
Hvala.
https://www.gigabyte.com/us/Motherbo...support-manual
up load pic
Staro 07.12.2020., 21:21   #859
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Autor passko Pregled postova
Hvala.
up load pic
Ne kužim šta te muči? Pa imaš ukupno 6 SATA konektora na ploči. 2 manje znači da ti ostaje 4? A to je (ne bi vjerovao! ) više od! 3
Staro 07.12.2020., 21:22   #860
Postovi: 8,127
Još jedno pitanjce, ako spojim novi SSD sa 4x brzinom, navodno, gubim 2 ASATA utora. Trenutno koristim 3 SATA utora, 2 za HDD i 1 za SSD.
To znači da u slučaju kupnje novog ssda moram jedan hard umirovit? I dali se taj hard spaja na ovo crveno sa slike?
Da, ako iskoristiš M2F_32G (M.2 Socket 3 Connector), onda gubiš dva ASATA3 0/1, ali imaš još četiri SATA3 0/1/2/3 konektora, pa ne bi trebal imati problema.
Staro 07.12.2020., 21:34   #861
passko
passko's Avatar
Postovi: 31
Aha, ma zabrijao sam da ih imam samo 4
Nisam vidio na schemi da ih ima 6.
Alles gut, danke!
Staro 14.12.2020., 12:43   #862
housel
aka Sizif
housel's Avatar
Lokacija: požega
Postovi: 581
Pozz, molim pomoć.
Za sada imam 1x sata ssd koji koristim za OS i scratch disk dok su Photoshop i Premiere na klasičnom hdd-u
Vrijeme je za lagani upgrade pa me zanima da li kupiti 1x512gb ili 2x250gb te koje diskove uzeti.
Da su sata ssd u pitanju, uzeo bi 2x250 no kako za nvme nije isto kud ga bodeš, nisam siguran što je bolje.
Mbo je Asus Prime Z370-P, kupovao bi u Hr
housel je offline   Reply With Quote
Staro 14.12.2020., 13:32   #863
Nick7
Lokacija: Velika Gorica
Postovi: 1,513
Uzmi jedan veci... i vise nego dovoljno brzo, manje problema za sloziti, manja sansa za gresku (jedan vs dva diska).
Staro 14.12.2020., 14:49   #864
OuttaControl
Lokacija: Dalmacija
Postovi: 5,779
Došao mi je A2000 ali nemam šaraf :O Koji ide, jel ima to kupit u peveca m2 x 2.5mm? ako se ne varam
Staro 14.12.2020., 14:57   #865
DSA
Lokacija: Sarajevo
Postovi: 280
Sta je pametnije uzeti u ovom momentu, Adata XPG SX8200 Pro ili 970 EVO? Je li Adata ekvilavelent njemu ili EVO Plus?
Staro 14.12.2020., 15:02   #866
Postovi: 33,921
@outtacontrol
Šta nemaš neki šaraf viška od kućišta za mbo? Stavi bilo koji, držati će.
@dsa
Obzirom da je Adata počeo stavljati sporiji/lišiji kontroler na SX8200, 970 Evo je bolji izbor. Baci oko i na Kingston KC2000/2500 koji je jeftiniji od Eva, a ima solidne performanse.
Staro 14.12.2020., 15:32   #867
Postovi: 23,499
@outtacontrol
A nesrećo prekopaj kutiju od mobo,
jedino ako si dobio već složen komp bez ...
Staro 14.12.2020., 15:48   #868
OuttaControl
Lokacija: Dalmacija
Postovi: 5,779
Sam sam ga slaga al bacio sve ima cca godinu kad sam sređiva stan istekla garancija pa gledam sta ce mi...
Naša sam neki čini mi se da je malo premali al uvatio je i drži, bit će to dobro , sad mi upa check disk a tipkovnica ostala ustekana u USB3 pa nisam moga skipat sad vrti nesto...
Staro 14.12.2020., 15:53   #869
Postovi: 10,002
Ako ne planiras zaraditi na ploci bit ce dobar i manji samonarezni vijak, zazmiris, malo ga stisnes da zagrize navoj i bokteljubi :P
Staro 14.12.2020., 16:17   #870
OuttaControl
Lokacija: Dalmacija
Postovi: 5,779
Autor Corvin Pregled postova
https://prnt.sc/w2ia3v
Evo udrio i ja test, sve je tu negdi jedino ovaj Q32 rnd jel moran neki driver instalirat il? Nije da me puno sekira al ajd kad ga vec iman nek radi na full
